View Full Version : Parts Wanted
- Wanted: LT1 A4 to T56 conversion..All parts
- 4.3L LT1 crank wanted
- Anything for a 97Z
- 93-97 Camaro tail light panel
- wtb: Weld Pro Stars
- WTB 10 spoke ss wheels
- Basic Parts needed
- WTB LS1 Rear End
- WTB 93-96 tail lights
- ss 10 spoke rims
- newer style ss spoiler for 94 z28
- lowering springs for 97 t/a
- WTB: 4th Gen Leather Seats
- Weather stripping for 3rd gen
- Need a 4L60E...
- WTB: dash pad for 95 camaro
- Need 4.8 crank and rods!!!
- peice that goes around shifter
- I Need A Passenge Door For A 2000 Camaro
- WTB: Electric LT1 Waterpump NIB or Used in good condition
- i need a 3.42 carrier
- Transmission parts
- SLP Y Pipe
- Power hatch motor for 94z
- WTB/WTT: Firebird/Formula front and rear (LT1 style)
- low oil light sensor
- I need a LT1 94-97 MAF and complete stock LS1 airbox
- Looking for 4 18" chrome rims for a 1996 z28
- '00+ M6 camaro console and air box
- need 28" dr's or et streets/slicks
- WTB: Rear Lip for center tips
- Dash pad wanted for 93 camaro
- wtb fog lights
- 94 t56 Harness
- 3 Series Carrier Posi Unit
- looking for a granatelli Lt1 MAF
- WTT: Chrome Halo's for Stock Headlights
- 1LE Elbow
- wtb:pw/pdl switch panel
- Looking for 93-97 Firebird/Trans Am parts
- contrl arms
- WTB 2 salad shooters
- 4th Gen CIA
- WTB: 4th gen front seats
- WTB NEW LT4 intake
- new rearend anybody? 12bolt/9"?
- Wanted: Scanmaster for '94LT1
- WTB: (4) 17" Wheels
- PUT the dog thread back up!!!
- Wanted MBA products
- I'm needing a lot of parts
- WTB: ONE (1) Silver ZR1/SS Wheel
- WTB 93-97 SLP Ultra Z ram air hood
- cowl induction hood for 3rd gen
- WTB: trans shift cable for LT1
- IROC Wheel Needed
- Steering Wheel Radio Controls
- Y Pipe
- looking for a LT1 K&N conicle filter
- Need the bird on the bumber for the LT1 Firebird
- (2) 315/35 17's needed...
- Need wiper linkage splined post for '95 Z
- Need: '93-'97 Camaro headlight brackets
- WTB: 97&up Trans am bezel to go over gauge overlays
- WTB Carbon N20 Bottle
- WTB Aftermarket Valvetrain 1.6 RR/Springs/ Etc.
- WTB stock Z-28 RIM
- WTB 93-02 Trans am 97+Camaro T-top Windshield pillars in Graphite.
- Aluminum Drums
- Shroud
- wanted fresh LT1
- Clutch kit for 94 v6
- WTB: backing plates
- Wanted:: N20 WINDOW switch and MSD ignition!!!
- WTB: One 18" Chrome Z06 rim
- looking for 98 up front brake setup
- wtb engine wire harness
- WTB rear bumper light for drivers side ASAP for 94Z28
- WTB 2 Y2k C5 chrome rims
- WTB:Chrome Salade Shooter w/caps
- Need a Weather Sheild or NOAH Car Cover for 1995 Camaro...
- WTB dual cat y-pipe!
- Looking to swap a 4L60E for a T56
- interior pieces
- Black rear seats
- need a few items
- WTB: Eibach Prokit Springs
- need a front sway bar
- 20" ADR Sterling Chrome w/ tires for TT2's with drags
- Trade Clear Tailights for Stock
- exhaust flange
- mac style off road pipe
- WTB 98+ Taillights for Camaro
- Flowmaster
- GM 847 cam!!!!
- Intermediate shaft off 96 Camaro steering column
- Spohn Torque arm.
- suspension stuff
- WTB: MAF Housing, Intake Elbow
- WTB: 96-97 RS front air dam
- Need center mounted exhaust
- O2 sims
- WTB: LT1 Clutch ASAP
- dipstick & tube
- wtb: monsoon/delco headunit (1997-2003)
- WTB: LS1, LT1, LS6, Cams and Cranks
- WTB: Comp 918 Springs
- Ground Effects Rocker Panel
- Want some cheap 16's or 17's.
- WTB: 42#SVO,72,or 75# injectors for LT1
- WTB: Door panel
- WTB: Third Gen T-5 V8 tranny
- WTB: 95 Timing Chain Cover.
- WTB: 1.6 Roller Rockers
- oil pan and tranny
- 91 Leather Seats
- need header's lt,or mids for 94 z
- 1994 Z28 Needs Alarm Remote
- 93-02 Firebird/Trans Am bumper
- 98+ Front Spindles
- Wanted:6-spd Lower Shift Boot
- WTB: SLP CAI For 94Z28 & Underdrive Pulley
- WTB: 3.42 Rear end
- Stock SS Hood for a 95'
- *wanted: Stock Ss Wheels*
- stock y-pipe
- 4l60e needed
- WTB: 918 springs
- cc306
- WTB 96-97 y-pipe
- WTB- 95 fuel rails
- WTB: complete T-56 set up for LT-1
- 93-97 Camaro BODY KIT
- Wanted lt1 02 sensor extenders
- WTB: 1994 Camaro Z28 A4 PCM!
- WTB - Center Console with compartment cover still intact
- need wiring harness and air tubes for 00-02 TA seats
- WTB: 3Inch Y pipe for Longtube headers
- Hooker Catback Wanted
- WTB: Stock LT1 Throttle Bodies
- WTB LT1 T/A front bumper cover
- WTB 95 F bod engine harness A4
- wanted t5 flywheel
- WTB: Starter
- WTB Ebony Camaro Interior
- WTB: Long Tubes and matching y pipe
- trans am driver's window switch
- Need driver side front fender liner
- WTB Stock LT1 MAF
- WTB: 97+ Camaro Tan Leather Seat Covers
- WTB: T56 Bellhousing 93-97
- WTB- Headlight trim and interior piece
- WTB/WTT Sub and box
- looking for '00 Firebird black sunvisors
- Looking for Neutral Interior, possible trade.
- Looking for a set of AFR 210 or 220s
- WTB: 02 sims, door speaker, used tires...
- Need a Stock Antenna...
- low coolant censor and intake elbow
- ZR1 center caps, painted
- 94 or 95 LT1 Engine wiring harness
- WTB: Aftermarket Throttle Body
- wtb: aftermarket cd
- WTB or BORROW 96-97 air pump devices for smog ASAP
- 15x3.5 or 15x4
- 17X9 5 Spoke Chrome ZR1 Type SS Wheels
- WTB stock manual driver's seat slider/bracket assembly
- Want Whole T-56(lt-1) Conv Kit
- 1.6 Pro-Mag NSA 7/16" rockers - 7/16" studs - LT4 ED timing set
- WTB: Non-working/Dead Vented Optispark asap
- need 3/8 crane RR adjusting nuts
- WTB: Drivers side front turn signal 93-.97 camaro
- WTB: True Duals for Jet Hot Long Tubes.
- wtb: 4.10's
- Camaro Graphite leather door panels
- WTB: Hooker Y Pipe.
- GM 847 cam
- Dipstick for 3.4
- Firebird/TA Window Switch
- WTB: LT1 SLP intake PP heads
- WTB: Borla
- Center caps for formula rims.
- WTB: ls1 4l60e tranny please.
- need thermostat housing fot a lt 1
- WTB: Drag launch springs
- WTB: Stock 10bolt-TA Cover- w/ 4:10s....
- WTB: Camaro Stuff
- WTB 17" SS 5 spoke rims (not chrome)
- WTB: Low mileage EGR valve from LT1 M6 car
- need a 52mm throtle body quick got one?
- Skinnies
- WTB MAF ends 19978 LT1
- 98+ FireBird/Trans Am Parts needed
- Wtb: Lt1 Driveshaft
- Shift Kit!!!
- WTB: SS style or Ultra Z hood
- WTB: Used LT1 heads
- WTB: 30th anniversary wheels
- WTB/WTT: Dark Grey / Graphite interior
- WTB 93 LT-1 A4 engine harness
- LS1 Block
- WTB: Rear Tail Panel
- WTB: ZR1/SS wheels
- WTB: shocks
- WTB: chrome Y2K corvette front rim
- suspension parts wanted
- Wtb: Complete Ls1 Engine
- LT1 heads wanted, bare/stock
- WTB: Chrome Y2K C5 center caps
- Wtb: Lt1 Loudmouth
- Wanted: 4" catback system
- 93-02 Trans Am PAssenger Door and/or Front Fender
- LT1 heads-- Complete
- WTB: stock p/s pump for 94z28
- Wiper motor connector needed - 4th gen
- where can i get a bare 350 block
- want to buy a cam only
- WTB: 1998-2002 Camaro HEADLIGHTS or HALOS
- WTB: AC Bracket for 96 3.8 Firebird
- WTB: LT-1 Radiator
- WTB: double timing chain (low miles preferred)
- WTB: TH350 converter
- Need 95' LT1 Vented Opti
- 6SPD Shifter boot and Plastic ring
- Looking to buy a lt1 motor
- Need Recalibration Box
- WTB: LS1 Motor with Acc. & Harness
- shift boot and mounting plate wanted
- '85-86 V-groove/Serp combo Pulleys
- DipStick
- WTB fender and spindle
- Wtb 93-97-camaro Ss Hood
- Aluminum Drums
- Shroud
- Ls1 And Accessories Complete, Running Or Not!!!
- Jl audio sub + Stealth box (also looking for other subs).
- Right Rear Quarter Panel
- Passenger side interior door panel
- Grey non t-top headliner?
- OEM 94 LT1 Cam
- Need 94-97 Fuel Rails
- anyone parting out a convertible?
- LT1 clutch slave cylinder ASAP
- Meziere LT1 water pumps... not working
- WTB Seats in OH
- I need a glove box latch!!
- Water pump wanted Elec, or otherwise...
- Need Rear Impact Bar 82-92
