View Full Version : Drivetrain
- Moaning noise when turning. What should I do?
- TA performance rearend cover girdle worth it?
- best rearend when torque arm is not needed?
- best 4.10 or 4.11 gears?
- What 6 speed?
- Fidanza help
- PATC Need Feedback!
- Clicking noise while in reverse
- T56 Help!!!!!!!
- stock rear end strength
- Carolina Clutch
- V6 broke the T-5
- west coast custom tc's
- 4L60E: On last leg?
- Tranny Issues: See Inside
- Building up Stock Rear End
- Hesitation after breaking with an Auto
- Fidanza Aluminum flywheel
- what would cause the clutch pedal to just drop to the floor with no pressure?
- Help on possible gear selection A4
- Backlash and pinion depth
- P0742....Possible Transmission failure in the Future?
- clutch help
- is the 700r4 from a 88 camaro the same as the one from a 93 z28?
- Slave cylinder help needed...
- transmission and rearend
- partial tranny failure...possibly stall converter related
- Anybody found an easier way to get tranny fluid level correct?
- a few questions.
- Shift Kit
- High stall obd1 problem
- Yank Torque Converters
- tranny dipstick issues
- Need direction to buy a good 9"
- Better way to break in clutch?
- SLP Clutch and Flywheel - Comments Welcomed
- 12 bolt instal question
- 4.10 gears in a A4
- 1994 A4 Pause
- Jiffy Lube Trans Service
- question about shift kit and pcm tune
- Rear end
- Stock Cluctch and Flywheel Part Numbers
- Where can I find an explanation of trans. trouble codes
- Why can GN's 10 bolt rear hold up to 10s?
- deep trans pan???
- tranny mount bolts?????
- 4l60-v6,v8
- Tranny Mount
- Spec products
- Which clutch for a 600hp LT1?
- gear selection
- how to tell which t56 you got?
- what size stall?
- A4 Shifting Very Hard
- problem shifting/driving
- Clutch or Transmission Problems
- Anyone use LUK OEM clutches that are for sale on ebay?
- 87 Vs. 93 Octane
- Will my A4 survive a 1,500 mile trip?
- i was running 7/10 qt low trans fluid in my t56..bad?
- Funny noise
- LS1 T56...what do i need to convert to LT1 T56?
- How to get bellhousing back ON?
- Question about 4L60e accumulator
- 4l60e question
- 12bolt moser install,, ran into problems..
- questions about tranny
- 98-00 and 00-02 Clutch masters cylinders, any differnence?
- Ram clutch Powergrip HD ???!!!!????
- is 94 4L60e a direct swap into a 97 Z28?
- ls1 and lt1 auto swap parts interchangeable?
- U-Joints
- M28 Gear recommendation
- I Need Help Asap!!!!!!!! Thanks
- will LS1 T56 fit in LT1?
- I have a clutch question to ask.
- what went wrong during burnout???
- bad master? hydraulic problem? or is it the clutch?
- Help is it a blown hydraulic clutch line or what?
- A4 question
- 2001 Z28 Clutch Problem
- manually downshifting from 4rth to 3rd in auto
- Engine/transmission separation need help
- No TCC Lockup. Have replaced Solenoid and Converter.
- How much power
- Noisey t-56
- Clutch Overheated
- something makes a whine
- Car Rolls Forward In Park
- gears stick on new T56 swap
- Is my car a 3 speed????
- 6 speed manual in a 85' z28
- I want more mods, worried about blowing trans..
- ls1 t56
- McLeod Master Cylinder install tip.
- rear end gears
- hurst Billet plus install
- How many trans bolts
- How Many Bolts!
- what are the chances
- Deep sound and vibration??
- Shifting problems with 4L60E
- Wheel hop
- Part# for a 1LE Driveshaft?
- Fitting old rear-end into my Camaro
- trany wont shift out of first gear help
- how would u replace tranny fluid return line from radiator
- 200r4 Help!!
- Who has the best price on a z06 clutch?
- 4L60E shifting problems
- Tranny issues....
- think i broke.....
- Grinding sound with clutch pushed all the way in...
- Aluminum driveshaft to long?
- Locking up the converter
- best stall for LE2
- stock clutch on 383 with street tires.
- clutches (SPEC4 vs. RAM HD) LT1
- 6L80E tranny conversion
- Auto 00 TA shift question
- gears and results?
- Putting car in gear ?
- Problem with the clutch,, which replacement to get?
- Xtrem Performance Transmissions?
- 4L60E - 2-3 upshift problem
- Will a 4th gen rear fit a 3rd gen car?
- Powertrax No-Slip Traction System
- gear and tranny ?
- Is the torque arm necessary????
- why is my car not shifting right at WOT?
- KTRE rear end...what can they hold up to?
- Quick Gear Question
- How to tell if clutch is going..
- Grind in 5th (sometimes..)
- Rearend Question
- When Pinion Nuts Go Bad (Picture)
- No OD, D, or 2. Only Reverse. !!!???
- Driveability of a spool?
- Re-connecting shift linkage
- 3rd Gen Rear gear swap
- Fill/Start-up procedure with new A$ and converter
- Upgrading gears
- Looking for T-56 upgrade PARTS
- how much would it cost to get a stall installed
- $250.00 Off Strange 12 Bolt Rearends!
- T-56 transmission Horse power Question Please help??
- Mcleod Clutch/Factory Slave Cylinder
- what do you think
- Guys with 4.11's
- Does the ls1 t56 tranny have a removable inspection cover ?
- Hydraulic Flush
- drive shaft
- Question for the future, rear ends...
- Aluminum Driveshaft?
- Are third and fourth gen driveshafts identical length?
- another what gears question...
- i absolutely give up now :(
- GM dealership diffential service...
- ? for m6 cars with 4.11 gears
- question about A4 to M6 swap
- Adventures with u-joints/rear
- Please help me decide
- Tranny Question(s)
- built 4L60E question
- Question for anyone with an SLP DS loop
- trannsmission converstion question
- 1200 hp t56?
- Tranny won't shift to 3rd at WOT... not enough pressure?
- Bad vibration when accelerating
- What Parts to Swap for Shift Kit?
- 4L60E......cable snapped?
- Question about a set of Hoosier slicks
- A4 Shifter/Trans Problem
- Good price for used LS1 DS.
- cracked!
- rearend going out?
- tranny help
- McLeod Street Twin install question
- Steel driveshaft LS1??
- T56 troubles
- ES tranny mount!
- Spec 4 life?
- Car bogs after trans cooler install
- steel or aluminum flywheel?
- McCloud Master Cylinder Questions
- Breaking in Clutch
- Clutch replacement
- where do i find the code for what tranny i have and have slipping problem
- looking to put an IRS on my Camaro, input would be appreciated.
- Rear questions
- Torn between short shifters
- 700r4 installed..now 3rd - 4th does not work
- T56 difference between 1993 and 1994 up
- T56 Fluid Capacity?
- 4L60E transplant
- 4L60E bands slipping?
- Brake problem, I think... (Long)
- What are splines?
- did i mess up the install?
- sub frames
- 1997 Camaro RS, tranny question
- M6 Problem
- do i need to or not ?
- Knocking Noise
- Lt1,Ls1 transmissions
- New Clutch or rebuild?
- Whinning sound (transmission?)
- Newly Rebuilt 4L60E Slipping!!!!! Help!!!
- Which tranny mount for T56?
- HUGE T56 problem.Daily driver
- Transmission Problem! Mount or Tranny???
- 4.11s too much for a auto lt1?
- output shaft vs. driveshaft length
- tranny conversion
- Please Help... Clutch install problems
- How to find out what rearend gears you have, plus axle spline q
- Recommendations on a clutch you LOVE?
- Loud Boom in the back??
- streettwin rattling noise
- T-56 crunching a little
- centerforce vs. spec?
- Finding instant center on a torque arm rear suspension
- problems with t56 swap .. important
- Need flexplate - which one???
- Popping out of reverse
- help
- M6 Reverse lockout ?
- 96 trany questions
- Tranny problem, possible solenoid?
- Slp Limited Slip Differential???
- 6 Speed Swap/94Z
- Spec Question
- Pro 5.0 Install Guide
- Need a 98 up gear install page
- What clutch???
- Stall and Gears
- Mark Williams 3.5" driveshaft & Spohn TA not getting along.
- Torsen or Auburn?
- Need Part numbers for T-56 Parts- Please Help
- groning in the t56
- T-56 Tranny Problem !!!! Please Help
- Where to buy a new transmission
- 1LE Transmission mount parts number?
- T56 transmission rebuilder?
- stock T56, stock ds, and stock rear...
- How many miles to correctly break my gear?
- Auto problem
- Shifter linkage will not hook up
