View Full Version : Parts Wanted
- WTB: 12 bolt
- LT1 sensors and TA seat needed
- t56 parts needed
- WTB: Charcoal Grey Leather seats 94Z
- WTB: `95 LT1 Timing Chain Cover, stock LCAs
- WTB: Z28 Emblems
- W.T.B. Plastic chrome lugnut covers
- Camaro or Bird Seats
- WTB Global West Upper Control Arms
- WTB: Individual 10 spoke SS wheels (1,2 or 3) "undamaged"
- looking
- wtb center console 97+ firebird
- Needed OBD1 MAF A4 Wiring harness
- wanted intake & slicks
- 98+ ss spoiler
- LT1 or 383 short block
- I need SIDE TRIM for a 93-02 Trans Am!!!!...........
- 99-2002 Z28/SS (or firebird equivalent) rear brake parts
- WTB:pass. side fender 98 & up Camaro any color
- WTB: 4th gen 10 Bolt Rear
- wtb: 1 chrome zr1 17x9.5 56mm
- 26inX4X15 front runner (drag) tires
- parts wanted for trans am
- looking for a spohn torque arm without crossmember mount
- WTB 30th anniv camaro floor mats and
- Engine
- looking for lt4 heads
- WTB: Comp 1.6 NSA Roller Rockers
- OBD-I ALDL cable
- WTB: Z28 emblems
- WTB: 10-spoke SS wheels
- WTB 4 275-40-17's
- Looking for CAI
- 98-02 Honeycomb Tailights for TransAm
- want to buy sfc, and cai
- WTB-91/92 Non-AC heater control panel
- Need Multi-port '88 2.8 Complete Motor
- T-tops
- WTB: stock LT1 4L60E Torque Converter
- WTB: 2001 Camaro Trunk Hooks/latches
- WTB T Bar roof interior
- o2 simmulators
- WTB Posi
- Ram Air hood
- Looking for a stock LS-1 bellow
- wtb: lt-1 shortblock/longblock/complete
- Throttle bodies
- WTB: "camaro" filler panel
- 18" tires needed..
- Needed (1) 35th SS wheel
- WTB: F-body tail housing 1998+ 6 bolt type
- WTB: Endurex lifters or Crowler lifters for a LT1
- 95Z Shorty header set/exhaust manifolds
- Ebony Interior Pieces Needed & Complete Ebony Seatbelt Set
- ss hood
- Wtb: 98+ Gray Leather Rear Trans Am Seats !
- 1st gen ac stuff, and transmission
- WTB: 1994-1995 A4 Harness
- wtb 98+ SS wing
- lca relocation brackets
- tail light panel so i can do berger
- 1996 4l60e
- WTB: '96 Z Engine Harness/PCM (must be a 4l60e car)
- 98-02 rear camaro blackouts
- WTB M6 conversion
- wtb: 93 stock speakers
- lt1 starter for my 95 z28
- Complete superfueler setup
- T/A Front Bumper Cover 93-97
- WTB for 96-97 trans ams
- 1LE or stock Front Lower Control Arms
- A Pillar 2 Gauge Pod Wanted for 93-97
- Used Eibach Springs for 93-97 Z28
- wtb 1.6rr
- wtb 94-95 lt1 ecm and wiring harness
- Need 1 chrome y2k c5 vette wheel
- 1995 Timing Chain Cover
- Harmonic damper needed ASAP
- Hurst Competition Plus Shifter
- wtb
- rear disc brakes
- need seats and carpet for 93 camaro
- manual seat bracket needed
- WTB: LS1 WS-6 Ram Air Box...
- Need n20 and Subframes/lcas
- WTB Race seats
- WTB: LT1 WS6 air box
- need ASAP stock aluminum rims with tires
- WTB: 1.6 Ratio T&D Shaftmount Rockers #2310
- 1.6 rr
- LT-1 Leather seats
- 95 LT1 parts PCM, MAF, starter, etc Atlanta Ga
- 17" wheels
- 3.73 gears
- WTB 4L60E F Body tail shaft housing
- foglight, ss hood, bumper cover, C5-6 wheels
- Need LT1 Injectors
- WTB: '98-'02 performance parts
- TTop Shades
- WTT: M6 Setup to A4 Conversion
- WTB: 1997 Interior Stuff
- WTB: 93-02 Power Antenna Assembly...
- WTB: 4th gen Camaro interior parts...
- parts for LT1 card conversion
- WTB Pro 5.0 normal length stick
- 15x8-10 wheels for slicks
- Dash pad
- WTB: 36-37# fuel injectors
- WTB off road y pipe for a dual cat car
- WTB oil dipstick
- WTB: LT4 Valvecovers
- WTB: "EBONY" rear leather Trans Am seats
- Need a Flywheel
- WTB: 30TA rim
- Need Torque arm mount for T56.
- Wtb Cai
- Need a Pirelli P7000 275/35/18
- bottle warmer ....
- Lt1 or TPI
- WTB Wheels & Tires for 94 pickup.
- lt1 motor
- WANTED!! suspension upgrades
- body and peformance needed
- Manual Window Regulators
- LT's and Y-pipe
- cowl hood for lt1 camaro
- 1.5 ratio pro mag NSA on a 7/16 stud
- Leather seats wanted!!!!!!!!!
- wanted weld draglites 15x8 or 15x10
- WTB: Stock Trans Am parts
- Power steering pump hoses and reservoir
- Tonneau cover
- Ltb Hotcam Kit
- need a set or rim
- Need a 52mm TB!!!!
- need a 10 bolt 342 or higher rear for lt1 car
- 94-97 LT1 cai
- WTB: Coin holder for '02 console
- Looking for rims...
- WTB - black dash pad for 95 z28
- intake bellow for a 95 LT1 Z28
- Wanted cc305 cam or equivelent
- Body Parts Wanted 98-02
- WTB: LS1 Intake Manifolds
- Wanted, stock 10 bolt
- LT1 wiring harness, uncut for T-56
- Spark plug wire loom for 95 camaro
- 245/50r/16 Nitto 555r drag radials wanted!!!!!!
- WTB taillight covers for 97 TA
- i am screwed need help!!!!!
- Wanted: LT1 clutch
- WTB - LT1 Aluminum heads
- LT1 engine wanted!
- wanted mba billet z28 camaro hood inserts
- loudmouth adater for 94 lt1
- LT1/LS1 hatch trim pieces
- 98+ black SS hood and black leather seats
- WTB: lt1 fuel pressure gauge...
- WTB: Timing Cover and oil pan
- WTT: my 233/239 or 224/230 for your gm847
- WTB LT4 hotcam and LT4 springs new or used
- Need Broken 95-97 Opti for Delteq use
- looking for nx nitrous kit
- WTB: wheels in Michigan
- WTB:Long Tubes and Matching Y-pipe
- Lookin for a Radiator support bar/assembly.
- WTB: Perofrmance TQ Converter 700R4/4l60E
- Looking for price On a 1994 Z28 Canero 350 LT1 Unmolested ECU
- Pacesetter longtubes
- CAI for my Z
- WANTED : MBA Products for Trans AM
- Bilstein Ultra Performance Springs
- Ls1 Wiring Harness
- EGR Block off plates
- SLP or performance air lid
- Help on 2 tone seat cover......
- WTB:95 Opti Vent Lines
- 17 or 18's Z06 Wheels and Tires or? wanted
- wtb- 1.6 roller rockers
- wtb 93-97 CAMARO parts near michigan!
- A4 tranny lines ....
- WTB: 245/50/16 Tires
- 93-97 TA fog light asm. needed
- Looking for a power antenna
- Dash Pad for lt1
- Need ring for shifter boot on lt1 6 speed.
- 3.73
- GM factory SS hood and spoiler
- Stock catalytic converter 93-95 LT1
- WTB: Delco O2 sensors
- WTB: LT1 Stall
- ls1 brakes
- looking for LT1 cowl hood
- Shifter (B&M or Hurst or TCI)
- WTB- Lots of LT1 and LS1 Parts!!!
- WTB Harmonic balancer hub
- Y pipe w/Cat
- WTB: LT1 Tranny 4L60E
- Head lamp housing panel Plastic
- WTB: MSD 6A or 6AL and Driveshaft
- Need A pillars for 93-96 TTop car
- engine and suspension parts wanted
- WTT:LT1 block for junk LT1 heads
- 95 dowel pin needed... needed for 95+opti
- WTB: Early style SLP headers for LT1
- headlight motors for a 95 trans am
- Need as many LS1 intakes with no egr, but not LS6 ones, just LS1 Intakes, i can get
- Plugs for foglights - 98 Camaro Z28
- Looking For 2 Ss Wheels For 01 Ss
- Looking to buy 30th ann. White seats
- WTB: LT1 T/A fog light assembly
- opti for 94
- Camaro 6-speed shifter boot and plastic wring
- WTB: Wheels
- WTB: 2002 owner's manual
- wtb rear lower control arms and spohn torque arm
- Need 4th gen Sun Visors
- W.T.B.-Aluminum Driveshaft
- Looking for mba billet z28 hood inserts..
- strut tower brace.....LT1 stuff
- new or used front and rear brake pads, calipers...
- 93-96 Tail Light assembly
- silver 17x11 zr1
- lt4 knock module
- WTB: Mac header
- 1998+ Front Body Kit Piece
- need a low mile 94 opti
- head light motors for a 95 trans am
- 4 gen Trans AM/Formula tail lights + filler panel
- lsd rear end
- Need LS1 rear brake kit
- Looking to buy pro 5.0 for 98 t/a
- WTB: Belltech 2" dropped spindles for 3rd gen
- ASAP! Divertor Valve for 89 Firebird
- looking for spohn driveshaft for lt1
- WTB: newer o2 sensors
- Wtb Firebird Parts..
- 1997-2000 auto console insert
- WTB: Forged Pistons
- Anyone out there selling LE2 heads?
- WTB an OBD2 plug
- Wtb Stock 96 Camaro Manifolds
- ws6 ram air intake kit.....
- center console, cd player, side trim, rear bumper cover, fog lights, etc.
- windshield wiper motor
- WTB- Stock Driveshaft and Torque Arm
- k&n fipk intake
- Looking for front accesories: brackets, alt, powersterring and starter
- Wanna swap tranny's 1 for 1? A4 for M6?
