View Full Version : Drivetrain
- M6 shifting question
- LS1 VS. LT1 rear....
- First impressions of Spec stage 4
- Building a 4L60E for N20
- anybody here using a JW converter?
- Balanced crank, flywheel, clutch and PP?
- Torque Converter Installation Guide needed
- Rear tranny seal...
- shifting without the clutch
- T56 Conversion Question
- sof locker, or posi
- LS1 12 bolt in an LT1 car
- lt1s have a restrictor in the clutch line?
- help me pick the right stall speed
- 4L60E vs WC-T5
- 9 Bolt Help
- Rear end bearings
- What m.p.h with 4.10 m6
- rearend: what breaks
- 3.72727272 is actually 3.73 right?
- Need Advice HURRY!!
- 14 bolt on a camaro possible?
- Shifter mountign question
- question about lose pinion bearing
- Where to find clutch bolts?
- Some Clutch problems
- Spec LS1 Throwout Bearing/ Good or Bad????
- is this clutch shudder
- Paddle Shifters with T-56?
- Clutch Slave/Master Cylinder replacement
- Tranny hanging/studdering at 2-3 shift at WOT
- Pilot BEARING vs pilot BUSHING
- Fluid amount for 4l60e?
- trans coller install ideas
- ASR switch to turn ASR on instead of off
- i need a p/n for T56 crossmember for LT1 car
- After burnout 4l60e trans won't shift
- New clutch, car will not go into reverse!
- need a good clutch
- Sticky Clutch Pedal
- I need to firm up the WOT shifts in my car :(
- Different U-bolts???
- 4L60E hanging/studdering at WOT 2-3 upshift
- whats the weight difference between a ford 9-inch and a 12-bolt conversion axle?
- How to remove pilot bearing?
- Bleeding T56
- 1999 SS gear choices
- Do you or don't you have to do this?
- Code number question
- Will Strange engineering narrow their 12-bolt if you were to ask?
- play in the rear (please help me)
- how hard is it to change a a/t trans to stick
- After install questions...noises...?
- NEED HELP QUICK! Which way does Spec stage 4 disc go?
- Play in the pinion shaft with GM motive gears
- cluth fork
- 9" questions..
- M6 Difficult Shifts
- Name that noise! quickly please?
- Pilot [b]BUSHING[/b]
- 9" and gear whine
- Put new clutch in... still not working..
- What is the best wrench to use on bellhousing bolts?
- Tci
- T56 won't go into gear at 6k rpm?
- T56 Pressure Plate Torque Spec
- LT1 T56 in LS1
- How much does it cost to balance a driveshaft?
- Anyone else have this problem with their 12 bolt?
- Who makes bolt-in 9in rearends?
- How much gear oil do I need?
- Need Help Removing T56
- A4 in a C3 vette
- Dimensions of the LT4 'square' throw out bearing
- Tranny Crossmember help
- what is wrong with my tranny?
- spec stage 2 slipping...
- How hard is it to change your automatic shifter
- SPEC Stage 3 clutch
- Got a new noise from the T56...
- i have a different auto then everyone...
- 95 Grinding Noises
- Going to run a 28" tall tire...move the rearend back some?
- trans mount location
- Strange noise, sounds like something rubbing and hitting the bottom of the car.
- Gear change!! Is it easy to do yourself??
- Stock driveshaft spline Count?
- 4L60E kickdown problem
- rear
- Whats ALL needed for 6 SPEED swap from auto ???
- 3.73 gears and a 2800 converter ??'s
- a4 to m6
- New Differential...Car's in shop as we speak
- Cutting tranny cooler lines???
- A few quick Street Twin questions please...
- th350
- I need help! Ordered wrong gears....
- manually shifting 700R4
- Clutch problems...
- people with Moser 12 bolt + TH400 transmission. Quastion about driveshaft part needed
- level 10 kit
- clutch questions
- gear choice
- A4 slipping on 1-2 shift: Rebuild Ideas
- Clutch fork have to come out before tranny removal?
- Preparing for winter
- highway suddering/vibration
- Spec Stage 4 is in...
- Lt1 Spec Stage 5
- lt1/ls1 12bolt interchagability
- Tranny Problems in my 96
- turbo400 guys inside
- After Spec 4 install, clutch fork grinding on pressure plate
- T56 grinding while clutch is pressed in!!!!?????
- vibration, is it pinion angle?
- 3.73 gears, some info
- My slave cylinder fell off
- Checking rear diff fluid
- Transmission fluid leak
- Average cost of labor in clutch replacement?
- Bought a used Moser 12 bolt...call Moser for some guidance..pound salt basically?
- Who makes a bolt in cromemoly DS?
- Moser 12 bolt with long wheel studs?
- Blown seal in tranny?
- 4L60E Flares up going into 3rd gear
- vig stall converter and pump mod??
- 9 inch owners with stock driveshaft PLEASE HELP!
- Quick Flywheel question please. Aluminium or steel...
- Vibration???
- Synchro questions
- Dowell pins...
- how many more tenths will tci ssf 3800 shave off over a tci ssf 3500? is 3800 a good.
- A4 Oil and filter change how to ?
- Major m6 transmission trouble
- TCI's new flew plate for LT1
- Old rear out...questions about Moser...
- how much further can I go with the stock rear end?
- turbo 400 in 2001 ss
- caliper/rotor alignment (moser 9")
- Few clutch questions - Mcleod single disc
- Is something like this possible? (700R4 question)
- Need proper trans-coolersize
- Transmision Dianosis please
- 4l60E POS or bad mechanic
- Very strange transmission problem
- Place to Buy High Horse tranny??
- please help me with this converter question i appreciate it
- Whats the deal with my 700r4??
- Stock stall and I hit the rev limiter after heads/cam/header install
- Transmission Problems...
- clunk.... help please
- 3500 stall on 94 lt1
- 28" tall tires? Anyone have issues with them fitting?
- Another happy Spec Stage 4 customer!
- 4.10s To Much For a Blown Auto?
- What are the difference in these shifters???
- tranny not shifting at WOT?
- Detroit Locker? Pros and Cons
- Is this converter (SLP) ok?
- 500fwhp LT1 what clutch?
- tranny acting funny
- parking brake lever release
- Idea for ls1.com on converters for lt1s.
- Odd M6 tranny noises.
- high speed vibration, feels like trans, think its leaking also
- car shakes after SPOHN crossmember install(T56 related)
- Transmission noises..need help
- What year rear ends are identical?
- is the tci ssf 3500 stall that tci sells the same as the ssf 3500 that texas speed.
- what is kevin at tci's email?
- Problem Getting Into Reverse
- Inspection cover
- Spec 3 Install Question
- powerglide
- What Rpm Stall To Get ?
- moser forgets shims.
- McCleod Street Twin in a stock LT1 car?
- T56 Conversion questions
- im having problems w my 6 spd, please help!
- whos running a SLP billet flywheel LT1 style
- Rear end gear question??
- rear end
- Steering box replacement?
- Dont know what it is need help
- Do I need 4.10 gears?
- NEED HELP ASAP on 4l60e
- Anyone have experience with cheaper D/S loops
- Mcleod Street Twin
- Please explain difference on a multi-disc to single disc lockup converter!!
- 02 gears
- How much should a rebuild cost?
- Could a bad axle seal cause noise in rear??
- tranny toast ? 4l60e tranny
- Couple questions about a BBC and a T56...
- Gear Change In A 3rd Gen?
- aftermarket controller for 4L60E
- TCI Streetfighter Trans
- Wierd Noise
- Rear Gear and Stall Guys Inside Please!
- What converter do you guys recommend??
- How to keep car (A4) in 3rd on the dyno???
- Carburated swap?
- T-56 Shifter bolts
- 4l60e And Cryo Smart Techs Please Read
- which clutch for hi power daily driver?
- quick question need help asap
- Need help with rear end ?'s
- B&M Hammer shifter
- Combination Motorsports 4L60e tranny is slipping BAD!!!
- Setting up rearends.
- Replacing with an Eaton, please advise
- Help me with my A4 to T56 swap..need parts.
- Help
- Nasty rattle with new Spec III install.
- gear selector help please
- vibration above 3500 rpms??
- what speed stall should I get?
- KABOOM (went my rear)
- 3:73 out of S10
- Tranny Dipstick Tube sealing problems
- Transmission maintainance
- "Proper" way to drive...
- Shifter Knob
- 4.33 or 4.56?
- Gear Vendors overdrive ?
- transgo manual kit
- tranny problem need help ASAP!!!!
- Spec 3, 4, or 5?
- Transmission Crossmember: Auto's and manuals use same one?
- How does your Spec clutch drive?
- Ordered Moser.Now what do i need..(install)
- ASAP does the trans need to be unbolted to put clutch fork on?
- Question about new lsd
- T56 vs 4L60E dyno results
- 94 T/a A4 -help- No Place For First Gear!
- currie 9" with tru-trac problems????
- New gear issue, lil' input plz
- Question about Short Shifters
- Why did it do this
- 93 Tranny gearing
- Tranny is bad/What about the converter?
- Are 4.10's too much for my setup?
- Rear End Weeping...
- 2.73s to 3.73s
- New Tranny....Break in?
- How hard is your clutch pedal?
- Need Clutch Advice
- Pops out of reverse....
- Question about Tranny swap to th350
