View Full Version : Parts Wanted
- 93-97 LT1 dipstick tube....
- Wtb: Left 93-97 Front Turnsignal Lens Firebird
- WTB LS1 T56 core, broken or whatever
- need drag radials
- ls1tail lights harrness
- WTB: Strong rear
- 1le elbow for vented opti ---
- Hood for 99 Camaro
- wanted
- lt1 6 speed
- Radiator
- WTB: LT1 Heads - 643/374 Casting
- Vortech Mondo Bypass valve/Oil pan
- WTB: 2 16x8 ZR1s, Steering Wheel, Pro Kit
- wib lt1 perfromance heads
- WTB chrome ss wheels!
- WTB-WTT black A-pillars for 93-96 Camaro
- Cheap LT1 TB needed
- 94-97 stock LT1 Z28 or Vette cam
- window regulator & mirror
- WTB Driver's Side Door 98-02 Trans Am
- WTB: Vaccum Canister/Optispark Harness
- Wtb: Slp Dual/dual Catback
- Need 2 Lunati Street Race Rods
- CHEAP Wheels/Tires
- few misc parts
- junk t56 or front case
- LT1 Crossover pipe bolts
- WTB Charcoal/Graphite T Top Shades 94 Trasam
- Manual Conversion
- tb hose
- 94 M6 shifter boot.
- Hood & Nose needed
- wtb Long Tube headers.
- WTB 1993 drivers side AIR tube.
- dust cover for t56
- Wtb Lt1 Head Gaskets
- 8 1.6 Pro Mags 7/16th
- WTB: Stock LT4 rocker studs and locks
- WTB: front speakers
- FT:LT1 Exhaust/Headers/Flowmaster Muffler
- WTB: T56, for LT1 MD-DE-PA-NO. VA area
- 1994 Camaro Z28 Trunk fold down
- WTB: (2) 97-02 Automatic Center Consoles and (1) Automatic Shifter and cable
- Steering Wheel
- Catalytic converter for lt1 with RK sport or ASM headers
- 98-02 trans am electric door panels
- exhaust manifolds and pipe flanges
- WTB: stock 10 bolt posi
- 93-97 SS Hood (CASH IN HAND)
- Dust cover
- Plastic Pieces around air dam
- Alt relocation bracket
- WTB: Tuner Cats for OBD2
- iat grommet, torque arm bolts
- WTB: SLP lid or CAI. (LS1)
- rubber intake elbow adapters
- Stock LT1 hydraulic roller lifter
- 1994 Camaro Z28 Exhaust Tips
- driver's side TA headlight motor- any condition
- 93-02 firebird interior trim parts
- LT1 top end gasket set
- LT1 Retainers/Keepers
- LS1/T56 combo
- 93-97 rear brakes
- untouched LT1 aluminum heads
- Need ls1 parking brake cables
- Wtb:Stock LT1 fuel lines & brake lines!!!
- window motor
- WTB: Ported LT-1 heads
- Heads for a S/C 383 stroker
- water pump
- Ceramic Coated headers
- 93-97 Camaro SS Hood wanted
- WTB 98 or 99 AT Radiator ASAP
- WTB: 93-97 WS6 Ram Air Hood
- WTB: 30/36lbs Injectors
- headers
- window regulator
- Looking for nice sun visors for a 96 Camaro
- fender brackets & taillight harness
- WTB '99-'02 SS spoiler
- LT1 Supercharger.
- Looking for a 98+ dash, complete Firebird or Camaro
- Accessory Bracket
- Replacement Clutch
- I need an ss for my 96
- WTB: Aftermarket License Plate Bracket?
- Camaro SS Floormats Neutral Color
- Looking for motor
- hotcam kit wanted
- Drag radials - 325/50-15 or 275/40-17
- Wtb Vortec Super Charger
- Engine Parts & LTs Wanted
- y-pipe, striaght pipe, cut-out
- K&N Filter for 93-97 WS6 air box
- wtb relocation brackets for lower control arms
- wtb clutch master and slave cylinder asap
- Need some 94 firebird parts
- et drags
- Got a Cheap LS1 console?
- BLACK seats, carpet, door panels, msd
- need center console and iroc fog light
- Master Cylinder ASAP!!!
- wtb: Good brake booster
- Wanted: Gauge Cluster Bezel
- WTB Underdrive Pully
- stock tb
- Rear Needed
- OBD2 to OBD1 PCM Swap
- gt 67 turbo
- WTB: t-top headliner , ASAP!
- Wtb: Ud Pulley, Ll, Zr1's, 52mm Tb
- wtb linelock
- wanted: LT1 engine cradle and driveshaft
- WTB LT1 Nitrous Wet Kit
- WTB: Wheels/Rims (TX)
- Looking for Prostars!
- Mint upper dash pad & 6 speed console
- WTB: LS1 pullout (NJ,PA,MD,DE,CT,NY)
- WTD-->82-92 T5 shifte trim
- WTB: Complete 10 bolt
- need ls1 lower airbox, leather rear seats, etc.
- Stock oem WS6 ram air 96/97 TA
- WTB: 1LE intake elbow and a/c delete pulley
- traction needs
- Bilstein Shocks
- 87 Iroc Rim In Atl Georgia
- LT1 Parts, cam, rockers, ARP studs, head bolts, etc.
- 97-2002 Tail Lights
- Lt1 T56
- Block
- intake elbows
- WTB: Black/Grey 93-02 Camaro Interior Panels...
- Harmonic ballencer, oil pan, and opti spark cap
- Ac Needed Asap
- Headers wanted
- 1995 Timing cover
- Tires needed
- WTB: Stock LT1 MAF sensor
- Ls1 Intake lid
- New Cc306, Cc918 Springs, Lt4 Timing Set
- WTB: LT1 Fuel Pump Pulley
- lookin for a chrome molly cage: 95 bird t-top
- WTB: LT1 K member
- WTB: Hotchkis LT1 STB
- Need two front seats!
- need first genertion 350 block
- 17x9 wheels
- WTB: 4 used 17x9(9.5) Camaro/Vette rims
- WTB - 8 comp cams 7/16 - 1.52 rockers
- WTB: ZO6 or TT2 wheels
- wtb: MAF Sensor
- LT1 WS6 Hose that connects from throttle body to the maf sensor/airbox
- wtb powerdyne
- wtb 1.6 rrs
- wtb 1.6 rrs(self aligning)
- WTB: LT1 Block
- WTB: 98+ Ultra Z hood
- I need a cheap set of longtubes.
- WTB 2 American Racing TT II'S 17X11 for 96 z28
- WTB T56 Inspection Cover
- WTB cat
- 68 camaro ac evaporator box
- wtt or wtb 6speed swap
- harness and pcm LT1
- Wanted 93-96 firebird A pillar
- wtb: rims
- wtb:obd1 lt1 engine and tranny harness for a4
- I need this part underneath the front bumper(pics inside)
- wtb qa1 shocks with 300 springs
- Shift Knob
- **2nd Gen Z28 parts***
- supercharger install parts needed
- License plate holder, front bumper for 93-97 Camaro,Aeromotive fuelpressure regulator
- Radiator core support
- 93-97 T/A Black Front Bumper
- 95 LT1 Timing Cover
- WTB LT1 T56 Bellhousing and pedals needed ASAP
- 12 rib crank pulley for d1
- 4th Gen Wheels
- SVO 30lb injectors
- WTB:LT1 stock rubber intake bellows
- WTB LT1 Edit, obd2 cable
- Lt1
- WTB: LT1 T/A Tail Lights
- Opti vaccum hose
- WTB Fuel Rail
- Looking for Hot Cam Kit
- Borla Catback for 95' TA single Cat
- Optispark Harness Connector
- WTB 42lb injectors
- lt1 engine and 6speed
- WTB LS6 Intake
- WTB: Weld 15x10 w/7.5 back space
- fully functional valve hieght micrometer
- Need 96 Wiring Harness/misc. stuff
- 94 camaro rear hatch speaker grill?
- WTB 3.42 GM Gears
- 350 block
- Wanted--Lots Of Bolt Ons For LT1
- WTB - 58 MM throttle body: LT1
- Control Arm
- TPI Corvette valve covers.
- Trick flow or Vortech TB elbow
- T-top headliner & sun visors!!
- I need a 3000-4000 stall & some 3.73-4.56 gears
- WTB: scanmaster for LT1
- looking for ls1 dash part
- Used Pacsetter long tubes and/or ypipe
- Lowering Springs
- Firebird Windows
- wtb stock tips
- Need a few parts PM ME!!!
- Cluster
- WTB Factory Hurst Shifter...
- LT1 Supercharger
- 93-97 TA rear raised spoiler wanted
- stock 10 bolt with gears
- Looking for stock CD player
- Wheels
- Vented Opti, harness and Timing Cover.
- Radiator, radiator fans, and MAF for LT1 M6
- wanted 4th gen rear disc brakes
- WTB: LT4 Hot Cam kit
- 1985-92 iroc-z, z28 fog lights
- WTB:93+ camaro STOCK rear end
- need a 3.4l
- loudmouth
- WTB used Optispark working or not working...
- injectors
- WTB LT1 lifter spyder, and retaining bars
- 95+ opti check valve
- Looking for 93-97 rear calipers and ebrake cables... Thanks....
- WTB ttop holsters
- WTB: LT1 Upgrade Fuel System
- Wtb-4l60e 95-97
- WTB: LT1 Power Steering fluid reservoir
- WTB: Grey pillar post
- looking for heads
- WTB: Throttle cable for 93-97 LT1
- Parking brake cable
- lt1 Shortblock in michigan
- Camaro emblem on front bumber
- WTB: 58mm or 54mm throttle body
- 98-02 ultra z hood
- Looking for 2"lowering kit and used tires for 99.
- WTB:LT1/LT4 Composite valve covers
- Rear speaker/spare tire cover PLEASE!!!
