PDA
View Full Version : Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 [19] 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69
  1. Shifting Noise 00 WS6
  2. Correcting speedo on a 93 4l60/700r4
  3. Help! Clutch fork wont install
  4. For all you guys that have a 9 inch hitting the floorboard, I found the problem.
  5. grinding?
  6. Help I think I injured my tranny!! Weird problem!
  7. U-joint carnage!
  8. Pinion Yoke Weights
  9. Performabuilt
  10. Lock-up or non-lock up???
  11. vibration issue
  12. Anybody recommend a clutch?
  13. A4s Going Out....Weighing Options
  14. 700-r4 owners
  15. No line pressure in tranny. Bad pump?
  16. Transmission flush at 91K?
  17. New Gears in Speedo Correction Help
  18. Axle seal part number?
  19. 95 z-28 t56 specific camaro z-28 questions. Electrical circuits help please :)
  20. Clutch problem HELP!!!!!!
  21. T-56 Source
  22. 1993 Z with M6 and 2:73 gears
  23. Viper T-56 Conversion "Write UP"
  24. Cpt Trans Owners, Post Your Et, Hp And Weight In Here
  25. what kind of shifter would you buy from these three?
  26. WOT 2>3 shift problems
  27. Will a LS1 Aluminum driveshaft work and fit properly on an A4 Lt1?
  28. 6-speed guys with disengagement issues step inside
  29. How much to have gears installed? And what do I need?
  30. Vibration diagnostic check list
  31. what should i pay for someone to install gears
  32. How tight does 20"lbs feel?
  33. LT1+4L60E - will 168 tooth flexplate fit?
  34. wont go into reverse... all gears are harder to get into gear.. works with car off...
  35. Six speeds inc... my expierence. long...
  36. o.d stopped engaging, cooled for hour works great
  37. Cheapest Places to Get Clutches? Now which is the best?
  38. 4L60E doesnt stay in gear when decellerating
  39. 9" guys - is your driveshaft offset now?
  40. Spec Flywheels?
  41. manual tranny instead of automatic=> good performance increase?
  42. 80's tbi rearend = ls1 rear?
  43. Shifter Choices?
  44. zexel torsen HD LSD
  45. m6 conversion with different interiors
  46. NEED HELP...problems shifting...
  47. 3.73 (2 series) gear install pricing
  48. Parts needed to make build a 9in rear end?
  49. Has anyone ever bought 9-inch parts through Quick Performance?
  50. Skip Shift Solenoid
  51. What gears i have
  52. gears on a 94 camaro z28 6spd
  53. 1995 4L60E lockup question.
  54. M6 Shift boot ring fix
  55. GM Hightech 10bolt Build Up...
  56. Differential options
  57. Driveshaft Length.
  58. Trans Dead - Looking for Recomendations
  59. A4 > M6 Conversion
  60. Moser 12 bolt u-join girdle straps
  61. Whos running 4.56s with a stockish LT1
  62. Got Fuddle?
  63. 2.73 to 3.73 questions
  64. Gears 2.73 to ??
  65. Bad transmission input shaft bearing?
  66. LS1 with a LT1 T-56?
  67. rearend noise
  68. How Many Of You Guys Running 4.30 Or 4.56 Gears
  69. Operation TH400/LT1
  70. please help, can't get tranny to come out
  71. Looking for some info on assembling 9-inch center sections
  72. Who here had broken the axle shafts on a 10 bolt?
  73. Tranny (VSS) Issue...
  74. Is diff fluid like tranny fluid?
  75. Need help choosing stal converter
  76. removing caliper brackets?
  77. Is this normal?
  78. Weird problem after clutch install..
  79. URGENT will 95 a4 work in 97
  80. Does anyone know what size and tread pitch
  81. safety loop
  82. Can you tell what this "chatter" is? (video)
  83. Driveshaft problems...
  84. will LSD additive hurt anything if it's not needed??
  85. Pinion Seal How-To?
  86. Basic Clutch Question
  87. emergency: t56 rebuild help
  88. Is the Trans Cooler..OK to use? Need help from the pro's
  89. 95 4L60E Problem
  90. are my 3-4 clutch packs going?
  91. WOT lockup / Fuddle converter questions
  92. Help Please Soon!!!
  93. Transmission Mount/Torque Arm Bushing
  94. Satisfied CPT + Fuddle Customer
  95. LS1 M6: Just put in Motive 3.90's. Report:
  96. Whine with a load
  97. 94 V6 car, posi or open? GU5
  98. Rear End question
  99. Weird clank noise around 55mph, causes vibration and makes car jerk??
  100. pilot bushings/bearings from local store?
  101. tranny temp reads -40 on scan tool - code 59
  102. 97 4L60E slippage...or something...lol
  103. comonly ask trans Questions
  104. General tech info on the 4L60E and 700R4
  105. Torque converter questions
  106. 4l60e no 1-2 shift
  107. noise when i step on the clutch
  108. 4l60e Lockup Issues And Probable Causes And Fixes Fyi
  109. How hard can I launch my stock t-56?
  110. Trans fluid low
  111. What did your 10 bolt hold up to?
  112. Just Fought my T-56 For 2 hours... The T56 Won..
  113. six speed automatic
  114. Motive Gear "break-in"
  115. What could this be?
  116. transmission mount help . . .
  117. help transmission mount . . .
  118. stall question
  119. transmission how many quarts for a 4 ?
  120. help me choose a clutch
  121. Aluminum Flywheel...balancing
  122. Question about rear end... YES I ALLREADY READ THE STICKY...
  123. Master clutch cylinder location
  124. torque converter questions
  125. Manual Transmisson Rear seal & bushing issues (please read)
  126. Viper t56 mainshaft question
  127. lt1 clutch fork bolt
  128. Who has aftermarket gears in their 10B?
  129. cannot get flywheel on
  130. LT1 inspection cover same as SBC?
  131. TH350 Swap dipstick question
  132. Trans Cooling line Fitting?
  133. Transmission oil cooler into Oil cooler. Can I?
  134. What 4l60e trans will be a direct replacement for me?
  135. Who sells?
  136. Pilot Bearing or bushing and what kind. Found out some good info..
  137. 4l60e?'s
  138. Dang It!! I think somethine is loose
  139. inspecting a used rearend?
  140. Thump on takeoff
  141. relocation brackets wrong ones!
  142. What Actually Locks Up the Converter?
  143. New Flywheel
  144. Now Spec 3+ is gone (1000miles)
  145. Recieved my MCLEOD Clutch Master today!!!
  146. cruise control no work
  147. LT1 trans cooling lines?
  148. Identifying the trans in my car?
  149. LT1 T56 t-stud part number
  150. Torque converter and rear end help
  151. bleeding master cylinder
  152. Clicking Noise Sometimes When Goes into Overdrive
  153. how to put on transmission mount . . .
  154. question to the rear end gurus
  155. t56 parts question
  156. Should i buy a new clutch? Drifting \ Dragging 2 weekends apart
  157. Question on bleeding the Master/Slave Cylinders
  158. T56 Clutch Fluid AND gear box fluid... What do you use?
  159. T56 questions....what part is this (pics inside)
  160. shift points???
  161. BIG problem after getting on it.
  162. 93 v6 a4 shifting too soon
  163. LT1 Mcleod Clutch MASTER/SLAVE setup part numbers and info.
  164. Torque Converter with LT4 Hotcam?
  165. transmission mount
  166. Transmission Service And Mount . . .
  167. clutch position sensor pigtail connector? Cruise Switch Y Harness??
  168. Weird problem with my M6 - car behaves like it's stuck sometimes
  169. WS6 rims don't fit WS6 rearend!?!?
  170. what gears for my 10 bolt?
  171. Can't decode axle
  172. What is this about S10 converters?
  173. Just put in Trans cooler
  174. Diff Recomendations
  175. whining noise
  176. ABS Inop Light
  177. "Gauge" fuse blows when I put M6 in Reverse
  178. PLEASE HELP tranny problems!!!!
  179. 93z M6 tranny problems
  180. 94 z28 auto trans problems
  181. Overdrive vs. Drive on the streets?!?
  182. whats wrong with my trans pic inside(4l80e)
  183. My speedometer's not reading right?
  184. Strange sound from rear end...
  185. Master cylinder question...somebody help!
  186. Turbo350 trans?
  187. LS1 clutch
  188. Flywheel
  189. Built 4L60E maybe toast??? Feels like I'm towing a boat in OD???
  190. Short Shifter Selection
  191. '97 LT1 M6 - Trouble getting in gear, clutch seems partialy engaged.
  192. got a 9 inch rear end ....what next
  193. Information about transmission coolers
  194. Anyone swap a 4l80e in the a camaro?
  195. What is my Built 4L60e worth?
  196. Reverse & skip shift problems w/ M6
  197. Broke My HD Torsen
  198. noise coming from bellhousing
  199. Rebuild 4l60e Myself?
  200. Auburn posi and chattering?
  201. Throw out bearing reatainer
  202. clutch cover plate
  203. Help me choose gears
  204. 3.73's in 6 speed cause vibration please help
  205. need a new flexplate
  206. new clutch,slave master etc...still hard shifting!!!
  207. how to get a speedo to work after a tranny swap
  208. One Wheel Wonder
  209. Differential Gear Problems??
  210. street twin
  211. Parts list for a bulletproof 4l60e rebuild?
  212. Getting ready to buy a 9 inch from DLS
  213. 4L60E stuck in 3rd Gear
  214. six speed queastion. harder shifting gears.
  215. Humming/Grinding sound from T56 - Please help diag.
  216. 4L60E wont go into park =(
  217. Where do you buy rear end rebuild tools?
  218. help diagnose please..
  219. Options for 93 w/ 700R4
  220. 96 Camaro Auto-Tranny Problem
  221. Need nut size for clutch fork actuator studs.
  222. 4.10 vs 3.73
  223. Installing M6 Tranny.... OMG, SOB.
  224. Going from T56 to TH350
  225. Clutch question on 3.8L 1996
  226. Shift linkage question
  227. 1-2 Shifts When Hot
  228. Check out my Pedal Assembly. It came out awesome!!
  229. No Tach, Speedo, A/C after M6 swap
  230. Transmission Rebuild
  231. Manual or Automatic?
  232. Changing Automatic 2 a Manual
  233. 1/2 " ARP Wheel Stud Torque Specs
  234. Anyone running a monster converter?
  235. Rear Axle Replacement
  236. Hhhhhhhhhhhhheeeeeeeelllllllllpppppppp!!!
  237. How difficult swap the converter?
  238. t56 transmission inquiry
  239. T56 conversion questions
  240. LT1 Clutch Master U bolt part number?
  241. 4L60E Dip Stick pops out
  242. what auto trans is in my 93 T/A?
  243. M6 conversion in A4 LS1
  244. Where this tranny fluid come from!?!?!?
  245. Trany mount
  246. Order, or not to order
  247. Th350 swap out shaft
  248. drive shaft loop
  249. T56 owners ... how to fix reverse going out?
  250. 3.73s...Now Slower 0 to 60?
