View Full Version : Fuel and Ignition
Pages :
4]
10
- Hard starting 1988 z28 5.7
- Piecing together my dual walbro intake setup. Suggestions?
- Stays "ON" after key turned off
- Whats causing my gas tank to sweat so much?
- fuel tank assembly line
- Timing Chain Recommendations
- ??? gas tank?
- Going vented opti. Have opti but need everything else.
- Replacing Ignition Switch without "VATS"
- now won't start
- Relocating stock fuel lines?
- some asistence plz
- Code P0133
- Ignition problem: key won't turn far enough.
- FI fuel system
- LT1 with DELTEQ wire recommendation etc
- 1986 Camaro Rough Starting and Running
- My 91 Camaro has problem starting
- 1991 Z-28 stalls now, before would'nt restart
- Attn all you LE2 heads and cam people, what injectors are you running?
- Taping bottom of fuel tank
- Fuel Pressure Drop Question?
- Fuel Issue 95 LT1
- 1983 Z-28 crossfire injection
- How the heck do I get this apart?
- Best plug wires around!
- '96 Z28 starting issues
- Black smoke, idle up and down
- cooling and fuel system
- '87 IROC Fuel Pump
- Weird Hesitation Problem
- PCM Tuning Questions, Please help
- 383 Stroker Popping Out The Muffler
- 95 z28 - Car keeps stalling!
- fuel pump capatability
- LTCC and LS1 coil mounting
- Anyone use E3 spark plugs?
- Walbro fuel pump owners BEWARE!
- Bad check valve?
- fuel pump relay wiring
- Do you REALLY need to reprogram for 32# injectors?
- 2 cylinders wont fire
- Question about Racetronix fuel pump
- Need some help on the fuel line.
- Has anyone tried this opti
- Weird start when really hot out.
- Terrible Gas Mileage After Storage
- Surging and power loss
- fuel pump problems!!!!!!
- Engine misses and detonates with mallory 685
- Fuel Pump and Cooling Fan not working
- Routing fuel lines around SFCs
- Can a PRE - LT1 one wire alternator work on a 93-94 LT1 motor?
- Spark scatter on Taylor wires
- Z28 turns off while driving!
- 1990 Firebird Cranks But Will Not Start FIX
- Fuel pressure increase question
- CS144 Lt1 Alternators question
- Cold Air Intake?
- 1996 Z28 Fuel Tank
- Alternator Identification help
- Car surges
- Custom plug wires
- leaking fuel at quick connect
- Change ignition key
- Hesitation?
- 1995 Lt1 crossfire
- Starter not cranking...PLEASE HELP!!
- Bad egr valve?
- Access door F body
- Push button start
- Difficult Starting
- Effects from a bad tank of gas?
- Problem with plugs?
- fuel rail removal
- 96 camaro ignition switch
- 97 firebird v6-v8 swap
- lt1 spark plug wire suggestions
- Can you upgrade to MSD coils for EFI Connection 24x system?
- msd 6al
- Fuel Issue
- Fuel Pressure Question:
- Stock Fuel Pump Question
- Please help! ICM problem
- 96' v8 will not start..
- Problem...please help! 2001 Camaro V6
- Injector Constant question 36#'s in 93 LT1
- trouble starting
- random misfire from lean
- What causes ignition switches to go bad?
- optical sensor specs
- hard starting, runs fine, loose fuel pressure after prime
- Random misfires and vacuum
- wierd fuel problem
- Not the usual opti problems
- Can't turn key to start car
- Low MPG's
- Racetronix FP harness with Boost-a-pump
- 94z28 fires then stalls
- DynaSpark vent tube routing??
- Regulating fuel pressure
- Opening up an opti
- 94 Z28 suddenly not starting
- my 97 camaro z28 lt1 6speed will not crank or make any sound or attempt to start
- Sending unit wire
- P1351, used to start now nothing
- z28 running rough
- lt1 wont even start
- backfires under load
- Fuel Pump
- Msd ignition box ... Worth it?
- Weird p1351 problem no start without jumper wire!
- Fuel pump testing
- Fuel pump
- Holley Fuel Pump
- fuel pumps
- Hard starting!
- Coil resitance
- Z28 runs rough all of a sudden
- Vacuum line hook up
- Gas Guage Stuck Below E
- Walbro 255 & Wiring Harness #'s
- Fuel gauge never goes below 3/4
- access door cutout for fuel pump
- dont know where the ecm ground for the injectors are
- Help!
- 1994 camaro issues
- Racetronix relay connector wire colors needed.
- Fuel Pump Problem
- fuel pump install??
- my z28 wont start
- 93 z28 injector question
- LTCC W/2 STEP- Anyone done it?
- stock replacement injector questions
- Cut wire strap next to coil?
- 93 LT1 misfire
- Best optispark?
- Fuel Pressure gauge in AC vent
- 95 z28 that has a low end miss
- won't run
- local shop wants $500
- car running bad please help
- Sooo Lost. please help with fuel and ignition
- changing the fuel pump?
- Popping and dying win warmed up LT1
- Alternator Problems
- Racetronix Walbro 255 fuel pump
- Service engine soon and mult. misfires
- should i buy this fuel pump?
- ignition module
- Ignition timing
- Throttle body interchangable with Corvette?
- Fuel pressure settings
- Good opti for a 94' Trans Am?
- '01 3.8 won't start!
- OTVC Wire Options?
- New design MSD 8226
- You got LTCC ,so what plug wire are you using...
- What size and type of injector?
- 355 Down on Power and Shakes
- is there any difference between a fuel pump from a v8 car and a v6 car ?
- The best fuel pump
- looms for canton valve covers
- At the gas pump
- 4th gen fuel sending unit question
- 94 z28 stalled n wont run, gas guage went beyond full
- 85 iroc-z 5.0 caught on fire and i know why
- TRE Fuel Pump
- First SS!!! Gas Gauge NOT Working!!!
- optispark question
- FI fuel system. What size lines -6,-8 ?
- new to the site and cant find any parts .....
- Fuel delivery problem
- key switch problem on a 95 z
- Fuel pump
- Is This Okay?
- Another Strange Fuel Pump Question...
- 500 rwhp fuel system
- ignition for 1967
- LT4 injector replacements
- help with lt1 plug wires
- Is this all i need to finally finish my Header install
- MSD 6AL Issues
- 42# Injectors
- Dual pumps on stock wiring ?
- Fuel distribution?
- Which Pump To Use?
- (DRAFT) Guide to Sizing Fuel Injectors
- Hard starting/running weak
- Wacky change in idle air volume
- Location Of Fuel Pump Relay?
- fuel pump removal problem
- Spark plugs and Wires
- Homemade EFI Cleaning Machine
- would these be good injectors for me?
- Racetronix 255 pump and wiring kit horsepower limit
- Dual walbros or single walbro and boost pump on turbo lt1?
- No start condition need HELP
- Need some Advice for injectors
- Factory Fuel Line #'s
- wher is the fuse for the fuel pump on a 1995 z28?
- Car idle ways to high
- Anyone have bad experience with Accel Opti? P1351?
- ignition fuse problems
- 94 camaro idle problems
- Fuel pump noise?
- Resistance checking wires
- Fuel Pump Replacement
- What spark plug wires for LT1?
- 500/600rwhp 396 fuel and ignition
- Best fuel pressure regulator(boost sensative)
- gas tank
- What are Symptoms of bad fuel pump?
- Installed new fuel pump now problem
- Help way too much presser in my gas tank.
- Racetronix Fuel Pump Wiring for dummies....
- 1995 z28 runs and then dies
- After market injectors with engine mods
- oil leak after opti change what'd i miss?
- What kind of map sensor does a 95z have?
- Fuel injector replacement?
- Are these high impedance injectors?
- opti spark signs ?
- LS1 is acting up, I'm thinking fuel?
- How many feet -6an do i need?
- What is the max hp of a 42# injector ?
- OBD1 to OBD2 coil
- GM Fuel Pump Manufacturer?
- Fuel system upgrade needed.
- help identifying injectors
- wet optispark?
- Cleaning injectors
- Spark plugs
- What is the cause of the this sparking? help
- taylor 8mm or 10.4mm plug wires?
- routing spark plug wires
- no spark need help! car wont start!
- Zero fuel pressure
- injectors
- Need some help.....
- evac line from tank to cannister?
- Pontiac Timing Issues
- 700+rwhp fuel system
- Mallory 685 on 97 Z28, cant connect to coil
- Fuel pump or relay??
- best plug wires to withstand heat?
- Fuel Cell
- Engine backfires and does not want to start
- DELTEQ, Any updates?
- 95 z28 fire problem
