View Full Version : Fuel and Ignition
Pages :
8]
9
10
- dual fuel pump setup?
- My Z28 is dead!!!
- best spark plug
- LTCC Tach signal not activating Shift light or Window Switch
- stock fuel pump replacement??
- Where/what adapter to make the new style ford injectors work in my car
- Mallory HyFi 685 buttons won't work
- How Do I Know If Icm Is Bad
- Boxes similar to the Mallory Hyfire 685 VI?
- Test Injector Getting Signal
- Different SVO injector colors
- Cyliders not there on start up
- LT1 Fuel Pump Prime Connector...... where does it go? What does it go to?
- fuel pump going bad..
- Ignition timing tables for a stock 96 ss (z28)
- fuel pump
- Fuel Problem
- Aviation Fuel?
- No Fuel Pressure
- how many guys here running e85
- Running rough
- O2's reading .004 while cruising. Bad?
- fuel pump-where to buy?
- I know nothing about injectors, sizes, etc. help me out here
- Can you have good fuel pressure with a bad pump?
- Buying a F.A.S.T. 30-116010 kit...anything to look out for?
- getting new injectors.
- Seafoaming the baby tomorrow..I'm stoked
- hydro octane booster?
- Can a failing opti cause your Delteq not to work correctly in the upper rpms?
- I need to change the ignition lock & key on the steering column
- fuel pump or FPR ?
- corvette injectors
- Injectors size?
- starting problems.??
- who makes a good fuel pump
- What injectors and size to use
- 42# injectors ok for na 383?
- New Injectors---questions need help/advice
- Z-28 need key code
- centerbolt wire looms
- speed demon (running rich)
- Firing order from the distributor cap
- Is This An Opti Problem??
- Backfiring on decelleration
- Quick injector question
- Fuel pump assembly ground wire melted
- help!! racetronix kit quit working!
- opti question
- NEW MEMBER HELP! Injectors, Fuel pump ACCKK
- Need -8 or -10 Y fitting
- Opti problem
- accell INJECTORS
- Do i have a bad fuel pump or what?
- Whats the part# for 37lb Racetronix injectors?
- Emission failed. Please help
- fueling problem hard start ect
- Already tuned, but want to install...
- Mixing Race Gas?
- 98 Racetronix Plug N Play Kit
- LS1 in 96 camaro, how to use fuel lines and bypass return?
- Super Stumped! Fuel Tank Dilemma
- which injector?
- bad opti?
- LTCC and LS1 Style Plug Wires - Dumb Question
- To all running MSD 6A or 6 AL
- Opti Problem
- Ltcc & Maft +
- Z28 runnin 2 rich$$$$$
- MSD Coil
- OTVC wires?
- Delteq alternate mounting
- Plug wire resistance
- Moroso 8.5 wires
- bad opti?
- time for a fuel cell??
- plugs removal
- Benefits of Delteq on an LT1 vs. a new Opti - Gas Mileage???
- ls1 98 fuel pessure regulator location?
- Car died on the highway!! Coil?
- fuel pressure problems
- fuel problems with walbro 255
- Anyone know if the MSD cap & rotor any good?
- Fuel in tank for one year...any good?
- Not Starting
- walbro wiring help!
- Ignition Box Died...spark now blowing out...is there too "small" of a gap?
- Changing Ignition Coil....Change Wire Also?
- Huge electrical problem
- no power to fuel pump, new fuse, new pump, new relay...now what?
- Any ill effect from running bigger injectors w/o retuning?
- Fuel Sending Unit
- help me identify these injectors!!
- Fresh Air Line for MSD Opti
- Anybody done SS fuel lines to replace plastic junk?
- trap door location with plastic fuel tank
- When Opti goes...will the motor turn over at all?
- How much hp will Walbro sopport
- Engine cranks, but won't start...
- how to install the tach on an lt1
- Looking for install tips for 6AL
- melted fuel pump wiring...what to do? PICS
- Running rich as heck
- Fuel rail fittings......
- 1LE Fuel Tank
- 67' electric fuel pump help
- Need expert opinions on fuel line rerouting/hookup
- I think my aermotive afpr has gone bad...what are my options
- Aero A1000, Where are you guys mounting your pump/filters
- Oh Crap
- no fule pueresser
- fuel pressure of a lt1?
- help please
- walboro fuel pump been sitting for 7 yrs
- Spark Plug suggestion
- cyberdyne fuel pressure gauge
- Anyone use one of these fule pumps?
- Intake Modifications for Fuel Rails
- return vapor lines(fuel)
- too much fuel pressure help!!
- where do you put your inline fuel pump (please show pics)
- cutting access door method on a 96 vert.........??
- stock lt1 fuel pressure vac line on and off
- GM programs rich, cars run lean.
- otvc wires
- Mallory 685 problems again
- MSD Digital E curve on BB Chevy. Cant get advance ??
- Where to get stainless tubing?
- Which coil delco or aftermarket
- Fuel pump bucket
- Is it ok for me to use NGK Platinum???
- Started a small fire replacing battery
- Y or T fittings for Fuel Rail setup.
- -6AN adapter to stock fuel lines
- Oil on spark plugs?!?
- LS1 Ignition Diagram
- High HP Fuel Systems - Q&A (4th Gen)
- which plugs should i get??
- I'm stumped.... no fuel pressure.
- Control Module or Optispark?
- found random idle miss and dying problem
- Fuel pressure goes to zero after 30 minutes
- how to test fuel injectors
- how do I remove the hard feedline from the fuel rail?
- help!! opti gurus
- **URGENT** Rear black plastic fuel line damaged...
- No start after 685 install
- Tach problems
- fuel pump replacement
- My battery relocation wiring diagram, and pics
- Need Fuel Pump
- Fuel pressure drops to 0 after primimg pump
- loss of comunication with MSD 6AL hooked up
- 2nd fuel pump turn on
- LTCC setup
- Fuel injector Question
- Weird Opti Question...
- slight hesitation :(
- no spark, please help me guess
- identify my injectors please
- LTCC wire harness.
- Checking coils
- Make me a fuel system
- Crane HI-6R box
- What Fuel Pump???
- Is the fuel pressure check valve inside the pump, or part of the bucket?
- Fuel Sending Unit Issue
- Gas smell...cannister or tank?
- Accel?
- Injector question
- Fuel Pump Replacement for 1997 Z28
- Fuel calculation Questions
- FMS 36lb injectors
- Ignition switch ?
- Do you really NEED the racetronix kit?
- fuel pressure is dropping at wot
- need injector help
- need some suggestions on electrical stuff.
- ford racing Red Top Fuel injectors?
- Mallory Dead again???
- can opti's be repaired after coolant spray?
- stand alone fi systems
- will a bosh 420L/ph support 750ish @rw FI
- MSD Crank Trigger ?
- how to check for bad fuel regulator?
- MSD cap and rotor compatibility?
- aftermarket ecm?
- Any difference between ebay and racetronix 60 lb injectors?
- Noob injector install
- What size injectors in my 96 Z28
- Fuel line(s) help!
- installing injectors
- Will these Racetronix injectors fit LT1
- car starts then dies 1997 Z-28
- Mass Air Flow Sensor
- identification of svo Ford 30 balanced injectors
- opti corrosion and rust
- SVO injectors
- what spark plugs are you all using??
- Fuel Cell w/ Intake Pump
- Injector help/question
- my car cuts off and wont idle
- 89 Iroc Not starting
- Weird problems...fuel filter? Injectors? Opti?
- Starting problems - 89 5.0 RS Manual
- orange rusty color on my spark plugs?
- msd ignitions and delteq
- Correct MSD PN for 96 LT1?
- Possible fuel problem
- Ever have injectors cleaned ultra-sonic?
- Good replacement fuel injectors...
- Where to find.......
- something causing ignition switches to go bad?
- Fuel Level Sending Unit
- Help with Accel AFPR
- Parallel or Series
- 94 z28 starting problem
- Lil' help
- LTCC question
- 97 rs missing sevice light flashing after
- general msd/ignition question
- Fuel in cylinder
- More problems with ignition switch. Possible bad ground?
- Help! Installed MSD coil - car won't start
- how much pwr an ACdelco opti can handle?
- injector size?
- ltcc coils
- fuel pressure check
- will these injector
- Ignition switch wiring. 96 Trans am
- Will 22# injectors work for this?
- Inline fuel check valve
- Voltage for Factory Tach + Autometer Tach Adapter?
- Dropped the tank today
- best deal on Holley 58 mm throtle body?
- Digital 6 mounting/placement
- SVO 24# injectors?
- msd and there customer service.
- no fuel pressure help
- Venting fuel tank problem? Car cuts out on turns
- 94 camaro ..MSD-A w/ 8876 harness q?
- Getting Miss with Car Warm
- changed Rad and Thermo now misses and pops...
- weatherpack connectors for delteq
- Need to rewire fuel pump relay
- Delteq and timing? What gives?
- f.a.s.t? delteq
- Differences in IC Modules
- Ltcc & Msd 6al
