View Full Version : Parts Wanted
- WTB: Slave & Master Cylinders
- WTT: LM + install kit (if needed) + cash for used gmmg/corsa
- WTB LT1 Engine. Blew mine.
- WTB 97 stock intake
- WTB rs body kit for 93+ camaro
- WTB: Optispark Conversion Parts.
- looking for 6 speed
- looking for 94-97 cold air intake and maf
- Need a Low mile LT1 alternator
- Lt4 Production Cam
- 3rd gen front fender
- WTB LH Grid Style tail light - '86 Z28
- Need a 93-95 "rebuildable" car
- longtubes for a '94 Z...
- WTB ten spoke rims , cold air lid , superchip
- {SC} WTB: SLP Zexel-Torsen 3 series posi
- WTB: Lt1 Nitrous/Blower Cam
- WTB: Gm 847 or cc306.
- Looking for Sail Panel Speaker/woofer for LS1 Camaro
- wtb: LS1 f-body
- Wanted: any performance parts for a 00 WS6
- WTB, Hrland Shift Light and LS1 Stock Front Brake Lines
- WANTED: Stock Intake box
- Wanted: 2 chrome zr1/ss wheels
- Steel driveshaft $75
- LT1 Block Needed
- New TPIS ZZ9 Cam and SLP clutch
- 1.6RR non SA
- Need Shock Sensor - 99 TA
- Stock Chrome 94' Trans Am wheels
- Need clutch, fuel pump, 4.10's by 9/30 12pm..
- WTB driveshaft loop
- need a DASH PAD!
- WTB: Line lock
- i need cme tips
- chrome Zo6's
- WTB: Steering box to fit 350 crate on a 75 LT
- WTB: Ram Air Hood
- WTB: Set of 275/17 Tires...
- WTB backing plates
- Looking for a good LT1 block in the chitown area
- 1997 Trans Am Clear tail lights.
- Anybody got a single LT1 head?
- TA Performance Cover
- WTB: Stock 6 speed Rear to fit 98z28
- WTB: Vigilante Converter 3200 or 3600 stall!!
- LT1 Exhaust Manifolds, yes wanted!
- WTB: throwout bearing or MAYBE a clutch
- LT4 Roller Rockers
- LT4 Springs
- I need the molding that goes around the rear window
- WTB: 4 inch exhaust tip
- Throttle Body Plate
- Rally sport wheel trim rings
- WTB: 95 timing cover and 95 opti short harness
- WTB: y-pipe
- WTB: oil pressure sending unit
- WTB: flywheel + driveshaft
- WTB: 3.73's or 4.10's
- WTB: Walbro 255lph fuel pump
- WTB: clutch
- WTT: My T/A for another...
- WTB Shorty Headers
- 12 bolt anyone?
- Wtb....
- superram
- stock tpi fuel rails
- does anyone have a pair of these they wanna sell???
- 98-02 Trans Am Front License Plate Cover?
- Rear Trunk Lid Cover?
- I need a headlight bracket header panel
- Ford 9 inch parts
- Wanted 1LE Front Springs P/N:22132887
- need a 97 T/A ram air hood!!!!
- nitto 555r
- Need an LT1 97 manual transmission
- WTB: LT1 fuel tank canister
- Looking for 87+ Foxbody Mustang or L98 F-Body
- LT1 fuel rail
- WTB:LT's
- 1.6 RR and Springs
- Wtb, nx nitrous accesories
- wtb:march underdrive crank pully
- WTB: LT4 Knock module
- WTB: 4" Cowl hood(bolt on) for 93-97 Camaro
- NEED drivers side A-Arm Part
- Looking for AC controls
- WTB Salad Shooters
- ralley 15 x 8 wheels.
- kick panel screws
- 4l60e to th350-400 swap
- WTB 3500 stall for lt1 4l60e
- Wtt-mw 3200
- ls1 driveshaft and 96 6 speed console
- LT1 Transmission brace
- 1.6 Roller Rockers and Springs for a Hotcam
- WTB: LE2 heads and cam package.
- PCV Tube
- 95 z28 parts wanted
- WTB LS1 ALUMINUM 98-02 DRIVESHAFT (have Cash ready to send)
- WTB: Custom front air dam
- Looking for 3.42 posi rear for ls1 car
- Looking for ls1 black dash
- WTB 98-02 stock taillights
- Trans Am Interior
- 91 camaro parts
- 97+ Center console
- WTB: Need one (1) Enkei Win wheel
- Front leather seats out of a 4th gen.
- Suspension
- Driver side power door actuator
- z06 Clutch Kit/Flywheel
- For Sale Full Built Forged Race T56 6spd Transmission Conversion
- 95 3.4 programmer
- WTB:12Bolt,Injectors,Leather
- Stock Red Hood
- WTB: headers, y-pipe, rear gears
- Sun visors & Headliner
- 98-02 Headlights
- WTB: Heads, Cam, Rockers, Springs, Lifters
- WTB: Cold Air intake and catback
- WTB Air condition compressor
- power antenna mast needed!!!!!!!!!!
- WTB: LT1 Electric Waterpump
- passenger side t top
- WTB: Lower control arm anti-squat brackets.
- WANTED....Radiator for an A4 LT1
- WTB: 98 Camaro Passenger side headlamp and taillights.I dont care about the condition
- WTB: Interior pieces....
- wtb: wet nitrous plate for LT1
- oil pan for 1995 3.4 liter....
- WTB 100% Stock MAF w/ Screen
- Wanted Hood for 1979 camaro
- Wanted Hypertech Powerprogramer for 99'
- WTB: Weld Wheels 3.5 skinnies
- junk throttle body shaft
- 93-97 v6 egr valve
- WTB, LT4 Extreme Duty Timing Chain
- wtb 4l60E tranny
- Camaro Driver Headlight NEEDED!!!!!
- Throttle Body Bolts & Plate
- WTB complete TPI intake setup.
- WTB: 93-97 camaro gauge pod
- WTB: 93-97 Camaro electric passenger door
- Need some LS1 brake parts
- 98+ Trans Am Front Plate Cover
- wtb: ac delete bracket
- LT1 water pump
- WTB- Double Roller for LT1!
- WTB:LT1 in washington st.
- WTB: LT4 Valve covers
- right door lock actuator
- LS1 brake upgrade
- FAILED EMISSIONS... Need Air pump
- WTB Bilstein OR Koni shocks for rear-any condition!
- Upgraded your CD Deck? Willing to Sell your Stock one?
- WTB: LT1 water pump...
- WTB: 3.42 rearend or trade for 3.73 rearend
- WTB: LT1 'bird Ram Air Hood
- Wtb: Headers
- Looking for an LT1 PS pump
- RS emblems for 93+
- slp y pipe
- wtb: LS1 aluminum DS
- WTB: Ebony Driver floor mat
- WTB: body parts for 96 TA
- WTB: LS1 upper radiator support
- WTB lowering springs for LT1
- Wtb:good Or Rebuilt 4l60e
- WTB - 1993 M29 6spd and unmodified LT1 MAF
- WTB: Stock Spare
- Looking for a 98-02 LS1...
- WTB: 93-02 rear bumper cover (preferrably polo green)
- emmision stuff needed
- WTB: Salad shooters and tires
- In need of some 3rd Gen Parts...
- RS grille and hideaway light doors, front bumper, and front wing for 67.
- WTB: What are hte best headers and/or exhaust?
- Hurst shifter for 1995 Z28 T56
- Rims , monsoon , dash pad wanted
- WTB: 245.50.16 Tires
- WTB: Moroso Air Intake and air foil
- 95 Timing Cover vented optispark.
- Need 93-97 TA hood, 98-02 TA taillights ect.
- WTB - 305 / 350 / 400 small block
- Rear Window Louvers Wanted
- 95 formula firebird With the 350 LT1 V8 4 sale
- WTB: 3" inlet exhaust tips
- Need right rear brake caliper for '95 Z28
- Need '93-'97 Camaro driver's headlight assembly
- WTB 1.6 RR's & Timing Chain
- 98 LS1 Z28 or TA
- WTB: 93-96 black front bumper cover
- 93-97 Spec III or IV for T-56
- WTB: Driver Side Taillight Blackout for 95 T/A
- WTB: 2-4 Chrome 17" Factory WS.6 Rims
- 1 connecting rod for LT1
- WTB: M6 Pedal assembly and clutch master cylinder
- WTB new knock module for 97 Z28 LT1
- Need 1 Chrome 10 Spoke Ss
- Any Catback For A 2000 Z28.....
- WTB: ls1 auto shifter parts
- wanted: 94-97 black z28 around maryland
- WTB: LS1 Firebird tail lights
- wtb: sprortline springs
- WTB - ULTRA Z Hood & SS Spoiler for LT1
- Want To Convert From Opti To Coils
- Clutch needed
- WTB: used water pump for CSI install
- WTB: adjustable torque arm
- WTB Hypertech for 2000 3.8
- 2 2000 SS wheels
- Rear Bucket
- WTB- Vented OptiSpark/Cap/Rotor (perferably AC Delco)
- Wanted! 95-98 Z28 Lt1, T/a Lt1 Or Ls1 In The Houston, Tx Area! Must Be 6-spd
- mac ory
- WTB: LS1 engine
- Msd 6al
- Need Window Switch FAST!
- Stock Firebird Rims
- WTB: (2) 18x10 American Racing Torque Thrust II's
- Tons of parts wanted.
- Hood, Rims, Tires
- need 3rd brake light
- WTB: Taillights
- Trany Cooler Lines
- WTB: Roll Cage
- convertor
- need an adjustable panhard bar ASAP
- wanted 315/35/17 nitto D/R's
- WTB: 42# injectors, pistons, rods
- Lookin for SShood/Lt1headers/cats an guage pod
- wtb: 52 or 58mm tb
- WTB Stock cat for a 94 Z28
- Wanted driver side fog light
- WTB:LS1 LT Ceramic Coated Headers, And Wet Nitrous Kit
- 93 Z28
- WTB Silver TA rear bumper cover
- WTB 17" Polished 2000 Vette Wheel
- Looking for: 3" Mufflex Y-pipe with Cats
- slotted aluminum rims
- WTB 245-45-17 tires
- WTB: Passenger door
- lt1 ss hood wanted
- WTB: Stock tranny cooler line
- WTB: 93-97 Camaro dash pad
- Looking for 98+ T-Top M6 SS
- WTB: Autometer Cobalt OR C2 gauges
- WTB: Trick Flow LT1 intake elbow
- dk grey camaro door panels
