View Full Version : Drivetrain
- Trouble with Reverse
- White X on flywheel and yellow dot on pressure plate....
- Auburn diff in a 1994?
- Oil on my clutch... is it toast?
- Pressure Plate struggle
- Any diffrence between these 2 rear ends?
- t-56 part...
- short shift
- Trans Swap
- 98 z28 6 speed tranny grind/rattle when in gear
- speedometer. help!
- how long will this tranny last???
- tranny swappppppp
- Has Fuddle Racing cleaned up it's act?
- overtorqued pressure plate
- Question on carrier preload and shimming
- T56 output shaft question.
- 3000 Stall Lockup Issues
- Ls1 tranny in a 94 z28
- FLYWHEEL: Minimum Thickness?
- Performabuilt transmissions...sale?
- Is the trans ok with a stall and stock tune?
- M6 to A4
- A4 shifter problems
- Tranny solenoids in 94 z28
- 95 LT1 Clutch issues
- Bleeding help, mighty vac...
- V6 4L60E fit in a 95 S-10 4.3L
- Clutch engages too soon
- my clutch blew a brand new slave cilinder
- Tranny leaking from shift linkage...
- 10-bolt Pinion Seal Upate
- lt1 BRAND NEW slave leaking to bellhousing
- Odd clutch problem
- Another clutch form problem
- Gears
- torque converter lock up
- Auto shifter linkage problems
- rebuilding a t-56
- Re-using Pressure plate...
- Driveline vibration found. Coming from rear of transmission.
- P/N for bushing to replace roller bearing??
- Best place to find a 1LE tranny mount?
- Differentail fluid questions
- whats my tranny setup worth...
- transmission
- an ISSUE WITH MY 94 Z28... ANY IDEAS
- roller pilot bearing
- converter locking and unlocking while cruising
- Drivline vibe...I think they screwed up my driveshaft
- tranny issues
- Help identifying my Drive Shaft
- 95 z28 3.23 to 3.73 gear swap
- What is a used set of factory 3.42 gears worth?
- mcleod twin disk guys
- How can 3 studs power a car and not self destruct??
- Calling Frank @ CPT
- '01 T56 clutch pedal play after hard driving..
- Will a Torque Converter from a 4L60E work in a 4L60?
- 4l60e vibration in gear only
- help quick please!!!!
- LS1 Z28 clutch install
- Flex plate/ transmission shield?
- How much does a 10-bolt weigh?
- Trans for a boosted LT1 600-700RWHP streetcar?
- Powerglide Good For my LT1??
- 4L60E Surge Problem 3rd and 4th gear
- Do A4 4th gens have 2nd gear starts?
- Looking For A Transmission
- Help please respond back when you view this
- What's the big deal with replacing m and s cylinders w/ new clutch?
- t56 whining pretty bad!!!!
- intermittent 3/4 issues (a4)
- Weird TransAm Factory Gears&Does anyone use 4.30's?
- Bandit like shifter for 4th gens?
- replacing clutch need info
- Dipstick Color
- Tranny...
- How to flush out tranny cooler?
- Plugging Tranny Cooler Lines on Radiator???
- What socket combo to get tranny(4l60E) loose!??
- Anyone with experience with Fuddle Converters?
- 4l60e shift pattern and points
- bent Axel fixed - now rear end noise?
- Help with fitting Richmond 5 speed to lt1
- What clutch for cc306 + full bolt-ons?
- flexplate problems / wrong flexplate?
- Which differental is better?
- Need advice on T56 issues
- Quick clutch question
- pilot bearing...just slipped out of crank?
- Transgo shift kit
- Need to know what year rearend is
- Driveline help, broken
- How hard will a 4L60E launch? *pictures inside*
- Put in higher stall with rebuild tranie, shifts changed
- Need some info
- as alternator got worse... so did transmission
- what stall????
- Rear end question
- T56 Swap Part Numbers
- Stall on Old 4L60E
- when draining the trans fluid on a 6 speed?
- What broke in my T56 Transmission?
- Torque arm bushing replacement help
- 1LE transmission mount
- shifting problems... 4l60e
- M6- passing tech?
- Manually shifting 4L60E?
- vibration
- Quick Time Performance-?
- 12 bolt hp
- No 3rd or 4th gear in my 60E? Please help!
- Problem with Auto 4l60E in a 95 Trans am
- Six Speed Inc.
- Happy Thanksgiving to all from PerformaBuilt
- Anyone ever see this 9inch housing setup before? Few other Q's...
- Driveshaft ??s
- Does a LT1 converter lock at WOT?
- 1969 camaro rear end(10bolt)
- tranny problem at WOT(auto 4l60e)
- Does my tranny have a short?
- Quell my frears about stall...installs
- What clutch do you recommend?
- 4.10 auto
- 12 bolt limit???
- Interesting thought...
- Rear end swap
- turbo action cheetah in 93 thru 96 m6 console
- Tech info, cooler installation,dtc trouble codes obd-1 obd-2
- clutch help
- Is my clutch going out?
- Dimensions of brake to brake rear end ?
- Weird Shift
- trany 4l60e want shift think it's hung in 1 gear
- Clutch Return Spring Location
- Clutchnet Feedback/Options
- clutch install pages
- 3rd gen rear???
- gear tooth contact pattern correct ?
- wiring harness help 93/95 ? six speed swap to 95
- Sluggish 1-2 shift....AFTER REBUILD!
- Will Strange retainer/caliper brackets fit Moser?
- Clutch pedal squeaking
- Little help if possible
- RAM HD 900 Clutch Disk Part # LT1
- t56 grinding (all gears)
- 6 speed questions, what would u do
- SImple 10 bolt question
- Is it worth it to swap from 3.23 to 3.73?
- mushy clutch, help?
- LT1 clutch line drill mod?
- t56 noise issue
- torque converter
- !996 Camaro SS trans ?'s
- Need p/n for clutch hydraulic line o-rings
- tranny from a 96 v-6
- Big Thank-you for Frank of CPT!
- Best option for rear end
- Curb Check - bent axle?
- no fifth or six gear
- TH400 & Gearvendor
- Transmission leak in a4
- Denny's Driveshaft + Built t56 trans, driveshaft play question
- difference in art carr transmissions?
- What happens....
- Flywheel/Clutch balance alignment
- Difference between Ford and Chevy TKO600
- Broke Clutch Fork Bolt....
- Frozen shifter cable
- Small vibration from 3000-3500rpms
- wont shift till 4000,loosing od.
- carrier fitment?????
- I think my clutch is dead
- help! 4l60e in my silverado ss
- "HOW TO" add oil to rear end
- Need help to remove tranny on 99 Camaro Z28 "HOW TO
- Tranny or converter problem....?
- Squeal and vibration when clutch is engaged
- Where to buy new built T56
- TR 6060 tranny..
- Clutch slippage at high rpm?
- 4L60E Bangs into 2nd gear
- Stainless, Titanium, or Aluminum Lug studs????
- Transgo shift kit?
- summit ring and pinions
- Clutch won't bleed, almost no pedal resistance
- Took two yellow springs out of rear end.
- Need response fast??? please look!!!
- Is my TRANS on its WAY OUT!!!
- 93 Lt1 auto tans 1st to 2nd gear have to let off gas
- Six Speeds Inc Transmission question
- More questions about gears
- Torque converter: X2 E 52C what is it?
- Down shift to first
- LS1 SPEC twin disc wont disenguage please help!
- TC lock up problem in 4th gear
- Transmission problems
- a4 to a TH350, how hard?
- New Tranny Speedo reads way high
- 10-Bolt Pinion Seal Question
- Stall on Stock 4l60e
- Tranny Problems
- Transmission ???????
- What years did the Converters change?
- Transmission Issue (1997 Z28, Automatic)
- clutch wil not disengage(mcleod street twin)
- What broke in my th350
- Stuck Clutch Master Cyl. U Bolt....tips?
- Transmission Slipping? Went from shifting perfect to stalling?
- Torque converter swap question
- rear end whine and vibration
- Must i use an Adj. MC with Street Twin?
- Whats a 93 LT1 T56 worth?
- 2nd and 4th gear issues
- t56 hydraulics problem; wont disengage
- New clutch - Bad smell
- How do you check alignment between T56 and Engine?
- How to install short stick
- Fill rear to which hole
- Just how Weak are the 93 T56's?
- m6 tranny rebuilder
- Need help diagnosing rear axle symptoms
- Stall: shift kit or MOT for firmer shifting?
- Clutch for 383 with Aluminum Flywheel?
- tranny swap
- BMR/Spohn swaybar mount kit 12bolt clearance.
- help
- wut gears
- Need torque specs
- d or dd for street use
- What kind of gears?
- Vette 4L60e vs Camaro/Firebird 4L60e?
- Autozone "duralast" clutch kits...
- TH400 soft 2-3 shift
- 6 Speed Manual Spewing Fluid at WOT/High RPM
- Where does this bolt up? Black trans breather tube?
- What kind of tranny and rear end?
- Tranny help!
- pulling my t56
- Mcleod SFI Bellhousing for LT-1
- 2.75 first gear
- Strange s60 or moser 12 bolt??????
- auto over 6speed
- What size are the drain plugs for the T56 and differential?
- Rearend help
- Trans Temp Gauge
- 4.10's for LT1 same as LS1?
- Best place to buy gears?
