View Full Version : Advanced Tech
Pages :
9]
10
11
12
13
14
15
16
17
18
- Nitrous wet kit in 1 bottle?
- Home made headers?
- Jet Hot coated intake
- Two Powerhouses Bang Heads - Video
- Why Canton pans for LT1s?
- Need correct cam degree bushing set ...where to get and what PN (' 97 LT1) ????
- Correct way to fix heads that have been ported through the walls?
- Copper head gaskets and oringed block decks????
- The new vortec head design
- Where is the mileage stored?
- Miller-Cycle V8 conversion?
- 383 engine swap question
- Importance of intake tract design.
- Can I get some advice about cast iron heads on LT1 hi-po buildup?
- which 383 to go with?
- Adjusting Oil Pressure
- 3.5 Inch Stroke?
- Convert to HEI w/ stock PCM?
- Acid porting
- Compression / Piston problem.
- Even Warren Johnson has bad days.....
- DFI O2 sensor
- Reproduce a Ferrari Sound
- Interesting interview with GM chief engineer
- Exhaust dyno questions
- Blown 420 into a 95, need some advice
- to overbore, or not to overbore
- SBC machine work?
- bushed lifter bores
- When do I need a fuel cell?
- Howards powder metal rods, stronger than 4340
- oil pressure prob
- Need a quick dynamic CR check please
- Bearing clearances tight or loose on the mains?!
- Cam nose out of square?
- How do you take apart injectors
- what about this 383 set up
- Fuel Rail Modification (Fast guys, I'd like your input)
- the big block is up and running, now some tuning questions
- Fuel Delivery problem?
- Bad Or Good in use 2 stroke Oil
- Viton and Viton PC?
- Project
- Why rod bolts and not rod studs ??
- Tool belt for engine rebuild..
- FAST/Delteq/stock ecm woes...
- Callies internal balance???
- Piston to Valve Clearance
- Need some help here, converting to single plane intake
- Cam Lift Vs. Head Flow
- The Truth About Top Fuel Motors
- LS1 valve lock same as SBC
- Valve Covers with high lift cams
- When to move to Comp R Lifters
- 4-valve heads for GEN 1 smallblock.
- The Physics Of Throwing Rods
- Tricks to balancing a motor with a dual mass flyhweel?
- 600+ hp naturally aspirated mills
- Anyone running aftermarket fuel rails?
- Balancing ?
- L88 valve springs
- Gold Coating from Swain and water injection
- valve springs
- Need Info on Carbed SBC CONVERSION!!!
- big inch nessecities
- Forged steel cranks and high dollar rods in street motors?
- write ups On Using Epoxy for Head porting
- sorry to post here but ls1 ?
- removing metal shavings
- Egine Oil/Rear End Temps
- Piston to wall clearance and ring gap question
- 305 twin turbo, stealth ram, commander 950...wont run!
- Great service from Manton Pushrods!
- Need some serious engine builders advice
- Question about Tri-Y headers, 4-2-1
- new engine problems...oil pressure
- LT4 rocker arm studs
- Valve spring life: fast ramps vs high lift
- direct main-cap oiling
- Couple flow questions...
- Blown Speaker in My Exhaust!
- Cola does not make GM's new 3.800" crank
- LT1 v/s Gen1 Cam Specs?
- Bob weight question
- chewed up a cam and lifters ruined in 100 miles please help!
- Careful with Compression Calculators!
- need help with fuel tank pressure after a high po pump and line install
- Popped a Head Gasket weird deposits:Pics inside.
- No Opti w/ Stock ECU?
- Compression Test
- Speed Pro Plasma Moly rings
- LT4 short block Rev Limit
- Dyno result question
- Guys with no PCM and FAST inside
- cranking Rpm
- Valve springs and titanium top end
- Confused about heads for 350.....
- helium in tires?
- Old 1960s-70s 327 Chevy in 94 F-body
- How much HP can a 48mm T.B. support?
- Distributor part 2 (wiring)
- Propylene Oxide?
- What signal type for factory tach?
- HydraRev Kit Spring Pressure
- cracking roller rocker nuts ???
- 327 LT1 Destroker?
- 383
- Individual cyl. temp problem
- does oil pump need a gasket?
- Stroking a 305 roller motor.
- Powerband affecting gas mileage
- Can someone explain the purpose of this
- Just wondering if anyone got the Arao 32V setup running on an LT1
- Has anyone had to adjust rockers while running?
- cam firing order question
- Engine oil
- first 383 build
- This is going to SOUND like a Forced Induction question.
- lt4 valves
- I seriously need help.......my car keeps on overheating PLEASE DONT REMOVE!!!!
- Optimum rod length for a 396 Nitrous Motor
- Collapsing a lifter
- Advice on timing advance for my cam.
- Clearances between rocker and valve on solid cam?
- Clevite 77 H bearings teflon coated?
- head stud questions ...
- Valve size for stock ported heads
- LS1 CAM vs. 4-7 swap CAM
- 350 TPI combustion chambers
- Big inch, high horsepower LT1 4th gens, what are you using for headers?
- possible LT1 intake design flaw?
- Gen7 DFI Install
- 95' Z28 EFI 540 (Pics)
- Dart Iron Eagle pan gasket question
- Engine builders. Have you sleeved and LT1?
- Dilemma
- Cylinder Pressure and Spark Gap
- Breaking in my nice shiny new...
- Single Plane intake manifold and cam numbers
- new motor leaking air through exhaust valve...
- Will a hydraulic flat tappet cam work in a roller cam block?
- Perfect Top End for you advance tech guys-->
- Stock connecting rods to race rods?
- Gen 1 SBC Into LT1 Car
- Hung up on #s
- Opti rotor degreeing?
- Drilling for distributor
- Reference voltages and sensors
- Ceramic coatings - possible sensor contaminants?
- Rocker geometry question
- Need help interpreting hardness testing results on wiped cam & lifters
- New 383 has vibration only at 2500rpm?
- ? about affects of valve sizes on head flow
- Looking for engineer-type opinions on bike exhaust
- Coating your head ports and pistons
- HEI distributor or edis
- timing set problems
- I got a question about a 383 in a CJ5
- please help, cam may be wrong!
- The weirdest sound coming from the front of my LT1..please listen and post ideas.
- BBC Heads
- non resistor plugs
- anyone heard of these guys?
- X vs H
- computer wiring help.
- Dynojet Questions
- Presoaking Lifters? The ongoing debate
- Teflon vs. Viton valve seals?
- DEI dominace?
- Merge Collectors
- Advice needed on how to fabricate a plug & mold for carbon fiber layups
- Engine breathing: carb vs efi
- Lucas 42 lb/hr disc type injectors and 80 + PSI fuel pressure
- 1969 LT1 Chevelle
- Valve spring dampener coil question
- gm 383-4340 crank
- Prospective build, looking for input
- geometry
- optispark signals need help
- real quick ARP stud question
- Different kind of engine
- TPS Voltage , Relation to Throttle responce?
- 4 bolts vs splayed
- 396 questions
- Aluminum Rod question....
- engine building tricks
- bottle hone brush
- Fabrication How to???
- Oil squirters
- AFR 210s Flow numbers... a bit odd..
- Custom Cam/Injectors ??
- Stainless vs chromemoly rockers
- Split BLM, TB, fuel rail question
- 454 tuning questions
- Block filler
- Lexan Race Glass
- Getting rid of Opti w/ Accel DFI
- LS6 flow #s
- Reprogramming MASS vs MAP
- AFr 195, 210, 220???
- Info on Cam Motions cam?
- oil pessure for 400?
- Question about "stretch" method for rod bolts?
- Manual Rack
- Compression & Timing Curves
- drilling splayed caps
- need some definite 100% sure oiling system answers
- Why WON'T Vortex Devices Like This Work...
- ? about Vacuum pump and PCV system
- External oil cooler for LT1- line size
- swaping up
- Cam lobe/lifter orientation question
- what plugs to run
- Flowing Heads
- Finish this Equation :)
- 4.00 Stroke?
- AFR for lean-cruise carbureted engine
- conversion to msd distributor(wiring)
- "The Truth About Chassis Dynos"-- Hot Rod article by Marlan Davis
- The "WORLDS" best Advanced Tech car?
- Highest flow 4 inch in/out muffler, need some test data
- Anyone got pics of a Wilson LT1 Sheet Metal Intake?
- some ?'s about breaking in new motor on the dyno
- Whats makes the diff between Lt1 hubs
- Yanking PCM/Harness ?'s inside
- LT1 on Nitro=Zoom or Boom!
- Plenum volume and torque/gas mileage
- Cryogencially treated parts?
- oil pump
- 4L80E swap in depth w/ pics
- Mirror Image Pistons
- Advanced Tech's, A total Loss Now. Need Help
- Cutaway vs. full body lifters?
- Torn between two different intakes
- Piston oil holes
- Is it possible to have a motor that won't ping regardless of the amount of advance?
- Forged vs. Hypereutectic for turbo applications
- Internal coatings
- cheap TIG welder?
- Oiling, Accusump, Filter relocation, and coolers
- Intake inner runner wall removal
- Carburetor choice
- What's retarded here - Me, My FAST, My CRANE?
- Exhaust collector theoretical question
- Block Preparation
- Flow charactoristics of bends
- comp 1.6 promag question
- LS1 PCM to control 4L80E in LT1 car
- Good Head Match?
- 383 stroker damper/flywheel ???
