View Full Version : Parts Wanted
- 94 A4 Ecm
- WTB: SLP Loudmouth w/ or w/out resonator
- WTB: Honeycomb taillights
- Needed: 4th gen interior parts
- Comp Cam 503 (CC503) and 1.6 Roller Rockers
- WTB: LT1 heads Port and polish
- stock grill 98-02 camaro
- 93-97 V-8 firebird LH tail light
- WTB: 93-97 Bird or t/a Front clip, PS Fender, PS Headlight assy.
- Wtb 18" Slicks Or Radials For 10.5wide Rims
- 224/230 Comp Cam
- ICM & Bracket needed
- Need 4.10 for 2 series carrier
- WTB: 373s for my lt1
- ICM and with mounting plate 95-97 LT1
- gears 4.10
- Bilsteins
- Short Shifter, 1.6 RR's, CC503, Valve Springs, Electric Cutout
- Wanted: 3.73 rear axle
- rims
- WTB: grey interior for 97 Camaro SS
- headers
- Wanted LT1: Tubular K-Member, Manual Rack, Lower A Arms, Coated LT Headers
- lt1 stuff
- ls4 tb
- NEEDED 2 lt1 intake manifolds
- Anybody has stock driver side head?
- WTB: LT1 fuel pressure regulator
- Few LT1 parts
- TA parts needed
- Need T56 trans tunnel boot & oil dipstick...
- Chrome 10 spoke wheels
- Looking for 4th Gen Interior, Rims, and T56
- ac delete pulley
- GM 7.5 4.10 gear...
- Wanted: Spohn body mount torque arm
- WTB Stock Bose CD player from a 4th gen
- WTB dual cutouts 97 lt1
- Stall needed 3000+
- WTB: Borla Exhaust and ORY (99Z28)
- need help with headers??? cant find them ?
- Ignition box, coil
- Turning car back to stock for sale, Stock LT-1 parts needed
- 93lt1 optispark harness needed
- After catalytic converter O2 sensors needed
- WTB: Stock LT1 style SS hood
- turbo header pipes for a 96 3.8 v6
- Looking for T56 swap parts. Already have tranny.
- WTB LT-1 Block
- keyed crank hub
- Magnaflow Catback Exhaust, Camaro Headlights, etc.....
- cc503, 96-97 timing setup, and cover opti vent hose
- Y pipe
- WTB: 94 LT1 engine harness
- wtt summit racing 4-bolt mains for stock
- Wtb Front And Rear Main Caps
- 95 camaaro gauge cluster
- WTB: GM 3.80 stroke crank.
- WTB LT1/LT4 Hotcam!
- 17 11 ZR1 wheel
- WTB: hooker LTs, ORY, and SLP LM1s.
- Looking for these parts
- Need this tiny interior part from 97+ F-body!!
- cc503 cam
- LT1 T56 Bellhousing
- WTB: Camaro wheels with slicks or DR's
- Front side marker lamps
- Gray Cargo Carpet
- 96-97 SS Hood
- Looking fr multiple parts
- WTB: Driveshaft loop
- wingswest ground effects an ss hood or ram air
- WANTED ASAP 99-02 M6 Wire harness
- I need 2 315/35/17 drag radials.
- wanted seats
- wtb vented opti
- 17" or 18" Black Rims Buy or trade...
- Passenger Side Speaker Grill for 94 Camaro
- U bolt for slave
- 98+ TA door panels.....
- Wanted: Good fan assembly for a 1994 Z-28 - NJ
- 3" ss hood wanted
- Wanted : LTCC Harness
- wtb: 58MM THROTTLE BODY
- 93 camaro long tube headers
- WTB: Moser 9"
- WTB these parts
- Upper and lower A-Arms
- Power Window Motor
- Camaro Door
- 1998-02 Camaro Front Clip
- Needed Borla Catback Parts !!!! **READ PLEASE**
- drag launch springs
- Shift knob
- LT1 slave cylinder.
- 93-94 lt1 4l60e automatic transmission near upstate NY
- WTB: grill for 79 firebird
- Need 97 Firebird pass tail light or both
- Passenger side T-top
- Silver TA 93-97 Rear view side mirrors.
- O2 sensor square plug
- looking for headers 1994 z28
- NSA Rockers, 7/16 stud, 1.6 ratio
- Wanted: Stock manifolds
- WTB your old LT1 EGR
- I desparately need an EGR, anyone have an extra?
- LT1 MAF (mass air flow) ends wanted
- 98-02 Honeycomb Tail Lights
- I Need Two Z28 Rims W/tires - Michigan
- need airbag plug from 2002
- LT1 complete, longblock, or shortblock
- Wtb: T56 Bell Housing A.s.a.p.
- Inspection Cover for LT1 M6
- Wanted - Brake shim
- gas tank, in MI
- 1994 lt1 wire harness w/ or wo/ computer
- Tan floor mat, drivers
- th350 swap needed!
- WTB: LT1 t56 Bellhousing
- Y-Pipe For My Pacesetter LT's
- WTB: 93-97 Hood
- 98-02 Firebird Lights
- CAI and LT headers
- body control module
- WTB: Stock LT1 flywheel shifter boot
- needed
- WTB Mids with Y
- '93-'02 Camaro LH side mirror (manual) wanted
- front sway bar
- lt1 head
- WTB: LT1/4 Composite valve covers
- wanted.. Drag Radials
- TH400 output shaft
- drivers wiper arm needed
- WTB 1.6 SA Roller Rockers
- Looking for MAC mid's or Edelbrock headers
- WTB:monsoon door speaker(s)
- wtb: t top shades
- 94 6speed camaro ECU ASAP!
- for trade 1985 mazda rx7/5 speed/ twin turbo setup for t56 swap
- WTB: 94-95 4L60E in N. KY area
- parts wanted 98 - 02 camaro Cash in hand.
- 91/92 Camaro Drivers side door
- looking for the metal plug boots for the spark plug wires
- Wtb Dot Bias Plies Tires
- WTB! Cowl hood for 1991 Camaro
- hood or gfx
- Polylocks
- Hurst White/Black Ball Shift Knob
- If you have a K&N Cold Air Intake, Read Please
- LT1 M6 stamped plate between the motor & tranny
- brake fluid cap
- LT1 rubber elbow
- 21mm Rear Sway Bar Wanted
- WTB: !!! Bare LT1 block.
- WTB:OEM black ZR1 17x9.5's
- wtb lowering springs
- need some 42lb injectors...
- SLP Loudmouth Install Kit (LT-1)
- wtb t-56 pigtails
- 94-96 Camaro CD player BOSE ?
- 98-02 Xenon front air dam piece for Camaro
- looking for wheels
- Torque arm bracket + Mount + Bolts
- WTB LT1 TA Tailights
- WTB:// Passenger Front Fender 93-97 Firebird
- Cold air for LT1
- WTB camaro parts
- low mileage stock rear shocks
- WTB Pro Stars
- 97 MAF screen
- 98-2002 dash. gauges, console
- 93 Emissions parts
- WTB: Flowmaster 80 series single in/dual out
- 3" Bullet
- RK Sport Guage Piece
- LT1 Parts Wanted!
- t56 cluster
- 95 stock LT1 Cam
- HELP PLEASE needed ASAP
- 89 3.1 turbo grand prix ECU!!
- WTB: Clutch, struts, headers
- Cowl Hood + Zr1 Rims
- 98+ firebird hood
- LS1 3.42 complete rear end - alum drive shaft
- WTB: headers and a cam
- Center Consule Insert For M6 Trans And Stock Flywheel
- headlight motors
- headers
- Stock Lug Nuts & LT1 Drivers Fender
- looking to buy a cc306
- WTB: Trunk open switch
- I need a 94-96 150 mph z28 gauge cluster
- stock lt1 rod
- WTB DR's, Shocks/Springs, Aftermarket wheels
- pacesetter longtubes and y pipe
- WTB: Clutch inspection cover. 92-97lt1 t56
- WTB Stock LT1 valve covers
- No way anyones going to have this..but Right Side TEAL Mirror
- Need stock torque arm and set of rear springs
- LT1 intake needed
- WTB: White 30th anniversary SS wheels
- 95 Stereo Brackets
- Front Upper Right side Spring Cup
- Silver WS6 wheels
- WTB: Ported or aftermarket LT1 heads
- Long Tubes
- 383 or 400 crank ground down for project
- LT1 Crank
- wanted SLP part 210280430 (block plate for ram air)
- WTB ported lt1 heads
- WTB 42lb Fuel Injectors
- WTB Cam: CC306 or GM847
- Wanted- LT1 complete/long/short block...not bare block
- Clutch Friction Disk only
- 36# or larger injectors
- LT1 Aluminum Flywheel
- Need Window Seals
- Longtube Headers or offroad y
- WTB: T5 from 96+ V6 Fbody
- 98-02 Parking light passenger side....
- WTB 98-02 TA Front Clip
- WTB Firehawk rims
- Wings West or longer Air Dam
- WTB: Tuner Cable for 94 LT1
- WTB. Aftermarket Oil Pan Canton/Morso
- WANTED- WTB- LS1 Oil Pan- Camaro/Firebird or ????
- WTB: LS1 engine block
- WTB Hotcam
- flowmaster 80 series and z28 tips
- Catback for LS1 WS6
- Head light assemblies
- WTB front brakes off ls1 f body
- WTB: Victor-E Intake!!
- LT1 383 Long Block
- WTB CAI + ac delete pulley
- LT1 LT Headers, Cut Outs, Ported Intake and Chrome Rims
- LT1 rear brakes needed
- WTB: pass sun visor, poss interested in pair
- WTB- used or new ET Streets 28 x 11.5 x 15
- WTB: LS1 T56 Transmission
- WANTED: LT1 A4 Trans Crossmember ASAP
- Wtb: 94' Trans Am Or Camaro Lt1 Auto Engine Harness!!!
- z06 anthracite
- LT1 engine
- Longtube headers
- 93-97 ws6 ram air hood
- 3.4L Camaro Exhaust Wanted
- 93-97 Firebird/TransAM Headlight assembly
- little things
