- Shift points strategy?
- Tuning questions.
- Idle running rich(116 blm and going lower) after nearly nothing...
- Need a decent tune for a cc306 and le2 heads 350ci
- Tuning for a mac off-road pipe
- computer chip
- How to reset my iac sensor if unhooking battery doesn't work
- TunerCat - 350 to 383 - Questions
- Reflashing the PCM for gear change
- Speedo off
- MAFt Translator/MADZ28
- Cash for clunkers computer
- Please help with Locking BLMs
- Help..Old and Decrepit...and this car won't fire..'95V-6 to V-8 conversion..OBD1 pcm.
- Pcm lost connection while reprogramming..
- EGR settings in Tunercat
- P1133, I've searched and learned - just need a "probable cause"
- Need a dst tune for 97 auto lt1
- tuning the 93 Z28
- reading live data 94 lt1/pcm
- Lt1 Edit connecting to computer???
- Wiring single electric fan
- Forged 383 with 235/242 cam 278/210 cfm heads only making 380whp@5500rpm? Help!!!
- 94 LT1: weird miss at light throttle
- Can't read my PCM
- Stock Flash and not 2-3 upshift
- Runs great after retune then falls off.
- 85mm maf swap and now problems
- OBD1 EPROM Flashing-what all do i need?
- No engine braking in OD, nor TCC lockup. 94 LT1/4l60E swap.
- lt1 Heavy bog-knock retard.
- cc305 cam tune
- shift light
- stock 95z m6 BIN file needed
- Couple of questions about auto trans tunning
- Stuck in cells 16,17,18
- Scanmaster hook up OBD-2 PLUG? Need help
- P0441, made tune near perfect
- Tuning package for a '98 Z28? What one?
- tuning my 93
- 1996 Z28 Lt1 Tuneup
- Car goes dead
- Z28 wont stay cranked...computer?????
- Can't get engine and trans working correctly together.
- Diagnostic Tools for OBDII
- Po 171- po 174
- Datamaster problems
- Split BLMs in Cell 17
- Does Anyone Know How I Can Do This?
- Hacking Auto X-Ray Cable?
- clearing codes
- New 383 tune
- 383 LT1 Emissions Tuning - Passed with flying colors
- Auto trans programing help needed
- Datamaster idle log can somebody please take a look?
- Check engine light, no codes with Free Scan
- MPGuino Install
- 2 bar map reading odd..
- stock bin file
- super lean in closed loop fine in open..please help
- switch to OBDI and get tuner cat, or get ign. box for nitrous??????
- 97 LT1 holds 1800RPM after WOT
- Logging boost and widband through stock computer
- Anyone have the pinout for the knock module?
- PCM tune, MAF or No MAF?
- Speed Density vs MAF
- code 33 map sensor
- Performance Tuning
- BLM Locker
- What the heck are my O2s doing?
- Question about the basics
- Tuning question for my build
- Problem after "Battery Voltage Out of Range"
- Open Loop Tune - Run me through the basics guys...
- Tuning for Smog - Any tips?
- Wiring Issues- monsoon amp
- How do I tune my computer??? Please help
- Any J2534 compatable tuning progs out there?
- IACcounts pegged at 160
- Anyone ever had trouble with FreeScan giving wrong values?
- Split BLM's - Getting Worse - Running out of things to try ... Help Please ...
- '97 LT1 Smog Pump Removal?
- Injector Offsets - Stock vs Delphi 38# Injectors
- .bin To .LT1 Extension
- TPS % not reading 100% at WOT in scanmaster
- Ny problems running TC with AVG running in the background?
- Rewire and now BLM's are off?
- Tunerpro RT V5 Beta
- 95' engine in a 96'
- Missing some constants in TC
- ALDL cable (snap on)
- tach stopped working??? whats wrong?
- PCM BAT fuse keeps blowing
- Anyone have a Tunercat definition file?
- air bag light came on how do i diagnose this?
- Code Reading
- 96 LT1 computer acting crazy
- OBD1/2 USB cable
- TTS Datamaster
- High idle on LT1 swap
- my volts are redlining
- Code P0420 bank one cat converter is driver side?
- How to desensitize knock sensor in tunercat ?
- Rich Idle & Variable Knock...Datamaster files
- Tuning questions, check it out
- tune and o2 sensors
- hyper tech pp plus help
- 96 LT1 TA issue (Diagnostics)
- Obdi or obdii??? Please help!
- Anyone using Auterra dynoscan?
- EGR - what is the correct RPM setting?
- 97' Firebird Overheats at when idle PLEASE HELP!
- MAF Sensor and VE Tables Question
- Whats a good LT1 dyno tune worth ?
- Vats disable question?
- Went to the track, Knock retard!!!!
- 1993 Camaro OBD1 tuning
- Scanned codes...where to begin?
- Where can I get the computer reprogram
- 383 lt1
- Tunercat table for PE or WOT fueling
- Unknown Dash Light
- which o2's to use?
- 1996 Camaro ECM cooling fan problem
- Air Bag and Service Vehicle light
- O2 Reading Oscillating at WOT?!
- TTS Datamaster 4.0 Released
- Anyone used this software?
- Which way to go
- I need a little help with my hypertech guys
- ABS Delete Question
- Supporting Vendor
- Negative Fuel Trim
- data logger
- Hesitation/Vibration when I do a slight roll on the throttle
- New map sensor needed for a boosted 95 LT1 ?
- has any one ever played with the jet dst that can help me ?
- Need stock '97 M6 .LT1 file
- 1995 z28 obdII or obdI?
- Would you choose a 95 or 96 z28 pcm to tune.
- Alert! Tunercat users read if you have version 2.24
- 94 lt1 computer speedo calibration
- Need something to datalog my LT1
- Diagnosing the pcm
- old head needs help
- Lt1 CC306 Tune Request
- 1997 camaro odometer question
- Setting 4L60E shift points
- Datamaster read question
- Need good stock tune and MAF calibration table
- O2 Sensors Volts
- Individual Cylinder Fuel Trim
- Stock LT4 PCM settings vs LT1
- Why so many errors? tunercats
- Anyone with a 383 big cam VE table?
- VEmaster will it help a MAF car?
- blm question?
- Freescan - Status messsages window running, but no Dash Board
- VSS throwing check engine light
- freescan: How long to connect
- Long Term fuel trim
- Fuel Trim
- RS232 adaptor to USB 2.0 good to use with Freescan
- Stock Tune Needed!
- tuning question
- Deleting emissions
- Dyno Shop fried my PCM - Don't think they transferred the LT4 Knock Module
- PCM values for 3:42 rear ?
- Should I be real rich during excel?
- TCC WOT Forced Lock Speed Threshold Vs. Gear
- hypertech pp3 does work. have timeslip
- USB to Serial port adaptor
- BLM Boundaries
- .bin to .lt1 or vice versa converter
- TunerPro
- ECM Configuration File Version CV
- soloman's phone #
- Flash a new OBD2 PCM?
- tunercat cable failure message
- monoblade and idle issue
- Run bad without tune?
- How can I log wideband along with regular engine parameters?
- Air Bag Light
- More problems with the Z, surging stops if i disconnect MAF!!!
- 2nd gear lockup?
- help!!! obd2 to obd1 aldl
- EFILive, where can I buy it?
- DFCO Spark Retard: Why does it matter?
- hypertech tuning
- can scan sensor data master but not with a snap on scanner
- trouble codes help
- Trans Tuning
- wideband recommendations
- Help me understand BLM cells
- Baro Update RPM Threshold
- akm cable and vista
- Is ecm bad?
- Wideband for twin turbo setup
- odd misfire only when temp is above?
- Deleting Emissions
- Where to download tune
- still no where to tune a 93??
- Ecm
- tuner cat lt1
- engine idle
- closed loop tuning question
- Programing question
- Idle spark advance
- Problem with starting '95 lt1
- Remove TCC functions?
- HPP3 and HPP Plus? Questions on both.
- does this make any sense
- Tuning?
- Bad Computer
- DFI or BS3 and HOW????
- Intake
- Heads
- problems with the ta codes 48 and 32
- About check engine light
- 133 and 139 codes..should i worry?
- Why can't I check my codes on my LT1
- First datalog- have questions
- 95 OBD1 in 97SS
- Which cable and software best
- Win7 and TTS Datamaster
- DFI gen6 .. getting timeout errors
- Running lean after backfire
- HELP!!! rough stumble between gears
- MALF 41: EST Open
- Target A/F ratios at throttle positions
- cuts out wot and boost...
- Sketchy RPMs at WOT
- BLM Boundaries HELP
- Where to jump 12V switched wire for wideband
- 93 computer conversion Q's
- 95 LT1 Issue
- Need a stock tune for a 94Z A4
- Aeroforce Interceptor Guage
- wideband o2 question
- Stock or fast computer for tuning stroked and supecharged lt1
- I want to tune my 95 camaro
- 383 on stock injectors, 42lb tune
- MEMCAL socket
- Need a few opinions on no-mod tune
- getting set for tuning
- Update To My Split BLM Issue - Suggestions?
- How did you route your wideband wires into the car?
- Reverse Lockout Malfunction after new Master
- Help with choosing tuning platform
- oil temp and fan functions
