PDA
View Full Version : Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 [29] 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69
  1. Tell me about the converter that worked great or awful on your daily driver
  2. "Clink" when the car shifts or gets put into gear
  3. stock rear end and driveshaft
  4. which gear set up with supercharger
  5. piolet bearing
  6. Best Tranny mounts? Where to buy?
  7. bad vibration over 4000rpm HELPP!!
  8. pilot bearing still in with automatic??
  9. stalled A4 vs. M6
  10. LT1 pressure plate to fly wheel bolt part #
  11. question about the posi in a 93 Z28
  12. CPT offering $100 discount on "Race" and "Pro Race" 700/4L60E's through August.
  13. Is my tranny broken? Wont shift with car on
  14. T56 conversion-sending Codes.speedo dont work.
  15. Pinion support on a 9" only had one bolt installed would this.........
  16. Crap...where is the best place to buy a remanufactured t56?
  17. 4l60e Ratchet Shifter ?'s
  18. Can a T56 mate up to a BBC (454)?
  19. t5 clutch fork
  20. Wierd gear whine...
  21. T56 Rebuild
  22. Need Help On How To Change Rear Studs To Longer?
  23. transmission problems
  24. What series carrier?
  25. Nothing after rebuild.4L60E
  26. T56 whining
  27. rearend making a whining sound
  28. How flush is the pilot bearing suppose to be? {PIC INSIDE}
  29. 4L60E downshift problem
  30. Howling from stock rearend
  31. Adjustable Panhard Bar or Not?
  32. What clutch do I want?
  33. Best 4.10 gears, problem with motive
  34. Tranny Problesms
  35. 9 inch moser housing/axle, which studs? Speed-Eng.
  36. looking for 9"/12 bolt
  37. 4L60E and converter question
  38. Rear end leaking in two places- Help
  39. Help plz: Knocking from driveline under normal acceleration
  40. Clutch/Pressure plate/T.O. bearing suggestions please!
  41. SPEC Stage 3 Plus Users
  42. TH-700R4 question!
  43. Tranny Help...............Please!!!!!!!
  44. Re-Assembling the drivetrain
  45. I think I can hear my layshaft spinning.
  46. Is my M6 trans' days numbered???
  47. Can i do this axle swap?
  48. 3rd of 4th gen rear end in a first gen?
  49. Anyone useing an aftermaket hydraulic throwout bearing in there T56???
  50. Swapping to a th350 or th400
  51. 4l60 rebuild kits
  52. Help 4l60E problem!
  53. Which TH400 shield requires the least BFH work?
  54. 4L60E Rebuild DVD!!
  55. Diffsolutions.com????(9bolt.com)
  56. Ticking noise-Clutch
  57. Clutch master empty.
  58. Therory Or Fact, Please Give Your Feedback.
  59. Loud Tick after Clutch Install (LT1)
  60. rear gear change.....vs is it the best
  61. Exploded pictures/view of a t-56 please
  62. destroyed gears in the rear-end..
  63. Removing bell housing! Help
  64. tailshaft bushing
  65. help m6 vs a4
  66. Clutch/slave cylinder question
  67. B&m transpak or shift kit??
  68. which programer
  69. Neutral safety switch question.
  70. tranny install??
  71. Setting Pinion Angle
  72. Marble Between Crank and Trans ?????
  73. Tranny dead - need tranny shop recommendations in jacksonville, fl
  74. Real axle info needed
  75. Taking apart the pressure plate/bellhousing
  76. post your or anybody's differential cooler pics!
  77. 4L60E no first gear/ DTC 97?
  78. Rear End seal leak ?
  79. Pics of stock PP?
  80. yay trans is out!
  81. m6 to a4 swap
  82. I swore I had 3.73 gears
  83. Help Me! My car idles too high!
  84. transmission mount and tuneup kit. . .
  85. Any Gain With Converter locked Up?
  86. TH350 vs TH400..any TH350 LT1 cars ???
  87. GM stock 10 bolt
  88. Wierd THUD coming from under center console...
  89. 488 gears???
  90. Rear end Question?
  91. Transmission perform botton??A4
  92. rear end noise
  93. the skip shift light
  94. 4L60E wont shift to second past half throttle.
  95. Another Broken T56 Thread, Need some help
  96. Can not Shift into REVERSE...
  97. Is buying Used Nascar 9" complete center sections a bad idea?
  98. The Mickey's killed another rear end
  99. Dammit!!! please help
  100. Broken Eaton "super strength" posi (12 bolt)... what are my options?
  101. What the... dipstick?!?
  102. Richmond or strange?
  103. Confused about 4th gear....
  104. SPEC4 pressure plate with a McCLeod single disk??
  105. rear end finally gone. i think..
  106. Uh oh ... 2nd gear slipping bad!! (A4)
  107. Trans brake???
  108. T56 Conversion Guys Inside
  109. Axle Tube Diameter?
  110. ATF fluid & filter change
  111. M6 swap: Does a stock LT1 fly wheel need to be balanced when put on another lt1?
  112. Rear sway bar install question.
  113. trans mount bolt size?
  114. Ati Or Precision Industries... For Strip / Street ????
  115. Pressure Plate bolts
  116. How often do you change your trans fluid?
  117. What part is this????? Pic inside
  118. transmission leaking
  119. Would you be interested in a Ford 8.8" or 9" rear end?
  120. Break in mileage?
  121. Th400 in LT1 What Size Converter
  122. Car Will Not Go Into Any Gear!!!!!!
  123. What gears...
  124. CPT new shop address
  125. Converter Woes
  126. Aftermarket paddle-shift transmission for 4th gen LT1?
  127. Transgo+Vig 3200 = WOW!
  128. Should I try to change a transmission myself?
  129. clutch chatter..?
  130. Girdle or something else?
  131. Clutch test for wear
  132. Transmission
  133. Pro 5.0 vs B&M SS
  134. Gear ratio & tire size
  135. something is hopping around!!!
  136. looking to sell 96 T/A Tranny
  137. T-56 Help!!!
  138. Loud banging from underneath car over small bumps?
  139. T-56 Help Please!!!
  140. ES Tranny mount ???
  141. 5sp trans
  142. Running without the lower tqConverter cover on
  143. Positraction?
  144. ls1 clutch drill mod
  145. going to be replacing a clutch.....
  146. Whats the mcleod single disk rated to?
  147. Help me make a list for Dropping Trans & New clutch
  148. t56 is realy messed up after broken driveshaft
  149. What's the diff between a 93 and a 97 t-56
  150. TC Lockup Question
  151. Gear Whine
  152. 7.5 or 8.5
  153. loud screech when shifting
  154. auto driveshaft the same length as m6? 9 inch? 1350 yoke?
  155. Torque COnverter Question
  156. I think the transmission is dead.
  157. Question and Problem
  158. PlEase HELP!!trouble getting into reverse
  159. Bye Bye Traction! Stall Installed...
  160. Are these transmission coolers basically the same?
  161. 9 inch moser housing and torque arm?
  162. 9 inch moser housing, ford center section, 3 channel, 4 channel, and more questions?
  163. Which rear fits both gen?
  164. Are LS1 rear brakes any bigger than LT1?
  165. How hard is it??
  166. homebuilt short stick
  167. screw in wheel studs NEED HELP!!!!!!!
  168. Drivetrain problem...need some help!
  169. Po' Boy's Clutch
  170. T56 dust cover needed
  171. How much should a stock LS1 clutch go for?
  172. Heavy duty ATF?
  173. 4L60E - Guru Guidance Needed!
  174. Changing rear gears, where can I find some heavy duty cap bolts?
  175. Tru Cool 4490 - No Instructions
  176. Question About 4l60E Slippage
  177. Clutch going bad? How to tell ??
  178. 4L60E question
  179. drivetrain vibration HELP!
  180. Rough Shifting
  181. Tourqe Arm / Noise
  182. Takes awhile to shift out of 1st at WOT...
  183. 2400 stall
  184. transbrake and converter
  185. Shifter Problems?
  186. th400 slapstick for 93-97 camaro?
  187. Freak T56 Failure/Problem??
  188. Which pinion seal for a '01 T/A?
  189. T56 rear seal leaking
  190. Changing 2:73's to 3:73's
  191. Rear End
  192. New Car
  193. What broke, clutch or tranny?
  194. Transgo 46-Mod Vacuum pressure
  195. 9" Posi or Locker?
  196. Exactly HOW MUCH does the STOCK tranny cooler do anyways??
  197. 8.8 Ford Rearend
  198. 94Z Trans Issue
  199. **[for sale content deleted]**
  200. can you rebuild a stock possy unit?
  201. Need TransGo Shift kit Instructions
  202. 4L60E compatibility
  203. Fuddle Or Vigilante
  204. What is going on with my trans?
  205. Will moser 12bolt from lt1 work in ls1
  206. Can someone please post a picture of the boot that covers the trans under the console
  207. massive wheel hop!!!!
  208. Skip Shift eliminator … a waste of $$$???
  209. My 4L60E---->th350 experience..
  210. Weeee'rrrre baaaaack! The rebirth of CPT
  211. knocking when in reverse only
  212. tranny or TC problem?
  213. Trans Problem?
  214. A4 to T56 Conversion wiring pics? write ups?
  215. GM Limited slip additive
  216. TH350 tools?
  217. What is the difference between an Lt1 and LT4 PP?
  218. Spec 3....so far, so good.
  219. What is the best transmission fluid to use in my M6?
  220. t56 to a4
  221. t-56 question
  222. Cost of repairing/balancing Carbon Fiber Driveshaft
  223. Clutch slips in every gear but 4th?
  224. Need Ring & Pinion Advice!!!!!
  225. How to tell the difference in a 2/3 Series Carrier
  226. Fuddle Converter bolt holes do not line up with flexplate
  227. **** B&M v.s transgo shift kit
  228. LT 1 Flywheel-M6?
  229. 700r4 conversion question
  230. is this good fluid?
  231. Bolt sizes for pressure plate on T-56
  232. Clutch fork hits new street twin (LT1)
  233. autotranny problems. *loud thunk*
  234. POSI Question
  235. 98 six speed shifting problems
  236. MCcleod Single disk vs. Centerforce DFX Clutches
  237. posible wrong stall converter
  238. Hurst Internal Rail Comp Plus!? Anyone Use?
  239. Big tranny problems!!
  240. lt1 and ls1 yolk, is the ls1 bigger
  241. Blew my rear end
  242. Stall Speed for modded LS1
  243. 1994 4L60E in a 2002 WS6....
  244. Hard to get into reverser after....
  245. Mcleod single disc - Adjustable master needed on and LT1?
  246. Holy Crap, MAD vibrations above 90mph
  247. Best Place to buy Mccleod Single Disk
  248. What to rebuild my rearend with?
  249. stock 10 bolt
  250. 3200 or 3600 converter for LT1?
