View Full Version : Drivetrain
- RAM HDX Clutch Disc Died on me, for no apparent reason
- 12bolt From A Truck?
- big stall guys please chime in..
- Dangers of testing w/ rear wheels off the ground
- Lowest price for Mcleod LS1 bellhousing??
- good price for 3:73 gears..
- 3-4th Not shifting @ WOT
- Rear end noise
- 4L60E no 1st or 4th gear. HELP
- 700r4 question
- Anyone ever rebuilt a DS center bearing?
- Stock rearend can't handle 398RWHP HELP!!
- Used gear question
- 1993 A4?
- A4 exhaust mount/cat support vs M6 exhaust mount/cat support... same?
- Max power for a stock 10 bolt?
- Stall converter
- 8.8 ford rear in camaro
- For strength which gear ratio is best 373 or 410
- Moser 9" axles
- Slipping tranny
- installing gears help
- Pilot Bearing Install
- clutch/slave question
- I have a mod kit can i make it work? 4l60E
- What tranny fluid for ZF-6?
- auburn diff
- Any advantage to a WOT lock-up on a torque converter?
- dont know if this is the right spot but..
- What to do my 6th gear is gone i guess
- 2nd to 3rd Gear Not Shifting At WOT?
- Anyone Rebuild Their Own Tranny
- gear install, and c clip elimonators
- rear debackle
- will a Lt1 T56 bolt right up to a SBC
- Thinkin 4.10s A4
- high torque shift rattling...
- Trans Question?
- What size gears are these?
- rebuilding rear end
- About flippnig synchos? reverse only?
- need too change tranny fluid 104k
- 4.56 gears.
- Anyone ever use an LT1 T56 with an LS1?
- McLeod Soft-Lok clutch
- GLOBAL WEST TRACKLINK w/MOSER 12 Bolt
- Rear End Removal
- Question on swap
- clutch install?
- question about stalls....
- Couple of Questions
- LT1 bellhousing bolts........
- aliminum driveshaft
- B&M Shift Improver to Transpak?
- Not shifting to fourth
- rear end girdle
- Need Flywheel Help
- T56 Conversion Question
- help me build up a T-56 for some serious TQ...suggestions?
- Will a Dodge 8 3/4 or Ford 9" go into our cars?
- Is it worth it spending $300?
- Prescision GEars Question???
- Rear Axle Removal - What Tools and Where?
- New Driveshaft--U-joint Strap?
- B&M Racing Buys Hurst Shifters
- Tranny problems please help !!!!
- Rear End Replacement Questions?
- five speed question
- question about shift kits and transmission perform
- 4.10's?
- what gears should i get?
- Changing rear gears to 3:73
- Rear end whine
- Shift kit?
- ooh ooh that smell...
- Broken Tranny Mount
- M6-A3(th350) help.
- people with 2800 stall
- 700r4/4l60e question
- 4l60E to 700R4 conversion.
- Some may have taken my post about Performabuilt wrong
- Gear questions 10 bolt
- 2.73, 3.73, 4.11, stall
- M6 and A4 ?
- A4 and M6
- Transmission problems...
- Performabuilt?
- Need help with clutch!
- shift light in side defrost hole?
- Finally! A Trans shield for 700/4L60E
- What should it cost to have gears installed?
- Need Help with 91 Camaro RS
- spragless?
- Gear ratios for various trans of interest
- Whats needed to swap to a 700R4?
- is there a way
- Anybody know part# for LPE DS u-joint?
- clutch fork t stud
- 700r4 ?
- Can you have a anti-ballooning plate installed?
- trans cooler fittings
- LS2 Flywheel / LS7 Clutch - What else do I need with my 2001 Z?
- 2800 stall speed
- will a 4l60e work on a lt1?
- Would you buy a used clutch?
- New to the fourm, spec clutchs....
- 4L60E problem?!
- My rearend has been changed?
- T56 swap - hard to shift
- 4.10's
- 4l60e help
- Slave Cylinder hose connection
- replaced slave cylinder, WTF now no line pressure.....
- HELP more drivetrain problems...
- accumulators
- DTC P0758 2-3 Shift Solenoid Circuit Electrical
- valvebody and th400 rebuild question
- 4L60E to T56 conversion??
- Questions on T5 Transmissions and other specs
- Part number for stock driveshaft and 1350 yoke?
- Transmission Help
- Trans maintenance
- Caliper mounts
- SPEC stage3+
- what parts to buy for strong t-56?
- What kind of T-56
- 3400 Stall to big for bolt-on/sprayed LT1??
- t56 input shaft
- Spohn LCA Relocation Bracket Owners - In Here Please
- flywheel balancing
- Will my stock 10 bolt last?
- Car feels like someone is holding bumper
- Building a 10b to handle ~500hp.
- LT1 4l60e bolt up to LS1?
- Centerforce Clutch?
- TH350 Re-Seal -- Parts List?
- GM Gears - Part #??
- 1/2 inch studs
- My Fuddle Review
- M-6 to A-6 conversion
- Synchros or Clutch???
- redlining in first, give me the news.
- Rear end howl/ whine
- 3-4 clutches burned up..... again
- Clutch little slippery on cold/damp starts
- Clutch Pedal Vibration
- Converter sporadically locks/unlocks
- Whats the black tube on t56?
- torque specs for lt1 pressure plate
- T400 vs. T56 in a turbo car?????????? Looking to maybe swap...
- tranny guys...
- Torque Converter Lockup Switch?
- Cost for A4 to M6 conversion?
- could this been the pressure plate or clutch ?
- where to go to buy shims or spacers for dialing in the differential
- clutch installation
- How Hard Is It To Change The Spider Gear From One Auburn Diff To Another?
- Need some Ford 9" help...
- A4 trans problem, opinions please
- Newb tc question.. yes I read the lock up sticky
- bent axle or warped rotor..
- GM Synchromesh Fluid?
- 96' t56 Input shaft check
- street twin space and washer setup help
- Trans guy need sum info
- Pro 5.0
- 4l60e torque converter #4842ss info
- Any Fidanza clutch users?
- 97 Camaro LT1 Tranny Options
- New tires/rear end concerns
- whats wrong?
- Limited slip breakaway torque
- Help me pick the right parts
- and....the TA breaks down.
- I think is the drivetrain
- Bad clutch I think.
- Dead pump or converter?
- axle bearings/seals question
- transmission problem maybe??
- Frank @ CPT ... EXCELLENT customer service!!
- Gear Question
- ATF at the back the trans
- Transmission Fluid- Synthetic or Dino??
- What was the 1993 Automatic Tranny
- Spec 3+
- Help diagnose 4l60e problem
- removing axles, need help with c-clips....
- 6 speed manual ratios
- 6 speed help
- Pilot bushing and input shaft ???'s
- 1996 T/A - How much would a differential cost?
- New Tranny Pan
- What Stall????
- 97 4L60E in a 95
- Best supercharged gear ratio
- Strange 12 bolt
- made the swap
- Late upshift, no downshift?
- Whats the difference between a '95-'97 LT1 4l60E
- Transmission seal leak
- What's a good clutch? (only slightly modded)
- Tricks on pinion spline
- Part Number
- 3.73 vs 4.10 ratio mph difference
- Gear Chip
- ram powergrip hd rated at 600hp?
- Anyone with u-joint knowledge please read
- Who Makes Aluminum Flywheels For LT1's
- Trans. swap need info
- manual 4l60e
- Trans cooler lines: Feed & return???.
- 94 lt1 tranny options
- how do you tell if your 10 bolt is a 7.5 or 8.5
- Clutch Problem
- Need a 12 bolt
- split bellhouse 4l60e
- time for the rear-end..
- Who builds a good 4L60E, street and mild strip ?
- convertable gears
- Disable the lock up?
- Rear end squeak?
- trading 7.5 for 8.8
- reluctor ring?
- looking for a new d/s
- anyone build a 8.8 inch ford rear end ?
- Recent 94 4l60e rebuild vibration 2-3 shift.
- How long has your CPT transmission lasted?
- clutch problem or lsd problem
- will a auburn carrier fit in a torsen rear end ?
- 700r4 no forward gears just reverse
- B&M Pro Stick Install
- difference in rearends...
- does not shift into 3rd under load
- trouble bleeding!
- did i get the wrong stall?
- how torque converters work
- T56 Rebuild Underway!
- Pinion seal leak repair
- Clutch Recommendations
- How Much Hp Will A Stock T56 Handle???
- Ram Power grip HD?
- Replacing Pinion seal on a Currie Ford 9"
- clutch not dis-engaging?
- McLeod Street Twin question
- Replacing yoke on ford 9"
- is the rear end the same in a 3.4 6cylinder and a 5.7 v8 fbody
- ls1 clutch fit lt1?
- what does a 12 bolt come in
- T56 Rebuilds Review...
- im trying to find info on the disassembly of the rear end internals ?
