View Full Version : Fuel and Ignition
Pages :
6]
10
- Key switch causing no start???
- Timming light problem
- Minimum Fuel System for 8#'s
- Fuel Pressure problems
- Aeromotive Fuel Pressure Regulator Failure
- Does anyone have a suggestion for an Inline Fuel Pump 97 SS with 6# Powerdyne
- So did I jinx myself or ...???
- will -10an feed/return be too big?
- Fuel Injector Duty Cycle
- 99 v6 camaro wont start! help!
- Opti Questions
- Another injector size question
- car runs then shuts off
- Autometer fuel level sender in stock tank? Anyone?
- Dtc 16
- Msd Coil 8226
- Where is the fuel pump reset 01 Z?
- Electrical problem need help
- High or Low pressure walbro?
- Car won't start
- need help with possible ground problem ?
- Car stalls at idle.
- Supercharged LS1 T/A fuel system
- Sensor location ?
- STILL stuttering and skipping....
- What does your walboro sound like?
- security problem please help
- Fuel Pump/Regulator Troubleshooting
- soooo.....the nose on my starter broke off the other day.......
- New problem... Ignition fuse keeps blowing
- Help... Car died on me today and wont start?
- Help me pick my fuel pump please
- Low voltage problem on 3rd gen?
- Is my fuel pump trashed?
- 2002 z28 pass lock/security light flashing
- Coil plug !!!!?
- wierd hard start problem
- Dynaspark Opti-Spark Question?
- multiple cross platform problems
- What distributor for blown 383.
- 1996 z28 fuel pressure drops after turning key
- Starts somtimes, not others, no spark.
- new fuel pump but still psi issues
- Starting issue
- Ls1/chevelle low fuel pressure!!!
- Delayed start and Throttle response?
- 94 z28...what could cause this?
- Help plz.
- Ignition/starting problem
- fuel pump help lt1
- Best plugs and wires.
- walbro fuel pump install question
- 91 rs quit running w/no codes
- Car misses/cuts out at high rpm!!!!!
- dirty fuel line question
- missfire + more!
- My Car is possessed...???
- otvc wires
- MSD cap,rotor and coil
- fuel filter on work van
- fuel pressure lt1
- ? after racetronix Install
- TREperformance fuel pumps are no good
- Racetronix pump booster interface connectors
- Stirred up dirt in tank. Now barely runs
- Sometimes car needs to be started 2-3 times!
- Is my fuel pump bad
- Need Help ID'ing relay, I think
- Stumped on miss
- What is the Secondary Terminal on the Ignition Coil!!???
- 94 wont start
- Help my poor camaro
- Do I go Bigger???
- Your ideas for this....?
- Some pics of my plugs
- Need 60lb injectors WHICH ONES??!!!
- Problems with injector pulse width
- Opti, oxygen sensor problem, & ????????? HELPPPPPP
- how do my plugs look???
- fuel pressure problems
- Ignition Module?
- Access door?
- injectors?
- 97 Z28 that's been sitting for a WHILE
- Fuel Pump Basket/Walbro Pump
- ICM Differences and Consequences of wrong one?
- Need bigger injectors. How are these
- Fuel Pressure drops to Zero, Pump Primes, New Regulator
- Help, just changed one spark plug.
- smelling fuel
- Plug wire arc'ing
- Help with fuel/n20 problem
- Fuel Pump Question
- fuel sending unit
- twin 255
- fuel pump/pressure problem???
- Problem with a MSD opti(early model)
- Spark Plugs??
- 82z28 w/ lt1 swap... no fuel pressure after storage
- 30# injectors hitting 90%DC. What size do I need?
- Factory fuel pump wiring..
- Starting troubles that Arn't due to the starter...help anyone!!!!
- Ignition problem i'm sure, advice needed?
- fuel pump relay?
- Taylor Cut to fit wires - help
- Do I need a FPR? Bigger injectors
- Concenses?? OPTI Pricing??
- Help! Car wont run properly
- Fuel pump stuff
- Paxton Blue / Aermotive Pump
- Racetronix wire up...
- What happens when you loose fuel pressure?
- WOT fuel pressure bleeds down
- I know in my heart I need an OPTI....
- Delteq still in business??
- crane cam igniton problem
- Fuel pressure 36-37 psi on 3.4
- Randomly died after rebuild.
- In need of a Fuel line fix
- msd coil 8226
- TB bypass and descreen MAF mods...
- Unstable with missfire
- Ignition Control Module ?? Theories?
- Fuel or Iginition? Help Stranded!
- Quick question before I start tearin into things...
- diffrence in fuel pumps in 95 camaro
- need help! changing LT1 plugs and wires
- Best way to flush an LT1 fuel rail???
- is this an opti problem?
- LT1 throttle bodies
- 95 camaro issues
- 1993 Z28 will only run if pumping gas pedal
- Having a little problem with fuel pump I think
- does a 1990 camaro rs have a cranksenser?
- delteq/fast together?
- Fuel Pressure
- fuel line size for 1,600hp
- WOT and fuel usage question
- Key on, Fuel pump primes and primes and primes...
- eng. shuts off on acceleration
- tons of black smoke when trying to take off
- 91 RS Remove Fuel Tank Question
- 30# injectors installing
- Spark plug wire question
- Will aftermarket ignition box cure minor cam surge?
- Ebay Plugs and Wires
- Racetronics Fuel Pump Install
- Need a new Fuel Pump
- Fuel pressure not rising while acclerate
- Your opinions on Racetronix injectors...
- so here's my problem (LT1)
- Another Opti Question (or two)..
- Fuel Pump Out...Just Replaced
- Racetronic Fuel Pump on a stock car
- No Start
- Fuel Sending unit needed!!
- fuel pump isolator
- Problems from leak at flared fuel line tubing
- Engine pop sound problems help
- Smog check failure
- MSD 6AL benefit my setup?
- Fuel(not raw) smell inside car
- Turns over-but won't start... or shut off
- a 58 Holley t/b question
- Fuel pressure problems
- 95 Firebird LT1 Running E85
- changing plugs in a 94 Z28
- 3rd gen fuel line
- Before blaming the Opti
- problem with fuel pump??
- In-line fuel pump
- Need help figuring out which fuel pump wires go where...
- 93 lt1 running really rich and jerks from idle all the way thru rev
- Megasquirt???
- Is this a fuel pump problem?
- weird.... brand new opti acting up
- Fuel System
- LT1 no-start. No voltage to fuel pump
- 58mm Throttle Body
- V6 and V8 fuel line question.....
- Access door to change fuel pump - 4th Gen
- How rich?
- 94+ fuel rail setup
- what is wrong with my engine?
- dying at idle after 58mm throttle body?
- Fuel Pressure Regulator
- '95 Camaro Diagnosis
- Fuel problem?
- fuel gauge with sharader valve...
- Compression fittings on fuel lines.
- what is the 4th gas line on the sending unit for?
- what opti to purchase?
- Just say the word....
- Delteq??
- i think im running rich
- where is my fuel filter?
- Im getting bad gas mileage....need help figuring out the cause
- Question about Racetronix new 79# injector design please...
- Emulsion bleed tuning
- Is this normal? Fuel pressure ?
- Super fueler still around?
- Just shut off
- testing fuel injectors
- great place to mount MSD box!
- OTVC conversion. how?
- msd ignition boxes
- Fuel Pressure drops off when car starts
- car will not start
- fuel line and filter
- Help
- Ignition to computer link ?????
- loosing fuel pressure
- Fuel injector pulse width
- Fuel system...
- Fuel Gauge
- Venom Injectors
- car won't take gas... any ideas?
- New design for 30lb svo's
- Help with hooking up Evap fuel vapor canister.
- octane booster
- Fuel Pump Line problem
- Which battery disconnect switch?
- backfire out exhaust and intake
- Misfire at Idle...
- What is wrong with my car?
- Help making a fuel pump fit.
- Problem with opti rotors?
- Having starting problems
- adding 2nd pump
- Help repair fuel tank Holes.
- What Kind Of Tool
- What can i do to increase my MPG?
- worse gas mileage after racetronix fuel system
- Need help deciding which injectors..
- Cleaning fuel injectors idea
- Quick fuel pressure sender location question please.
- MSD Opti Timing screw??
- New Holley 0-3367 carburetor ('66 327ci)
- Fuel Pump Help.
- 95 Z28 starts hard, have to press gas peddle
- Fuel line routing
- Autolite xp5245 0.060" or 0.050" gap?
- Hard starting after fuel pump install
- Stupid Question
- Does the Tornado or Airaid tb spacer add power?
- Fuel Pressure?
- Where to get injectors flow match and cleaned?
- 94Z idles but will not rev, towed home
- no fuel gauge!
- car cranks...but wont fire
