View Full Version : Exhaust System
Pages :
9]
10
11
- Header Horsepower ?!?!?!
- RK Sport Headers, waht the skinny?
- Header bolts (LT1)
- Has anyone ever used these?
- Headers
- Pacesetter LT's + SLP TOTL exhaust
- help
- Pacesetter Lt Install?
- Will my new headers ruin my wires & more?
- is this possible
- semi-unique exhaust thread
- cheap exhaust prices
- LT Headers With Spohn Torque Arm??
- 1997 camaro- where can i get a stock header cat-less y pipe from?
- What Exhaust Sounds the Best On LS-1
- 95 z28 with 96 exhaust
- Please help: quick question. Y-pipe. About to go bananas...
- Cam/headers + magnaflow?
- Slp 2otl
- Header Install
- lock tight on header bolts????
- Cat making sounds
- alternative to expensive qtp cutout controller
- Rochester, NY Exhaust Inspection Questions
- BBK Headers
- Collector Size
- 3" True duals and pro-kit clearance good??
- Jethot headers?
- OK kind of a unique question here (Headers/ dynomouth(stock cat-back)/ cutout )
- What's the lowest acceptable ground clearance for header collectors on the street?
- A few pics of duals
- corsa?
- Cut out location?
- Flowmaster 40 series catback?
- LT! to LS1 swap question
- Cat back question
- random tech. duel flow cats for 96 z28
- What is a good sounding 3" single in/out muffler?
- AS&M Header starter access
- Flo Pro Exhaust
- loudmouth II or Magnaflow
- Mac mid length headers
- Keeping the Flowmaster Sound
- Jeg's vs Summit cutout
- Where to put o2 bungs?
- A new Magnaflow catback?
- hooker+lm?
- Finished Header install car not running great
- Summit cutout?
- Exhaust Performance Question
- Flowmaster Questions
- Exhaust Video: Catted GMMG with Stock Manifolds
- Magnaflow mufflers on true duals?
- Exhaust tips to close rear bumper?
- Is spending the $ on having your headers coated worth it?
- (LOOK) video with sound clip of new exhaust.
- Ghetto fab. sound clip...
- SLP catback adapter?
- Exhaust System Tools
- No o2's until tune? Manifold bolt ?'s
- gutting the CAT
- What are my options?
- Hooker LT's installed, ABS harness too close
- 2 converter with different lengths. Which is better?
- Can't use fresh ceramic coating during new engine "break in"?
- Pacesetters
- lt pc's and magnaflow
- O2 sensor stuck in the manifold!
- Pacesetter differences
- Which is the better catback system between these two?
- Kooks true duals
- true duals *video inside*
- Raspy exhaust question
- collector bolts...help pleaaase
- sooo, what do ya think??
- 93s with Lts need a tune??
- Using a tailpipe expander to make a 3" pipe slip fit?
- Shorty True Duals?
- My exhaust leak has lasted long enough (buying parts)
- How to install headers
- Mid Pacesetters (how does old come out and new go in
- just finished LTs and true duals
- Does it matter which direction a cat goes?
- 02 sensor low response
- SLP headers
- open exhaust gains??
- Anyone Try Magnaflow Bullets
- Sound clip of the ghetto exhaust...
- help help help?
- Y-pipe bolts studs necessary or can bolts be used?
- where to order y pipe
- I kinda messed up my order
- my vid
- Ghetto Hack job with flowmasters...
- best style of exhaust for longtubes on a 3rd Gen ?
- EGR emissions questions
- do pacesetter lt's only hook up to pacesetter y pipes
- header bolts/gaskets for pacesetter lts
- corsa, borla or slp loudmouth exhaust?
- Though i had a bad ticking under valve cover
- About to install electric cutout, need help with wiring.
- best exhaust for MPG
- Need pics of 3inch or 2.5 true duals OVER the axle
- bullet difference?
- Exhaust Manifold gaskets
- Best Headers?
- manual cutout p/n??
- Best way to find big exhaust leak.
- Hedman LT's in 3rd gen w/T-5
- Slip fit primary tube...
- Y-pipe to catalytic converter bolts
- quick question before duals get installed
- coated header question
- A few pointers on a header install on a 93
- Busted 02 = Misfire?
- What can I do?
- shorty headers
- cats function properly when warm?
- race headers/ORY vs. emission legal exhaust
- Anyone have pics of their exhaust on their Formula?
- Ever been busted for benig catless?
- header gaskets for hooker super comp longtubes
- Doing the ole switcheroo
- y-pipe
- one chamber flow in the Ipipe??
- Wiring an E-cutout?
- collector inserts
- Stock exhaust without dual cats
- cat or no cat
- rk sport gaskets
- pacesetter longtubes
- Borla to true dual??????
- dr.gas cat back lt1
- 2 1/2'' or 3'' X-Pipe
- qtp electric cutout
- AIR Fittings - Need Reducer Size!!!!
- True duals
- Header Install
- Mid Pacesetters In route (install question)
- slp loudmouth 1 vs. 2
- Ordered the Exhaust
- pacesetter gaskets...
- Anyone know where i can get 3" Stainless ball socket flanges
- ? about which headers
- which muffler (bullet style)
- New High flow cat. Are they worth it?
- Header Questions
- header install?
- best cat back system?
- where can i find a 2.75 intermediate pipe?
- Finally got some drive by vids of my car.
- High flow Cat? With mid headers & Magnaflow
- Flowmasters on a TD setup
- Flowmaster Back Pressure ?
- seeking exhaust advice... need something better
- Headers
- MagnaFlow
- Pacesetter or Jet Hot?
- Flowmaster Exhaust
- Will new headers ruin my 02's
- time for duals, couple ?s
- HELP! exhaust removal
- Stock tips
- Headers (BBk Edelbrock Pacesetters) broken bolt!!!!
- Mufflex Group Purchase!
- 02 sensor simulator question?
- Single vs. Dual Cut-Outs?
- Header bolts...
- Borla with CME
- Muffler Question
- Header Leak HELP
- Kooks LT's, O/R Y, GMMG cat-back
- Stock '95 Trans Am Exhaust
- Magnaflow Install?
- loudmouth to borlamouth help
- Pypes cat-back.
- Dynomax bullet muffler instead of cat
- modifyed exhaust ticket
- Anyone use the Stainless Works LTs and y-pipe?
- Catalytic Converter ?s.......
- FLOWMASTER or GMMG?
- mufflex y and pacesetter LTs??
- H pipe instead of the common X?
- Downpipe
- Headers!!!
- Mufflex y pipe questions
- true duals pics
- pacesetter long tubes and stock y-pipe
- Who said you can't put Daul cats on with LT's
- Pacesetter LTs and ORY with cats???
- Catalytic Converter Placement
- Taking off exhaust in one peice, possible?
- couple of true duals questions
- What catback
- Cutout in place of cat or at axle?
- Header Bolts
- 3.5 inch single max power?
- Dream system for 96 on a budget
- mufflers?
- Which Gaskets
- Cheap alternative to GMMG or stainless works chambered exhaust!
- Ticking noise
- Quietening down a loud performance exhaust?
- sad day
- exhaust cross pipe really any good?
- 94Z o2 sims? Help please
- long or short
- How hard would this be/price?
- muffler decisions??
- Exhaust
- anyone tried this?????
- need help after header install
- Pacesetter LTs
- ok 1 thing
- headers,y-pipe and cats????
- Cutout where cat is at?
- Exhaust for stout small block
- Are these mid or short length
- Borla with no Borla muffler
- true dual setup
- header fitting problem?
- Where to buy SLP Loudmouth 3.5 Single/Single Tips?
- what do i need to do this upgrade.??
- BOrla form a 4th gen to a 3rd gen?
- E cutouts
- mac header install complete, sterring linkage rubbing flange ?
- headers?
- 1 5/8 inch band clamp?
- Need some insight on an exhaust idea...
- double triple quadroople gaskets?
- Hooker Aero Chamber Muffler.
- pacesetters are finally in for my 3.8!
- Stainless works
- Dual X Dumped Drone?? No cats.
- Straight bullets/exhaust off headers vs. x-pipe
- CUT out
- flowmaster 40 series on race car
- MAC catbck exhaust?
- pace setter header question
- Borla/Flowmaster and Resonator
- Header Install
- Center exit ehaust
- best exhaust for LT1???
- pacesetters and TSP catted Y, or mac mids?
- Lt1 longtubes (hooker vs pacesetters)
- what do you think about this setup
- mac mids 2 mac high flow cat 2 loudmouth w/chambered muffler. How loud would no cat b
- (LT1) MAC mids and oil cooler
- Help me get below 90db.
- How do install a 2 bolt flange?
