View Full Version : Fuel and Ignition
Pages :
3]
10
- Fuel Pump doesnt always stay running
- vacuum hose or fuel injection issue
- Ignition Switch heat problem
- Fuel pressure test
- OPTI Sustainment
- Icm won't ground with heat sink
- Opti Question
- Throttle cable connection to throttle body
- Fuel injector
- msd problem?? i think?
- fuel issue
- LS1 wont idle half the time
- Fuel Pressure Gauge Install Fittings
- Stumped by low fuel pressure
- Pump Replacement Question
- Fuel Rail and injector question. Simple.
- Summit Injectors
- Fuel Injectors...Suggestions?
- fuel pump not priming
- hopefully simple problem
- Fuel Pressure Regulator.....Bad?
- Question about my injector install
- Source for 0-rings for fuel cross-over pipe
- Help!! Need Walbro Fuel Pump
- 97 lt1 p0300 help
- Need new OptisSpark.
- need help
- 2 step wiring on MSD Digital 6 Plus 6520
- Service Engine light ON
- Fuel tank vent valve VS. Canister purge valve
- Fuel Line Question
- Ltcc conversion
- PCM/Ignition fuse
- EGR/AIR questions.
- Trap Door for Fuel Pump Access
- Fuel leak at fuel pump quick connect, FIRE HAZARD
- msd coil problems
- Special pre filter for fuel pump needed?
- 96Z won't start
- car wont start! no spark! HELP!!!!
- Restarting car that has been out of commission
- Optispark good or bad help
- long start on 98 z28
- 94 lt1 36 lb injectors
- Fuel pump does not prime intermittently
- timing
- Replaced Opti, Coil, ICM...having problem
- fuel pump instalation help
- Help identifying these fuel injectors...
- i need help with a code 16
- lots of pressure after removing fuel cap.
- 94Z won't start
- racetronix fuel pump
- 1968 302 timing
- 96 Z28 accelerates unevenly
- injector cleaner
- lean
- good aftermarket boost reference regulator for LT1 ?
- Car no start with MSD box
- 95 LT1 went to twin Walbro pumps - will stock regulator work?
- Where to buy Injectors
- injectors i should run...???
- Spark Plug search
- Please explain how the ignition in the LT1 works
- transmission codes for a 94 camaro
- 94 camaro code 16
- Possible bad fuel pump
- Im so lost
- Fuel pump replacement
- MSD cap and rotor
- AC Delco Fuel Pump and Regulator?
- Racetronix raplacement fuel pump on a V6 F-Body
- Missing throughout entire RPM range when warm...ICM?
- Plugs for ls1?
- Injectors... 36 or 42?
- lt1 no spark
- fuel smell through fuel lines??? !!!
- Fuel Gauge always on FULL
- Misfire diagnosis and a big thank you!!
- Performance plugs?
- summit opti distributor cap and rotor
- 91 z28 wont take throttle
- Map sensor smells of fuel
- msd digital 6 plus problems opinion needed
- 96 z28 Runs for 3 seconds then dies
- 1999 Camaro SS fuel pump replacement - "trapdoor" style
- Potential AFPR leak
- Opti Vacuum Line
- Multiple Random Misfires
- Diagnosing a stumble after warm up.
- Air in fuel line
- Fuel pump Relay
- Need help with Racetronix LT1 fuel pump kit 97 Z28.
- Floating fuel guage
- Gas Tank Switchout.....
- 97 Z28, just pulled fuel pump, loose hose?
- fuel pump problem?
- Are these the correct injectors?
- lean
- Breakdown at operating Temperatures
- Autolite Iridium Plugs?
- spittin, sputterin now won't turn over!!!
- alternator issue?
- So... I'm in the middle of the trap door mod...
- Fuel gauge problem
- Electrical Wonders.
- Fuel Rail Question for 500+ hp LT1......
- Which AFPR fits a 93 Fbody?
- Raw gas coming out of exhaust manifolds -- what could be the diagnosis?
- whats your favorite flavor?
- Once again
- Electrical / no start
- ltcc question
- Gas cap question
- igniton wiring help
- 1992 camaro rs
- 94 camaro rs 25th edition 305
- Gas cap o ring
- Connecting stock fuel lines to holley fuel rails?
- fuel pressure bleed off
- '86 Z28 half engine won't fire
- Anyone Ever Use AIP Electronics 10.5MM Plug Wires From eBay?
- 93 z28 w/jasper crate motor dies out
- 94 Z28 Won't start - Electrical Demons?
- Opti Vaccum idle Spec at inlet elbow
- 94 Z28 No start
- 1989 firebird and 1984 camaro
- New fuel pump
- alternator wiring - 250a Dual Rectifier
- Rich smokey idle
- misfire while cruising
- Turn on ac and car dies
- found this in my trunk 0- what is it?
- 95 camaro wont start
- fuel issue
- For the tuners
- Camaro 2002 Wont Start
- msd ignition
- vats bypass box
- Low Mileage after fuel pump change
- 89 camaro problems(VATS)
- 4th gen fuel system HELP!!!!!
- Miss Fire On my Truck Need Help.. thanks
- Afpr?
- 91 z28
- 94 z28 starting hard
- spark plug gap and heat range
- Homemade twin in tank pump kit?
- 30lb injectors
- 30-35# injectors
- 1997 lt1 383 stroker
- Backfiring right before/at shift @wot?!!
- Trouble accelerating over 95 all of a sudden
- can a msd digital 6 plus be fixed?
- 97 camaro just died and won't restart. helppppppp
- Starter Problems
- Best fuel pressure regulator
- fuel pump hot wire kit
- Starter Enable Relay Location on a 93Z
- Found a Universal Fuel Level Sending Unit
- Air/Fuel Ratio Gauge install ?
- Injectors: 3 Prong Cone or Split 20o Spray Pattern?????
- 96 Z28 no-start condition
- Recently swapped a head/gaskets and now camaro turns over but no fire
- Dies while driving/idling
- Need help!!! Car won't start!!
- Over the Valve Cover Wires
- problem with 96 camaro not starting after warmed up
- What is the best way to test an Ignition Control Module (Stock '95)
- Injector and Fuel pump questions
- [VIDEO] Fueling Video How-To Thread
- Fuel Sending Unit
- 93 camaro starting issues
- In-tank fuel pump
- Whole left Bank not firing.
- "Jumpering" the fuel pump
- Fuel pump install
- Fuel injectors not fireing
- Fuel pump replacement question
- Fuel injectors?
- Would optispark misfire change based on temperature?
- fuel pump ?
- Adhesive for fuel pump bucket
- Versa Fueler
- Will the stock fuel reg go 1:1 for boost?
- Opti, IAC, ICM, Coil, or worse?
- 1981 Won't start
- my high hp fuel system
- Fuel leak from top of gas tank
- fuel pump issue with new motor
- Mass air flow sensor Problem?
- External Fuel Pump Location
- 30lb injectors?
- help i put a hole in the bucket
- Injector formula???
- Fuel pump issue?
- New Pump- New Problem
- For 500hp flywheel, are parallel fuel rails needed?
- oxygen sensor?
- My idle is constantly changing. HELP!
- fuel pump is going?
- need sugestings car is skipping
- Beware of summit opti
- Air/fuel Ratio Gauge
- fuse panel location
- Battery Issues
- 1997 Z28 will not start
- misaligned opti run???
- Fuel Supply lines
- Opti question
- Problems with car running
- Whole Left Bank Misfiring....
- Idle problem
- 1998 camaro z28 fuel problems
- Inline Fuel Pump Question
- External Fuel Pump Harness
- Multiple Misfires
- Another dead Optispark ...
- '94 z28 stumbling, missing, backfiring
- Am I running "Rich"?
- Fuel pump hose connection?
- Battery Draining
- Second Opinion on Fuel Pump, Dead?
- Best replacement opti.
- Car won't re-start once warmed up.
- fuel injectors
- Fuel System Upgrade for Nitrous Options
- EFI connection LSX PCM
- Help! Camaro down! Possible stuck injector
- ignition switch or key and tumbler
- Mounting an external fuel pump help?
- Fuel pump recommendations for my 97 Z28.
- Code 15, suggestions??
- Stays running while holding key
- school me on opti's please...
- code 41
- fuel pump diagnoising questions
- Which wires should be hot on the fuel pump relay?
- Will dual walbros and stock lines handle this build?
- 95 cami will turn over but not cank up
- Anyone have Bob Bailey (LTCC inventor) phone number?
- cant figure out my backfire and misfire on my 97 lt1
- Is this safe?? need a wiring expert for fuel pump wiring..
- Need help with a fuel gauge issue...sounds like one for the Injuneer!!
- Where can I put a fuel pressure gauge on a stock lt1 fuel system
- What setting do you run your 42lb injectors at
- Fuel gauge not working: always empty
- Whats the recommended fuel pump now?
- Won't stay running
