PDA
View Full Version : Parts Wanted
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96
  1. WTB LT4 Knock Module
  2. Lt1 overflow metal tube.......
  3. WTB Factory Sport Appearance Package (Y3F) front lip pieces
  4. Wtb: 94-95 timing cover
  5. WTB: 93-97 OEM SS Hood
  6. Wtf lt4 knock module
  7. WTB PCM for 94/95 LT1
  8. Wtb LT4 Knock module
  9. Good/New 3rd gear needed for LT1 T56 rebuild
  10. WTB: 4.3L L99 in NJ/PA
  11. Wtb 1995 abs sensor with traction control
  12. Hurst shifter
  13. 93-97 LT1 T56 Trans
  14. lt4 gotcam 1.6 RR
  15. master/slave assembly
  16. Original Copper Carpeted Floor Matts for a 86 Iroc Z28
  17. WTB: GM only AC Delete Pulley
  18. WTB....3.73 Gear and Pinion Set
  19. A/c compressor
  20. WTB: Delteq Coil Jumper
  21. WTB: 93-02 F-Body Sail panel
  22. WTB: 98-02 Camaro fender, bumper & hood
  23. Need a few front trim pieces 93 camaro
  24. Hotcam, LS7 lifters, Opti, Headers, Timing chain, maybe more
  25. Le2 heads
  26. Fuel Sending Unit Needed Please!
  27. WTB LT1 Water Pump Drive Shaft
  28. wtb 24x conversion harness
  29. WTB 1.6 rockers
  30. Need a ECU for a 93
  31. `85 -`90 f-body Borg Warner 9 bolt parts wanted
  32. Anyone have 1 of these?
  33. WTB 1.6 Rockers.....
  34. WTB LT1 T56 Clutch Fork
  35. WTB: '95-'97 Optispark harness
  36. Wtb 3600 stahl converter
  37. LS1 steering shaft
  38. WTB: 93-02 Trans Am Side Skirt, Factory ground effects
  39. Need LT4 knock module.
  40. Looking for ALDL setup!
  41. WTB lt4 hotcam
  42. Looking for coolant tank/battery mount with hose
  43. WTB Shift cable for 4l60e
  44. WTB: AC Delco Optispark
  45. ls1 t56 input shaft and midplate
  46. My list of needed lt1 383 parts!
  47. icm
  48. 94-95 Knock Sensor On Block Anyone ??
  49. Anyone has an 94-95 LT1 OBD1 Knock Sensor Module
  50. WTB: LT1 T56 Clutch/flywheel
  51. Anyone Selling Valve Springs
  52. WTB: 24x conversion stuff/96-97 timing cover
  53. WTB Intake Boot: 95 5.7 LT1
  54. Header
  55. WTB: working LT1 era 4L60e, stock or built, in NJ
  56. needed 95 wiring harness
  57. Vortech discharge pipe
  58. WTB LT1 Aftermarkert Valve Spring
  59. Wtb 95-97 Camaro z28 Coolant Steam Line
  60. Wanted: 2800 - 3200 Stall
  61. 383 stroker kit
  62. Wtb slp shorty headers 96-97 dual cat
  63. LE2 Heads
  64. WTB 93-97 WS6 OEM Hood
  65. Wanted mac mids lt1 94 single cat
  66. LT1 K-Member
  67. 99 visors, shift boot needed
  68. wanted - rear end for 95 z
  69. WTB rear abs sensor
  70. WTB - Bose OEM Door Speaker Amps for '93 Z28
  71. D1SC Procharger LT1 kit for sale
  72. WTB- Power Door Lock Switch '93 Z-28
  73. WTB - Bose OEM Speakers for '93 Z-28
  74. Looking for a lt4 knock module!
  75. Wtb: '94 pcm auto
  76. wtb 1994 drivers side door bezel with pw,pdl controls
  77. WTB T56 Clutch Fork
  78. Wtb: 93-02 camaro firebird front lower control
  79. WTB 36# or 42# Inj. LT1 Plug style
  80. WTB..LT1 rockers and lifters
  81. Wtb lt1 fuel rails
  82. Monoblade Nitrous plate
  83. T Roof Parts
  84. WTB: Steering Shaft 98-02 Camaro
  85. Roll Bar for Convertible 4th Gen
  86. Fog light for 96 Camaro
  87. Wtb: Factory radio and bezel for 96 Camaro, springs and shocks
  88. E C M for a '93 Camaro manual trans
  89. Looking to buy lower control arms for 95 TA
  90. 96-99 SS wheels (ANY version)
  91. OBDI/LT1 Tuning/Data logging software
  92. WTB: 1995 4L60E trans
  93. SS Hood 96-97 OEM
  94. Injector retaining clips
  95. Wtb ls6 intake
  96. Walbro 255gph hot wire kit
  97. LT1 carburator intake
  98. Ultra Z hood and spoiler
  99. Transmission dip stick for 94 LT-1Camaro
  100. 98-02 ported 80mm or 85mm throttle body
  101. forged rotating assembly lt1
  102. Lt4 knock module 16214681 wanted
  103. WTB: LT1 Wet Nitrous Kit
  104. 1995 z28 Tan Mats Wanted
  105. Tubular A-arms/rear shocks
  106. WTB: 1980 camaro kick panels
  107. 2000 ss
  108. WTB: Adjustable Lower Control Arms
  109. 1993 F-Body LT1 M6 ECM
  110. Selling any working parts off 93 z28 camaro
  111. 1994 LT1 Knock Module
  112. WTB: Stock LS1 Valve Locks - Used is Fine
  113. wtb canton valve covers
  114. WTB: 1.6 Roller Rockers
  115. WTB: Stock MAF w/screen
  116. WTB tunnel mount torque arm w/loop
  117. WTB: Your non working 16188051 PCM
  118. Rear spoiler
  119. LT1 Stock CAM
  120. Wanted: LT1 Parts/ Inj & timing cover
  121. ---96 z28 few odds and ends---
  122. 87 with TPI
  123. Rear cloth seats - gray/black - near MA/NH/CT
  124. 27 or 28 Hoosier QTP
  125. Monoblade Throttlebody
  126. Misc parts..
  127. need 2002 drivers side door handle bezel
  128. Fuel injectors
  129. Any Ultra Z Hoods for sale?
  130. WTB 1994/95 MAC Shorty headers NON A.I.R.
  131. LT4 KM GM#16214681 Delco 216-67
  132. 1995 camaro 4l60e transmission
  133. IAC/Coolant Housing
  134. WTB Orig GM Hurst shifter
  135. d Bumper SD Lower GM Part# 10274366
  136. fuel pump assembly
  137. Le2 heads wanted
  138. WTB: 97 rear abs speed sensor harness
  139. WTB UMI 3PT connector - 1995_LT1
  140. WTB LT1 24x stuff
  141. WTB LT1 PS Y-pipe
  142. WTB C5 Front Brakes
  143. 1998 z28 Brakes and Rotors
  144. Single Cat SLP Headers
  145. Need OBDII to USB to use GaryDougs Software
  146. WTB: 1.6 self aligning roller rockers
  147. Need 43" driveshaft
  148. Wheels
  149. 94 OEM Injectors
  150. WTB stock cam/lifters/dog bones/retainer
  151. In need of wheels
  152. Need rebuilt t56
  153. WTB alternator 94Z28 LT1
  154. wtb/LPE 219 CAM
  155. Wtb: m29 t56 complete
  156. 799 or 243 Head castings
  157. WTB Mid Length Headers
  158. wtb lt1 scanmaster
  159. R/F fender
  160. 1993-1999 horn switch/contacts
  161. Good Headers and/or y-pipe for 1997 camaro lt1
  162. 383/355 rotating parts wanted
  163. Looking for known good opti/distributor
  164. LT1 Performance Parts
  165. wtb lt1 cam
  166. '97 Z28 ABS Control Module OE No. 16220641
  167. WTB: GM LT4 Intake
  168. WTB Aluminum DS for T-56 and 12-bolt combo
  169. Looking for Hurst stick
  170. 98-02 Tail lights Left and Right
  171. 95 v6, A4
  172. WTB: HP Tuner Pro
  173. 1989 Z28 5.7 ECU Chip Wanted
  174. WTB 94 Trans Am skirts
  175. good running LT1
  176. WTB 1997 Camaro PCM
  177. Wheels CCW Classics 17 x 11
  178. wtb race longtubes and y pipe Lt1 camaro
  179. WTB: Throttle Body Cable (1995 LT1)
  180. 1973 Z28 Body Parts Wish-List finding ...
  181. 10 bolt with 4.10s
  182. Viper main shaft
  183. engine oil cooler hose
  184. WTB: ONE Short Head Bolt
  185. OEM Ram Air or Firehawk Hood
  186. LT1 Fuel Sending Unit
  187. dash pad (cover)
  188. Wanted 93-02 Chevy Camaro Convertible Tonneu Cover Boot
  189. Looking for a LT1 f-body Accessory Bracket
  190. Tubular K-Member for stock stearing
  191. Stock Lt1 Cam
  192. emmisions legal headers for a california 95 z28
  193. Manual trani for 95 z28 V8 wanted
  194. Headers for 95 z28
  195. WTB 97 Springs, drivers door. Central NC.
  196. Used motor low Mileage
  197. wtb broken vented optiparks 95-97 lt1
  198. Seat belt guide
  199. LT1 Head Gaskets, Head Bolts, Aluminum Heads
  200. WTB stock batt tray
  201. LT1 diagnostic cable wanted
  202. WTB: K&N Cold Air Intake
  203. Fuel door for 94 Z28
  204. WTB: Ls1 aftermarket fuel rails. Fast?
  205. WTB: 93-02 Fbody driveshaft loop...
  206. ltcc
  207. WTB Moser 12bolt or S60. Killeen Tx
  208. 1995-1997 opti
  209. scanmaster
  210. 93 lt1 pcm
  211. WTB Tan Leather seats 93-97
  212. WTB LT1 blower,blower cam and other LTx parts
  213. procharger lt1 pulley and spacer, new
  214. WTB-OEM TB cover for 95 LT1
  215. Front bumper cover (not stock)
  216. WTB CAI kit for 1997 Camaro 5.7
  217. Torque Converter
  218. Tuning cable for 94 LT1
  219. wheels
  220. need lt1 long block close to Staten island, ny 10314
  221. 93 optispark
  222. 96-97 LT1 Timing Cover
  223. LT1 Engine
  224. wtb Lt1 Shorty headers and ypipe anyone close to 10314
  225. WTB LT4 hot cam anyone close to 10314
  226. 97 camaro rs parts. everything
  227. WTB..'98 ls1 pcm
  228. WTB: MSD vented opti and blaster coli
  229. Wtb Borla y pipe 93-95 single cat
  230. WTB 16214681 knock module
  231. WTB: 4th Gen. Y3F Sports Appearance Package Ground Effects Body Kit
  232. 94-97 Formula/TA tail lights
  233. Trade two SS 17-inch wheels
  234. wtb mono blade throttle body
  235. WTB: stock LT-1 camshaft
  236. LT1 fbody accessory bracket needed
  237. wanted T-56 for a 1995 Z/28 (replacement trans ) not a swap .
  238. Trans Am PS side skirt, ground effects wanted!
  239. Wtb lt1 heads
  240. Wanted 3500 cylinder heads
  241. Wtb side rail - gm (10282836)
  242. WTB grey sunvisors for 95 camaro hardtop
  243. WTB HOOKER LHT Y-PIPE P/N 16765 for 2231 LTH
  244. WTB: torque arm mount/clamshell/bracket for manual trans car
  245. Wanted: 98-02 camaro headlights
  246. WTB Black 94 firebird driver side door
  247. 93 ecm needed
  248. Wanted - 2000 Z28 Boot Cover Bag
  249. WTB sun visor
  250. WTB red 94 z28 driver seat
