View Full Version : Drivetrain
- T56 speedo question.
- Please help with the programming for my TC!!
- how to lock trans in third on dyno??
- A4 guys ? on gears and MPH
- Cheapest 10 bolt alternative
- Should I put in 3.73's?
- Need How-to for T56 front (input shaft) seal replacement
- Help? tranny a4 questions?
- Cant figure convertor out?
- Need to upgrade Clutch on LS1
- I have an A4 and Feels Like M6!
- T56 rebuild - help me make a parts list.
- Zexel torsion Posi
- 6-speed throwing out of 1st
- few rear end questions
- wont shift
- found a 12 bolt for $150! have questions...
- 4l60e Lost 3rd and 4th fine
- front yoke
- Need some flywheel help
- Not too happy with spec right now...
- whats the quickest time someone has run with a 10 bolt with a M6??
- Name that Noise!! HELP!
- Converter replace with XMSN!
- Tranmission clunks & noises
- Trans Temp Gauge Install??
- torque converter installation
- Doesnt always go into overdrive
- Backing Plates??
- Torque arm bolt.....tranny side....
- weird thumping feeling from shifting (auto)
- M6 to 4l60e Swap???!!!
- HELP pilot bearing
- Weird noise after M6 swap
- Ghetto tranny removal
- Installing gears, which ones?
- Tranny and rear end questions
- slight clunk/clunk under console and floorboard
- What brand of gears.......
- flywheel
- Replacing 2.73 with 3.42
- Will not get into gear
- [B]Clutch Question??[/B]
- Grinding Noise From Rear End..Help
- What is the noise?
- Looking for a good tire......
- how do you know it's time to rebuild tranny?
- Street twin issues
- Dumb question about belts?
- another six-speed question
- Stock LT-1 Car Pulls Through the Brakes
- dumb six-speed question...
- Making 4L60E manual
- isolator valve, sleeve, regulator valve for 4l60e?
- BIZARRE clutch problem T56
- 4L60-E shifting problem
- Tranny leak.
- T56 grinding problem
- Help me choose a posi-unit & gears
- 4:10 install question...
- Just installed my 4L60e need help
- performance mode
- install of vig tricks?
- what does this mean?
- Very bad transmission noises
- Code 83 Automatic Transmission 95 Z
- 4l60/4l60e
- best transmission
- Tranny cooling lines
- spacer?
- Three Series Gears on Two Series Carrier
- Torque Converter I.D. Tag?
- need help! major clutch problem (long)
- Question about Speedo Gear
- questions for 12SCNDZ
- Questions about cluthces????
- Groaning/squealing noise
- Does anyone know the size or PN of M6 to bellhousing bolts?
- Converter Problems?
- Buying a used clutch???
- Converter?
- Clutch explosion(and no its not a dessert.)
- Triple Cone Synchros
- Rear end carrier?
- Clutch Vibration
- clutch and flywheel questios and suggestions
- Stoked
- tranny swap questions
- Rear End Rebuild
- transy changing hard
- any help
- What 4spd was used in 82
- Where can I order a tranny mount?
- can backlash in rear diff cause vibration?
- 94 Formula problem!!!
- Those with M6 / Moser 9in combo
- Drive Shaft Swap
- Need some suggestions with my transmission rebuild...
- diferences between tranny's
- clutch ???????
- do I need a 12 bolt
- Aluminum drivedhafts--which one's are good?
- TCI Part Number Help
- Anybody ever brake their tranny mount while installing?
- Hey, Its FRMULA1... got a couple questions about my tranny drop and stall
- Spoke with tranny guy today, please reply
- Rebuild or buy new?
- 4l60e shifting problem also speedometer problem
- TCI 3000 didn't come with bolts
- Need help!! 4L60E starting in 2nd gear
- what rearend fluid do I need?
- 3rd gear problems
- is this th right kit? GM#8673948
- Driveshaft too long? Help! Injuneer??
- Anyone here install a brand new slave?
- Posi Spline?
- Smokin Clutch
- is this my vigi ?
- WOT 2-3 shift problems
- Transmission shifting problem at WOT
- Why do people say the Street Twin is expensive?
- Clutch problem, anybody else have this one???
- Rear end Q.
- Transmission cooler
- Clutch in LS1 F-bodies the same as vettes?
- 3 channel to 4 channel
- 4L60E broken :( Code 84 - what to do?
- Posi
- T56 gear issues
- Opinions on Gears and Drag Radials
- 4L60E temperature range and 3rd/4th problem
- Rate my new tranny... 4speed auto
- rear end gears???????
- 96 rear end in 91
- Tranny from 99 S-10 ???/
- Fresh 4L60E rebuild, throwing new code.
- M6 pedals question. T56 conversion people inside please.
- LT1 vs. LS1 T-56's...
- A4 to t56
- Clutch wont fully disingauge.. changed master and slave.. little better..
- where to buy steal braided clutch line
- will this fit a 93 camaroz28
- New Carrier/ Posi Need Help!!!
- flywheel ?
- question? transgo shift kit
- Amazing Find Behind Clutch Slave Cylinder?
- Aftermarket Auto Shifers....
- 700r4-RPM's shoot sky high after 90mph...
- Converters
- any one here use these guys converters
- Rear End Questions
- which gears???
- Gear Help
- What do you guys think about this transmission?
- time for breaks
- Gear opinions please!
- Does anyone here use a billet power servo?
- need some help with a t56 not going into any gear???
- searched, but still need some help
- Speedometer Problem.
- 3000 or 3600 stall?? for you a4 guys
- MacLeod Twin Disk is slipping (4+ years)
- '98 Z28 M6 shifting......
- trying to make a 4L60E last with around 500 rwhp, got a a couple questions
- 95 Z28 Camaro 4L60E
- Spec 3 Problems--Need some advice!
- 2.73 to 3.42 swap! Now speedo is off, cruise wont work!
- What is involved with putting a LS1 T56 into a LT1 car?
- which clutch
- TA rear end girdle install question??
- Hitting stock rev limiter sometimes with my 2800 vigilante now!!
- transgo, b&m, or TCI?
- V6 Rear
- Need tranny advice...lost 3rd and 4th gear.
- Flexplate
- 4l60e Q
- 1997 T56 in a 1993 Z28
- Why is my transmission temperature high with my trans cooler?
- Torque Converter Install
- Differential Grease
- Ring and Pinion Help
- 12 bolt/10 bolt 69 camaro...
- rattling from tranny.
- Match balancing flywheels?
- stall converter
- 5 speed Spec stage 1
- TH350 Problems continue...plz help
- What gears does my car have?
- Driveshafts...
- Strange banging noise????
- Broke something. Details inside.. Help!
- Best clutch + Pres. Plate???
- What gear should I chose?
- Th-350
- shifter question
- How to diagnose a weak 700r4???
- 10 sec car driveshaft
- Strange rear end sound
- Can I swap the tailshaft on my 4L60E?
- 1993 6speed swap
- Aluminum driveshaft question
- Will this damage my tranny?????
- tranny slipping!??!
- M6 to Auto Swap
- Clutch or Tranny ?
- Can you power shift a hydraulic clutch
- clutch kit and flywheel for my new 383
- Should I resurface my flywheel in this case?
- Converter Bolt
- New Clutch Suggestions
- Spec Stage II people... share your experience
- gears an rears - opinions
- First time with an LT1/ 6 speed
- Blew out the trans pump... 3rd time!
- Bought a tranny mount from AutoZone... got questions...
- double checking on pinion angle (measures inside)
- Thank you 1Bad86Z
- Odd tranny problem A4
- 4L60E Replacing the Pump???
- Rear End Trouble
- Torque and Differential HELP!!!
- Quik question please help me
- Shimming a resurfaced flywheel
- 700r4 vs. 4l60e
- Torque converter (4l60/4l60E)
- Gauge Cluster, or VSS???
- Trans Help. What Next?
- tranny
- T56 probs...need some help!!
- ANY way to determine gear ratio ? by looking at gears ?
- Clutch
- 4l60 vs. 4l60e
- Skip Shift
- ckperformance 2004r transmission manual
- T56 won't disengage from engine.
- How much power can a stock m6 bolt handle??
- ? on torque converter
- 1993 T-56 swap
- Having trouble getting stock TQ arm to fit on Moser 9 inch
- No 3rd Gear
- Rear End Swap (LS1 to V6)
- Need rearend help...
- Thinking of going 3.42 to 3.73
- Spec probs?
- downshift?
- 4000 or 4400 stall?????
- t56 rebuild help w/ some options. allready found the problems
- Open diff or LSD?
