View Full Version : Drivetrain
- Stock Driveshaft...
- T56 Limits
- question for A4 guys
- Syncro Replacement?
- Stock LS1 T56 what kind of fluid?
- 3.42 rearend Vs. 2.37 rearend???
- Trans is grinding...
- 2nd clutch blown up in a year???
- Question about Clutch.
- Poly Trans Mount - CrossMember Modification!? Help
- T-56 swap
- Strange 12 bolts back ordered???
- Th200-4r ????
- hyd clutch system 3rd gen
- What gears/stall do I need with my stroker/nitrous beast???
- vigilante torque converter
- M6-3.73,4.10-10 Bolt guys
- opinions for stall
- best place to buy a 12 bolt
- gear oil on torque arm/floor boards
- Bent torque arm
- Need advice on what clutch to get for my set-up
- 4L60E upshift problems on 3rd rebuild
- spec stage 4 hybrid...anybody have any comments
- 3.4L 5 speed trans on a 3.8L v6 engine
- Transmission question
- 2002 Z-28 Rear End Gear Ratio "Opinion" 2:73 -vs- 3:42
- Any vig 2800 owners notice idle is kinda lopey now?
- how to rebuild a T56
- Tilton dual disk, Steel Twin, McLeod?
- bigger gear, more horses
- How to....
- 3.73 or 4.10??
- t56 swap wiring .. car wont crank .. heres pics.
- whati is the difference between "lt1 and LS1" Tranny
- low rpm putt
- white smoke
- t56..
- Dextron III Fluid Differences
- 1st to 2nd is "jerky"
- Moser 9" Help!!!(Need Help Bad If Your Familiar)
- t56 sap done- WOnt start. Turn key- click....
- Best clutch for lt1??
- Prothane transmission mount parts number from Summit???
- Rear end chunk questions.
- 4:11? 6 Speed
- Grinds going into first??
- 4L60E DIY Rebuild
- What did I do? Differential gear chipped.
- transmission jack adapter ?
- Need grade8 bolts for rearend cover?
- can i use a stock master cyl on a twin disc?
- How to tell if my converter is bad
- low frequency hum vibration noise at start & stop
- clutch slipping,rear main oil seal
- What u-joint to use with stock DS and 9" 1330?
- converter not locking when hot
- Where can I get flywheel shims?
- Help Me!!!
- t56 swap - wiring reverse lights?? type on alex's guide?
- 3.73 Part Numbers
- banging trans: don't know were to look
- Weird vibrations
- 2 series or a 3 series how to tell????
- What is causing this driveshaft noise?????????
- Problems with transmission
- building a 12 bolt...how to fab up abs?
- balancing a internally ballanced street twin for use on a stock shortblock
- Rear Diff
- .500 boost valve 700r/4l60?????
- 4.30 or 4.10 for an M6 car with 17x40x275?
- shat! I need IMMEDIATE help - T56 LT1
- Eaton Locker or Eaton Limited Slip?
- Shiftkit Questions
- About to do the reverse syncro flip.
- Yet another torque converter question (about 1,3, or 5 disk setups)
- options for rear-end
- Serious question about BMR TQ arm and Moser 12-bolt (cutting involved)
- Anyone who has done th400 swap
- torque converter?
- B&M Governor Recalibration Kit on 93 tranny
- 2nd Gear doesn't like me.......
- NEED QUICK ANSWER on tranny mounts
- figure this tranny problem out. please.
- 2.73 -> 3.73 on auto, better mileage?
- transmission cooler installation
- Clutch question
- Vibration through the shifter and clutch?
- 3 4 shift solenoid.....which one is it?
- question about a posi!!
- no reverse
- gears whine??
- Hints on rearend rebuild??
- Rattle from Transmission T56
- Which transmission fluid line is the "return" from the radiator, top or bottom?
- could -3* pinion angle cause vibration?
- A4 -> M6 conversion - which rear gears??
- breaking in the gears???
- Tranny problem all of a sudden?
- I don't understand my clutch....
- need pro advice on custom converter
- Where can I get new C-Clips?
- Motive the only one with 37/9 Gear Cut?
- rearend noise
- Well i got the tranny rebuilt....
- Clutch slave install, help ASAP!!
- Broke U-Joint Cap Connector on rear u-joint. Okay to run without?
- 3.23 to 4.10 gear swap auto results
- Wheel hop with 1LE tranny mount.
- Strange A4 Problem
- pilot bearing or bushing??
- Clutch inspection plate surgery: yes or no
- Specs for resurfaced flywheel?
- 2000 ss
- great shift handle and knob!
- how to recognize a shift kit
- strange vibration.... not the common things your thinking
- Can I reuse my aftermarket PP and put in a new clutch disk?
- Tranny is jumping
- Problems pulling the trany
- Need pinion angle for 94 -Fbody
- 4.10s w/o posi
- Tranny Temperature?
- Anyone have problems with Ratech Install kits?
- Want to do an A4 to M6 swap. Please help...
- Rebuild the 10 bolt or Get a 12 bolt?
- 4 speed trans and a LT1
- Short Throw Shifter
- PCMforless tune- now clunk going into 2nd
- Question about torque converter install.
- What tools do I need to rebuild my t56?
- Stock 95Z with slightly built 4l60e
- t56 rebuild ?'s
- 10 bolt crapped the bed
- tranny cooler install?
- getting ready to do t56 swap. resurface/balance flywheel?
- So my torque arm nuts were finger loose....
- Intermittent loss of 3rd and 4th.
- how to put a 95 trans in 94??
- Installes Gears, one question.
- Anyone put 3.73's on an M6??
- LT1/Ls1 rearend swap
- torque converter?
- Switching Auto to Manual?? Need Help!!
- fluid for t56... dexron III brand???
- Rear End choice...
- wont shift into overdrive help ASAP
- Clutch damper springs broke...
- 500 dollars for rear end?
- 93 clutch hydraulics
- Front Wheel Bearing/Hub Choice
- Clutch pedal stuck, reinstalling tranny...
- help!!
- Converter fluid ?
- problem with t56
- clutch being bad??????
- Would you be interested in a T-56 Trans cooler?
- For Sale - BMR Glide/TH350 Conversion Crossmember for 93-97
- diff fluid and additive
- What clutch should I install in my 98 M6?
- Torque specs
- t56 rev lockout connector
- ***need Help ! ! !***
- Clutch problems
- Gear install kit!!!
- Stud kit for Rear end covers
- ls1 a4 trans
- Gears
- Torque converters
- tranny problems
- is this a torque arm bracket in this pic ?
- How To: Installing a B&M ratchet shifter into your 97+ f-body
- General T-56 Question
- What clutch works on a T-56/
- Shift Kits
- rear end swap, 93 to a 95
- Anyone have a Carbon Fiber Driveshaft?
- Car won't downshift into 1st
- Converting Rear Drums to LT1 disks, what parts needed???
- 4l60e to th350 swap
- Richmond 4:10's..any good?
- 96 4l60e 2-3 shift at part throttle hangs for split second
- I need to rebuild my transmission. Parts needed?
- Clutch?
- 4l60e motor swap will trans work?
- Add oil to tranny?
- Dana 60 in a Fbody... Anybody do it???
- Can anyone identify these gears??
- 2.73 to 3.73???
- TA arm bracket
- New Heavy Duty T56 Retro-Fit 6-Speed
- Tranny cooler Question
- which gears
- 10 bolt strength
- limited slip rear end one wheel??
- 2nd gear and overdrive
- t56 harder to shift while car is moving??
- trouble codes and how to fix?
- Transmission cooler?
- Centerforce clutch and Fidanza Flywheel
- was a 3:08 rear available in the 4th generation?
- have a problem with my 4L60E?
- Looking for a few internal T56 parts
- spedometer pigtail on '95 T56
- 84 10 bolt to a 94
- Wierd trans shifting into 2nd gear.
- factory stall for a '93 ?
- Hesitant 2/3 shift
- harder to shift while car is moving
- T56 Swap
- what the hell is an exhaust mount doing here..
- a4 to m6 conversion... Who offers kits?
- Transmission bellhousing on 4L60E cracked!
- Will a '98-'02 axle shaft fit a '95?
- Tailshaft area squealing???
- CLutch Advice
- Moser 9" install instructions w/lt1 brakes?
- Figuring out spline and gear brand
- Converter opinions
- Spec Stage 3 or 4 clutch. Please help me decide.
- Turbo 400 question?
- what all do i need with new clutch install?
- What Posi unit comes in a 94 Z28?
- Can anyone explain this rear-end noise
- noise tranny at higer speeds....
- Wiondering about my trans purchase now
- Converter Lock Up at WOT???
- HELP with 12-bolt issues
- Vig Problems...Graph Inside!
- Torque Converter question?
- Converting auto box to 6 speed manual.
- stall converter
- Flywheel cover discontinued?
- clutch problems....cant get no straight answers
- aluminum driveshaft
- stumped, cant figure out the noise. T56 related
- Re-threading....
- Clutch is going out, what all do I need to buy?
- 2.73 to 3.42
- TH400 conversion..
- 4L60E Servo Swap
- T56 Swap - Bolt specs needed
- T56 to TH350 swap, flywheel question
- Can anyone explain this?
- How much do I torque do i use on LT1 pressure plate?
- Heavy Duty yoke
- Would a T56 from an LT1 car work with an LS1 engine?
- what gears
- Broken Posi??
