- need help setting pinion angle on new BMR adj T/A
- diff breakin
- Driveshaft
- "new" 12 bolt or "old" 12 bolt
- abs with a torsen diff
- Rear end question
- Unplugging lock up
- Mcloed ST question
- Does a TH400 rob horsepower?
- I don't understand rear ends...
- Zexel Torsen
- 4.10 gear change question
- 2nd gear grinds.. can i just have the synchro done or what?
- trans not shifting
- WHITE SMOKE coming out of transmision whend i hit 80 mph or more.
- Draining Tranny
- TH400 advice needed.....
- Loose Clutch Fork Question
- Gear/Speedo ?
- there goes another T-56
- GearVendors Overdrive w/TH350, good setup for mostly stock car???
- New Converter suggestions
- width of 3rd gen and 4th gen rear ends???
- Have One Question Before My Clutch Is Installed
- Rear brake rotors 2002 Z28
- Q about camaro ls1 short shifter
- Convertor write-ups
- Motive Gear Info
- Gear Ratio in Camaro
- Help, I think I broke it...
- need price ASAP please reply if u know
- Proper way to build a jig to weld an 8.8
- rear end question?
- The 7.5" "mini spool"
- help! vibration
- leak after tranny cooler install..help
- How much would it cost to swap my A4 for a M6
- v6 transmission question
- Does my tranny have the vette servo?
- Transmission fluid capacity?
- Anyone toasted their Torsen diff?
- Will This Posi Unit Work?
- M6's: Is it a Tremec?
- tranny temp gauge and sender
- CAR WONT SHIFT INTO 4RTH need advices.
- NEED ADVICE ( about trany) car wont shift into 4rth.
- Slipping clutch
- driveshaft question
- Z06 brake conversion
- Changing clutch what else to do???
- rear end strength
- BANG! Rear end lets go!
- Twisted output shaft...
- Lca ????
- Apparently my rear-end took a bath...
- Need a New Clutch, What to go with?
- How to tell what series carrier...?
- What rear can I use?
- TH400 Converters
- 373s???
- transmission drain plug on t56?
- torque management
- automatic transmission
- How much $$ is a reasonable gear job
- MY A4 starts off in 3rd Gear!
- Cost of T56 swap??
- 31 Spline strong enough?
- Need to Check Clutch Fork
- What gear do I have(and I'm not an idiot)
- 10 Bolt
- Failing Lock Up?
- 9" questions (again)
- street twin question
- A Little Differential Help
- Tranny Rebuilt now no Torque
- Noises...etc... should I be worried?
- TH 350/400 help needed ASAP
- How can this happen? (trouble with zexel torsen)
- Who loves there 12 bolt
- Anyone Stalled a 4L60E w/over 100k?
- CAR will not move after tranny install
- TH400 Gearing (2.75 vs. 2.50)
- Using a 4.3L converter??
- Cheapest place to but a SPEC Stage III?
- new noise noticed after new bearings installed in rear end.. help!
- FINALLy got my new clutch in today
- Homemade Adjustable Master Cylinder?
- 10 Bolt
- How much tranny fluid after rebuild
- 2400 stall problem
- TH350 Gear Ratio Change
- TA rear end cover
- "Viperized" t56 or Th400
- clutch choice?
- differential seal is leaking, help!!
- Will a 94z 4l60e fit in v6 Camaro?
- down sizing gear ratio
- Where can I find one of the $1500 T56 Convesion Kit!!!!!!
- Suggestions for a rear diff cover that has drain and fill plugs
- tranny lines
- Yank SS4200 is in!
- 12 bolt Vs 9 inch
- aluminum driveshaft
- torsen HD
- Rear Gearing
- Clutch install help
- Quick question about seals on the moser 12 bolt...
- Driveshaft Length
- clutch
- has anyone ???
- 2000 LS1 M6 Hydro problem?
- let the richmonds roar!!!
- CAr wont go into 4rth! please help.
- high stall (3500) with 2.73's???
- lt1/4 corvette clutch in trans am
- bought a viperized t56 from dd performance
- Pilot Bushing keeps making noise!
- tell me now before i order please(buying clutch)
- Help with speedo calibration problem please...
- Monster Motorsports transmission?
- Should I change dif. fluid?
- How can I get the ring gear off the carrier?
- TH350 short/long tailshaft
- street-twin assembly
- Shift kit Question
- Hurst shifter or factory
- Throwout bearing questions
- changing t56 fluid
- LT1 converter questions???
- What is the gear ratio for the 6 speed in the 2002
- LS1Speed's Short Stick
- Cries, blew rear end tonight on first pass on new clutch
- Help!
- Weird noise from t56
- 700R4 and shift points
- T56 conversion for people that have done it
- How to remove tranny with Heads off?
- what did the th350 come in
- Minimum thickness for flywheel?
- How Do I Tell Which Gears My Z28 Has Out Back?
- 4l60e differences (ls1 vs lt1)
- help with my shift kit problem
- 4L60E High Stall no 1-2 Shift
- Speed shifting
- Tire Size comparo?
- 4l60E transmission front pump
- 4L60E price??
- Pressure plate not mated with flywheel?
- quick help
- I need help with a transmission swap! Someone explain...
- 94 Z Cutch install - can't shift
- Problem with my LS1 T56 into 97 T/A A4
- mcleod 7500/5500 clutch question
- Reuse Pressure Plate
- A4- 350 turbo swap??? HELP!!
- Good ol' BW T56 :)
- Transmission Serial #s
- Sound from rear axle!!!
- Transmission??
- 12 bolt question
- Do I Need A New Clutch With These Mods?
- price is just too low. anyone use torco??
- 4L60E shift kit / upgrades
- Used Ring & Pinion
- F-Type lubricants
- Will stock clutch hold 410RWHP?
- ASUS posi...anyone have it?
- another tc question?
- Trans Shifting Problem-2 Ideas
- Anyone have the .pdf file for a T56 rebuild?
- I've got a good one for you...
- slipping clutch ?
- ABS INOP Light and Speedo Calibration Problems after rear swap...
- Convertor whine? Is it normal?
- Anyone heard of Pro Torque converters?
- Tranny Problems
- T56 Transmission Connectors
- What kind of trans fluid does everyone use?
- What stall? Vortec 550
- dead tranny??
- Anyone hear ever break a Vig converter?
- Homemade 12 bolt question.
- Syncros or something worse?
- New syncros? 1st gear slides right out.
- Help on clutch master/slave cylinder
- Torque Converter ? before i order
- Best place to buy a T56?
- A4 question
- T56 noise
- Clutch install ?'s
- Getting a Mcleod or Spec Clutch w/out doing billet flywheel?
- th-350 speedo question
- $1,500 to Rebuild my Tranny! is this fair price?
- Tranny problem??
- Transmission question
- I need emergency help
- Who here manually shifts there A4?
- cant decide on 3.42 or 3.73
- Rattle in the rear-end???
- replacing tranny mount
- swapping to 3.73s help needed!
- Tranny keeps overheating...
- Ring gear spacer?
- Replacement Gear Question for Moser 12 Bolt
- Shifter Question
- Pontiac Guys
- Torque specs for preload bolts on DTS cover?
- 99 Camaro recall...manual trannies
- how can I make my tranny cooler more effective?
- What should i ask for when i get the tranny rebuilt?
- Vibration through steering wheel
- 3.73 install
- Rebuild your 4l60e yourself
- SPEC stage III & Billet Steel Flywheel (pics) INSTALLED
- Needing 4L60E rebuild for 11's, who to use??
- B&M Supercooler Transmission cooler...
- Tranmission problems on Vette...my friends.
- Keep the B&M or go with 5.0?
- tranny mount
- Tranny mod
- All automatic guys !!!! A4 guys !!!
- What gains with the Lockup switch?
- aod for 6speed
- LT1 clutch bleeding ...
- bolting TH400 to ls1???
- Little help on a T56 install
- question about mid-west!
- SLP converter ? HELP!
- need torque specs??
- 4l60e-th400
- Gear Question
- Trans Cooler? Odering tom. please help
- 4L60E or TH400??
- Tranny seems a little sticky when under WOT
- So I'm about to install a new clutch...
- Reprogramming for a 3500 stall TC?
- will this rear end work?
- Ford 9" rear end
- torque converter..bad?
- Torque converter install
- trans.
- Rattling from transmisson?
- manual transmission vendors
- Valve Body for automatic
- Corvette flywheel in TA??
- Weir Hot Rod aftermarket T56 bellhousing
- stock 10 bolt 7.5 or 7.625?
- my transmission's crazy....
- Code 72 trans output speed sensor
