View Full Version : Parts Wanted
- WTB 93-97 Firebird wiring harness and LS1 MAF
- wtb z28 fog lights
- Parts needed
- Wanted, LT1 clutch master/slave hydraulics
- lt1 rear cyl head coolant pipe
- LT1 Interior Parts Needed
- T56 manaul transmission
- Auto inspection plate with bolts
- WTB 97+ Complete Middle Console
- 1999 camaro dash
- Wtb:bbk shorties for 96-97
- WTB: Catalytic Converters - Any and All, What do you have! - Prices Updated: 3/30
- wtb supercharger
- WTB 10 Bolt
- GEARS: 3.23, 3.42, 3.73, 4.10's for 2 series
- INTERIOR PARTS WANTED, A4 shiftplate, console armrest
- wtb cc306
- Torque Arm Mount
- WTB: 4.10 Gears for 3 series carrier 1997 camaro
- Cam, stall, headers/y-pipe
- Anyone have a junk 4l80e laying around?
- wtb lt1 motor
- WTB: Dark Charcoal front seat belts for a 97 Camaro, LH Door speaker grille
- Looking for a 94 4l60e in Wisconsin
- WTB: Mufflex exhaust system for LT1
- WTB Trans Am Door Emblems
- 295/35/18 tires WTB
- LT1 clutch kit
- Wanted: 3rd Gen Aluminum Bumper
- need passanger fender and stock or after market springs
- WTB: A/C delete bracket/pulley (LT1)
- Need T-top shades Tan
- 2 screws for TPS 94 Z
- WTB: 93-97 f-body black leather interior seats
- WTB- T56 (M6) Bellhousing LT1
- wtb 93-97 turn signal blackouts
- c5 corvette wheels
- non self aligning roller rockers
- 17x11 ZR1s that are cosmetically-challenged
- Wtb headers
- Wiper arms and Interior
- Drag wheel set up
- Maf wanted!!!
- Wtb hot cam
- WTB: 1.6 rr's and springs for lt1
- WTB Polished radiator support/cover-LT1
- WTB - LT4 ED timing set / Stock LT-1 Valve Covers
- wtb 1 or 2 chrome zr1's
- AC temp. knob
- WTB '95 LT1 Timing Cover
- wtb cc503 cam
- Need opti and waterpump for 1996 Roadmaster
- WTB Single 30lb SVO
- WTB: LT1 F-body Steel Fuel Lines
- WTB used exhaust system
- WTB: SLP LT1 SS Intake Airbox with duct work
- WTB: TOTL exhaust and WTT 98-up SS spoiler for 96-97 SS spoiler
- Need SLP speedometer calibration instructions
- WTB: LE head or any other ported heads
- WTB: 10 bolt rear end
- WTB Conv. Top 'Boot' for 96 Firebird
- WTB: 99-05 grand am gt white hood
- WTB LT1 Harwood hood
- LT1 M6 Shiftboot
- Need a CC503 & 4inch Mufflex & Elec Waterpump
- WTB: T-56 in Canada or close enough to ship
- Wanted CC503
- WTB: Aluminum DS
- Modded LT1 Longblock/Shortblock
- WTB cold air intake
- WTB: LT1 shortblock
- headlight motors for 96 Firebird
- WTB timing cover vented opti
- LS1 Brake Swap (Front)
- Front bumper cover 93-97 camaro red
- ls1
- WTB: LT1 Trans am Passenger Taillight
- Tires needed
- Looking for a stock 10 bolt
- LT4 Block
- Posi rear for 93 formula
- Ultra-Z Airbox
- WANTED: ls1 t56 and other stock ls1 parts
- 93-97 ta/firebird drivers fender
- Wanted: Stock 1995 LT1 camshaft
- Wtb n2o kit for 93 lt1
- LT4 knock mod.
- 1974 emblems
- WTB: 17x11 chrome ZR1 rims
- WTB: '93-97 2-inch Cowl Induction Bolt On Hood
- lt1 42# injectors
- T-top conversion
- WTB: Plastic lug nut caps for GM CAR lug nuts
- LT! Heads
- tranny
- reaer end for LT1
- 97 LT1 Timing Cover
- WTB 97 Digital Cluster
- Wtb stock air bellows off ls1 cars
- driveshaft for 67 camaro
- ls1, ls2 shortblock, longblock
- Run light housing
- Z 28 emblems bages
- Short shifter & lowering springs!!!
- WTB: stock rear springs
- 58 mm throttle body for my 96 lt1
- in desperate need of wiring harness...
- Wtb: 383 shortblock low compression
- Need a Performance Lt1 cam
- wtb m6 swap parts
- WTB: LS1 Emergency brake Brackets
- Eibach Pro-Kit Front LT1 springs
- 93-97 4l69 cross member and torque arm mount
- 1994 computer and engine harness needed!
- Rear end(12 bolt or S60) and F1A.
- OBD1 to Laptop cable???
- WTB: 96-97 SS ramair airbox
- Radiator level sensor(need not work)/fan plugs
- 243 Heads
- LT1 M6 shift boot
- boyd center caps
- 2002 manual trans ashtray cover?
- wtb 255 fuel pump
- WTB cc306
- WTT: light gray interior pieces for dark gray
- WTB intake elbow
- WTB 95 Camaro Body Kit/Ground Effects
- 2800 stall
- WTB: Center caps for Camaro salad shooters
- 3inch catback for my 94 Z
- I really need a t56 flywheel cover, and lower shift boot
- WTB SS Hood and Spoiler 96 Z28
- stock fogs wanted
- hydraulic clutch assembly
- WTB Ram air hood inserts (93-97)
- WTB 10 bolt
- Looking for a LS series motor & T-56..
- 95 lt1 crank hub
- 95 Lt1 4l60e transmission
- 1974 z28 emblems
- WTB good 10 bolt housing for '96 V8 Camaro no TCS
- need a engine or block 350 1969
- wtb lt1 complete w/trans(auto)
- WTB: Short throw shifter for 6 speed T-56
- WTB: Rear D/S panel that holds speaker in hatch area from 97 camaro
- WTB: CD player monsoon style for a 97 camaro
- WTB: 97 Camaro Power Cloth Drivers Seat
- Aluminum Driveshaft 4th Gen
- stock ls an lt injectors
- 2800-3500 stall converter
- Looking for a 2 series posi
- dead opti for a 94
- WTT SVO 30# Red tops for 42# or bigger
- Need passenger side control arm/spindle
- 93-97 Dark Grey Rear Seatbelt Buckels
- Wtb 2000 z28 front bumper/fascia preferably white
- Wtb-- lt1 headers
- WTB: 2otl muffler
- Strano or BMR Springs for '00 WS6
- LT1 Camaro P/S front fender (black)
- WTB 17" Rims and Tires (WS6+)
- WTB: EGR/AIR MAC Mids 94 LT1
- WTB 1997 Throttle cableNeed a throttl
- stock lt1 flywheel needed
- Need valvetrain parts
- WTB LS1 air filter tray from air box
- Need radiator and cooling fans for LT1
- Looking for a fast xfi system for an LT1
- 255/50/16 Drag Radials
- need a 3.4l upper and lower intake manifold
- wtb twin disk/10308's
- Need an lt1,
- WTB: Radiator lower air dam and another plastic part
- Converted Super Victor
- Wtb 93-7
- Needed LT-1 Stock MAF
- wtb cc306/ crane 10308's
- wtb mirror triangles
- parts for lt1 camaro
- wtb torque converter for my 94..
- WTB:Lower A arms
- 94 v6 performance chip!!
- WTT: ZR1 wheels
- Wanted: Hood, Dash, Rims
- WTB: Graphite Sun Visor(s)
- stock balancer or underive pulley's
- WTB: Borla Cat Back Exhaust and Center Console (93-97)
- WTB: All TPI Parts
- WTB upper dash pad
- WTB: 80lb or bigger fuel injectors
- WTB complete LT1 engine in the NC region
- WtB o2 sims
- Need A/C compressor 95 LT1
- Wtb:dash cover
- 16" slicks
- Cruise Control Module
- WTB: Polished/Chrome LT1 Valve Covers
- LT1 Spark Plug Wire Holder
- Stocker lt1 rods.....
- W/C T5, TKO600, Richmond Super 5 or Jerico 5
- Headers
- 93-97 rear caliper brackets
- WTB: Vortech Aftercooler - LT1
- WTB: T/A Side Skirts
- WTB 93+ Firebird/TA door panels and auto shifter
- wtb 93-97 camaro low beam headlight
- WTT brand new Lingenfelter CAI for complete LS1 lid conversion
- WTB ANY hood 95 Camaro
- WTB 17" '96-'97 Camaro SS wheels (grey), 2 or 4
- WTB/WTT: Stock Manual Shifter Boot + Stock E-Brake Boot
- WTB: LT1 AIR pump
- WTB 93-97 Firebird front and rear bumper covers
- Wanted 3rd Gen 1LE rear brake brackets
- BMR Torque Arm Bracket (Rearend)
- t56 parts
- WTB: GMMG oval tips
- 95' OBD1 AKM Cable
- wtb 97 m6 shifter suround
- 2000 T/A Fan Bracket
- heater hose for 94 lt1
- Passenger Side Mirror
- WTB: OEM auto trans mount
- WTB 94-97 LT1 block
- 79' z28 parts needed
- 93-96 fbody shifter boot retainer
- WTB Opti to Harness adapter
- 1974 type lt emblems
- 1994 Chevrolet Camaro & Pontiac Firebird Factory Service Manual - 2 Volume Set
- 1994 parts wanted...
- MSD digital 6
- Solid roller lifters
- engine part needed
- WTB Torque Thrust II's
- WTB: 12 bolt rear end
- wtb: acpt driveshaft, alum flywheel, a-arms
- LT1 LT headers
- 93 waterneck
- need drag rims
- Lt1 cowl hood wanted
- ALDL Cable and Tuner Cat Program
- WTB 99 LS1 Emissions junk
- WTB - LT-1 Throttle Cable Cover Bracket
- Left and Right side A-Pillars for 97 Z28
- hooker y pipe
- t56 inspection cover needed!
- 93 opti
- WTB: Low mileage drivers cat. converter
- WTB: Low mileage shocks/maybe springs
- WTB LT1 Cam
- wtb used throttle body
