View Full Version : Drivetrain
- 3 And 4 Series Carrier?
- Which route should I go? Help me decide!
- Rear End Popping
- 4L60E transmission line fitting
- pinion shims and bearing
- 1st Gear in Auto
- What's it like having a stall without a shift-kit?
- Drained and filled my rear end with 80/90 do I need an additive??
- Overdrive engagement problems
- Started T56 swap today!
- ram clutches
- Torque Converter Issues* Please read*
- one wheel peel
- C5 Z06 trans question, will it bolt up to LS1???
- drag radials
- Clutch fork problems, can I get some help?
- 2.73's vs. 3.42's or Bigger
- converter ?
- Stock gears in a 98z?
- Is my next mod going to be a rear end?
- Transmission Cooler!!!!!
- Limited slip additive?
- car won't stay in reverse
- Auto to 6-Speed swap ???
- Are V6 pedals the same as V8 pedals?
- yes centerforce will hole 500rwhp PROOF
- TC problem???
- How do you know when its time for a new clutch/gears?
- Clutch engaging earlier now?
- cheap 9"
- Adjustable Clutch Master cylinder thingy.
- 2800 or 3200 Vigilante? Opinions PLEASE
- Need new brakes and rotors, suggestions...
- PCM tuning after TC install
- 1st and R giving me troubles
- Transmission problems
- stock tranny?
- Gas Milage with 2800 Stall
- how much tranny fluid into stock tranny?
- Manual shifting an auto
- Spools
- Torque Converter:
- dreaded 4l60e
- M6 to 700r4 Swap Help
- torsen take out diff?
- Which shift kit?
- 4:56 or 4:11 gears
- 4l65e
- LT1 Dave Tranny
- clutch problem?
- T56 Swap Kit For LT1
- How Necessary is Power Steering?
- Shifter knob removal on my ls1
- Clutch pedal switch mounting clip?
- rear end clank
- Moser 12 bolt or Moser 9 inch???
- will a 700r4 off of a 305 tpi bolt up to a lt1?
- tci converter
- Need advice on tranny choice
- tell me why i need a torque converter
- torque converter for daily driving???
- Won't shift into 3rd at WOT
- tranny lines
- how much for a used 4l60e?
- do i need a aftermarket flywheel
- tranny doesn't want to kick down
- 17" et streets
- 4l60e or 700r4 ??
- B&M 4L60E Deep Trans Pan
- Will this clutch hold up
- Well the trans needs a rebuild.
- They sent me the wrong Gears
- Pulled the Pan on my Th400 w/in
- flywheel
- camaro rear end
- general T56 swap question
- Clucth problems
- Tranny Fluid in Exhaust
- Clutch or Coolant?
- used 4l60e, how to flush radiator
- What should my first Mod be?
- What the??? TC's increase hp too?
- Rear axle
- Whats that noise?
- LS1 clutch disks work in LT1's
- Drag racing with a TC question.
- Big converter in a 94Z ?
- Limits of a stock A4
- cannot get M^ on after trying for three days, need help
- rear end
- What will I notice going from 3.73's to 3.42's?
- Are new Master/Slave assemblies pre-bled?
- M6 to A4/ Swap ?s
- Tranny Cooler
- TC help!
- race prepped 4L60E
- rear sway bar hittin rear end?
- clutch install
- Squeek from clutch fork pivot point
- Tranny Install/please help
- New Spec Hybrid Clutch
- 4l60e
- tranny
- Torque Converters?
- MOSER- EATON - CLUTCH NOISE? help
- West Coast Converter's?
- Good clutch that doesnt chatter? Z06 in an LT1?
- TH400 swap cost?
- How hard is it to remove TH350 valve body?
- Pro 5.0
- 4l60E 3rd gear slips (or fourth, not sure) when at WOT
- ...pinion seal and bad bearings...
- Stock clutch questions
- 1985 iroc z28 tranny identification
- New Moser axle... NEED ANSWERS!
- Where does the speedo gears go?
- Tranny installed, couple Q's
- How do you drain and refill the T56?
- B&M Deep Transmission pan?
- 4.10s vs 3.73s M6(pros and cons)
- 28 or 31 spline for 8.8 conversion.
- how many quarts in a 12 bolt
- Have questions about stock flywheel.
- Yup. You guessed it. ANOTHER Rear end noise.
- What about 4:56 gears
- Drive Shaft doesnt want to come off!
- T56 noise (pics inside)
- Wrong Fluid in my TH400
- need a new 4l60e
- Whats the best/cheapest trans. cooler?
- Limits of LPE driveshaft
- Cheapest Place for Axels?
- 4:10 Gears is it worth it ??
- clutch "clunk"
- built 4l60e or th400
- How long will it last????
- Should I flush my 98 T56? Advice plz
- best trans for drag car?
- Popping Sound
- Limited slip not working?
- Mcleod rebuild
- Slipping in Automatic question
- funny noise in clutch/tranny when downshiftin-help!!
- Posi install gone bad!
- Clutch reservoir line all full of holes... how to replace?
- Need help bleeding hydralic clutch
- strange feeling clutch pedal, what can cause this
- Do i need to tune pcm for new converter?
- Weird vibration
- heres some help for people doing a t56 swap
- cheapest place to buy SPEC stage 4?
- Need price on stock flywheel(asap)
- aluminum flywheel balancing question????
- clutch link
- Rear end noise
- Programming for my Art Carr 4L60E
- HELP...Need part #
- People with 2.73's..what RPM @ 60mph in D
- TH350 shifting issues
- Powertrax lock-right?
- Got my car back from shop after spec clutch (stage 3) got a few ques...is this normal
- Need to beef up my rear end without getting new one
- My tranny has about 65K on it, should change the fluid? And what should I use?
- Problems After installing Mcleod Clutch
- where to mount aux. tranny cooler
- which shift kit?
- SS wheels not going on correctly
- transmission sensors ??? where to go
- bellhousing????????
- Unplugging lock up(Can't find harness)
- LS1 drive shaft?
- Transmission removal troubles
- transmission fluid
- Driveshafts
- Sounds like my Clutch needs WD40?
- whats the best tranny route??
- rear end hp
- rear differential exploded during a dealer test drive
- Ok gearheads some info please
- Stock Clutch hold 350rwhp?
- Differential rebuild question
- Clutch fluid
- what to do next
- reliability of the 4l60e
- Axle hub
- Detailed instructions on converting a LT1 T-56 to a SFI bellhousing
- Wheel stud removal
- 4L60E or TH400
- 94z tranny questions
- B&M Hammer Installaion Question
- Would this converter allow me room to grow?
- Dual friction?
- help me find out my rearend question
- Ram clutch
- Width of Stange 12 bolt?
- grinding noise? Tranny or Clutch?
- Manually shifting the 4L60E?
- Any real world difference at the track Th400 vs. Th350
- Performance 4L60E rebuild kits
- Rear Diff interchange
- transmission question?
- Clutch
- Axle snapped, cant get peice out...
- Clutch vibration/grind
- Last bolt on transmission
- Messed up E-brake during shifter install...
- my TA wont go into FOURTH! any tips?
- T/A rearend cover question
- flywheel HELP!!!
- Clutch vibration/grinding
- spec stage II
- proper shifting with a 4.10...
- flywheel ridge
- Don't flame me but need clutch advice
- ...Rapid acceleration......
- 4L60e aftermarket rebuild kits
- Need Help PLEASE!! Wheels don't fit
- new clutch
- new clutch
- Speedo off of Abs sensor
- Funny noise
- Rearend Fried! Need help Plz!
- Mcleod Question for Stock LT1
- 6 Speed problems with shifting
- Trans problem 2: Knocking noise now gone??!?
- What to do with flywheel???
- Poly Transmission Mount
- Need Help Asap
- whoa, almost messed up... diff questions inside..
- rskrause, anyone, please check this prob out
- t56
- How do I adjust my clutch?
- How often do I change tranny( T-56) and Diff fuilds?
- who makes the stongest 10 bolt ring and pinion?
- This is my third time posting and i NEED this before tommorrow!!
- springs in diff? Please Help ASAP!
- spec stage 4 HOLDING POWER
- M6 swap help
- T 56 Fluid Change
- T 56 Fluid Change
- Converter stall or transmission slip?
- Transmission lines
- Will the 4L60E fit underneath car?
- McLeod Single Disk Problems
- will LCA relo's lower the rear any?
- how to get the motor on the M6 when putting it back in through the top?????
- 4l60/700r4
- Pilot Bearing or Bushing?
- T56 build up for lots of hp
- Rebuilt 4L60-E break in period
