View Full Version : Parts Wanted
- WTB: stock 22# injectors
- WTB trans cooler for A4
- need a cam and waterpump
- 1993 LT1 computer A4
- wtb: opti
- Want T56...trade or purchase
- need a cross member from a 93-97 automatic lt1
- WTB: Hooker Cat Back
- Shorty Ls1 Headers
- WTB: Long Tube headers for 94 LT1 Camaro
- WTB Morosso or K&N Cold Air Intake
- Need LS1 DriveShaft
- 42 Lb Hr Fuel Injectors Needed
- 1 3/4 Longtube Headers Needed
- 58 Mm Throttle Body Needed
- Flowmaster X-pipe NEEDED
- 3.73 Ring Gear And Pinion Needed
- Need Vigalante Or Yank 3600 Stall Torque Converter
- walbro 340 fuel pump NEEDED
- Comp Pro Mag 1.6 Rocker Arms For 7/16 Stud Needed
- Comp R lifters NEEDED
- GM hi-tech pushrods needed
- need GM bolt and gasket kit
- WTB:LT-1 heads
- WTB: SLP headers or...???
- Wanted PERFORMANCE HEADERS
- looking for low mileage 3.4
- WTB: o2 extensions
- WTB: 94-96 Bose CD player
- looking for hood,bumper,drivers fender in pewter for ls1 camaro
- WTB - Headers/X-pipe or H-pipe/cat back
- Stock LT-1 Throttle Bodies
- Wanted: 93-97 Ss Hood
- 1LE elbow needed!
- 95-97 opti harness
- wtb: vfn 2" cowl hood
- Need lots of parts guys. Please help :)
- LT1 M6 flywheel
- I Need A 98-02 Ss Spoiler A.s.a.p.
- Looking for 98-02 Firebird/TA driver fender
- pass side taillight blackout
- WTB: LS1 & LS6 Intake Manifolds
- i need a t56
- t56 conversion
- WTB Wolfe 6 Point Roll Bar
- Must have soon. T56 in ny area
- wtb-cai for lt1/v6
- i need weld prostars 16"
- WTB m6 center console insert for 94z.
- wtb moser 9" housing and axles for 4 chanel abs
- WTB Directional
- Stealth Box
- Need rear quarter panel for stealthbox
- WTB: LT1 Block
- White Camaro Passenger Door Needed for 94Z
- WTB: Universal dry nitrous system
- WTB LT1 rear brake setup
- 92 TPI supercharger kit
- WTB LT1 block
- Wtb: 99-00 Ls1 Pcm
- WTB: LT4 intake
- 98-02 camaro headlight bracket
- WTB: 93-97 Firebird Fender
- '93 Z28 M6 Starter
- I need one 16" chrome Trans Am wheel
- 3.42 Rear end
- Need parts for my 01 Camaro 3.8L
- WTB 15x10 w/7.5 bs drag wheels
- WTT: My K&N FIPK and Trickflow Elbow for....
- WTB: 2 17' wheels
- LS6 intake
- WTB: T-56 conversion
- Frame ties, OBD II scanner, Window motor
- Need LT1 rear disc brakes
- In need of exhaust parts...
- plastic piece running along floor??
- water pump & timing kit + wish list
- WTB Hooker LT's
- A/C delete pulley and belt tensioner for 93 LT1
- WTB LT1 58MM TB, Comp R Lifters
- WTB: MAF Translator
- WTB LS1 Brake Conversion for LT1
- WTB Jet-Hot Y-Pipe
- WTB: MSD rpm pill
- WTB: single ZR1 rim 17x9.5 - any condition!
- looking for a fender 98-02
- wtb: 93 Camaro upper dash
- Door hinges and Dash pad needed
- Wtb: Ls1 Maf
- WTB: Rear Hatch Bose System with amp
- Need to buy head coolant lines & smog stuff
- Wanted to buy. vette lt valvecovers and rail
- Passenger window motor for 95 z
- where the hell can i get a 95 timing cover and a stock TA catback!!!!
- 93-02 z28 black and grey seats
- WTB: N.O.S. 10lb bottle
- Need a good LT1 Harmonic balancer (Stock) 93 - 97
- 93-97 TA/Firebird REAR Bumper!!
- WTB lt1 block
- WTD: 1 Eagle Alloy 077 18x8 rim
- wtb: passenger taillight lens and center lens w/ Trans Am logo
- WTB - Delteq System for LT1
- Looking for 96-97 RS / 98-02 Sport Appearance Rear Spoiler
- TPI Runner and TB Air Foil
- WTB: ABR100T Audiobahn bass boost remote
- WTB: Hooker or Jet-Hot longtubes
- i need complete front end
- wtb: cingular cell phone
- Wtb Bbk Y-pipe
- gauge cluster
- looking for 10 bolt rear end for 1995 formula
- WANTED : ASP Underdrive Crank Pulley (LS1)
- few parts wanted
- 93-97 DS Camaro Door
- NEED 1 tail light blackout
- wtb: Hooker Catback
- Looking for two Cat. converters.
- Wtb Obdi Pcm
- Want to buy torque covnerter and a cam
- WTB: Neede ASAP 1993-97 TA front clip and parts
- 1LE Springs
- Looking for a new trans casing 4L60E
- wtb ultra z hood grill
- LT1 LT headers
- WTB: LS1 Intake Manifolds
- wtb axle shaft for traction control rear end
- WTB: 1994 LT1 6spd PCM
- 98-02 slp loudmouth???
- WTB: 96-97 ram air hood "nostril screens"
- stock exhaust tips and ls headlight motor
- 91-92 Rocker panel Emblems
- cd changer
- 350 trans long tail ext housing
- Fuel line needed for 94 LT1 Firebird
- WTB: aftermarket hood (SS, ram air) for 96 Z28
- horn/steering wheel
- looking for red z28 rocker panel emblems
- Need Fuel Line O-Ring/Bushing for 2.8
- Need Stock fuel rails and lines.
- WTB centerforce flywheel 700173
- !!NEED!! Oil Dipstick Tube !!
- 2 18"x10.5" chrome zo6 rims
- electric water pump
- 3.8l 5 speed.. v6 cluster
- WTB 6spd center console
- Parts I need for a 93
- Need 4 Inch Mufflex For Camaro
- Wtb: 97 Z28 Lt1 Headers!!
- WTB LS1 spindles
- wanted cd player for a 1994 camaro
- WTB: 99 LS1 valve covers
- Looking for good LT1 block
- Torq Thrust II 17x9.5 & 17x11 or similar
- Looking for LTCC kit
- Need front RS or other brand ground effect 93-97
- decal
- WTB- 2 CHROME Y2K C5 wheels
- WTT: 4L60E <--> T56 Transmission Swap
- looking for 4th gen WS6 center caps.
- LT1 K-member and spindles.
- One A/C vent for 4gen firebird
- ls1 brake upgrade and lt4 cam (open to others)
- WTB: '88 Camaro Armrests in Black
- Wtb:gauges
- WTB: 28 spline axels
- 93-02 Trans Am Ground Effects (door)
- WTB: LT1 Short Block
- WTB: Wings West side skirts for 98 T/A
- WTB rear brakes
- WTB 95-97 LT-1 water pump
- WTB A/C delete pully for 93 LT1
- WTB: LT1 T56 swap setup near Ontario, Canada
- 17" Chrome Firehawk Rims
- IAC Valve
- Electric Cutout / Dump WANTED
- Camaro Tail Panel
- need a driverside headlight assembly
- Looking for mechanic!
- Lt1 1994-1997
- hood and body kit
- WTB 1993 LT1 Auto computer
- chrome lug covers
- wtb: impala ss head gaskets, timing cover gaskets, intake gaskets
- 3000 stall lockup converter 95 lt1 4l60e
- WTB: Seat belt (drivers) for 92 Camaro RS
- WTB: Ebony Sunvisors...
- WTB: ASAP! 94' M6 Wiring harness
- parting out 1995 z28 camaro
- WTB - Rims and Tires (Chicago)
- Center Console Lid to fit 98 Camaro
- WTB: 97-98 Fuel Rail Covers FRC
- Lookiong for a LS6 Intake manifold.
- Wtb: 95-97 Opti Harness!!!
- custom front bumper???/
- Looking for an LT1 t-56
- WTB 4th gen power antenna mounting bezel and seal
- NEED ASAP: Driver side t-tops
- Looking for Jet Stage 2 chip for '01 V6 Camaro
- I need a fan switch for '01 V6 Camaro
- WTB:LT1 to LS1 Front Brake Conversion
- Wtb/speedster Tonneau Cover
- WTB: 6 speed console insert for 97 'bird.
- stock ls1 exhaust tips
- WTB: LT1 ASP Crank Pulley - E-WP
- WTB: LS1 aluminum driveshaft
- WTB : MAC headers and y pipe
- Wanted: SS Hood and Spoiler
- WANTED COLD AIR INTAKE FOR 94-97 Camaro Z28 pref near or in NJ
- WTB: 17"x11" rims - any condition
- Need dash pad for 93 Z28
- Need 1 chrome salad shooter...
- LT1 MAF needed
- WTB: Silver 98-02 Firebird Hood
- looking for 98-02 front body parts
- looking for a catback
- I need a SLP air lid.
- I need headers for my 2001 Camaro V6 3.8
- wtb LS1 T56/Manual Transmission setup
- WTB predator for 2000 camaro ss
- WTF 3rd gen carbon fiber body panels
- WTB: Center Console Lid
- WTB: LT4 Pressure Plate
- stock 4th gen exhaust
- WTB: T56 Pro 5.0 shifter & 94-97 LT1 T56 starter.
- wtb: dr.gas x-pipe
- WTB: Front A Pillars In Grey
- WANTED:3K stall converter
- WTB: 3.73 for 2 series carrier.
- WTB: 97 T/A Cat Converters (dual)
- Console, seatbelts, & door panels
- WTB LT1 Steering Rack
- WTB: Stock 16" 5 stars
- WTB: gears
- I Want Your Slp Clamps
- Autometer Gauges
- Wanted: 1 Weld Draglite, 15 x 8 5 inch backspace 4 3/4 bolt circle.
- 93-97 chrome radiator shroud
- WTB- Guage Cluster for a 96 Trans Am
- Need a Catback!
- WTB LT4 heads and intake and SS hood
- Camaro Bose Cd Player 94-96
- WTB: 98-02 SS Spoiler in white
- wtb: 3.4l to LT1 conversion parts (- engine and tranny)
- WTB clutch
- WTB Front Ground Effects
- I need headers for a 2001 V6 Camaro..
- M6 wiring harness for a 94'or 95' LT1
- NEED a 1g BOV) flange
- Wtb: 275-40-zr18 Tires
- Wtb!!!! Lt1 Headers And Comp Cam 305
