View Full Version : Parts Wanted
- 93-97 RS air-dam ground effect
- wtb stock t56 shifter
- wtb upper dash cover and...
- Wtb throttle cable
- 98-02 LS1 F BODY Radiator support
- 93-97 Camaro Rear Bumper Cover Wanted
- Torque arm bracket !!!!
- Built or upgraded rebuilt LTX T-56
- fluiddamper
- T56 torque arm bracket ASAP
- Lt4 cam
- Black 97 firebird front or rear bumper cover
- Wtb lt1 cam
- WTB LT1 Oil pressure sender
- wtb 97+ m5/6 ashtray cover.
- wtb supercharger
- LT1 Alternator Relocation
- Crossmember for 97 M6 vert
- WTB: TA-Firebird seats
- Torque arm mount
- Looking for.........
- WTB: LE1 or LE2 llyod elliot heads in ILLINOIS AREA!!!!!!!
- WTB: LT1 M6 Clutch Flywheel
- 95 z28 5.7 a/c lines
- Stock cd player
- lt1 parts wanted
- Cc503
- wtb: broken clutch fork
- 93 Z28 flywheel cover
- 1993-1997 Trans Am Front License Plate Holder.
- WTB: 98+ 3:42 rearend & aluminum driveshaft
- vented opti, 1.6 pro mag, 58mm tb
- WTB 4th gen parts *manuel rack, k member, abs delete, line lock
- MAF AC Delco
- wtb 82-92 camaro front impact honeycomb peice
- stock lugs
- clutch fork
- kyb agxs or bilstiens
- WTB; MBA Billet shift knob T-56
- WTB AI cam, inspection plate, and more
- Looking for chrome SS wheels
- WTB etc, 36-42# INJECTORS LT1
- Wanted Used 5th gen rear trailing and toe link arms
- lookin for tires
- CCW Classics
- wanted 02 camaro 10 spoke ss rims polished and black
- wtb 4l80e, tubular ls1 k-member
- WTB: Single MSD 8.5mm Wires..
- WTB LT-1 Block/short/long E. Wash
- 4th gen lt1 passenger fender
- WTB: Bose front door speakers - 95 Z
- dark charcoal console!!! 95 TA
- 94 Z28 various parts
- WTB: 4th-gen F-body 10-bolt w/ 3.42 gears
- WTB: 93-97 RS Ground effects (teal green met.)
- 1995 a4 z28 pcm
- WTB ls1 camaro p/s pump, lines and bracket
- Kyb agx rears, Tires & Panhard bar
- WTB Tubular A-Arms
- WTB: T56 crossmember for 93-97 f body
- need 98 up WHITE Driver side fender
- WTB:Oxygen Sensor Simulators
- '93-'97 Trans Am RH tail light
- WTB: PCM Bracket from 98-02 F-body
- Camaro turn signal
- Rear Main Seal bracket/holder hardware.
- 99 or newer wiper arms
- injectors
- Need a hood
- WTB: turn signal lens
- Need a SLP or Hooker Catback for a 95 firehawk
- Wanted Y-pipe for lt1 Hooker long tubes
- WTB a pair of O2 sensors pref. AC Delco
- looking for a rear end
- wtb LT1 engine
- looking for headers/carpet
- Looking for wheels (w/tires a bonus)
- WTB sun visors dark gray or black
- A/C Compressor for LT1
- WTB: LS1 Fronts and Rears for LT1 Conversion
- Need a complete t56 swap ASAP!!
- SS Spolier
- ***need a fender***
- 4th gen camaro fog lights
- Need Borla Adjustable Plates for 94 Z-28
- Starter and Headers wanted for my '00 Z28
- Flow Reducer
- WTB: rear cargo cover
- 97 camaro fuel lines on a v6????
- Need transmission wiring/connectors (700r4)
- WTB: Lt1 Nitrous Outlet Monoblade Plate
- WTB: 93-96 LT1 CAMARO Tail Lights!
- Wanted: 218/224 or 223/230 Elliott cam
- lt1 SLP fan switch
- WTB: LT1 headers
- ltcc
- WTB: Wolfe Bolt In 6 point Cage...
- Heads
- Posi rear end.
- Salad Shooter Center Caps?
- Need badly a ws6 hood
- WTB: T56 Transmission swap for 95 LT1 Camaro
- WTB: LS1 Motor
- need 6-speed center for 97+ console
- 98-02 Front Brake Swap
- F Body LT1 near Gulfport, Mobile or New Orleans
- WTB: 3-Series Limited Slip Carrier
- oil pump stub gear
- ls1 radiator support
- wtb:AIR elbow
- WTB 93-96 camaro clusters 150 mph
- WTB LT1 supercharger
- WTB: Stock 24# injectors
- WTB 93-97 Z28 Cowl Hood
- water pump drive shaft wanted
- WTB 3 series carrier
- 99 LS1 M6 Wiring Harness NEEDED
- WTB-LT T56 Trans Swap
- WTB: 18'' tires
- WTB: White Side Mirrors (Camaro, powered)
- Starter for 93 lt1
- WTB lt1 cam, new or used
- Wanted: E-brake cables
- wtb cc 306 or gm 847 cam
- WTB 6spd Console
- WTB: LE3 cam
- WTB: Rear end, no traction control
- Heater Lines for 1996 LT1
- WTB: Chevy 3.4L V6 Engine
- Looking for stock T56 bellhousing for LT1
- 94 convertible top switch
- WTB: WS6 air bellow for lt1
- Suspension parts
- Right side wiper linkage 93-97
- WTB: A-pillar panel for hardtop 4th gen
- WTB: 96-97 OBD2 Timing Cover
- Stock Torque Converter for 95 Z28
- 94' Opti-spark
- WTB front bumper
- ls1 air lid/radiator support
- vented opti, water pump, etc
- Timing chain cover,etc
- rockers, springs, guides, and pushrods
- Firebird Door - Rear Axle - Antenna - MAF - More
- wtb: rear hatch panels and LS1 M6 lower rubber shift boot
- ATI 8/12 rib 2.55 2.65 pulleys D1SC Head Unit
- newby here: needs a tranny (T56)
- 97 fuel lines HELP!
- WTB 3.73 gear for Camaro 95
- 94 Z28 interior parts
- wtb driver side ext parts
- powerglide crossmember and shifter complete
- anyone have an extra sping retainer layin around
- stock lt1 bellhousing
- WTB single gauge pod for fbody
- WTB- LS1 Block complete, 243 heads, red camaro bumper in ILLINOIS AREA
- Need An Intake Elbow...
- Looking for 'Vert roof thingamabobs ...
- 17 x 9 Painted ZR1 wheel 1 or 2 (GM)
- Looking for cruise control module for 94 T/A
- Need Xenon Bodykit + Rims/Tires
- WTB: LT4 extreme duty timing set
- cam and rockers
- 750 CFM Holley (or the like)
- WTB 4th gen fuel rail bracket
- 1996 T-top Headliner and Front Seats
- WTB: LT1 Clutch fluid Reservoir.
- 94z28 M6 Parts Needed
- Wtb MSD spark plug wires for lt1.
- Need asap! Slave and master
- LS1/LS6/LQ4 maf
- 93 - 95 LT1 Single cat Shorty / mid Headers
- Front End Parts Needed for 98-02 SS
- Wtb-LS1 T56 input shaft in good shape
- Lt1 Nitrous Outlet Monoblade Plate and Jets
- WTB: Holley 58mm tb, 42lb injectors
- air bag cover
- camaro shift plate
- wanted: FLP y pipe and posi rear end
- WANTED: Blue CAMARO CAMARO CAMARO door panels for 83-84
- T56 Inspection Cover - LT1
- (2) zr1 WHEELS NEEDED 16" X 8" / 17" x 8.5"
- WTB Detent cable cor a 93 Z28
- Inner and outer torque bar bracket
- Wanted: LT4 Knock Module
- 95 Firebird T/A rear end
- door handle bezels, rear bumper cover stud mounts
- Someone Dayton/springfield Ohio local....
- seat foam
- WTB: Sun Visors
- 93 z28 ecu
- SS Ram Air hood for LT1 body
- Wanted set of four 10 spoke SS wheels 00-02, TOP DOLLAR PAID
- 58mm Throttle body
- 94z28 Parts Needed
- LT-1 Supercharger or turbo kit wanted
- White ZR-1 wheels
- Ws6 hood
- stall convertor for LT1
- wtb: LTCC
- LT1 Parts I'm looking for...
- Z06 or ZR1 wheels
- Engine Rebuild Parts Needed
- Body parts for 1970
- 00 SS 10 spoke wheels
- Need 98-02 parts
- Wanted : Stock LT1 cam
- WTB: Tail lights-Both
- 42 lb injectors
- stock parts wanted
- Auto shift cable
- WTB: LS1 driveshaft
- Looking for tri color driver side tail light + Center console 6speed 4th gen
- Trade 98-02 clip for 93-97 clip
- rockers 1.6
- 93 camaro interior parts
- WTB 14101083 Cylinder Heads
- WTB convertible parts for 97
- WTB 93 up ttop holders
- 94 Camaro Window Switch Bezel
- non-vented opti shaft
- wanted. camaro 97 dashboard
- Seat cover
- camaro rims
- WTB: Wolfe 6 point Bolt In Cage
- WTB: 1996-1997 Camaro SS / ZR1 Wheels
- Dip stick
- in need of OBD2 Timing Cover 96-97
- Need 93 lt1 f-body parts!!!!!!
- LT1 head/heads
- 1LE fog light deletes
- stock lt1 springs
- High Flow MAF
- cam setup
- ZR-1 wheels?
- Pressure Plate Bolts/93 Z28
- LS7 Clutch, Upgraded Fuel Injectors
- Need some parts to finish my build
- SLP Muffler
- 1995 Z28 Center Console, Rear Seatbelts and Dash!
- LT1 a/c everything....
- 1994 Firebird Switch Bezels
- Rear bump stop 93-97
- OBD2 LT1 M6 engine harness
- 91-92 rear hatch/trunk release button- yellow
- 91-92 Delco Bose Stereo head & Speaker cover
- WTB: Kooks LTs and Catted Y
- LT1 T56 Flywheel
- Need EVAP switch and/or EVAP vaccum solenoid
- I need an LT1 front bumper bracket!
