PDA
View Full Version : Computer Diagnostics and Tuning
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36
  1. Any free scanning software for OBD2 vehicles?
  2. Dyno tuning shops
  3. Frogot How TO Read the PCM (TunerCat) ~ Been A While!
  4. No cats, how to take of engine lights
  5. 98 ls1 wiring question
  6. Tuning after a gear change
  7. Stumble at Start
  8. BLM locker won't work
  9. Blue Smoke out back on less than 1000 mile non raced motor?
  10. How to send a Datamaster log
  11. Stock ECM with MSD opti, or Big Stuff 3 and a dizzy?
  12. Needed: 98 & 99 LS1 F-Body Connector Pin-outs
  13. Got the laptop, now I need to know where to get the free version on DataMaster
  14. Need help! I think it's running rich, rich, rich!
  15. Freescan Help
  16. Problems with my 97
  17. ABS woes
  18. SpeedO
  19. OBD 2 Inspection question
  20. where to send pcm to be flashed back to stock?
  21. service light comes on and off
  22. Holding a tune
  23. 2-Bar Scaling - Questioning the validity of 2x
  24. 95' camaro PCM tuning
  25. Stall Wall Fix
  26. OBD2 to OBD1 Conversion - No 4th Gear?!?
  27. I goofed up and wiped my ecu
  28. bank 1 ltft at 25%
  29. Maybe a bad PCM? (Kind of long.)
  30. trouble code p1361? help!!!!!
  31. Camsurge related problem...SD and Jet DST(tunercats) OBD II question
  32. 2 Codes P0100 and P0303
  33. help, running very rich
  34. Tuning in michigan
  35. Using VEmaster with the 96-97 LT1
  36. What reads other than engine codes (>c1200)?
  37. Cheap software to read DTC with link cable/laptop?
  38. Black stains on White bumpers
  39. DataMaster/Tuner Cat questions.
  40. No Communication
  41. Volumetric Efficiency vs RPM vs MAP....
  42. O2 sensor depth (in bung)
  43. A4 ECM for T56 car
  44. 93 computer converting to 94+
  45. Need help with tuning discrepency
  46. Timing question
  47. Tuning LT1 for no tranny
  48. not accessible?
  49. Program: LS1 Edit
  50. Rough idle with big cam
  51. Trouble with tune
  52. 97 lt4 383 tune help, jet tuner
  53. Please, help with knock. TTS data attached
  54. 94+ T56 VSS pulse per mile
  55. Long Term Fuel Trims Split
  56. Stock lt1 pcm and boost?
  57. Finally got things set up to tune, and now the questions
  58. DTC42 starts then dies
  59. No lift to shift box
  60. Need advanced tuning help. MadZ28 Tune.
  61. boosted lt1 stock pcm
  62. No Start 95 Z28
  63. O2 sensor error codes and tune questions
  64. Computer/Electrical Problem
  65. Scanmaster and laptop question
  66. 95 3.4L, OBD '1.5' - Can't get scan tool to connect
  67. Can someone help with some trouble codes i got with datamaster?
  68. p0441
  69. LT1 Tuning help, 02/fuel trim #s
  70. Tuning Spark Advance w/out a working Knock Sensor?
  71. Which tuner cat program do I need?
  72. performance chip/module
  73. can't get data master to run
  74. 96-97 Crank Sensoe Relearn ?
  75. Heated O2 and running rich
  76. 1996 Z28... Data Logger and tuner?
  77. Fans not comeing on
  78. OBD1 Scanner or laptop?
  79. mechanical or tuning?
  80. Cable NOT Found???
  81. Timing reduction issue
  82. anyone tune obd1 LT1's in jacksonville?
  83. How to remove wiring Harness 94 lt1?
  84. Can you split this forum in two? 1bar vs 2bar?
  85. Mail order or Dyno tune?
  86. What's neede to tune OBD1/OBD2 LT1's?
  87. 1st prime pulse width vs coolant temp
  88. Anyone using MAF Translator Pro w/OBD II?
  89. Reusing a tune and pulling a tune...
  90. '99 SS - Tuning or 4L60E trans problem?
  91. Ne1 use Innovate DB kit with the A/C Datamaster mod
  92. Surging at idle
  93. Cruising & WB goes to 12.5 then normal
  94. Bench testing PCM
  95. SES light but no codes?
  96. Cant scan the comouter!
  97. Strange issues with my tuning program files
  98. Dyno tune or street tune which is better??
  99. Best pc based diagnostic software?
  100. Lean at WOT with open loop.....
  101. Who is re-socketing PCMs now?
  102. Tuning for 58mm TB and ported intake? (tunercat)
  103. trans temp
  104. Brothers LS1 ******?
  105. Need help with my tune
  106. need advice, nehoff vs. gm vs salvage PCM
  107. LT1 Tuner in central Florida area
  108. Guru's please look at Freescan file and tell me whats wrong.
  109. What does Hypertech tuning do actually?
  110. Theft system
  111. Invalid response from pcm
  112. 2 Bar MAP conversion chart
  113. Datamaster intermittently going out
  114. Set new gear only with ALDL cable
  115. DA2 Tuner Cat help
  116. Seeking pcm suggestions
  117. Which OBDI Cable?
  118. Lets discuss WOT tuning strategy.
  119. Tuner cat questions!!!!!
  120. Tuner Cat Questions!!
  121. which tuner to choose
  122. just bought tunercat and a laptop..should I buy a USB or serial cable?
  123. Tuner Cat PE questions
  124. Power Lock Probelms
  125. Dual-bank wideband users...
  126. Disable alarm on 00 SS
  127. Is my PCM going brain dead?
  128. lt1 runs on ls1 computer using modded OPTI
  129. fans coming on way early?
  130. Tuning for installing cats? Recommendations so I dont ruin the cats?
  131. IAT adjustments?
  132. SLR motorsports chip
  133. perfect tune maybe
  134. 1987 IROC Any Ideas?
  135. lt1 tuners in ne arkansas, se missouri, or west tenn
  136. Datamaster or Freescan help?
  137. Is this true ?
  138. ECM constants affecting spark
  139. guage problems on dash
  140. Where did most of you guys start???
  141. Can anyone give me the correct calibration for my speedo?
  142. obd1 scanner help
  143. Question about stock car w/ 60# inj. and open loop
  144. Abs
  145. Shift points
  146. problem code 0118 need help
  147. OBDI low octane tables
  148. My '95 camaro z-28 will not start
  149. Knock retard @ idle, but goes away when I give it gas??
  150. car runs better right after tune, then falls on its face.
  151. knock sensor....how much timing
  152. LT1 obd1 pcm use with BCM???
  153. Did I ruin my MAF?
  154. Flasher unit Location
  155. Knock retard
  156. ? about data port?
  157. wide band readout with fast xfi
  158. Accel dfi emissions tuning
  159. needs help
  160. RELAY (Fuel Pump) is chattering...
  161. Need help choosing a way to go about tuning
  162. Can't get a data logging program to work
  163. Lt1 edit - help got questions -
  164. Hypertech
  165. Security problems...still
  166. places that dyno tune obd1 cars
  167. How to replace Bank 1 #2
  168. No Power to scanner?
  169. 383 tuning
  170. PCM help
  171. Scan Tool Sensor Information
  172. Need Jet DST file
  173. Stock 95 Z28 M6 PCM file
  174. Tuning for GM 847 cam
  175. MAF and Speed Density?
  176. Reprogrammed PCM problems
  177. Switching from MAF to SD...turbo,2Bar map???
  178. 3.90 R&P to 4.11 R&P. What do I change in my tune?
  179. M6 or a4 tune?
  180. Soo i just killed my first PCM. Questions...
  181. 1995 lt1 pcm tune help
  182. P0507 code
  183. 95 LT1 WOT VE tuning issues!
  184. Using RT Tuner with a 97 LT1, OBD2 to OBD1
  185. 1996 does it need a chip?
  186. tuning options
  187. Can someone help with Datamaster .CSV's, Please
  188. Bad sensor in water-pump????
  189. help tune ??!
  190. 93 camaro to 95 firebird Harness and pcm
  191. Can't get TCC to stay engaged in 4th!
  192. p1870 help
  193. p1406 code help
  194. MAF delete?
  195. Rough Idle runs good at WOT - Data Log Inside
  196. 93 ecm interchangeability?
  197. CAS Sensor
  198. Tuning Question on '96
  199. Bcm or alarm module
  200. lt1 edit or jet ds tuner
  201. hypertech on lt1
  202. PE idle
  203. p0420 quick fix for emmisions
  204. 94 camaro LT1 in 1997 camaro ss
  205. jet lt1 soft ware
  206. 94 M6 Stock Virgin Tune Needed Please
  207. which one?
  208. Question on running the LT1 with a non OD transmission
  209. Service engine soon
  210. cats files anyone?
  211. diablo tuner
  212. OBDI PCM - Past 7K
  213. FNG checking in, like some advice, datamaster file
  214. Fried the ECM
  215. ECM are they the same
  216. issues
  217. TP sensor
  218. Building an Bench EFI
  219. quick question bout ways to datalog
  220. HELP Emissions Problems
  221. datalogging for obd2
  222. Interesting link for noobs to datamaster
  223. tunercat help
  224. PCM reflash question ,Gurus help!!!!
  225. obd1 to usb ???
  226. How to change LT1 vin in file?
  227. Already have AutoXray ALDL cables, wanna use to link laptop
  228. MPH versus rpm question
  229. Turn your iPhone into a scan tool
  230. gear ratio vs shift point
  231. Map reading high I think
  232. Am I missing any options? looking for help.
  233. Looking for a dyno tuner in Phoenix/Tucson area.
  234. Datamaster 1/4 Mile Estimator...lol
  235. Code 33 MAP high
  236. Anyone having problems getting ahold of tunercat recently?
  237. Is it possible to convert OBD 1 to OBD 2?
  238. 98 Camaro V6 - Electrical problem(Radio, Transmission, and now Starting problem)
  239. what tuning cable for obD1 conversion?
  240. ? about tach signal
  241. mail order tune?
  242. Running very bad !
  243. Help with LC1 setup
  244. Upgrades.
  245. Confused about scanners and programmers
  246. malf 42 est grounf
  247. Project '99 SS threw two codes today - help?
  248. installed a CompCams camsahft into 1987 IROC 350.
  249. Donor cars for 93 LT1 and trans
  250. Left Bank Rich, Right Bank Lean? Why?
