- Screw in IAT
- LT1 wiring harness question
- DFI timing map
- wanting to change from obd1 to obd2
- Custom PCM mods to support nitrous
- pcm fried sorta
- Software using USB cable
- stock 95 trans am file
- will a 94 computer work with a 93 wiring
- My Datamaster files - Wanna take a look?
- 95 lt1 engine harness and computor going in a mustang.
- Does Tunercat run on Vista?
- 94 z28 pcm cable
- my speedometer is possesed
- Help with the BCM!!
- Can a bad battery cause an improper PCM response??
- LT1 computer problem
- Chip # or model# for '93 LT1?
- VSS wire location?
- tuning myself with a base calibration tune
- Map programming for boosted car?
- anti theft elating to not cranking
- 94 formula not connecting
- tcc trouble
- data cable
- RAM-AIR MAF tables
- Using LM1 Wideband Simulated 02 Output?
- LTFT questions
- hypertech III
- New to Tuning. Need Help pleasee
- Roots blown LT1, need serious tuning help!
- 2 Bar Stock PCM Speed Density Tune for >6psi (Forced Induction)
- Left bank running richer than right
- Using wideband for tuning supercharged lt1
- running rich at idle
- Tune to make shifts less firm?
- Found good PCM tuner in Vancouver, BC
- obd1/obd2 quick swaps
- PCM Error writing Tunercat
- looking for a Tunercat tune file 383 with 306 cam
- Where is the diag. codes thread?
- 95 lt1 and tunercat
- car won't start HELP!
- is there a way to by pass the knock sensor on a 93
- Crunching the numbers...
- 1994 Z28 PCM revision "B" or "C" ???
- MAP threshold to enable WOT ???
- hooking up obd1 to a obd2 scanner
- Locking converter under WOT bad?
- got efilive now i need a wideband 02 sensor
- Are Manual and Automatic steering colums interchangeable?
- Question on Hypertech Tuning Module
- Dyno Tune In Ga
- madz28 tuning
- How many dyno pulls in an hour?
- did a little shift point adj.
- Changed gears from 2.73s to 3.42 speedometer is off.
- OBD I Not Giving Codes
- Help Could It Be Opti!!!
- electrical problem
- Weird Speedo problem
- Datamaster for AFR Data?
- OBD1 Scan Gauges?
- datamaster question
- traction control disable
- AutoTap Sample Rate
- Question on TCC Settings 1994 Z28
- How Do I Know
- C.A.T.S users in here please......
- ALDL Signal Ground wire/ Where does it come from?
- akm cable question?
- HAS anyone used PCMFORLESS to Dyno/Tune?
- O2 mv rich/lean mean threshold vs airflow tables? LT1/4
- Wireing Help/ How to wire a OBDII port?
- Someone Help me with TunerCats and Freescan Problem
- Any ideas:replacement PCM causing incorrect speedometer readings and reverse difficul
- Cant lean out AFR
- Output Driver Module Fault
- fault code 43????
- OBDI guys, how are you reading your wideband data?
- Tunercat Lt1/lt4 Tuneing Program
- Freescan Question...MAP readings
- Need help wiring up my 98 LS1 in my 1996 Z28. Thanks
- Knock retard after replacing MAP. Why?
- Mail Order Tuning...Who???
- Weird MAP readings
- Free datalogging software?
- Those who flas there own flash chips inside please. Need Help!
- I need some pinouts of these 98 LS1 connectors (c100, c105, c210, c220, c230)
- programing the bcm in a 97ss
- Which serial-USB adapter to use for Tunercats?
- In need of 1996 and 1998 F-Body PCM Pinouts!
- what table does what
- I thought the Baro air pressure would stay the same.
- Need advice on spark timing tables
- Code 15: Coolant Temperature Low
- Dyno tuning near Vegas..?
- Can't read PCM even though there is communication
- security light
- no wot 2-3 shift command
- Tunercat table for idle?
- Who wants to review my log?
- efilive v2
- Idle problem suggestions
- Ls1 swapped into fox body.. computer issues yet again
- PCM4Less
- tuning near NE Iowa?
- What is the signs of a dying computer
- Freescan user please help
- 96 TA with obd1 conversion emissions?
- Now offering programming on "black box" Vortec trucks
- Headache
- Changing air/fuel
- ABS and TCS/ASR lights on intermittently
- Car wont start
- 4A-->T-56 conversion
- add fuel via rpm in open loop?
- Wanted: Datamaster files logged at 10 records/second
- Tunercats or LT1edit in MI??
- Does anybody local to SoCal run the older F.A.S.T
- Looking for a dyno place
- 94 Hypertech Programmer use in a 95
- Xd-16
- LT1 datalog info please
- PCM Learn issue
- 408 going in, base tune for initial fire-up - critical
- 6LS Box
- Body Module Computer
- Plz explain cat over temp
- Gear Change
- Tuning out knock with Tunercat
- 4L60E --> T56 conversion information
- your opinion
- how to read a freescan diagnostic text?
- After dyno tune, no lock up, no WOT shift command
- Best bet.
- FAST/XFI, Anyone modify their Optispark for use as Cam Position Sensor?
- OBD2 to OBD1 conversions
- Will tuning fix my 3rd gear lockup issue?
- abs codes
- PCM Tuning with Aftermarket MAF
- Datalog. What the best way to get the most info?
- good reprogramming software=> which brand to buy
- main spark advance tables w/ cam and heads
- could some one look at my data files?
- 42# Racetronix Injectors - pcm changes
- Are '96 and '97 computers interchangable?
- good tune for my car?
- Newbie to tuning, please check out my current tune.
- how can I richen up my tune at partial throttle - current vector tune
- need a tune to get started
- OBDGauge: OBD on your PDA
- Programming Rev Limiter
- wiring question
- Holding 3rd in an a4
- Custom programming has never been easier
- need info. please help
- Auto trans LT1 swap into manual trans jeep??
- will work for file?
- Which to buy and Why? hptuners,EFI live, Ls1 edit?
- Knock retard and pulse width help please...
- Installing Drivers for AKM
- how can i get datamaster to work
- I have a idle problem, I recoreded part of my screen with tts running
- BLM's are higher on left. What could be wrong
- 12 to 16 pin adaptor work w/ tunercats??
- 115 to 155 speedo can comp be programmed to read accurate?
- Fairly stock 94 T/a runs rough no power
- Stuttering
- Torque management ,line pressure.etc questions in my 96z
- Datalogging for boost
- laptop requirements
- reflash pcm
- Motec VS. Megasquirt
- gen VII DFI
- Datamaster files inside
- AFR used for your higher comp LT1 engines?
- FAST double bank wideband
- usb to serial converter
- VATS Question
- OBD II port is dead
- AKM Cable?
- Logging with autotap and tunercats cables?
- Anyone have idea how knock correlates to power loss?
- Need someone to help with datalogging
- Do i save datalog on disc or harddrive?
- Pulling Codes
- need less fuel in open loop , is this the correct way to do it.
- Affordable wideband controller :-o
- How do I get more fuel at the top end?
- Diablo Predator Available
- Knock experts please help
- Pulling timing under heavy load... is it abnormal?
- why is my car showing this rpm like this?
- Can't get scanner to read HELP
- TUNERCATS Binary File Compare Question?
- Knock counts & knock retard question...
- LS1 in my 96 / LT1 Gauges on LS1 Engine??? Adapter??
- Can't figure out how to datalog.
- use dm to diagnose exhaust leak before o2?
- need stock timing tables for 95 lt1 a4
- turbo tunning with tuner cat help
- stock LT1 TA things to change with tuner cat?
- DIY ALDL cable?
- Tuner in the Kentucky area
- Is this tuning kit any good ?
- what am i doing wrong??
- Jets dynamic spectrum
- Stock 95 camaro z28 342a4 bin file
- Wideband install question
- 342 Shift points and downshifts
- obd1 vs. obd2
- Datamaster trans logging question
- Blocking off EGR & A.I.R. Injections a problem...
- Security System Malfunction
- PE tables
- Open Loop AFR vs Coolant Temp vs MAP
- hard wiring oxygen sensor
- startup and in open loop not running right
- FROM 18 TO 24MPG with a few tweaks!
- tunercat question
- Idle surging.... Long story and log inside
- How to add fuel with Tuner Cat to richen mixture LT1
- can someone tell me why my 02s are doing this
- AFGS to CFM conversion
- RWHP and AFGS readings
- Problem with tps, 02 runing rough.. need help
- New dtc's: 16, 41, 42, 51
- Tunercat file
- Laptop Based Tuning for LT1s
- Checksum
- Questions about Datamaster
- Changing shift points with Tuner Cat.
- Did I pop my computer?
- What exactly is done to an OBD1 computer to make it work in an OBD2 car?
- BLM Counts resolved?
- Trouble code
- tuner near or in Alabama?
- hypertech questions
- pcm adapter harness
- northeast pa street tune
- Is converter lock up controlled by speedo on a 89 IROC?
- Racetronix 32lbs rate specs
- cable question
- Need an .xdf file for a 93 LT1
- transmission has tuning or mechanical issues?
- so ive got another problem
- Does the speedometer have any effect on the computer at all on an 89 IROC.
- Looking for a starter bin 383 gm847
