View Full Version : Parts Wanted
- block
- WTB Front Bumper cover for '97 Camaro
- Wanted t56 input shaft
- Low coolant sensor too
- WTB:Front Marker/Signal...
- Aftermarket Y-Pipe LT1
- WTB:93-96 Camaro front seat trim
- Wtb: Hot Cam Kit
- wtb-rear adjustable shocks
- wtb-pillar pod
- wtb 4.10's for 96 ws6/ o2 sims
- WTB: LT1 Front Rotors
- Window Motor
- WTB 94+ tb
- Transmisson
- Need SFC ASAP
- Wtb Oil Cooler Lines For 92 Z28 350
- WTB left fender and lugnuts and caps
- Good valve shrings 600 lift
- WTB: 93-97 Prokit
- MBA black pontiac crest shift knob
- Headers
- WTB: LT1 rear calipers
- WTB: 98-02 OEM Chromes / SLP or Borla Cat-back system
- Double Roller timing set
- wtb: lt4 intake manifold
- WTB: 1 used tire to fit a 17 x 9 rim
- WTB cheap 10 bolt posi units
- wtb: LS1 Camaro M6 center console
- Charcoal grey sun visor needed
- factory rubber exhaust hangers
- 93-96 upper dash pad
- one z06 wheel...
- WTB: Pulley Puller
- WTB: Torque Thrust II's, Hot Cam Kit, Honeycomb taillights.
- WTB: 1LE or similar elbow
- wtb-18" tires
- WTB Rear End
- $1500 to put in the 00 T/A Ls1
- Winter Rims for my 94 Z28
- aluminum drivesahft and 12 bolt
- WTB LS1 SS Spoiler
- WTB:t top shades
- WTB 3.42 or 3.23 gears
- WTB manual steering box for 2nd gen
- Leather Seats
- WTB: 93-97 Pro-kit
- WTB: vortec lt1 elbow or other metal 90' elbow for nozzle mounteing my wet system!
- WTB: LT1 Fuel Rail (94-97)
- WTB: Black 98-02 OEM WS6 TA Hood
- I need a few LS1 things... T/A wiring for seats. rear shocks ash tray lid.
- 160 degree stat
- SLP "FlowPac" wanted
- lt1 pacesetter y pipe for LT
- WTB Steel driveshaft
- Zexel Pinion Shaft
- WTB: Convertable Switch Wiring Harness
- WTB: Twin Intercooler setup
- WTB: opti, some seals, amd misc stuff
- Need Lt1-lt4 Fuel Rail/injector Clips
- WTB Ported heads and intake for a 396
- Turbo kit
- seats
- wtb right fender '00 ta
- WTB:chrome SS 10 spokes
- WTB 96/97 OBDII pcm
- NEED TO BUY!!head/cam gaskets. hooker LT's,
- WTB Electrix water pump and valve locks for stock springs
- WTB: 96 and up 3.8 w/auto tranny/harness/pcm "low mileage" 30-70k
- WTB: 97'ish Firebird Folder. ( Not Owners Manual Folder )
- wTB stock air box for 95 firebird in D/fw TX
- 97 Camaro Fog Lites
- T-Top Shades
- wtb-1 or 2 lt1 alum heads
- Wtb front e-brake cable
- front end bumper assembly
- Need front turn signals for 1998 z28.
- anyone have a 355 block for sale - old generation??
- looking for an SS spoiler and rims
- WTB emission tube and fitting
- Retained Power Accessory Module
- still looking for a hood..
- WTB NOW - Main A/C hose for 95 LT1 (attaches to compressor)
- 94-96 Gauge Cluster Wanted
- Stealth Ram
- Wtb: Msd 6al
- looking for a stock MAF for LT1
- wtb:o2 sims for 01 ls1
- looking for a carbed intake for a LT1
- Y Pipe for long tubes
- WTB Complete Ls1
- I need a cut out plate
- 98+ camaro headlight brackets
- WTB: SS Wing
- headliner 94 t-top z28
- WTB: gm 4.10 gears
- LT1 Heads
- WTB stock LT1 heads
- Steering Wheel Radio Controls
- Need a 95 LT1 timing cover
- Looking for 3rd gen fog lights
- Front Glass! I need an orginal windshield - LOF
- Th 350
- WTB: Long tubes and matching Y-pipe 4 LT1
- '93 6 speed
- WTB: Stock 4th gen catalytic converter
- WTB : Pushrods
- Firebird Honeycomb tailights
- oem car cover
- WTB lowering springs
- 98-02 front end piece's
- intake elbow
- WTB: Fender Passenger Side
- Forged Shortblock for lt1
- WTB: Exhaust valve
- WTB: Driveshaft Saftey Loop
- WTB: Sticky Tires
- WTB: LS1 or LPE driveshaft
- WTB: Stock 93 F-body chip
- Wtb/wtt Slp Cai - Lt1
- Want - Front License Plate Frame
- Wolfe Bolt In 6 Pt. Roll Bar
- Tan Interior
- Torque Arm Bracket
- LT1 balancer hub
- Rear sway bar
- LS1 Low Mileage Lifter
- WTB: LS1 Brakes
- WTB: LS1 Brakes
- WTB: Stock 5 (or 10) Spoke wheels
- WTB: Cable to go from laptop to OBD1
- Headers..!!!
- Stock Cd Player
- I need coil connectors from wiring harness for Lt1
- Wanted:93-94 OPTISPARK
- lug nut covers
- WTB: clutch disk
- WTB 94-97 stock intake tube
- Adjustable Fuel Pressure Regulator for 95 camaro
- NEED: EGR block off for LS1
- WTB: LT1 Short/longblock
- WTB: Non Power Driver Side Slider
- Wings West Front Fascia Air Dam
- Need A tranny for a 3.8 97 firebird Auto
- hurst or pro 5.0 shifter and interior...etc
- What i need.............
- WTB: AirFoil! Cheap! Preferibly Used
- WTB: stock driveshaft for 96 TA
- Front Shocks T/A
- NEED 16 POLYLOCKS! For CRANE GOLDS!
- Wanted: Complete black interior for third gen
- WTB: 94-95 Camaro Keyless Entry Master Remote
- Possibly need a lifter retainer(spider)
- LT1 heads or a single heads
- WTB 1LE or Stock springs
- Wanted 93-97 Driver Side Headlamp Motor
- WTB: LT4 roller rocker
- 90-92 z28 Spoiler
- WTB 4th gen f bod thrd brake light
- remote oil cooler.
- I NEED a set of LT1 cooling fans
- Two OEM ss 10-spoke aluminum wheels
- lt4 KM
- WTB 16" Drag Radials
- WTB: Stock M6 T56 Shifter, Stock z28 swaybars, Stock salad shooters(w/ tires if poss)
- white firebird passenger side fender 98-02!!!
- Purge kit
- WTB: LT1 aluminum elbow
- WTB Good IAC for 97 LT1
- WTB: Electric Cutout
- a4 to m6 conversion
- NEED 1.6 RR's! Comp Cam, Crane Gold, any! New or Used!!
- WTB: 12" Stealthbox
- Needed - Graphite Leather Drivers Seat Or Replacement Cover
- 10 bolt 3 series carrier
- WTB: Jacks, Stands, and Air Compressor
- Wanted: Reluctor/CPS ring for 96 LT1.
- Wanted: Torque Thrust ll
- LS1 t56 bellhousing and bolts
- WTB: High Flow Heads
- lt1 t56
- anyone have a hood?
- WTB: 1LE Front Springs
- Wanted MBA products
- salad shooters
- WTB: Adj. Suspension parts...
- WTB: Optima Battery...
- WTB: Fuel Rail Covers...
- 6" Vortech crank pulley
- Need this
- Exhaust (cat-back)
- NEED: 275/40/17 Tire
- nitrious
- Driver side tail light for 1997 Camaro
- Used LT coated headers w/ Y 97 !emissions
- WTB: 98+ interior pieces
- 4 bolt main rear seal adapter
- Need a dipstick for a 94 V6 !!
- WTB: Roller Rockers (S/A 3.8stud 1.6ratio)
- Oil Dip Stick , I need it badddddddddddddddddddddddddddddd!
- cd player
- side mirrors
- Need Opti spark ASAP!
- Rear seat parts.
- 1995 Z-28 wheel
- WTB: Torque Converter for my 97....
- rims
- T-5 Wanted
- Borla or Corsa
- WTB- Mcleod Twin-disc master-cyliner
- wtb trans crossmember
- Need 87+ tpi intake
- WTB: Stock MAF
- 96 T/A Window Sweep
- wanted lowering springs and 17" wheels for 93 and up f-body
- ISO: LUGS! Need 20 lugs with cap threads
- NEED LT4 KNOCK MODULE! Where to buy?
- Wtb weld racing pro star rims
- WTB: Lou's SS for Hurst shifter
- Need center console!!
- wtb 265-35-18s drag radial perferred but not needed
- Need Headers
- Need LT4 Valve Springs!
- tpi dual fans
- Any Catback!!!
- WTB: obd1 a4 pcm
- wtb: zr18s
- LT1 MAF screen
- WTB- fbody car cover
- One 16" Chrome 5-Spoke Rim
- WTB stock 2 bolt LT1 main cap.
- Passenger Side Rocker Ground EFX
- vizage side skirts and /or firebird/TA ground effects
- WTB: Hooker Longtube Y Pipe.
- 3.8 exhaust
- 98+ oem or aftermarket ground effects
- Need guages for my guage pod
- Needing a LT Y-pipe and cat back, WILL TRADE FOR TRUE DUALS!
- WTB stock cd changer for f-body
- WTB: 98+ RS ground effects
- comp cam 224/230, springs lifters etc.
- WTB: Adjustable Fuel Pressure Regulator
- LT Headers and ypipe
- wtb mid length headers
- LT1 intake manifold
- WTB: Floor mats
- stall converter
- WTB: 1999 LS1 stock exhaust manifolds
- WTB: 93+ Z28 fender emblem>
