PDA
View Full Version : Parts Wanted
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. Driver side motor mount
  2. LT1 Throttle Cable
  3. WTB: F-body brake and clutch pedals and shifter
  4. Air Injection Pipes
  5. Stock Injectors
  6. ISO: Polo green metallic hood.
  7. WTB 95 camaro factory radio
  8. WTB - 00 Firebird Mirror, Console Lid, Radio
  9. WTB - SLP Shorty Headers
  10. WTB 93-97 Camaro/Firebird clutch fork
  11. Wtb 52mm tb for 95 z28 plant
  12. WTB LT1 - 0847 cam
  13. LT1 T56 clutch fork
  14. lt1 upgraded valve springs
  15. WTB: Magnaflow catback for LT1
  16. ewp
  17. Wtb tpis happy hooker
  18. Header install price
  19. WTB 1994/95 PCM with ZZ9 M6 and 3.42
  20. WTB Shon Herron billet alum oil pump drive
  21. ISO long tube headers
  22. Looking for Lt1 camaro performance parts
  23. need 81 rear frame
  24. 3.4 exhaust y pipe needed
  25. Wanted Vortech MaxFlow Cooler aftercooler
  26. WTB LT1 52mm Throttlebody
  27. WTB LT4 Knock Module
  28. Lt1 overflow metal tube.......
  29. WTB Factory Sport Appearance Package (Y3F) front lip pieces
  30. Wtb: 94-95 timing cover
  31. WTB: 93-97 OEM SS Hood
  32. Wtf lt4 knock module
  33. WTB PCM for 94/95 LT1
  34. Wtb LT4 Knock module
  35. Good/New 3rd gear needed for LT1 T56 rebuild
  36. WTB: 4.3L L99 in NJ/PA
  37. Wtb 1995 abs sensor with traction control
  38. Hurst shifter
  39. 93-97 LT1 T56 Trans
  40. lt4 gotcam 1.6 RR
  41. master/slave assembly
  42. Original Copper Carpeted Floor Matts for a 86 Iroc Z28
  43. WTB: GM only AC Delete Pulley
  44. WTB....3.73 Gear and Pinion Set
  45. A/c compressor
  46. WTB: Delteq Coil Jumper
  47. WTB: 93-02 F-Body Sail panel
  48. WTB: 98-02 Camaro fender, bumper & hood
  49. Need a few front trim pieces 93 camaro
  50. Hotcam, LS7 lifters, Opti, Headers, Timing chain, maybe more
  51. Le2 heads
  52. Fuel Sending Unit Needed Please!
  53. WTB LT1 Water Pump Drive Shaft
  54. wtb 24x conversion harness
  55. WTB 1.6 rockers
  56. Need a ECU for a 93
  57. `85 -`90 f-body Borg Warner 9 bolt parts wanted
  58. Anyone have 1 of these?
  59. WTB 1.6 Rockers.....
  60. WTB LT1 T56 Clutch Fork
  61. WTB: '95-'97 Optispark harness
  62. Wtb 3600 stahl converter
  63. LS1 steering shaft
  64. WTB: 93-02 Trans Am Side Skirt, Factory ground effects
  65. Need LT4 knock module.
  66. Looking for ALDL setup!
  67. WTB lt4 hotcam
  68. Looking for coolant tank/battery mount with hose
  69. WTB Shift cable for 4l60e
  70. WTB: AC Delco Optispark
  71. ls1 t56 input shaft and midplate
  72. My list of needed lt1 383 parts!
  73. icm
  74. 94-95 Knock Sensor On Block Anyone ??
  75. Anyone has an 94-95 LT1 OBD1 Knock Sensor Module
  76. WTB: LT1 T56 Clutch/flywheel
  77. Anyone Selling Valve Springs
  78. WTB: 24x conversion stuff/96-97 timing cover
  79. WTB Intake Boot: 95 5.7 LT1
  80. Header
  81. WTB: working LT1 era 4L60e, stock or built, in NJ
  82. needed 95 wiring harness
  83. Vortech discharge pipe
  84. 93-97 front passenger fender
  85. WTB LT1 Aftermarkert Valve Spring
  86. Wtb 95-97 Camaro z28 Coolant Steam Line
  87. Wanted: 2800 - 3200 Stall
  88. Wtb slp shorty headers 96-97 dual cat
  89. LE2 Heads
  90. WTB 93-97 WS6 OEM Hood
  91. Wanted mac mids lt1 94 single cat
  92. LT1 K-Member
  93. 99 visors, shift boot needed
  94. wanted - rear end for 95 z
  95. WTB rear abs sensor
  96. WTB - Bose OEM Door Speaker Amps for '93 Z28
  97. D1SC Procharger LT1 kit for sale
  98. WTB- Power Door Lock Switch '93 Z-28
  99. WTB - Bose OEM Speakers for '93 Z-28
  100. Looking for a lt4 knock module!
  101. Wtb: '94 pcm auto
  102. wtb 1994 drivers side door bezel with pw,pdl controls
  103. WTB T56 Clutch Fork
  104. Wtb: 93-02 camaro firebird front lower control
  105. WTB 36# or 42# Inj. LT1 Plug style
  106. WTB..LT1 rockers and lifters
  107. Wtb lt1 fuel rails
  108. Monoblade Nitrous plate
  109. WTB: Steering Shaft 98-02 Camaro
  110. Roll Bar for Convertible 4th Gen
  111. Fog light for 96 Camaro
  112. Wtb: Factory radio and bezel for 96 Camaro, springs and shocks
  113. E C M for a '93 Camaro manual trans
  114. Looking to buy lower control arms for 95 TA
  115. 96-99 SS wheels (ANY version)
  116. OBDI/LT1 Tuning/Data logging software
  117. WTB: 1995 4L60E trans
  118. SS Hood 96-97 OEM
  119. Injector retaining clips
  120. Wtb ls6 intake
  121. Walbro 255gph hot wire kit
  122. LT1 carburator intake
  123. Ultra Z hood and spoiler
  124. Transmission dip stick for 94 LT-1Camaro
  125. 98-02 ported 80mm or 85mm throttle body
  126. forged rotating assembly lt1
  127. Lt4 knock module 16214681 wanted
  128. WTB: LT1 Wet Nitrous Kit
  129. 1995 z28 Tan Mats Wanted
  130. Tubular A-arms/rear shocks
  131. WTB: 1980 camaro kick panels
  132. 2000 ss
  133. WTB: Adjustable Lower Control Arms
  134. 1993 F-Body LT1 M6 ECM
  135. Selling any working parts off 93 z28 camaro
  136. 1994 LT1 Knock Module
  137. WTB: Stock LS1 Valve Locks - Used is Fine
  138. wtb canton valve covers
  139. WTB: 1.6 Roller Rockers
  140. WTB: Stock MAF w/screen
  141. WTB tunnel mount torque arm w/loop
  142. WTB: Your non working 16188051 PCM
  143. Rear spoiler
  144. LT1 Stock CAM
  145. Wanted: LT1 Parts/ Inj & timing cover
  146. ---96 z28 few odds and ends---
  147. 87 with TPI
  148. Rear cloth seats - gray/black - near MA/NH/CT
  149. 27 or 28 Hoosier QTP
  150. Monoblade Throttlebody
  151. Misc parts..
  152. need 2002 drivers side door handle bezel
  153. Fuel injectors
  154. Any Ultra Z Hoods for sale?
  155. WTB 1994/95 MAC Shorty headers NON A.I.R.
  156. LT4 KM GM#16214681 Delco 216-67
  157. 1995 camaro 4l60e transmission
  158. IAC/Coolant Housing
  159. WTB Orig GM Hurst shifter
  160. d Bumper SD Lower GM Part# 10274366
  161. fuel pump assembly
  162. Le2 heads wanted
  163. WTB: 97 rear abs speed sensor harness
  164. WTB UMI 3PT connector - 1995_LT1
  165. WTB LT1 24x stuff
  166. WTB LT1 PS Y-pipe
  167. WTB C5 Front Brakes
  168. 1998 z28 Brakes and Rotors
  169. Single Cat SLP Headers
  170. Need OBDII to USB to use GaryDougs Software
  171. WTB: 1.6 self aligning roller rockers
  172. Need 43" driveshaft
  173. Wheels
  174. 94 OEM Injectors
  175. WTB stock cam/lifters/dog bones/retainer
  176. In need of wheels
  177. Need rebuilt t56
  178. WTB alternator 94Z28 LT1
  179. wtb/LPE 219 CAM
  180. Wtb: m29 t56 complete
  181. 799 or 243 Head castings
  182. WTB Mid Length Headers
  183. wtb lt1 scanmaster
  184. R/F fender
  185. 1993-1999 horn switch/contacts
  186. Good Headers and/or y-pipe for 1997 camaro lt1
  187. 383/355 rotating parts wanted
  188. Looking for known good opti/distributor
  189. LT1 Performance Parts
  190. wtb lt1 cam
  191. '97 Z28 ABS Control Module OE No. 16220641
  192. WTB: GM LT4 Intake
  193. WTB Aluminum DS for T-56 and 12-bolt combo
  194. Looking for Hurst stick
  195. 98-02 Tail lights Left and Right
  196. 95 v6, A4
  197. WTB: HP Tuner Pro
  198. 1989 Z28 5.7 ECU Chip Wanted
  199. WTB 94 Trans Am skirts
  200. good running LT1
  201. WTB 1997 Camaro PCM
  202. Wheels CCW Classics 17 x 11
  203. wtb race longtubes and y pipe Lt1 camaro
  204. WTB: Throttle Body Cable (1995 LT1)
  205. 1973 Z28 Body Parts Wish-List finding ...
  206. 10 bolt with 4.10s
  207. Viper main shaft
  208. engine oil cooler hose
  209. WTB: ONE Short Head Bolt
  210. OEM Ram Air or Firehawk Hood
  211. LT1 Fuel Sending Unit
  212. dash pad (cover)
  213. Wanted 93-02 Chevy Camaro Convertible Tonneu Cover Boot
  214. Looking for a LT1 f-body Accessory Bracket
  215. Tubular K-Member for stock stearing
  216. Stock Lt1 Cam
  217. emmisions legal headers for a california 95 z28
  218. Manual trani for 95 z28 V8 wanted
  219. Headers for 95 z28
  220. WTB 97 Springs, drivers door. Central NC.
  221. Used motor low Mileage
  222. wtb broken vented optiparks 95-97 lt1
  223. Seat belt guide
  224. LT1 Head Gaskets, Head Bolts, Aluminum Heads
  225. WTB stock batt tray
  226. LT1 diagnostic cable wanted
  227. WTB: K&N Cold Air Intake
  228. Fuel door for 94 Z28
  229. WTB: Ls1 aftermarket fuel rails. Fast?
  230. WTB: 93-02 Fbody driveshaft loop...
  231. ltcc
  232. WTB Moser 12bolt or S60. Killeen Tx
  233. 1995-1997 opti
  234. scanmaster
  235. 93 lt1 pcm
  236. WTB Tan Leather seats 93-97
  237. WTB LT1 blower,blower cam and other LTx parts
  238. procharger lt1 pulley and spacer, new
  239. WTB-OEM TB cover for 95 LT1
  240. Front bumper cover (not stock)
  241. WTB CAI kit for 1997 Camaro 5.7
  242. Torque Converter
  243. Tuning cable for 94 LT1
  244. wheels
  245. need lt1 long block close to Staten island, ny 10314
  246. 93 optispark
  247. 96-97 LT1 Timing Cover
  248. LT1 Engine
  249. wtb Lt1 Shorty headers and ypipe anyone close to 10314
  250. WTB LT4 hot cam anyone close to 10314
