- Just won a 1994 Firebird Formula...
- got my kirkey seat and 5 point harness in
- Estimated H/P
- replacing loudmouth resonator
- V8 exhaust on V6...will it fit right? GMMG?
- Name that Vacuum Line
- Window felt...need part numbers and info.
- Horn relay/turn signal canceling cam
- how much is all this worth
- Rear gear question
- Lucas Oil Stablizer
- dynomax exhaust
- Car wont start, did search, Im lost
- gauge overlay
- Light weight LS1 Starters
- Selling my car next month, what should I ask for it?
- cheapest higher amp alternator
- y-pipe rattle
- Install an "OOGA!" horn?
- interior lights problem
- gurgling sound after SLP CAI install?
- Am I right or wrong??
- Trans Am rear hatch question...
- any order from MacEwen products?
- front end conversion??
- What is involved?
- T/A still in storage, bonneville SES light, where is ECM plug?
- Exhaust help
- Crankshaft Pulley Bolt Removal!!!!
- should l sell my bird or not? need some suggestions!
- ABS/ASR Problem!!
- How much to sell block for?
- Need help fast..Can you weld on top of header coating???
- Crankshafts per year, nationwide
- Cheapest place to buy parts for my TA?
- rear hatch sun shield on 4th gens
- thud sound in rear of car during shifting
- [Podcast thread of the Week!] Anyone "taking your car out of storage" tips?
- Fuel Line Retainer Broken
- Question for ppl with Magnaflow Cat Back System
- Changing stock headlights....is it tough?
- Removing "CAMARO" Panel
- why did chevy use 2 diffrent drive shafts
- Bulb replacment for fog lights ??
- Car Died 5 Times Coming Home
- 2nd gen carpet?
- How much horsepower does a Moroso CAI add?
- Z28 vs. Inifiniti G35
- popping/exhaust
- ? about wiring up BBC in 95 Z-28
- A/C Just Went Out
- Wet floor
- back again w/ignition problems!!! OPTI???
- Camaro Hood Material?
- Which band clamps??? pacesetter quick trips
- Replace w/ clutch fan or Flexfan...?
- Need Help, Possible Cooling Problem???
- need fuel pump help
- Door lock replacement
- Where to Find SLP totl?
- Bad Vibration under moderate and heavy braking...
- CSR water pump wiring
- SLP ss spoiler v.s. Rksport ss spoiler
- Flowmaster or???
- Cylinder 6 Misfire??
- 1967 camaro 454 engine sale or trade
- Electric side mirror doesn't go up and down
- Left blinker stopped BLINKING!!! ---
- Anyone know the dimensions of the t-top storage area?
- My Camaro is full of suprises!
- Power washing engine bay
- No Power When I Get on the Accelerator?!?!?!
- Exhaust pipe knocking against SFC
- Does anybody know any....
- T/A and X-pipe clearance
- 97 Wiring Schematic Needed
- Traction Control
- New here..........
- 97 Camaro z28 SS questions
- Which fuel pump is easy and cheap?
- Driver side DRL out and turn signal stays on!
- Interior sail panel
- Force pro series mufflers?
- Replaced Radiator Now No Heat??
- throttle body
- Weird Fan Noise...
- got some knock retard........normal???
- LT1 steering wheel controls fix
- Is this B4C for real?
- Best way to clean out heads.
- Road Noise ?
- What are 4l60es worth?
- Miscellaneous rear hatch/electrical/console questions
- Ls1/Lt1 possible swap...opinions needed
- fuel tank venting?
- Holy Crap!!
- Getting Driver's Side Fender Off!
- horsepower question
- Strange electricall problems after winter storage. Advice.
- a/c compressor removal
- courtesy lights
- I paid $100 for an AC Delco 7 year battery. Is that what they cost?
- Odd radio problem
- Does anyone in cali...
- A SIMPLE...SIMPLE!! Wiring question..
- BCM What does it control?
- Gauges 101
- Taking Steering Wheel Column Apart, Got Stuck
- Anylast thought???
- Camaro seat tracks
- port and polish tools
- fog light replacement
- 94Z AC Compressor R&R
- Headers banging off floor, what can i use?
- What to check for on a used Z28?
- How to fix convertible top...
- how many miles would be too high?
- Exhaust HP Gain
- take apart the dash?
- What should I do to my car this summer?
- ls1 in lt1 trans am 94
- T-top question
- WS6 question
- dual exhaust
- I'm Too Short!! Can't depress clutch pedal fully, help!!
- Headlight problem
- 94 formula abs inop problem
- Where to get: Weather Stripping around door, around pass. WindShield and PW Base.
- Synthetic or Regular
- Another Ignition Problem
- Question about Ignition parts...
- When you run a carfax on an SS does it come up as a z28 or SS?
- Ignition Problem
- LT1 Trans Am Seats in LT1 Camaro
- WOT and free mods
- What to check for buying 1999 Z28 80k miles?
- New Exhaust
- LT1 question
- Unsure??
- Traction control
- Convertible top
- A/c
- Cruise control
- rust free exhaust?
- Will it fit?
- Light Problem
- Is this frame damage causing the car to pull to the left?
- Which one to buy?? I know someone has some input...
- bad alternator?
- cooling fans not working
- side pipes
- Why does my heater core keep leaking?
- map light replacement question
- Deciding to trade LT1 for LS1 but.......
- LT1 is not the same as LT-1!
- i have some qestions
- radiator hose
- Where would be the best place to buy an aluminum 400 block ?
- How do you know what # a SS is?
- Potentially stupid question
- Stop leaks?
- Castrol 0w-30
- which is lighter?
- Seafoamed this weekend...
- Gains from basic bolt-ons
- passing obd-ii in NY with mods
- Factory disc changer
- header wrap-does it work?
- Ideas why interior lights don't work in '96 WS6?
- what y pipe is avaible for A4 Verts?
- Weight Reduction
- GMHTP Budget Bolt-ons "1.6RR"
- Who's Installed the SLP Speedo Recalibration Box
- My car isn't polo green?
- Torque Wrench suggestions
- HSR L98 vs. stock LT1
- 69' Maro Taillights
- braided hoses
- adjust headlights??????????
- Help with exhaust set up.
- How do I make a kill switch for my 97TA ?
- Gremlin in my Car?
- exhaust question
- Coolant
- Keeping An Engine In My Garage
- Camaro dash board conversion
- AC removed - what plugs to use?
- Power window motor brand preference??
- Pro 5.0 owners pls comment..
- Ok Camaro guys...Need your help!
- Cats
- Anyone ever see this Camaro test mule before?
- vats problem
- Turn signal not blinking.
- best battery?
- Weird question
- A few questions, please!!
- Security Warning Light
- Shop time for a rad in and out?
- Weird Idle!!
- Voltage too high from alternator?
- Who makes the best Borla e-cutout?
- window motor install ?
- Center Mount Exhaust Questions
- Dash Noise
- APC seats??
- Is this vibration normal?
- Custom shift knob removal?
- hose questions
- Trip odometer getting stuck
- 94 Z belt size
- Will this buff out?
- Heater Core Help
- Power Passenger Window Problem
- a noob question about tail lights
- Heat/ A/C Vents on 1997 camaro not working...
- mufflers on my duals for race application
- Mellow tone mufflers?
- problem with rear seats (Pics included)
- Get rid of Hatch Lock?
- Is there a difference?
- Which fuel pump to buy?
- How much is this worth?
- are setting on a mallory 685 box saved if the battery is disconnected?
- Is Part # 52466004 right for a 95 LT1 Radiator?
- New exaust bung
- Replacing rear wheel stud
- Shifter problems...
- Where is the drain hole/plug for the gas tank?
- Big probelm. . .
- Oil sending Unit
- GU6 code on 2002 ss
- Weird Headlight Problem
- oil filter only filters about 10% of the oil each minute
- No answer *at all* from Comp Cams?? :confused:
- 68 front shoulder harness.
- Keyless Entry - 94 - Horn doesn't honk on lock?
- how do you get the parking brake handle cover off?
- Friend locked keys in car - who to call
- LS1 taillight swap
- Car information?
- 93+ Front Drag Race Brake systems???
- Where to buy a 9 inch rear?
- What foglights fit?
- LTs & 3" True Duals Without Cats
- Size of stock 4th gen exhaust?
- Lt1 to Lt4 converstion
- driving treatment
- It's time! Taking the car out of storage.
- Cutout Wiring help
