View Full Version : Drivetrain
- Hard to get in gear
- Will it fit?
- Tranny temp. gauge pinned over 250 Deg. !!!!!!
- quick diff question
- quick 4L80E question for all you tranny experts...
- gearing and gas mileage..
- SPEC clutch feedback...
- Question on setting up gears, can someone help?
- Sign Of Bad Ring and Pinion?
- Holy crap! Look how bad my old clutch was....
- strongest gears for stock rearend
- Clutch Problems?
- Tranny will not shift 2-3 @ WOT??
- 12s with just bolt-ons?
- Guys with a T400 or T350
- Transmission Mount Nut:
- Anyone go from 4L60E to 700R4?
- 4th Gen SS- A4 to M6 Swap?
- T56 Grinds when speed shifting into 2nd?
- Flywheel replacement? (A4)
- Clutch not gonna last much longer...
- What inch and bolt differential?
- What auto transmission?
- Vibrations with new driveshaft and rear diff
- Rear End Rebuild
- Question for 9" owners.........
- No first gear...whats wrong?
- Will a LT4 clutch hold a 383 stroker?
- converter and gearing ??
- Pete Z bars
- Which Clutch
- T56 Experts! Need help!
- Clutch
- 12 Bolt Vs. 9inch??
- What oil to use in Moser?
- torque converter
- M6 doesnt feel right
- T-5 clutch engagment problem
- Rearend noise
- intelligent opinions on gears 373?
- A4 funny shifting
- Actual line pressure vs pcm value
- Any way to tell if a T/O beaing is good?
- Transmission
- b&m or transpak
- LS1 clutch adjustment
- Shim Pack Question
- wrong tailshaft for TH350 swap? (9")
- Problem installing slave cylinder into T56
- Anybody using an aftermarket speedo with a TH-350 or 400?
- How hard to launch with a street twin and a 10 bolt?
- Hi-po lockup converter (TH400)
- okay...lets have a small quiz....tranny temps and longevity
- tires, drivetrain related?
- Who builds the best tranny (4L60E)?
- shift kit??tranny rebuild
- T56 noise (again)
- Where can I find out more info on PCM programming of 4L60E?
- How much to get vigilante converter restalled?
- Battle of the rear ends, 12 bolt or 9"?
- TCC Lockup
- TCI 4l60e??
- 3:73 ?
- Towing rear wheels down will damage transmission??
- Predator Torque Management?
- LS1 Clutch question
- HELP! I think I shattered my clutch!
- Lous SS website?
- Question about brakes and lower control arms.
- Car doesn't shift at WOT
- Transmission issues.
- ? about the pro 5.0/lous
- Vibration
- Tranny Rebuild
- shift kits
- Trans Problem
- stock gears and et streets (3.23's)
- TQ Convertor ?'s
- Chattering from new clutch?
- Spohn Torque Arm
- 4:10 gear swap???
- read end question
- M6 shifter
- what type of pulse does the trans put out ?
- 2800 or 3000 stall for the new transmission?
- Jasper Transmission
- Vibration at high speeds
- Axle Seal on a moser 12 bolt.
- change trans fuild-how many miles
- paddle kit
- Spec stage 3 is in WOW
- How loud are your 4.10's?
- New Transmission...
- Anyone have problems with Spec billit steel flywheel?
- Symptons of a Bad Pressure Plate?
- 9 bolt vs 10 bolt
- How to tell if the new slave has over extended?
- Is my tranny dead?
- Adj. Master Cylinder for the street twin.
- Street Twin installed....loud screaching noise
- GM Parts instead of shift kit....
- Grinding noise from shifter after new clutch install!
- Bearing Question
- T56 rebuild
- Rear End size
- Called McLeod and this is what I found out
- Th 400?
- A4 with a mind of it's own
- T/A rear girdle leaks?
- Engine vibration & motor mounts
- What has to be done to put a powerglide in a 3rd gen?
- TA cover
- whining sound in rear end
- Trans temp gauge won't work
- Vibration
- Urgent Clutch Info Needed!!!
- How hard to replace a driveshaft???
- high speed "humming"
- Soft clutch pedal
- A4 to T56 swap, what mods do I need to do to the A4 harness??
- Drill mod with the Street twin
- know any good tranny shops around here?
- autozone clutch
- Low-speed Rear end noise when backing/turning
- drive train noise!!
- LT1 and LS1 STALLS Compatible????
- Broke the slave cylinder...
- 4l60e trashed 2 pumps in 2 weeks?
- ls1 brake swap
- Rear End Girdle worth it?
- Need help 4L60E question
- How do I know when its time for a clutch?
- where to buy t56 internals
- Play in the driveshaft...Is this normal?
- Mcloed Adj Master Problems!!! Please help
- spec Stage 3 ceramic install finished!! but have a question??
- Suspension Setup
- Transmission Problem
- 1350 u-joint
- Clutch Replacement
- Does a new clutch need a break-in period?
- Master Cylinders, LS-1 and LT-1 the same?
- Persistent clutch problems, has the shop stumped.... HELP PLEASE
- Gear Swap Questions (2.73 to 3.42)
- down shift noise??
- Bolts n' nuts for 9"
- Good Girdle price
- I'm in need of stall converter suggestions...
- How much would a new clutch installed cost for a '94 Z?
- Starnge 12 Bolt Whine...
- Difference in V-6 4L60E and V-8 if any????
- Torque Converter, will it only help on the launch?
- 3600 stall and Trans go
- Quick, what do I put on the rear diff pinion splines to seal theyoke?
- Rear end clunk noise/problems
- 98+ 7.5" carrier the strongest made?
- Gear swap on a 93. Questions on Speedo gears
- Thoughts on M6 conversion...
- Where can I get a shift kit?
- Try this here, grinding in third...
- Installing weld in relocation brackets
- Removing the mainshaft bearings without a bearing press?
- Exact width of our rear ends
- Weights of different rear ends
- TransGo full manual shift kit
- 3rd gen Temp Spare (inflatable type)
- Torque converter and dyno #'s
- Will a 2001 10 Bolt fit on a 97?
- Buick 8.5 rear?
- Shifter?
- Grinding in third!?!?
- detroit locker?
- clicking noise from betwee the backseats
- good deal on transmission?
- A4 Reverse GONE -please help, serious crisis
- DIY gear install
- Gears?
- A4 Question
- popping around right turns
- What would cause my a4 not to shift
- shifter spring to center
- question about manual transmission fluid
- I never thought I'd ask this, but.....
- Aluminum Driveshafts?
- Converter making banging noises when it locks up
- Possible manual transmission problem, need insight
- Number of splines on T-56 output shaft?
- no third gear at wot
- How Bulletproof is a T56?
- Torque specifications for tail mount repair
- Auto to M6. Question on Flywheel.
- difference in viper t56 and ours???
- 3rd gen 12 bolt in 4th gen?
- Flywheel balancing...
- trans wont shift out of 2nd what setup?
- 12 Bolt vs 9 Inch Rearends
- LT1 Brakes, all the same?
- speedometer wont go past 20
- Changing point of clutch engagement
- HELP...Transmission
- Ford 9"
- Manual valve body 4l60e? (for OBD1 high stall fix)
- The answers we've been looking for (attn: firepheasent, etc)
- Max Main Line Pressure settings for 4L60E
- What brand of gears?
- Slave Cylinder, Street twin Master Cylinder
- super strength posi
- driveshaft yoke
- trans not shifting wot
- Is this normal operation for a tourqe converter?
- rear end going soon?
- Identify this part please! (pics inside)
- What is all needed for gear install?
- lt4 clutch disc in z28
- were can i get a slave cyl??
- 5 speed must go...parts for sale
- L65 and PCM issues
- anyone else's shifter pop out of reverse?
- TH 350 swap-94Z28 questions.
- when should I change my tranny fluid?
- dam ST!!!!!!!
- Drivetrain
- Overdrive solenoid?
- b&m or trans go
- Whose good on clutches?
- Question on Chevelle 12 bolt rearend
- series 1,2,3 carrier..??
- Rearend trouble
- Help Me Confirm if this is Gear Whine
- Moser 12bolt assembly questions
- Off the forum question...
- Back Up Chatter
- part #s lt4 pp/c
- How do U take out shift lever knob?
- Converter going away on me?
- When do you need a torque converter?
- tranny not right
- Strange 12 bolt sale ending soon!
- Converter Problems, PLEASE help me
- identify this leftover part from Street Twin install
- Drivetrain noise
- interchange?
- Will this center section/3rd member be okay?
- L69 to 400 SB swap
- A4 shift kit??? Which one?
- Is my short throw tearing up my tranny?
- 700R4, What does it handle stock?
- Serious SPEC clutch or slave cylinder issue. PLEASE help
- Who Can Build a Stong MVB 700R4?
- No Backpressure!
