View Full Version : Parts Wanted
- Body stuff for a 1996 Camaro.
- wtb: 2 black zr1 rims
- SLP 1 3/4 headers for 3rd gen
- wtb/wtt Zo6 wheels/ possibly Zr1's
- Wanted: 1998 z28 gauge cluster
- WTB - 91/92 Blister Hood & High Rise Spoiler
- WANTED.....Stock leather shift knob for 2000 Z28
- Wanted: LTCC and wiring
- WTB: low mileage fuel injectors
- Wanted: 93-97 Wings West W-Type kit
- stock lt1 clutch pressure plate & flywheel
- WTB: Interior parts.
- WTB: Keyless remote module & wiring
- WANTED: Cold air intake.
- Wanted: Passenger Mirror
- Wanted: Coated Headers
- Wanted: Chrome Rims
- RR's and keyless entry
- 98-02 Driver and Pass Headlights
- LT1 Block
- ALTERNATOR - ATL, Ga
- Wanted: SBC Heads
- Stock Parts wanted Inside please.
- WTB bolts that hold jack & spare tire to the car
- WANTED: Bilstein or Tokico Shocks
- Wanted: Pair of LS1 Camaro headlights...
- Cam needed
- WTB LT1 performance parts
- 30-34lbs injectors
- wtb holley stealth ram
- injectors 30+
- rack and pinion
- WTB, 1994 m6 engine harness
- alernator plug in
- WTB: Stock CD player for 93 Formula (Delco)
- Need a rearend for my 00 SS Please HELP!!!!!!!!
- MCLEOD Slave cylinder
- Wanted- a couple of things for 88 iroc
- 1 or 2 ws6 wheels 01-02 speedline style
- 30th annv. leather seat????
- Looking for a 93-2002 6-speed trans x-member
- wanted: passenger front fender for 93-97 TA or firebird
- WTB 92 Z28 High Rise Spoiler w/ 3rd Brake Light
- Looking for exhaust for 3rd gen. Camaro.....
- WTB Mac off-road pipe, 93-95 single cat type
- egr Solenoid and vaccum lines!
- WAnted Wheels 18/17's z06's chrome
- WTB LS1 and T56 Tranny
- WTB- March or ASP Pulleys
- Electric water pump and 1.7rr LT1
- WTB: Driver side ls1 spindle
- fs. new lt1 ported heads
- WTB: opti wire harness and brass bleed screw
- WTB: Stock TB **CHEAP**
- 52-58mm TB
- wtb: front headlight springs (2) and headlight adjustment bracket (1)
- Third Gen Backing Plates Needed
- WTB: Cylinder #2 Accel Wire
- WTB Aftermarket Air Dam Delfector ....WingsWest/RKSport etc etc MUST FIND ASAP!!!!
- WTB: (2) 275/40/17 Tires
- WTB: 35-38# injectors
- WTB: 94-96 Camaro 150mph cluster
- WTB OBD1 LT1 harness and ecu
- WTB: LT Headers
- anyone parting with their ssra?
- LT1:Want to trade some self alinging 1.6 Roller rocker for 1.6 non-alingning rockers
- WTB SSBrake lines
- Looking for 18" tires
- WTB:1993 LT1 ignition modules
- Need an LT1 computer
- WTB: Seatbelt guides
- BMR Lower A arms 93-97 f-body
- drivers side manual window triange trim part
- wtb: seatbelt loop(attached to seat) and drivers side manual window inside triangle
- ls1 front brakes
- WTB: Dash pieces 93-96
- Wtb: 96-97 58mm Tb
- WTB: 1994-ish Trans Am TAN Trunk/Speaker Panels
- Anybody have a stock LT1 dipstick???
- WTB: shifter, sfc, stb, rims, emblems
- Wtb: Lt1 94-97 Cai
- I need an LT4 KM ASAP
- I need a stock LS1 F-body clutch master cylinder with hose.
- 1996 Trans Am Headlight Assembly
- {SC} WTB: LT1 REAR calipers, complete
- Need a Pass Door and Fender
- keyless entry
- WTB: LT1 Edit OBDII
- WTB: EGR solenoid.
- WTB: Stock LT1 starter
- Need Supercharger
- NEED 02 Extension Wire
- I need a Y pipe for manifolds (93-95 LT1)
- WTB: Driver and Passenger door Mirrors
- Wanted: Hard intake pipe for vortech SC
- aftermarket cd player & speakers
- WANTED: 12 bolt or 9 inch for 95 camaro
- One 5-Spoke Chrome 16x8
- limited slip
- WTB: Rear 21mm sway bar
- Looking for a supercharger for LT1
- Looking to buy complete supercharger or turbocharger kit for my 1996 Z28
- Need LT1 PCM Harness.
- 93-97 instrument cluster...speedo v6
- Wanted suncoast creations Air box!!
- WTB: 96-97 SS rear Spoiler
- Power Drive Accessories
- WTB LT1 cooling fans
- WTB: Power window motor
- Wanted to buy bare LT1 blocks around Nebraska
- ATI P1SC or s or T Trim Aftercooled
- SS Air Box '93-'97
- WTB: Lou's Short Stick for Pro 5.0
- Anyone got an a/c setup lyin around
- WTB: Transmission for a 95 Camaro, 3.4L, Auto
- Need M6 or 95 4l60e
- WTB. Y-pipe
- Ford 9" spool
- intake elbow and front speaker
- Looking for a 96 SLP loudmouth cheap.
- WTB: LT1 Gas Pedal
- WTB: LT1 Clutch/Flywheel
- power window motors
- wtb-shocks
- WTB Chrome Firehawk Rims
- 93 rubber air intake elbow
- Need Longtubes!!
- wtb-overlays
- Water pump for my 87
- 93 LT1 fuel rails
- Center exhaust tips wanted for SRT-4
- WTB: M6 center console for 94 Z
- WTB: rubber lower shift boot for 94 Z
- WTB: Headers in the Houston Area
- 93 and later Upper Cloth Seat Cover or Seat Needed....
- WTB:A4 Lt1 trans
- Looking for Chevy center caps for rims....
- !!32-42# injectors, adj. LCA's, and relos!!
- wtb-58mm tb
- Looking for 94 Z28 speedo cluster
- Old Porcelin Signs (Gas & Oil)
- 1993 Lt1 Ecm
- WTB- Non bose cd radio for 95 z28!
- Third Gen Weatherstripping
- 58mm tb
- looking for magnaflow catback 93-97
- WTB:Y-pipe for Hooker LT's
- Wanted power seat track
- F.A.S.T. ECU for LT-1
- WTB: '98+ T/A Honeycomb Tails
- WTB: MSD DIS-4 w/ coil interface units
- WTB short/longblock
- WTB: Exhaust Tips
- WTB:: Stock 98 MAF
- WTB: Front Caliper Bracket
- coolant overflow tank
- Need USED stock clutch,flywheel,slave,master cylinder,shifter
- WTB: LT1 200 amp alternator
- WTB: SLP 3.5" Slash Cut Tips (from loudmouth)
- Need ONE PASSENGER'S SIDE GTS BLACKOUT
- WTB: LS1 M6 center console
- WTB: 4th gen 3.42 posi rear end
- WTB: Bare SBC or LT1 block in Seattle area
- M6 Crossmember Needed
- WTB: 93-97 Trans AM front bumper cover - beat up is OK
- cai
- Torque Arm Mount - T56
- cai wanted
- Warbird hood or other for 93-97 TA
- WTB stock LT1 Rear Brake Calipers/Rotors for Conversion!
- 1 spare wheel wanted
- WTB TA Rear end girdle
- WTB OBD1 pcm
- WTB: Power steering line
- CompCams 212/218 XE roller grind
- wtb 94 tail light driver side
- WTB lt1 wiring harness a4
- wtb pass side lt1 fender
- 98-up Dark Grey Cons0le Needed.......
- WTB: M6 shifter plate/insert for 94 z28.
- wtb: 98+ Camaro Passenger dash airbag cover
- WANTED-T56 related parts
- I need an engine wiring harness from a '94 M6 car!!
- Camaro Parts
- *NEED* 94-97 T56 clutch hydrualics
- looking for a set of lt1 injectors
- GM Weatherstripping, for a third gen.
- WTB: 93-96 Camaro radio bezel & 93-96 6-speed shift plate
- Wanted:Ebony Leather Trans Am seats
- Need 1969 Z28 badges
- offroad y pipe
- WTB: 7" crank pulley
- Wanted L98 Longblock
- wtb or trade cai
- WTB OEM Black WS6 LT1 hood
- WTB : 4th gen sunvisors
- WTB: LT1 Supercharger
- WTB: 98+ front calipers, baskets and bolts !
- WTB 98+ power window/lock controls
- WTB- Low mileage A/C compressor and ABS unit
- wtb: lt1 plug wires
- WTB Camaro SS rims & tires who has them ??
- 95-97 vented opti
- Need Gears and a Posi Unit
- WTB: Hooker Aerochamber Muffler/Catback
- WTB complete LT1, trans, wiring harness
- front wingswest piece
- Parts for a 1976 Monte Carlo
- 18 by 9 inch Mille Miglia MM 2 rims needed (two)
- vented opti, opti harness, comp r's,
- wtb holley 58mm
- need ground effects air dam
- LS1 coil packs
- WTB- Tuning setup for a 97Z. (datamaster)
- wtb- triple pillar pod
- 12 bolt
- M6 Crossmember
- wtb- lt1 oil cooler
- WTB: GM 847 Cam, Springs, Rockers
- 700r4
- WTB: SS Spoiler
- 98+ front lip wanted
- WTB: 98+ LS1 Firebird Formula front clip
- Need a set of SBC 2 pc seal main caps
- WTB- Everything needed for a4 to t56 conv in a 94 Z
- Need rear cloth seat bottom....
- 1999 camaro v6 3.8l owners manual
- WANTED: cheap FMU
- Wtb Headers For 99z28
- 3 piece spoiler for 93-97 Camaro WANTED
- WTB: '97 Front driver-side speaker
- Moroso fabricated centerbolt valve covers
- WTB: 2 rims
- High Capacity/High Flow Radiator
- Set (4) BMR Springs
- WTB - 9" or 12 Bolt
- I need a nonworking vented opti
- need eagle 077 rim
- Shocks,lca, Adjustable Panhard, Relocation Brackets
- Looking for a Trim Ring
- need a 10 bolt 28 spline 3 series open carrier
- 68' Camaro Rear End
- need a 52 mm throttlebody
- Comp Pro Magnum SA 1.6rr for 7/16" stud
- WTB: Passenger side t top 98 camaro
- In need of complete a/c system out of camaro or trans am LT1
- Wanted: Passenger side engine mount that bolts to K-member for LT1
- WTB 93-96 instrument cluster harness/plug
