View Full Version : Drivetrain
- Question about Pro 5.0
- ST3500 torque converter for my lt1?
- How many automatics running 3.73's/4.10's
- 700R4 in place of 4L60E
- Need help with Tranny in 98 C5
- 95 Z-28 Rear End?'s
- Motive or Strange??
- What kind of gears should i go with??
- McLeod thickness ???
- Centerforce dual friction
- McLeod Single disc vs. Spec 3
- LT1 4l60e same as V6 4l60e????
- SLP Shifter
- lenco behind a ls-1
- 3rd to 4th grinding
- Which size rear end?
- 1993 LT1 T56 Swap
- damn pinion seal
- gear whine in reverse and when turning hard
- Servo Cover Snap Ring Help!!!!!
- Cost of T-56 Swap?
- McLeod big trouble, please help ...
- How to remove clutch line
- old diff fluid/ problems?
- Emergency
- rear diff cover and stud kit worth it?
- The pin in the slave cylinder
- What rear gear oil do you use?
- Draining Transmission fluid to take out slave cylinder?
- how easy to install a pro 5.0 shifter
- Torque converter diffrent from 1998-2002?
- BIG TIME tranny problems...
- installing Torque converter
- Double Checking my pinion angle..
- installing a rearend on my fbody ?
- Gear install.......spedo change?
- What do I need to say it goes on to find a rear end cover gasket for my strange 12?
- Source for 90-92 axles?
- 4l60e Shifting Very Hard 1-2
- newbie with a shifter question
- not shifting
- new to T56 - please explain "skipshift"
- Are automatics really slower?
- Help me pick a stall speed
- [b] What Shifter Should I Use [/b]
- brazed or welded,west coast converter
- Difference between the new Spohn TQ Arm and the old one.
- What Shifter Do You Recommend?
- Clutch install questions
- Spohn Troque Arm..best suspension mod.
- will axles from a 78 monte carlo work in an F-body?
- HELP! Driveshaft will not come out of tranny!
- In my '95 Z, I hit a curb. Both tires were damaged. I've put on 4 different rim/tires
- Tranny Blew need some part #'s
- th350 into 93 camaro what must be done
- Tranny or engine question :P
- Which stall converter?
- 10-bolt spool & mini-spool question (basic rearend knowledge)
- Swapping out T56 for Auto?????
- help here please... when clutch fork is engaged
- Question about gear change
- 3800 stall ok????
- mid west torque converters: Customer service blows
- Question about stall converter.
- Replacing rear shocks
- First gear Shudder
- Torque converter & shift kit
- 3.73 gear,carrier ID
- T56 overhaul kit: is there such a thing?
- Installed 2800 Stall Converter. Questions inside.
- Do I need a new slave cylinder?
- New LS1 owner, a few Q's
- Cant figure out which is better.....Torque converter guru's in here please
- Gear replacement?
- Transmission Brace spacers for poly mount..
- Does This MPH/Gear Combo Sound Right?
- Rear Disc Brake Conversion
- Power Brake Conversion for 80 F Body?
- v6 t5 the same as v8 t5?
- MOser 9" guys, what are you using for a torque arm?
- Moser 9" question? Quick...
- Dropping trans. to put in new slave cylinder?
- T56 conversion
- will a GM TECH II scan tool correct gear changes?
- has anyone heard of luk clutches?
- LT1 transmission options
- Tranny or Diff, neither or both?
- question about breaking in my new moser
- clutch question
- Crossmember Part #
- 12 Bolt owners IN HERE
- truck rear end?
- Hypertech Shift Settings
- what else do i need to replace when getting a new gear?
- ABS reluctor ring on carrier
- Shifter Knob
- Tranny clunking
- Spohn TA and Moser Owners
- rear end gear questions
- Trans Swap Help
- best flexplate
- Best Flywheel ??
- Traction Control
- V6 and Z28 Rearend difference
- Best 3.73 Rear End Gear?
- t5?
- guages interest in 3.73s
- ES poly trans mount Q...
- Street Twin or Spec 4
- How much hp & tq can SPEC stage II handle?
- rear end for sale???
- Need a quick rundown on how to replace rear main seal please...
- My a4 shifter is F-ed up, PLEASE help...
- best rear gear fluid?
- TA Stud and Girdle Kit/Gears
- how many here uses the Main Cap Stud Kit, for the heavy duty rear end cover
- When running a non lock up converter....
- B&M torque converters any good?
- clutchs and flywheels
- Tranny noise normal?
- Throwout Bearing Question
- My search for a "Bulletproof" Drivetrain has left me with this...
- best shifter PLEASE!!!!!!!!!!!
- got nitto 555r's and tons of traction should i go to 4.10s
- gears
- Vibration in Tranny when pushing in the clutch
- Drivetrain
- T56 is starting to whine
- gears & emissions?
- 4L60e to th400 swap. 3 last minute questions.
- which stock carrier is stronger for 373 gears the 2 series carrier or the 3 series?
- A4 not shifting right
- question about 3.73 and locker set-up
- How to get the T56 to mate to the bellhousing?
- Where to look up Trans(T56) Description Tag Codes???
- speedo recalibrate
- Is this rear end strong enough?
- Pro 5.0 Shifter
- t5 question
- Pinion Angle?
- Shudder on 1-2 shift ABS Inop light on now
- Is it the clutch or the ignition?
- Best place to get a 4l60e built
- Help on a Z06 Clutch please
- manual transmission whine?
- recommended location for tranny cooler on a LS1 camaro
- 10" corvette wheels
- A4 cause of overheating?
- Drivetrain Trouble?
- spec stage III
- Sticker on the t56
- Manual Valave Body in an Auto Tranny
- 4L60E Strength?
- 2.73 to 3.73 swap
- Rear Bearings? Help?
- M6 Feels Notchy?
- Clutch
- Help!! Car won't shift to 2nd at WOT
- slp shift improver
- Probably a shoebox question or anyone knowing about tranny's
- Question about non-lockup converter?
- Solid Pinion spacer question ??
- i keep seeing more and more "auburn" rear...
- Breaking in 4L60E
- Vacuum modulated 4L60E question
- Need part #'s
- th400 Question
- New Stall and 3.73 (Questions)
- engine braking ok in an m6?
- best place to buy sreet twin
- 3rd to 2nd
- LS1 4L60E Shift Firmness?
- opinions on clutch..
- T56 needs rebuild, some questions..
- vig 3200???
- Master cylinder U-Bolt
- hitting rev limiter on an A4
- Setting Backlash
- Popping in low gear...
- G-force T56 installed
- 4L60E Tranny Temp. ques.
- Gears too thick to install? Cant put pin in?
- this may be a dumb question...
- Pinion Angle...Question....
- Right Rear Axle
- Oh wonderful gears......
- Clutch advise
- Possible to shim a flywheel???
- 700R4 help needed....
- strange engineering gears good to go with?
- Trans temp gauge
- 3000 stall or more?
- 4th Gear Not Sticking....
- clutch explanation for newbie
- shifting trouble
- Broken SPEC Stage 3 carbon...
- Need help ASAP, only getting reverse!!
- Rear Drum brake to Disc Brake conversion
- Important question regarding tranny swap in a '96 SS M6
- who sells motive 373 gears for the 2 series carrier?
- which is best to go with? Pilot bushing.
- Air in Clutch line...
- Question about a new stall install
- Tranny Mount
- bellhousing
- Beefed up 10 bolt?
- Reasonable Gear/Posi intall price??
- Does anyone have specific details of SLP clutch install
- would a 3 series 373 gear work on a 2 series case
- are richmond gears good to go with? how many here use richmond gears?
- Humming/howling sound coming from rear of the car!
- rebuild kit for T56?
- Vigilante Lock-up Problems
- Something ya might think about....
- 2400 High Stall?
- Need Help Figuring Out Which Gears I Have
- Hurst Shifter Problem...
- Are all 10 bolt gears (3: carrier) interchangeable?
- can you help me figure out what gears i have?
- custom t56?
- tranny took a **** on me
- New Mcleod clutch problems
- what gears to use
- Need some advice on Clutch/Tranny
- Do I Need A Tranny Cooler
- need tranny
- B&M Shifter Plus
- LS1 Tranny Mount Better for the LT1?
- tranny-mounted torque arm-Anyone Broke the mount?
- 10 bolt vs. 12 bolt vs. 14 bolt
- Should I get a shift kit to go along with my Torque Converter?
- Trouble staying in reverse.
- 4L60 help needed badly!
- hard clutch pedal/notchy gears.
- 3.73 how much 1/4 gains???
- tci street fighter 2800
- ZO6 clutch/slave/throwout bearing
- tranny swap?
- I need some tech advise on a clutch.
- What type of fluid in a T56?
- Clutch install problems
- Which Flywheel to get? And how many teeth does the LT1 Flywheel have?
- strange 3.73's
- Clutch Master Cylinder ?
- Need part number for the posi clutches
- Tranny Problems
- How to get to the trans line to plug it back in?
- whats a good Torque Converter for me?
