View Full Version : Drivetrain
- can i make these gears work?
- fbody 10 bolt in an s10?
- No reverse in A4 - need advise
- No WOT Downshift...
- Differential Vibration???
- ls1 t56 to lt1
- help with gears!?
- Clutch peddle position question
- Has anyone built a strong 10 bolt and what is the best 60s your getting out of it?
- Th-400
- Factory Hurst v. Aftermarket Hurst - Visual difference
- Need advice on rebuild or swap
- Figuring out gears in used car I am buying
- What RPM stall convertor to get?
- How much for labor and parts on Syncros?
- 4L60 vs. 4L60E
- Auto tranny fluid leak...
- I know its been asked a million times, BUT, what is the best convertor?
- best clutch for the money
- Transmission Cooler Install
- M21 or M20?
- Yokohama v/s Nitto
- Torque specs for the McLeod street twin please...
- tranny prob, please help
- 94 A4 Tranny problem (missing 2nd)
- very knocking/hard going into 2nd
- Shifts feeling a little harder
- Short shifter Question
- Replacing Clutch
- t-56 stuck in 4th gear...whats wrong?
- flex plate on 383
- clutch squeaking?
- Need Help with New Transmission
- Six speed gears into an A4 Car
- where to get a new axle?
- Tranny Problem????
- G-Force T56
- shift kit q's
- I can shift from 4 to 5, but not 6 to 5, what gives?
- Mcleod street twin info
- when do you need a Viperized T56?
- My SPEC Stage II Experience
- Very Bad Shaking.....
- Auto or Manual for very high power
- where to go now?
- Autozone clutch no longer $199
- Need help, will this work??
- Lt1 Clutch bleeding procedure
- How to do "Resistor trick"
- SLP clutch w/ a 150 shot?
- How much did your ET drop with a vigilante converter?
- where can i get a midwest or edge convertor?
- new transmission acting wierd...help?
- Money 2 spend...clutch?
- Can I
- Is My Tranny Shot???
- quick help on pulling trans!
- Jarods or Lous short stick( i need quick response so i can get this b4 christmas)
- A4 to M6 advice
- Problems a month or so after SLP Clutch install. T/O Bearing?
- tranny mount broken. please help...
- Torque Convertor Question
- a4 to m6 conversion?
- Did I ruin my rear end?
- New tranny goes in this week, what else do I need ?
- 4:10 Questions...
- Is this noise normal??
- traction was bad before.... with cam forget about it! HELP!!
- Transmission, Overhaul or Reman?
- Vigilant vs. TCI converters
- How can I tell if the CLutch fork isn't on right? What are the symptoms?
- Gears for an A4???
- LS1 Rear End Questions (Brakes, Torsen, Gears?)
- IS this on right?
- Best Clutch
- 400 speedo sender
- Rear axle work
- Tranny Cooler Question
- Corporate GM 12-bolt out of a Suburban? Can it work?
- reverse lockout wiring help!!!
- Bad Vibration
- Heeeeelllllpppp!!!!!!
- Key Stuck / Wheel and Clutch won't lock
- Clutch disk material... what do I want?
- Yank stall questions...
- Agghh!!! Someonehelp!
- Big hp (650rwp+) guys with m6s inside please.
- I CANT stop misshifting even with a pro 5.0 shifter! I NEED a rocket scientest HELP!!
- How bad is a leaking rear main?
- shift kit for a4
- Whats wrong with TCI??
- Cheapest 12 bolt out there?
- Cheapest place to get 12bolt rears?
- SLP gears...
- 3.73 gears?
- Getting my TC soon
- Can splines be fixed?
- LS1 Axle Shaft in LT1 Rear End
- Help With Getting C-Clip Off
- Can I mis-match gears???
- Pros and Cons or Redline Synthetic Tranny Fluid
- 3.73 gears
- Converter questions!!!
- Th400 running a NON lock-up 2800 vigilante, is this "too much"?
- How are 3.73's in an M6???
- LT1 + 5-speed manual?
- 3.90 gears now available for the Strange 12 bolt
- Grinding/rubbing noise from T-56
- Auto shifter sticking
- Could this have something to do with my Drivetrain?
- Who sells spools for 10 bolts?
- What is needed for 4.10 install on 136k mi car?
- 4L60E Problem
- 7.625 Eaton
- where do i get the A4 to M6 conversion kit?
- funny noise making me go insane!
- Posi Unit for 9"
- TH400 VSS Sensor Install ?
- what is the best tranny fluid, rear gear fluid???
- 4.10 lowest differenial ratio?
- Broken Wheel Stud on New Strange RE
- increased line pressure via PCM... good? or bad?
- 4l60e delayed shift/ PLEASE respond.
- choosing stall speed
- Anyone use Centerforce Dual Friction clutch?
- Need opinions on a good clutch setup
- need stall advice
- Goodyear P275/40ZR17 Eagle F1 Question
- TV cable problems?
- Can't get them off.
- Need info about 6spd swap. Search=No Luck.
- Here's a die that works for the Pro 5.0 handle...
- identifying a 8.5" 10-bolt from the rest?
- Up shims creek!
- Drivetrain vibrations
- stupid newbie trans. question
- th400 guys come in
- 3.73s? Gonna throw me in the seat?
- Powertrax Locker
- Synthetic Gear Oil
- how does a gear
- guys running th400 come in
- Question on 95 4L60E
- Motive OR Strange?
- B&m Shift Kit
- Spec Clutch?
- Concerning TC change
- transmission help
- clutch pedal noise
- One-way clutch grabbing? Rich Krause, 12SCNDZ, please help.....
- a4 tranny rebuild kit?
- shifting without a clutch??
- How do you use a dial indicator?
- T56 rebuild
- carrier??
- Help installing an aluminum driveshaft
- width of lt1/ls1 10 bolt rear?
- TCC solenoid part number?
- 3.73 a4
- which gears should i get?
- New strange noise
- reverse lock out gone bad
- trans question
- What are some simptoms of a bad clutch?
- TC and 373's
- Tranny Question
- button on shifter wont depress easily
- going to rebuild my t-56, how to make it stronger?
- tranny help!!!!
- Transmission Syncro
- What kind of Bearing puller.....
- Flywheel balancing?
- loud gears
- Need Part #'s
- I Rule!!!
- help me please... Ford 9" fluid change.
- Upgrading T56 - D&D vs Donato Engineering.
- full manual 700R4 in a 93 Camaro, what are my shifter options??
- moser installed ... but..
- B&M Transmission SuperCooler, does it work ?
- winter tires
- Did I break it?
- Clutch experts, Need your help, my Street Twin is toasted
- B&M Ripper ?
- Opinions on SLP Clutch/PP/TO Bearing
- So I'm driving home..........
- Anyone ever double sealed their T56 tranny input?
- 3.8 V6 4l60e?
- Those w/ Aftermarket Auto Shifters
- What did I do wrong?
- Clutch Shims
- question for M6'ers
- RPM's to Gear Ratio
- component list for clutch swap
- Best Shift Point?
- Hypertech shift firmness setting - Good / Bad?
- differential oil, hellllllp!
- Stock Hurst Vs. Pro 5.0
- Turbo 350 downshift problems
- Weird Noise from shifter area??????
- 1993 Z28 Tranny help?
- Can't get Tranny on!!!
- D.S. Loop no fit?????
- aluminum drive shaft
- Trying to figure shipping. Need TH-400 stats.
- master cylinder install!!!!!!!!!
- t56 trans fluid?
- clutch pedal problems. 3" and stop.
- Question about "stallin' at the line"
- Rebuilding T56???
- What kind of 60' is expected with a moser 12bolt with 4.10s?
- 3400 Yank too big...
- Just got the 5.0 installed !!!
- 4l60e
- More on that clutch pedal of mine
- gear install in TX?
- zoom clutch kit
- right turn hop
- Where is the Clutch Slave Cylinder located?
- trans wont move
- Whats a good transmission? and Where can i buy it?
- Two different ranges per gear???
- what rear end gears do I have?
- Help With C-Clip!!
- URGENT: Best clutch for abuse/reliability under/around $300
- 01-02 Master Cylinder
- t56 growling
- Ring and pinion install prices?
- Anyone with RPS turbo clutch?
- Tranny Valve Hanging??
- rear end
- Just one irritating bolt to go...
- clutch and hydraulics
- Stock Torque Coverter Question
- Can anyone tell ,e where to get the best price on a 12 bolt moser
- 4.10 Gear/Posi? Paddle Kit?
- Grenaded Stock Trans....
- Weird Shifter Problem, Please Help....
- About to replace my clutch...
- Motive 2-cut vs. 5-cut gears
- Problem downshifting
- A few ?'s about gears
- A few more ?s about the 93 tranny.
- Tailshaft question?
- Possible stock shifter for turbo 400 swap?
- Reasonably priced clutch for nearly stock car?
- looking for strange sized tire
- trans mount?clutch?wtf?????
- HELP! Clutch torn to pieces...
- T56 experts inside
