- Need Opinions, i'm a n00b
- Installing gauges
- True WS6?
- Vacuum?
- vehicle speed sensor
- LSGUN on HotRod TV
- Which brand of belts do you prefer?
- Car Wont Even Crank Over?!?!?!
- Concerns about stalling
- What is this? ASR or Cruise Control?
- whats the worst that can happen?
- reverse glow gauges
- Darn high voltage got me in trouble again...
- Strane gas mileage consumption and performance.
- I need an opinion on 95 camero
- Highbeam switch broken?
- Coil Relocate and Valve Covers
- how do I check my headlight control module
- Warm air on Heat Setting
- Can someone explain these things?
- Storing a Car for Winter
- Does this sound godd?
- O2 sims mod, What a difference!
- open headers on stock lt1
- Oil Pressure Gauge
- Car just quit
- In need of one header Bolt
- Oil 5w - 50
- Whats up with my steering?
- Clear intake elbow.
- A/C low pressure switch
- sloppy steering wheel
- sunroof option
- Headline: Additive turns oil to jelly and kills engine
- So Sad
- What do you guys think the parts off this car would be worth??
- T-tops vs. Hard top
- Exhaust Experts, 02 Sim question..
- Brake fluid leak from ABS unit?
- where to find dyno in IA?
- Headrest Seatbelt Restraints
- Camaro Seats in a Formula
- My LT1 feels weak
- What are the trade offs with going with a short block vs longblock vs crate engine?
- Why are there so many options to reach 700+ Rwhp in a 4th gen Fbody?
- Anyone Used These Window Lift Motors?
- New members Read: Top 5 LT1 mods in order
- Anyone with an auto have problems with the shifter sticking?
- Fuel Filter Replacement
- Few problems... all related? (just got car rebuilt)
- Clutch Pedal Return Spring Problems
- Seatbelt Removal
- A little advice if you're thinking about selling
- Ignition switch problem
- Low fans not working?
- Zerox G05 v. Dex Cool
- Macwen Motorsports phone number
- Shift Light for a Delteq-equipped LT1?
- Limit of longtube headers?
- 4th gen Egro's suck....
- What happens when you dyno an A4 car?
- Headlight problems.......please help???
- What could I have possibly damaged????
- Shaved hatch key hole-how to get in?
- What Camaro Magazines Are Out There?
- EGR Valve Technical Information, Testing.
- Street Twin Installation Question
- Putting Gear Selector Console Back Together
- Cutouts
- had anyone made the LT1 hood functional
- Fred or Rob. Please read.
- ok.. my car is scared or something
- CG-Lock
- Bad noise when cold start?
- Well, I just helped contribute to the stereotype of young drivers and sports cars :*(
- bang for da buck??
- My car doesn't like cold weather
- door lock mechanism
- Will a 2000 Z28 exhaust fit on a 1998 Z28?
- Whats this emissions related part called?
- Which SBC cam bearing tool?
- Summit racing seats....
- dexcool or ethlyn glycol
- Traction control, can it be added on to '94 model F-body?
- O2 Sims?
- Blown Blinker
- I need help with this one!!! Pads or tranny mount-?
- how to make hood scoop functional
- Firebird headlight problem
- Found source of hatch rattle!!!
- Can a Canadian find a low cost fuel pump
- Gas gauge problem?
- About an LS1 I found
- Smog Test Failed, Opinions??? +pics
- Rear boot
- header wrapping? bad?
- milled heads = longer pushrods needed right?
- Which fuse is this?
- Heat Shield for Intake?
- AC prob
- Seafoam?
- electrical gremlin
- Simplest Question Ever!!!
- Who sells locking header bolts & o2 extensions?
- head studs vs head bolts
- a/c help!
- 4BBL TB vs LS1 style TB
- My car's almost back! Paint prep pics inside...:)
- Part # for headlight connecter socket
- Seat repair
- Almost 12's for my 2000 Z28
- Dashboard/Windshield reflection!
- Electrical questions
- Rare options
- AC compressor rattle only when off
- Storing the Z for the winter
- removing windshield wipers
- Removing Badges
- Pacesetter Mids - PCM Reprogram?
- Found some rust in a very uncommon place. Every one might want to read this.
- TT 79 Camaro
- Ses Light Flashing!
- T-Tops question
- 96' convertible top cylinder fluid type
- Sylvania Silverstars
- High speed cruising?
- Adjusting or Replacing Speedometer?
- Heater Problems
- Paint on 94 Rearview Mirror
- How in the world do I access the headlight housing to change my lowbeams?
- Factory alarm goes off everytime ?
- Any problems with fiberglass hoods?
- T/A Turndown tips question / photoshop request
- Electronics experts- I need help with adapting LEDs for a 12v electrical system...
- emission failure
- Vert top not going all the way down
- Speed shops in Florida
- Ram Air H.P.
- z28 02 rear ended
- Camaro no start, intermittent:confused:
- Breslin?
- Guages?
- Need some advise - engine stalling out while driving
- How to fix Interior leak?
- rpm/transmission problem..any junkies here?
- Changing the fuel pump.....?
- ls1 in to 76
- battery question
- cost of LT1, LS1, or carbed motor swap?
- exhuast question
- Quick Door Lock Question
- Rear Defroster Problem
- Anyone do a trap-door fuel pump install on a Convertible?
- seat alternative?
- help with injectors
- Steering Column
- I need part number for K&N filter for Suncoast air box.
- tach problem
- Performance Oil Filter??... Stupid Q.
- pressure bleed down problem
- Installing a front end bra. Need instruction!
- part numbers
- Power seat not moving forward or back?
- More electrical wiring woes, 93 Camaro LT1...
- Deflating power lumbar - Non lumbar car
- Fuel Pump... Hard to install? 94 Z
- Battery Relocation with Diagram
- I need an exhaust part
- Anybody have the part numbers for the manual pedal switches?
- Defective SLP Skip-Shift Adapter?
- Uh Oh, Popping sound from the rear...
- 93-97 air bag question
- Camaro Dash in T/A?
- Where to look for loose connection?
- No turn signals?
- Broken Starter?
- OVERALL BEST 5.0 or LS-1?
- LS1 in an LT1 car?
- Dash Cluster
- Need info on factory LS6 blocks in 01-02 models
- LS1 and LT1 catbacks the same?
- Convertable top question?
- rear bumper exhaust?
- Turn the key to start, and nothing happened
- how do i remove/bypass the tach filter in my 93?
- Slow blinking turn signal?
- rpm guage goes the wrong way!!!!!
- LS1 wont start but cranks
- ?about edelbrock tes fitment, and coatings,cermaic and ti tech
- air bags
- My cutout is getting louder, confused
- What resistors work with Pellet Code 15 for the VATS (security light on)
- this doesn't make sense
- Opinion on leaving the ABS out of a summer LT1 car?
- Power Seat not working and fuse is HOT.
- Most of my gauge install problems solved, but tach still acts wacky @ 4000+ RPMs...
- GM Electric water pumps?
- My '98 Z's tach just stopped working
- SS airfilter
- changing turn signal bulbs on a 94 z
- Anyone dealt with Combination Motorsports?
- Car Has Been Sitting/SES Light
- Not sure if this is the place, but...
- What is this?
- Interior Lights Stay On Always?!
- Gas Gauge in 96 Lt1
- 1997- headlights or 1998+ headlights
- Floors soaking wet...
- Cruise Control quit working after intake gasket replacement
- SES Code 29
- Quirky wipers
- VATS / Opti Help? CAR WON'T START!
- Pipe with flanges to replace cat
- Does anyone know how the SGS switch works?
- shift light for an ls1?
- Gas Tank Building Up Pressure
- Gumout Fuel System Cleaner
- 94' Z speedo
- Camaro turn signal lever.
- gas tank
- stud sized
- car wants to die - help
- Please Help - Electrical Problem
- Buying An LS1 Car, Need HELP PLZ!
- What was in my Boot ???
- Fuel pressure gauge sender install problem- leaks!!
- Has Been Ask To Many Times V6 To V8
- 94 camaro heater question
- 94 z28 with security light?
- 1993 Idle issues
- 1971 Camaro A/C box question?
- 2 batteries 1 alternator
- Need advice on how to wire up custom gauges to replace the OE cluster on a 4th gen...
- TC rear in non TC car?
- Help
- Heater blowing out ice cold air
- Closed cutout hindering sound and performance.
- new era performance parts.com
- Flushing heater core?
- Exhaust clamps... Can I use the WIDE band clamps?
- cooling fan relay **3rd gen**
- SES Codes don't know what to fix?
- Window Motor Mod??
- speedometer problem
- Low and flow
- Could this gain some Horses?
- Wiring up my aftermarket gauges- electrical problems...HELP!
- anyone ever try one of these?
- SLP Loudmouth II catback question
- battery relocation questions
