View Full Version : Parts Wanted
- 4 channel abs wireing harness
- Lt1 Icm
- Headlight Panel With Lights and Fogs
- WTB 98+ TA front end
- V1 T-trim headunit
- 95 ta 6speed shifter boot frame
- WTB Fast xfi
- Wanted: LT4 Hotcam
- WTB 10 Bolt Girdle and Nitrous Window switch
- WTB Koni
- WTB front clip
- WTB '95 Front Timing Cover
- WTB LT1 Heads
- Composite Valve Covers
- 58 mm TB
- WTB Borla V6 Rear Section #11441
- Door Actuator
- Salad Shooter Center Caps
- WTB: Comp XFI 268 or similar for LT1
- WTB: Drag Radials
- WTB: Scanned instructions for a Hypertech PPIII #340752
- LF: Neutral/Tan Floormats (94 Formula)
- LF: Hatch Struts For 94 Formula
- Wtb: Cc 306
- WTB: LT1 firebird - weird odds & ends , if you're parting out you may have this
- 93 throttle/trans cables
- WTB: Z06 wheels
- Wanted GMPP lt4 hotcam
- Hard to find part
- WTB: LT1 WS6 Ram air box
- looking for parts '97 camaro
- WTB: Z28 SS floor mats
- WTB Stock LT1 heads
- WTB 4th gen cloth seats
- WTB: Hardened LS1 Aftermarket Pushrods
- WTB 1993 to 1997 flat fiberglass bolt-on hood
- LT1 Camaro Brake Harness
- Looking for ULTRA Z decals
- Wtb: Tan/beige T Top Conversion
- LT1 Intake with fuel rails
- WTT: slp intake tube
- WTB 93 LT1 ECU - No maf, speed density
- 3.23-3.73 10bolt
- 4:10 gear cheap
- Tranny
- shifter base
- need black manual door panels
- Bra *front end cover* for 1995 Z28
- WTB: stock LT1 intake elbow, CAI, rear brakes
- 75-81 Stock Z28 Wheels wanted
- WANTED- WTB- Camaro Cats- 98-99, or 00-02
- lt1 motor
- 18" Rims needed
- looking for switches
- 02 sims
- WTB Manual Doors and Manual Seats
- RS body kit
- WTB 93-96 Black Interior Door Panel
- wtb: fresh lt1 350 block with 4 bolt mains
- Lookin For Trick Flow Or Vortech Elbow
- WTB / Front lower spring perch
- WTB: LT1 accessory bracket and misc bolts
- Wtb: T Top Conversion
- Firebird Rims
- WTB 02 Sims
- WTB O2 simulaters
- wtb a qa1 shock
- Welds Wanted
- wtb 6" eagle h beam rod
- WTB y pipe
- looking for good stock injectors
- WTB: LS1 Valvetrain Parts (Overhauling)
- Need an LT1 longblock or complete
- Adjustable torque arm
- Wtb: Cc503
- 3rd gen rear/welds
- WTB : 95 LT1 Engine Wire Harness
- ls1 clear lid
- Looking for a shift boot.....
- Aluminum Driveshaft
- Misc '94 Parts
- WTB 1998-2002 Camaro/Firebird 16" spare tire
- WTB Passenger Camaro Front Chrcoal/Ebony Floor mat
- WTB 1998-2002 Camaro License Plate Holder
- wtb panhard rod
- T-56 Swap for LT1
- wtb hotcam kit and headers
- WTB Adjustable upper A-arms (used is ok)
- WTB: t-top holders for 96 camaro
- wtb: 96 camaro ss merchandise/brochure....
- Need Lt1 Fans Just One Fan With Bracket Asap
- Headlight Brackets
- Chrome ZR1's
- wtb 16 inch rims
- driver side 97+ tail light
- [WTB]98-02 BLACK Camaro Front Bumper
- 3rd camaro parts
- WTB Twin Walbro/Racetronix
- Wtb: 94-95 Ecm
- WTB: 4-barrel throttle body
- WTB: Front eibach prokit springs for ls1
- WTB: LT1 oil cooler for 96 camaro
- Panhard Bar and lcas
- WTB 12 bolt-9 inch s60 rear for Lt1 car
- WTB cowl hood
- WTB '95-'97 Harness
- Looking for aftermarket LT1 oilpan
- MSD Plug wires for 95 z28
- wanted used aftermarket or ported heads and Cam
- NEED HEATERCORE cheap!!
- looking for passenger side GFX and front GFX for 97Z28
- ZR1 wheels
- Tubular k-member wanted
- WTB Catback Exhaust and Black Rims
- WTB a stock T56 shifter
- Exhaust hanger for drivers side tailpipe
- Stock Bose CD Player
- I need a charcoal canister for LT1
- 94 Z28 K&N FIPK System or Moroso
- 2002 cav backseat
- Legal Copy of Datamaster EE 3.5.1
- WTB: A4 Transmission for Z28 convertible
- WTB: Borla Cat Back Exhaust System
- WTB - Lingenfelter or Dennys HD Driveshaft
- LT headers
- WTB: rear AC condenser bracket, need ASAP
- WTB: a/c compressor for '95 camaro Z28
- Wanted Low Miles 95 Auto Rear Axle
- Looking for a 6 speed shift plate for 1994 Camaro.
- Dash Pad for 95 Camaro
- Flange off a Cat converter - or where to buy one!
- need Steering Column for 2000 Camaro SS
- Needed: 98-02 Camaro fuel filler neck and connector
- jesel shaft mount rockers for afr 210's
- WTB ZR1's Original
- NEED TWO OBDI LT1 PCMs ASAP! 16188051
- need exhaust bracket for 93z
- slp radiator
- wtb:various 96 camaro ss parts
- WTB 93-02 Camaro drivers door, local only, within ~50mi of Bradenton FL
- WTB 00-02 LS1 Throttle Body
- Fuel Line for 94 Z28
- WTB LS6 Intake
- wtb 15x10 weld draglites
- WTB Ebony Seat belts
- control arm relocation bracket
- Wtb 94-95 Lt1 Pcm
- Drag Radials wanted!..255/50/16's
- Want 383 short block
- Want K&n Intake For My 94 Z
- hood height adjusters
- 96 Trans Am facia, left headlamp and pcm
- WTB: LT1 timing cover with reluctor 1996
- WTB LS1 drivers side steering knuckle
- WTB A couple Z28 items
- WTB: used working ICM
- WTB: Stock LS1 Oil Pan (fbody)
- WTB:Speed Pro L2441F pistons
- WTB: Stock LS1 Front Struts and Strut Mounts, NOT RUSTED
- bell housing
- WTB: SLP Quad CME
- 96-97 camaro ss slp hood
- wtb lifters
- WTB: Underdrive Pulley, LT4 KM, and more
- WTB LT1 engine/shortblock
- Searching for.....
- WTT - bbk 58mm tb for your LT1 parts
- LS1 intake manifold bolts
- Wanted: Pro 5.0 Shifter
- Looking for 1969 Z28 intake manifold
- WTB: C6 Z06 style "Z28" emblems
- aftermarket clutch
- WTB: 93 pcm f/ LT1 f-body
- roller rockers self align 1.5 or 1.52 3/8 stud
- need MAF
- ***LS1 MTI Clear intake lid ***
- WTB lt1 oil pan w/bolts
- Lt1 engine harness needed asap!!
- Looking for a boost-a-pump
- looking for 93-96 graphite sunvisors for a T-top Trans am
- 17/11in Silver ZR1 rims
- WTB: 255-50-16 MT or Hoosier DRs, ET streets.
- WTB set of 4 93-02 shocks (NOT DeCarbons)
- Hotcam Kit
- WTT: XFI and single plane for stock stuff
- WTB Pressure plate for a 6M LT1
- Console Lid
- wanted dash pad
- WTB LT1 T56 Cross member
- WTB-12 bolt or 9" for Lt1 Car
- Pacesetter Y-Pipe & Exhaust Hangers
- WBT: Long Tube Headers For !994 Firebird Formula
- CNC'd Heads for my LS6 Intake Upgrade
- 96-97 air box for a ss
- WTB: 96 Camaro steering wheel
- Conversion parts for th350
- 95 Timing cover
- Looking for Silver Doghouse
- WTB Camaro Interior Parts
- 1.6 Roller Rockers
- need some used LT1 parts
- 94 passenger side exhaust manifold
- 98 and up
- WTB Camaro seats
- small metal clip needed (holds window controls in door/armrest)
- WTB SS Or Other Aftermarket Hood for '95 Camaro
- Optispark and 3.5 inch cold air intake
- WTB Self Contained Procharger (P1-SC or D1-SC)
- console needed
- Manual Seat Tracks (driver side)
- Ford 9" rear
- Need a couple camaro convertible parts and firebird parts
- Steering shaft
- motor mounts
- 84 Firebird grill pieces
- Drivers Side Door
- WANT: SS Spoiler. (prefer LT1, considering LS1)
- 98 And Up Front Clip
- WTB: Cam Parts
- fuel EVAP lines for 95 LT1
- RK Sport 5" Performance Spoiler
- crank hub
- TORQUE ARM FOR 4th GEN
- 306/LE2 Cam and 30-36lb Injectors
- Clutch master cyl rubber sleeve
- headers & cam
- wtb 30 lb svo's
- A4 Shifter panel!! x2
- wtb opti
- WTB 4.10 Gears
- WTB-LS7 lifters, pr's, valvesprings...
- lt1 cluster
- parts for T56 swap
- LT1 turbo camshaft
- WTB V6 rear springs
- Looking for the following 95 Z28 parts
- WTB: AIR pump
- WTB GMPP LT4 Hotcam
- WTB camaro dash pad
- Crank Hub
- 1996 A4 Engine Wiring harness and PCM
- Looking for a 98-02 front clip
- LT1 Catback or true duals
- WTB: 94-96 Camaro Factory radio
- Need accelerator cable holder.
- 1981 camaro z28 tail light needed
- 93-97 TA right fender
- 94 camaro z28 mods.....?
- WTB: 96-97 LT1 timing cover
