View Full Version : Parts Wanted
- WTT: your 19" 2010 Camaro wheels and tires for my 20" 2010 Camaro RS wheels and tires
- Aftermarket 93-97 Camaro Hood & Spoiler
- Zr1 replicas
- O2 and air vac sol harnesses needed
- SLP spark plug socket
- Wanted Slp Loudmouth I cat back
- injectors/throttle body/vortech parts
- Need 700r4 Converter
- WTB LS1 rear backing plates and Ebrake assembly
- Wanted Lt1 valve covers and Harmonic Balancer.
- 1997 ONLY engine harness
- WTB vortec hsr
- wtb: LT4 valve covers...
- 98 + Camaro/firebird 6 speed console
- WTB: Rear ABS Pigtail
- WTB 96-02 Camaro dash
- 94 lt1 air intake elbow
- Wanted: Broken 2" gauges! .. Autometer , AEM
- Need driver side Ttop..
- Garage Sale: Interior parts, spare tire, Autometer, Sparco bases
- Pacesetter Mid Lengths/Y-pipe
- WTB: lt1 alternator relocation bracket
- 93-02 Convertible top parts - "link bows"
- WTB.. Stock LT1 heads..
- looking for some 96 z28 parts
- WTB Silver Zr1 SS Centercaps with matching lug,covers
- WTB: Light Gray 4th gen camaro hardtop headliner
- LT1 Trick Flow GenX 195 Heads
- Street twin clutch
- coil section of engine harness
- Needed Cheap shortblock/longblock/complete engine
- Aftermarket SS Hood
- WTB Mac headers, 94-95 style
- LT1 Inspection Cover
- 98-02 Firebird headlights.
- Stock exhaust mounts and hangers 2000 camaro
- Wtb: C6 black rims 18/19
- LT4 Hotcam
- Wanted: a 3.8 for 99 Camaro
- WTB: 98-02 stock Camaro grille
- Procharger kit/parts, D1SC or F1A.
- is anyone Intrested in trading your 6 speed to A-4?
- WTB- bilstein shocks/struts ILLINOIS
- wtb- camaro ss 10 spokes not chrome ILLINOIS
- 93-96 tail lights.
- LT1 engine
- 93-97 camaro fog lights and tail lights
- need a few parts for my TA
- y pipe
- 00-02 SS spoiler
- Wanted 94 pcm OBD1
- WTB LS1 Oil pressure sender adapter
- WTB - Qa1 Rear coilover - Will trade
- 94 Firebird Side mirror, driver side
- WTTB 97 + (auto) center console
- wideband
- Anyone have things they are looking to sell
- need an lt1 tubular k-member
- Wtb a F1a head unit
- WTB Sun Visors for 97
- 96-97 SS hood cowl insert SLP wanted!
- rear side marker lense for 95 Trans Am
- LT1 Air Pump
- WTT: LS1 front end for LT1 front end
- need LT1 Ramair parts
- Weld Draglites
- WTB 8 Rib 4.50 Procharger Pulley
- WTB cc 306, springs, rockers
- 92 Z-28 tail light, steering wheel, dash pad
- '98+ Firebird front license plate cover
- window switch bezel
- 3" electric cutout
- WTB bad opti for a 93
- LT1 SS hood wanted
- wtb: LT1 of LS1 fans and shroud
- autometer boost gauge
- WTB: 93-97 right rear brake caliper
- Ls1 pcm bracket
- anyone have a 97' windshield?
- wtb th400 crossmember
- 96-97 lt1 balancer an hub wanted
- a/c lines from firewall to condensor to compressor
- WTB: 1998 LS1 Harness and PCM
- 94 factoy airbox
- 97 SS. need intake tube (throttle body to MAF)
- abs delete kit
- Camaro Body Parts Needed!!!
- Moroso Cold air intake
- Looking for front leather seats 97 camaro
- 96-97 A4 OBDII Harness
- Bellhousing and slave cylinder spacer
- WTB 2010 Camaro SS L99 Exhaust w/tips
- Fog Lights
- WTB: Spark plug wire that goes from coil to opti
- 95 camaro dashpad,foglights wanted
- looking for lt4 compsite valve covers
- thottle cable
- Opti coupler, cam drive thing
- looking for a place to buy headlight covers for 93-97 camaro
- Y-pipe and 3" Catback
- WTB: 93-96 Camaro HVAC Controls
- Intermediate pipe or cat back
- Original GM floor mats
- stock hood emblem
- SLP Blackwing Air Lid
- camaro hvac knobs
- wanted 97 firebird front bumper lower moldings
- wanted 97 firebird front bumper lower moldings ted
- WTB stock 1997 cam and pcm
- center console 94 camaro
- 97 timing cover
- Sunvisor
- WTB fuse block
- LS1 PCM bracket
- WTB: Trickflow Guide Plates
- 1996-97 Camaro SS Air Intake setup
- Wtb: Air pump
- WTB: Driver-side front speaker for 2002 w/ Monsoon
- LT1 Longtubes
- Rear hatch struts
- Shift plate and boot for 95 M6
- 918 beehive springs
- WTB 92-94 unvented Opti IN GOOD WORKING ORDER
- 94 Camaro A-Pillar trim needed
- Looking for rear GTA wheels
- BOSE CD player
- Wtb 96-97 4l60e
- LS1 SS spoiler
- T-56 Shifter needed.
- WTB: 97 Tail lights (Driver & Passenger)
- Wanted 1995 350LT1 Everything Under Hood
- 95 z28 catalytic converter
- WTB 95 hypertech programmer
- needed ,drivers side door
- Wanted: LS1 spindles
- WTB: LS1 aluminum d.s.
- 94-97 LT1 fuel line bracket and screw request.
- otvc loom brackets
- Stock MAF with Screen
- WTB B&M part #81070 -OEM auto shifter rachet conversion kit
- 94 M6 Engine harness
- LT4 Composite Valve cover(s)
- WTB: 97 camaro gauge cluster
- 95 pcm 6speed and eunercats
- power windows wiring
- WTB: Front end parts
- Wanted (2) 16x8 ZR1 wheels
- Wtb: 10 spoke rimes in illinois? Indiana area
- Grey leather seats
- 93-98 wanted tan camaro sun visors
- Wtb: Blackout fog light covers
- Need 1 10 spoke "SS" type wheel
- 97+ camaro shift boot plastic...
- need a maf 95 lt1 camaro
- WTB a functioning IAC for LT1
- WTB happy hooker engine lift plate
- Fuel level sender- 94 up Camaro/FB
- WTB: SLP 1.85 Rockers LS1
- WTB Delteq
- smoothie II 18"
- T56 LT1 Crossmember
- cosmetically-distrassed ZR1s, 17x11
- need a clutch to hold up to a 383 lt1 camaro
- EGR Valve
- Crane Gold Rocker 1.6 - Old Style
- vented opti
- 1994 Camaro Hardtop Graphite Headliner
- WTB: SLP dual/dual or 2OTL exhaust
- Aluminum Driveshaft ls1
- 96-97 Timing cover & sensor
- wtb supercharger kit for ly1
- need 561 head for lt1
- WTB: LT1 heater core and hoses
- WTB Graphite Interior pieces
- White ZR1 wheels
- i need lt1 parts,,Springs, lifters, rockers
- ttop light gray sunvisors
- need 93 LT1 Mass Airflow sensor and intake elbow
- WTB 97 LT1 ecm
- wtb lt1 crankshaft
- 1.6 rockers "WANTED" For L-98
- WTB: Stock 1996 12 disc CD changer
- wtb ground effects
- spohn tq arm
- Rear brake rotors lt1 car
- WTB: SS rims
- WTB 245/50r16 tires
- vortech pulley
- Need ASAP - Scorpion Gold 1.6 NSA RR
- 94-97 lt1 fuel rails
- 1996-1997 engine wiring harness
- 2001 Camaro Key Fob
- 93-97 PCM mounting bracket
- WTB: LT1 Mac Mids
- Lt1 crankshaft posistion sensor
- Air injection check valve
- WTB: 69 Camaro RH Seatbelt Retractor
- Fuel pump sender
- WTB: '00 Firebird CLOTH Back-Seat
- QA1s
- WTB - Silver passenger mirror (housing) 96 T/A
- WTB:Stock and Untouched 94 MAF
- wanted: Long Tube Headers, Valve Springs, Roller Rockers, Push Rods, Stroker Kit?
- 93-97 SS Hood
- wanted... 94 CAMARO COWL HOOD.. ANY COLOR
- Looking for 4th gen motor mounts
- WTB: LT4 valve covers
- Need 4l60e
- 77-81 trans am firebird power door lock actuators
- WTB deck lid
- WTT heads off 96 T/A for seats
- SLP Dual Dual
- WTT throttle body and bracket
- WTB: LT1 to GenI conversion
- WTB: LS1 & t56
- WTB 93-97 Firebird OEM hood in dark green
- Front Lower Control Arm Bolt (vertical one)
- 97-99 Camaro passenger air bag cover
- Wtb gm847
- WTB 4th Gen Door Panels
- WTB Driver side Window/Lock control Bezel (No switches needed)
- 4th gen camaro cowl hood needed
- WTB th400 dipstick
- WTB: Lower Air Dam another another plastic piece
- Need P600B Procharger Piping & Fittings
- few parts needed for the 4th gen
- Pitons for a 3.4 V6
- 99-2002 Front Driver Side Fender
- SLP LM1 and/or driver door
- WTB Flywheel/Clutch Cover GM#10241153
- Keyless Entry Receiver/Module
- need black drivers side mirror for Trans am
- Looking for a 224/230 Extreme Energy or XFI Comp Cam
- Need lt1 block in Oklahoma area
- LT1 Block
- WTB: Factory Exhaust Manifolds/Ypipe w/ cats
- WTB Lt1 block
- 94 PCM wanted
- need a decent mileage Working shortblock for lt1
- WTB: LSX Valve covers
- 94-96 Throttle cable
- Fuel pressure gauge
- Wtb slp polished ss tip,off loudmouth exhaust
- WTB Kooks Headers 1 3/4" x 1 7/8" 3 1/2"
- WTB: LT1 Camaro Long Tube Headers
- I need an opti
- 4l60e for a 1997 3.8l firebird.
- Good rear end wanted for 97 ws6
- wtb LTx heads
