View Full Version : Drivetrain
- Trans shifts to softly
- G Force transmissions T56 part failures experiences
- clutch pedal connectors
- 4l60e
- 10 bolt + ET Streets theory?
- Are 3.42's enough?
- 4L60E Shift Problems
- What converter?
- 4L60 to T56 swap=> parts questions
- shift bracket...
- AC Clutch on 97 GrandAm maybe?
- Anyone make a transbrake for 4l60e?
- 4l60e not shifting and no reverse
- 4l60 Linkage problem
- 93 TV Cable Bracket #'s
- who rebuilds t56 transmission?
- Is there a high performance shift kit from Superior for my 97 trans am a4?
- Rebuilding the 4L60
- What to look for 4l60e core interchange.
- Is Drill Mod worth it on LS1/T56?
- 1995 z28
- No Overdrive in 4L60E
- rebuilding a t56
- Axle stuck, won't pull out...
- 94Z 4L60E trans shudders shifting 1 to 2
- Please post if you have trashed an input shaft with the street twin
- Need some general info-clutch brand, hp/tq, pros and cons
- 4l60e problems!?!
- Could a new driveshaft make it worse? Vibration?!?
- Stock clutch disk with Centerforce II Pressure plate?
- How wide is a 4th gen axel?
- Flywheel balancing question
- Rip T56 #2
- ASR Delete/ 12b Q's...
- TH350 install question...
- weight
- 700R4 swap question
- CAGS thread size?
- pass wheel movement along with clunking noise
- Which gear?
- 4l60e transmmission
- transmission question
- Shift Kit
- can't figure it out?
- Vibration Solved!
- 12 bolt's that do not whine, howl or make other noises...
- Clutch "chatter" or "buzz" what is it?
- My Car Has A Bad Sway PLEASE HELP
- Bad Transmission
- 7.5 strength?
- Is Scott Koresky still around???
- 3.00 Gears too low?
- my trans is at 250 degrees what should i get
- How to check a reverse Lockout on a m6
- Pinion Sea
- 2002 WS6 Popping out of reverse
- So what's the best?
- Throwout bearing gone bad
- GM 5 pinion planetaries question
- Any auto guys using aftermarket shifters with stock console?
- whats a good transmission for a 97 z28 automatic
- Opinion nice stall or T56 swap?
- centerforce dfx
- Two questions - cracked MAF housing, clutch "chatter?"
- 6 speed swap questions
- Performabuilt Lvl2
- what stage was this?
- loctite the bellhousing bolts?
- How much am I leaving on the table?
- transgo kits 7002+3 and SK 700 jr A kit? quick response please :)
- I need a 12 bolt
- Anyone breaking th400 cases
- thanks shoebox
- C-Clip for axle...Where to get some??
- Another use for CAGS
- Is the transmission fried?
- best lt1 t56 mount?
- Fuddle review
- High clamp LT1 clutch pressure plates. True or BS?
- v6 camaro m5 in a4 z28?
- Feramic friction clutch any good...
- how come my car wont go into gear?
- new tranny and supercharger
- Tranny leak, would it cause acceleration hesitation?
- mcleod master
- rear end question
- Clutch Hydraulic Fluid!
- brake pads
- sonnax sure cure kit
- startin to hate my m6
- New Transmission In park?
- 4l60e to 350th sawp
- 6L80 tranny
- New Clutch Slipping!
- High speed vibrations
- better converter for bolt on `02 WS6
- Transmission problems in 93 z28 automatic.
- Transmission Problems
- 95 Formula T56 issues
- mikronite
- Identifying T56 by numbers => Who know?
- Slp
- 3 Day Sale Level 1 $1175=700r4, $1275=4l60e Lt, $1375=ls1
- 99 Auto
- Need wheel studs replaced in rear, but have abs- Help
- How to check Driveshaft Angles?
- Weird sound getting worse?
- torque converter won't slide all the way on
- Hard clutch and weird noise
- What gear should I run?
- TH-400 drive shaft length
- opinions wanted on clutch issue
- stud size
- T56 to 4l60e swap & vice versa
- shiftkits
- yoke removal question
- power glide good or not good for my combo?
- stall
- pulling tranny
- T56 conversion wiring (hatch release)
- Pressure Plate Issue
- steel or aluminum flywheel?
- checkin gear ratio
- reluctor ring question
- Rear end help
- Hit & Run
- cross member question
- Manual vs Auto
- Tranny problem help
- new Spec 2 clutch performance?
- installing a 700R4/4l60 in a 94 formula
- Is this clutch useable or worn out?
- 4l60 95z28
- possible shift linkage problem
- best way to align clutch assy?
- Steering wheel not aligned from bent rear?
- Gear Brands - Motive/GM?
- Today And Thursday Only,level 2 Sale 200 Off +
- How to convert a 3 channel to a 4 channel
- looking for a good step by step M6 to auto
- Do gears only help on the launch?
- Moser 12 bolt vs. Strange 12 bolt
- How do I tell when it is time to replace the clutch?
- Trans and Rear fluid change
- Tranny Trouble
- screw on the throttle body
- 4l60e problem/question
- HYPERTECH PP3..vs..Transmission re-built
- stall converter
- 4L60e ses code 758 Help!
- 4l60e
- Do they all do it??????
- 383, t56 swap issues
- mikronite gear testing on power TV
- what axle do i need ???
- Flexplate Questions
- Help with drivetrain noise
- Help with tranny....
- tcc lockup solenoid wire
- 700r4 Questions
- moser and strange 12 bolt owners poll
- PLEASE HELP QUICK!! LT1 to LS1 rear-end swap!!!
- 700r4 tranny in 95 camaro
- how can I bypass the computer shifting?
- serious problem
- torque converter
- Question about new flywheel
- What gears?
- what is this on top of my 4l60e
- internal throwout bearing conversion
- Flywheel Installtion Question
- V6 Gears
- 4l60e Line Pressure...
- A4, 3:42 to 3:73, worthwhile & what brand
- Grinding when clutch engaged
- grindind when push in clutch
- Surging idle after stall install
- what carrier do i have???
- Spec 2+ with stock flywheel?
- losing vss signal
- Swap Question...
- How do I know I have a 4 or 3 channel rear?
- Which rear end do I have?
- Bent output shaft?
- humming while driving- loud, quiet, loud, quiet
- M6 ratios
- trans removal
- Rearend humm noise?
- LT1 - 4L80E Flexplates
- Balanced Flywheel?
- Trans Cooler questions
- Can't determine rear gear ratio?
- shift kit
- rear end question
- Anyone here with S60 expirence?
- 2.73 to 3.73 on '93 - reprogram?
- New Convertor..new cam..first crank
- transmission maintenance
- Richmond Gear Runners...
- Auto Trans Leak??
- T56 Dust/Inspection Cover bolt size???
- Which of these Strange drive shafts do I need?
- Reverse Lockout won't work on 96 TA after M6 conversion
- LS7 Clutch kit Question Please help!
- Tranny
- Clutch Master Cylinder
- think i lost o/d
- Tranny
- Gears, cost/HP/installation
- bad trans?
- how well
- Loud noise comin from the car
- t56 tailshaft bushing replacement - on car
- 4l60e question... please read...
- 2nd to 3rd shift problem A4...
- part numbers for clutch kits
- 7.5 ring gears
- 4.10 gears
- Clutch #2-Extreme Chatter
- What is the stock driveshafts' measures (Denny's customers?)
- ? about Motive Gears
- Very very strange 4L60E 4th gear issue.
- transmission help
- gear spacer
- Question about gears.. local shop's e-mail included
- 4l60e problem - stuck in 3rd(?)
- What size Transmission Pan do I have? - A4
- Help-Opinions Needed Rear Leak - Other than Pinion / Cover?
- weird transmission problem..
- Stock T56 main shaft issues???
- what stalls r better
- Recommend me a flywheel ASAP!!
- Does it sound like my rear-end is about to grenade?
- Driveshaft to eliminate vibration
- 700R4-4L60E VSS signal?
- Need a new driveshaft... which aftermarket do you reccomend?
- tranny snapped
- B&M Cooler Installment Question
- please help
- tranny problem
- Stock length wheel stud?
- whats the pros and cons of a steel flywheel vs. an alum??
- Tranny Out!
- 1996 Rear axle
- Mcleod single disk owners, can you slip your clutch at the track?
- th400 Governor Recalibration
- Spec 3+ grinding...
- rear end, tranny,axle
