View Full Version : Drivetrain
- Installed rebuilt trans, now will only shift when you left off gas?
- LS1 rear in LT1 car
- convert options ???
- 10 Bolt Rear Removal
- Question about my new TH-400
- anyone running 4.10s in their a4?
- SHIFT RPM FOR A 95 Z28 LT1 A4 - Stock
- 1995 Stall Converter Stock A4
- Whats the Stock Trans Cooler Look like?
- Obdi 4l60e??
- U joint/yoke questions
- need help with adjusting my ratchet shifter
- What to do with core 4l60e
- Need opinion on Spec Stage 1
- Loose converter
- High stall guys inside please!! (WS6ZXR post)
- McLeod Street Twin break-in Q's
- Stall Rpm For A Stock 95 4l60-e
- Saginaw 4 spd in 67 camaro 6 cylinder
- Tranny is gone Please!!!
- Question for those who have knowledge of 10 bolt internals
- Couple of tranny questions
- T5 identification
- Where can I get the plastic cover for the back of a six speed?
- Orange sensor for m6.
- Best clutch for LT1? Spec?
- how can i tell if i have an M28 or 29?
- trans go shift kit install ??'s
- ABS to work with newer rearend?
- 700r4 to Turbo 350/400 conversion
- HELP!..TRUE or Random BS
- Strange 12 bolt shipped weight.
- 97 camaro 4l60E, How many spline is inputshaft
- Tranny Is Gone!!!!please Help!!!
- 3 hooked to 4 channel ABS
- lakewood traction bars
- Stupid Question + Help With Vibration
- bleeding the clutch
- gearing question
- T56 #'s run
- Racing w/ the stock shifter..
- Valco Clutch and pressure plates? how good?
- How hard to replace clutch?
- Weight reduction in Alum. driveshaft?
- HELP ! Changing tranny mount in driveway?
- Which Trans Cooler To get?
- ? about puuting 94 tranny into a 95 car.
- 12-bolt
- Changing The Oil in My Rear Tomorrow...
- Good LT1 Clutch Disc?
- Need Help With 4l60e In 95 Z28, Help!!
- Need Help Fast!!! T56 Tail Housing
- Mad Dog 700R4 Punisher
- 4th gen drive shaft in a 3rd gen?????????
- shifters
- My 9inch Build up- pics and BLING!
- Raptors converters for 4l60e??
- Syncrhomesh in 96' t56?
- 5spd V6 crossmember..??
- Pilot Bearing Stuck, Any ideas?
- tranny service
- Flywheel install question (poll)
- will a 99 m6 flywheel fit in a 93 m6
- To get gears or not to get gears, that is the question
- Stock gearing for 2002 Z-28
- Can it fit
- Can it fit
- What's involved in changing stall converter?
- Q: regarding 4L60E-Rebuild, used or new?
- rear end noise
- 9" question
- how long will a ST last?
- LT1 slave cylinder assembly?
- Where to buy rebuild parts for T-56?
- LS7 clutch kit ordered.....
- Input shaft bearing replacement
- Help with my tranny
- Wont shift 2->3
- LS1 4L60E in an LT1?
- Shifting issues
- 4L60E Interchangability
- finished the th350 swap and wow
- Putting a Transmission cooler on my 4L60e
- Front Wheel hub Assembly
- Has anyone had any problems with their LPE driveshaft?
- How to change output shaft bushing?
- Gear noise from T56
- new clutch?
- clutch fork pivot bolt
- strange 12 bolt pinion nut size
- Problemo!!!
- TH350 Questions ???
- installation price range?
- Anything special when installing alum FW?
- McLeod release issues.
- STR - Tradeoffs
- just blew up my 10 bolt ! whats the best 12 bolt or 9inch ?
- T56 upgrades
- McLeod single: Will it hold?
- rear end gear break in?
- SLP short shifter
- clunking noise in rear
- 96 diff
- Upgrading 10-Bolt GU5
- What's need to do m6 to a4 swap?
- ls1 ds in a 12 bolt 95z
- 4L60E input drum air check issue
- Hard(er) to shift t56 after wot run.
- LPE driveshaft
- additional Transmission cooler placement, need opinion
- tq question
- Mobil 1 full synthetic ATF
- clutch plate
- Cost for 4.10's + install?
- Lock the converter on the dyno?
- T56 almost impossible to go into 6th gear
- Will It Fit
- Petition - GM To Stop Manual Transmissions
- u joint questions
- Transmission crossmember
- T-56 question
- 4L60E install
- Rearend question
- Spec 4 --to much for the streets???
- shift kit
- EXTEREMELY BAD shifting problem
- My Clutch Is Not Fully Disengageing
- Bad throw out bearing?
- P0740 Torque Converter Clutch Circuit Malfunction
- 1995 Z28 Transmission fluid leak
- torque converter ID
- missing 3rd and fourth
- tq install
- what do you prefer?
- Converter installed!
- ready to burn car after clutch install
- Spec 4 problems.... :(
- Bad Throwout Bearing?
- HELP!!! Drivetrain Vibration
- TH-400 5 pinion planetary gears?
- Stock Converter
- Low gearing better mpg?
- stock gears
- Quick question
- Loud metallic screech sound, new rear end swap today
- crossmember for 400 into 87
- can anyone give me some specs on the clutch and some bolts
- McLeod Master chewing piston seals
- Gears or Stall?
- Question please vote!! which is the best clutch and flywheel setup?
- Which Clutch Kit/Flywheel is better....?
- Oil pressure
- CPT on "hiatus" for a few weeks.
- Stock LS1 Driveshaft
- Transmission bellhousing
- posi installation
- Line lock
- Which stall
- wrong clutch?
- Did I buy the wrong clutch?
- Bad Vibration in Gear HELP!!!!
- 4L60E valve body
- slap shift
- SLP Rear Diff Cover (AAM)
- Balance Driveshaft??
- Longer Shift Handle? and a newbie M6 driver question
- how meny hours to install a converter and cooler
- Used gears?
- Better gear for an A4... 3.42 or 3.73?
- T/A/ Performance Cover - Question about magnet
- 3:42 gears in an auto?
- How to beef up Stock rearend????
- 3:73 or 4:10's???
- spohn crossmember possible issue
- Time to rebuild 4L60E - 303K miles!
- 6 speed reverse popping out
- Question on my clutch...
- General Question About Carriers & gears
- M6 is not good...need help!!!
- clutch and band chart 4L60E
- tranny help
- the best cam for a 3400 stall?
- blew my rear- whats best option
- streetability of aluminum flywheel??
- Just bought some 3.73s...hope these are the right ones...
- A4 won't shift at WOT
- ls1 rear in lt1
- is this right 93 z 4.10 steeper than 94z 4.10 gears
- Shifting Wierd on automatic
- 3.73's In An A4. What RPM?
- I need a new auto tranny mount.
- What should I get TA Girdle or AAM Girdle
- Rear End leaks?
- Help!4l60e
- First ever 4L60E trans brake
- need a part # please
- operation of a 4l60e
- megamaxtrannys on ebay
- slave cyl ????
- 4l60E, no engine braking in 1,2, or drive
- ?conversion?
- Gear swap W/Torsen diff?
- 700r4 2nd gear start
- Speed Sensor DTC comes on after hard launch
- Need help ASAP (4L60E Trannsmission)
- Q regarding V6 5speed swap
- syncros???
- 2.73 to 3.42 or 3.73
- think my tranny is going
- bad vibration in tranny afcter clutch install(only rolling from a stop)
- 1995 Z28 Camaro A4 4L60E
- ss rear gear ?
- Replacing torque converter lockup switch
- LT1 Torque converter the same as an LS1 TC?
- 700r4 -- 4l60e
- Flywheel Turning
- should I resurface my flywheel? pics..
- ? about moser nine inch
- Drive shaft tube o/d
- Shifter Bobs Up/Down over bumps, vibrates at idle
- Top of third with 3.23s, 3.42s, 3.73s
- How many shims are too many?
- good converter and cooler???
- Gear Change to 3:73
- street twin or spec 4???
- clutch peddle reponse
- Need clutch recommendations
- auto wont shift, redlines
- Couple gear questions
- T56 scatter shield???
- Torqe Converter Question
- Does ATF "wear out" in a T56?
- shift kit issues on 4L60E
- Anyone done a 4sp conversion on a LTx?
- Can someone explain strength of gears 4.10 vs. 3.9 etc
- LT1 Street twin balancing
- How many teeth on the stock '94 flexplate?
- Powertrax
- rear axle hp loss
- Pinion seal leak after replacement
- Noisy T56
- difference between 6@8 cly rear and
- Considering the T56 swap.
- Another spec III bites the dust
- did you have to "set" your spec clutch?
- Just installed Moser 9"
- how long does a ST last?
- 88 GTA Kickdown cable adjustment
- What exactly causes 3rd to slip on A4s?
- lt1/4l60e/273 question
