View Full Version : Parts Wanted
- Distributor wanted
- wtb short or mid length headers
- 94-97 LT1 stock front Springs needed asap!
- 69 Z Holley DZ Carb Restoration
- 1999 z28 sail panel
- lt4 knock module
- WTB 18x9 wheels - 50mm offset - 4th gen - set of 4
- WTB: Good Working Condition Optispark (Preferrably Stock)
- need a good 4 gen rear close to 10314
- WTB Mcleod LT1 Bellhousing
- WTB - 15 x 8 or 15 x 10 Weld Pro stars
- Need LS spare tire
- WTB: Alcoas 17x9.5, looking for 2 of them
- WTB. FUEL Rails for LT1
- Pacesetter y pipe
- Stock LT1 Drivetrain + more
- WTB fittings for oil pressure sending unit
- A.I.R tubing from exhaust manifold
- Wtb ported heads, ported intake and throttle body.
- LE3's or equivalent - LT1 383
- need inside door handle bezels (lh and rh)
- Looking for C5 325mm front brake rotors...
- 1.6 roller rockers lt
- WTB: Stock Air Box
- does anyone have a 3.23 rear close to zip 10314
- LT1 rear differential
- WTB 93-97 TRANS AM Fenders (pair)
- WTB Throttle Body Elbow 93-97 LT1
- WTB Pro 5.0 or MGW Shifter for T56 93-02
- WTB: Vacuum Pump
- WTB Spohn adjustable LCAs for 95 T/A
- Lt1 vortech supercharger parts
- Lt4 knock module
- 97 SS SLP ram air box
- BBK 58mm TB Wanted
- wtb lt4 valves
- wtb CAI, Slp preferred
- Air tubes
- wtb: LT4 Hotcam kit
- gmmg exhaust
- WTB new or used 11101 - A1000 FUEL PUMP
- AC hoses (1995)
- 1996-2002 SS exhaust
- DRAGG | Oxnard Police Department | 1979 Z28 | PARTS NEEDED | TAX DEDUCTABLE!
- side glass
- WTB Clutch Kit-95 lt1 camaro
- 2000 Z28 B4C car. Starting 6.0 build. Need lots of parts
- 1997 lt1
- Racing Seats
- Like finding bigfoot...
- 1997 4l60e VSS pigtail
- Lt4 hot cam and accessories.
- mabbco
- looking for a rebuilt stock lt1 short block in de
- 12 bolt Differential Wanted
- 1996 Camaro Z28 Rear Right Quater
- 95 camaro z28 stock manifolds and y pipe
- WTB: WS6 rear springs
- 1986 gas tank
- WTB: 93-96 passenger front speaker/amp (bose)
- Parts Wanted: 97-02 Camaro Leather Seats & Camaro SS Wheels
- WTB 93-02 Camaro Seats
- looking for convertible parts
- Want to say hi, and looking for a few things
- Front Bumper and Fenders
- WTB 12550719 cruise control cable
- 1980's / 90's hydraulic reservoir gasket
- WTB shifter ring for m6
- ls1 intake manifold
- long tubes and tubular K member WANTED!
- WTB: 97 Timing Cover
- Front RS ground effect 93-97
- lt1 cylinder heads
- LT1 knock module
- WTB FLP Headers
- 79 z28 grill emblem...wanted
- WTB Hood Liner for 93-97 Firebird
- WTB Aluminum driveshaft for 9" and 17x11 chrome ZR1
- F-body LS1 Power Steering Pump Assembly
- WTB: Stock parts for a 1996 Z28 M6
- WTB: 96 z28 stock shift lever
- Front Bumper
- WTB eibach drag launch springs
- cme exhaust
- Edlebrock 7107 Intake
- WTB 12-bolt for 95 F-body
- 3.73 gears
- stall converter
- LE1 setup
- WTB chrome 17X9 ZR1 wheels
- lf 94 stock pass exhaust manifold
- 93-97 long tubes
- ls6 intake or fast90/92/102 or typhoon 96 intake
- WTB: Red Front Bumper for a 93-97 Camaro
- 97 Z28 parts
- Wanted PCM 32 pin connectors (blue/black) 95 LT1 PCM
- Tachometer Camaro 1986
- Wtb rear side panels 4th gen
- WTB! 3.42 or 3.23 ring and pinion ASAP
- Silver 17x9 5 spoke AFS SS rim
- WTB good LT1 shortblock
- wtb lt1 383 rotating assembly
- Wtb lq9
- WTB SLP WS6 or Firehawk hood 93-97
- Comp 306 or similar
- 4L60e coolant line
- 97 Camaro SS Replica Rim
- WTT: Vigilante 2800 9" multi-disc stall convertor for t56
- WTB LT1 rear brakes
- WTB Dash pad for 95 TA
- WTB BBK 52mm TB, 95-97
- WTB ISO Single Plane Intake for LT1
- lt1 ss parts
- Salad Shooter Rim
- slp lid and ls1 front spindles and lt1 ws6 bellows
- (GA) need late model ABS CPU, wiring and pump
- Trans am gauge cluster bulbs and sockets
- AAM Axle cover
- WTB 98-02 firebird 16x8 chrome rims
- Eibach pro fronts only 95 Z28
- Need parts 1898 Z28
- 1998 Trans AM Visor's
- 95 Camaro Black Lighter Bezel
- Ws6 badge
- WTB 95 Camaro 6 speed Ecu
- ISO: LT1 PCM Connectors (Bench flash) & AN28F512E Chips From 94-95 PCM & JUNK PCMS
- Need a front bumper cover for 80 Z28
- need a power steering pump pulley 94 z28
- WTB low mile front hub/ bearings LT1
- WTB 1993-97 LT1 Engine Mount METRIC (LH & RH) Bolts
- Ls1 pcm
- WTB shorty headers
- WTB 94-97 camaro or Trans am 150mph Cluster ?
- WTB: ALDU1 and CABL2
- Driveshaft for a 93
- LT1 255 lph fuel pump
- WTB LT1 EWP, line lock kit, LT1 alt relocation bracket, racing seats, Pro stars,
- WTB LT1 OBD2 Timing Cover
- WTB: long tubes for LT1
- '95 F-Body Hub
- Wtb dash pad for 96 Trans Am
- lt1 carb intake
- LT-1 Fuel Rails with welded -AN fittings
- WTB 98-02 camaro light covers
- Car Seat Anchor for 1995 Camaro
- 1997 Z28 parts
- WTB - 93-97 Borla Catback
- Need stock rear )only want housing )
- Seats!!!
- [wtb] fourth gen ebony sun visors or sun visor bracket
- [wtb] fourth gen air dam
- P/S pressure n return lines LT1
- Fig light
- WTB A Kent Moore Tool
- WTB 93-96 V6 rear springs
- E Brake cable Brackets on rear housing for 93-97
- WTB SLP TCS Logic Module
- WTB: Black AMW catch can
- ls6 intake needed ASAP
- bose cd player
- Steering column parts
- t56 bellhousing
- Wtb Stock 93-02 Black plastic lug nut cover
- 96 Timimg Cover!
- WTB shell of a firebird, need rear panels to be great, front can be damaged
- 94 Camaro Stock Exhaust or Catalytic Converter
- Parts to "Unmod" my car
- SS Hood Air Intake
- 2000 Camaro 3.8L EGR Tube
- WTB: Ported Aluminum Heads
- Otvc kit lt1
- 3200 stall for th400 LT1 10.75 bolt pattern
- wtb ls1 f body auto trans aluminum drive shaft
- 93-97 firebird quater panel - drivers side
- WTB 93-97 set of z28 emblems
- the grocery list ;) for my 1994 Z28 LT1
- 1997 trans am instrument cluster
- Headlight control module
- 97 trans am instrument cluster needed
- 95 lt1 Alternator
- WTB, ((2)) 17x11 SATIN ZR1 rims :-)
- SLP Speedometer calibration unit Part #63007
- Need Motor Wireing Harness- LT-1 Automatic
- Procharger 93-97 lt1
- Need Power Door Lock Plugs
- Looking for used struts!
- Cigarette lighter bezel
- WTB LE2 Heads LT1
- WTB: LT1 water pump drive gear/shaft
- Wanted fuel tank vent valve!!
- Looking for a Hood (Ultra Z/ Harwood/SS)
- wtb: lt4 hotcam,cc305,cc502 or crane 227 cam
- Does anyone have their stock AIR pump components lying around?
- Slp 63011 fan switch
- WTB- Fuel pump sending unit for 94'LT1 Fbody
- Need a 98 Instrument cluster
- Driver's side rear side market for TA
- LT1 off road y pipe
- Valvetrain parts
- Pass side motor mount lt1
- Looking for a good opti 95 lt1
- WTB: Three (3) Milodon P/N 81150 Windage Tray Mounting Main Studs.
- Z28 emblems
- WTB D585 truck coils
- wtb: 96-97 f-body crank hub
- WTB: CC503 Cam
- valve springs
- Looking for dash pad cover for 94 Camaro
- Non Vented Opti GM only
- WTB: SS Style Hood
- Your optispark sitting on the shelf - NJ
- Looking for these items:
- WTB lt1 stock valve covers in Brandon Fla
- GM A/C Delete Pulley
- 1.6 Roller Rockers & Exhaust system
- 1994 Camaro V8 catalytic converter
- Need a 4L60E transmission
- SLP lid
- WTB lt1 heads
- WTB Longtubes for 94 Z28
- Front Bumper and Fenders ***RED***
- 4th gen entire door
- Rear End Needed!!!
- WTB Passenger grid style tail light
- 97 lt1 heater coolant hose
- WTB West Wing Body Kit
- wtb lt1 a/c compressor
- WTB 1996-1997 LT1 Wiring Harness
- WTB 4th Gen P/S Mirror Bracket
- aftermarket springs/shocks side markers/turn signal housings
- LS1 driveshaft n LT1 accy bracket
- WTB: Rear End Girdle for a 7.5 10 bolt 01 camaro ss
- Wtb/wtt
- 93-02 Camaro Graphite Carpet
- WTB: 97 Camaro Gauge Cluster
- WTB LS1 and T56
- WTB: One (1) stock rim for 1995 Z-28
- wtb: lt4 knock module
- Water pump drive coupler
- Cracked bell housing
- 2000 convertible tonneau cover
- 98-02 SS Hood
- WTB: Exhaust tips, 3.5" slant cut
- LS1 Intake
- Wtb
- 96 Z28 Leather Seat
- WTB: Timing cover for 96-97 LT1
- cc306
- WTB: Spohn torque arm for 94 Z28
