- Dyno tuned last night- But did I correct the right tables
- need a wiring harness..where to buy?
- For those interested in self PCM Reprogramming and Hacking
- With DataMaster, I am seeing huge timing retard
- Remote entry
- ODBII & Traction Control
- ls1 edit
- 4L60E trans table experts inside please
- Map Sensor
- What is "total" advance for ignition
- heads/cam: files, advice, false knock
- pcm for less or turnercat
- Tuning out Burst knock issue.
- How do you guy's feel about mail in tunning ?
- What are BLM's and should I reset Them?
- dyno tuning recommendations please
- When You Reset PCM What Table Does It Read At First???
- FreeScan MAP values??
- tunercat, O2s, and nitrous
- Lean, backfiring, and all of that other cool stuff
- what is code 43
- Looking for FAST website.
- TPI tunnin' ????????????????????
- how do i...
- Easy Question, How do you turn off the EGR and AIR Pump
- OBD-I Scanning/Logging/Diagnostic software; want to compile everything avalible to us
- OBDI basic tuning-setup Qs
- HELP!!!! DTC code 51, my car is running like crap at wot
- ls1 edit
- Eliminating Closed Loop....
- Can programming allow me to keep HP gains from FPR
- Cable error? Wrong Vin error?
- Opinions on the Electromotive ignition system
- Knocking while decelerating
- I think i screwed up --> Tunercat
- datamaster ????
- high voltage knock sensor
- Desperately looking for a tune for a blown 383?
- If I get MAF translater, do I still need PCM reprogramming?
- Power Programmer Erased
- Hard Question About 02 Simulants
- Best logger/scanner/reader software?
- is it worth getting my pcm programed for these mods?
- Hypertech with scan cartridge?!
- MAP readings drop slightly at WOT
- scanmaster accuracy
- code P1351 anybody?
- Anybody want to take a look at my log file.
- OBDII LT1 Edit vs LS1 Eit, simliarities?
- cheap chip reprogramming
- Please Help with Tuning (long, sorry)
- Did I Destroy my ECM?
- What does this mean.
- If coverting to OBD1 from OBD2....
- Is This Possible???
- Will An OBDI converted cable Work on Impala?
- corvette tuning in an f body?
- Rejected PCM on emissions test
- OBD2-OBD1 under dash connectors?
- Revlimiter, using lt1 edit!!
- Fried PCM, looking for a better programmer now
- EEC canister
- Those with Tunercat...
- pcmhorsepower
- UPDATE on ECM page
- Simple Question...?
- Advancing or retarding timing...
- RPM Limiter
- Speedometer adjustment with tunercat
- When should I shift
- Fuel injectors- cost vs. quality
- Leaning out at WOT
- What are safe trans pressures???
- just learning this stuff, and have questions...(long)
- Pcm programming
- Should my PCM be re programmed??
- .LT1 File for CC306, Stock Heads, 24lb's
- Is tuning for 96/97 years really kept in different cells?
- Dumb custom/HPP question
- LS1 Computer
- hypertech
- 26# injectors
- Accel DFI 6.0 files
- Turning off knock sensor
- Edit out Skip shift OBD1???
- Please help me get my car tuned .
- OBD2 LT1 edit help
- Learn enabled on LT1-Edt??
- What Do VE Tables DO Exactly?
- ANY Accel DFI Calmap files?? please
- Can the computer ignore your LT1 Edit commands?
- OBDII to I conversion- Can still diagnosis computer problems?
- Any software available for the Palm and OBD1??
- Trouble codes??
- lt1 edit cable
- OBD1 conversion now I'm having high stall problem?
- Anyone have some trans tables to make my 4L60E live??
- Reseting BLM's after programming for SVO's.
- Can Tunnercat work for an OBDII?
- Bin and Lt1 files. I am sick of waiting. bring it on
- cruise controll not working....and hints tips??
- Fan settings, what is stock and what should they be set at??
- anyone close by that can scan my car for me?
- Putting a used PCM to replace current PCM with LT1 Edit??
- Archive of .bin or .lt1 files?
- What better for tuning (perf application) LT1 Edit for OBDI or OBDII
- Tuning newbie - I got questions for those who have gone before......
- MAFT worth it?
- Ed Wright tuning
- heads cam file for auto
- reverse lockout
- Computer Problems
- Raising Rev Limiter
- If you run obd1 in a 97 car will scanmaster read trouble codes?
- Who runs a scanmaster in a 97 SSor Z28?
- 160 thermostat
- Anyone else running Speed-Pro(FAST)?
- Do I HAVE to have my pcm programed with a cam
- my car is running rich.....
- 95 m6 file
- What should my Idle RPM be?
- Can an ECM be programmed for a different year or type of car?
- questions tuning with MAFT+ and Auto X ray.
- Programming tranny pressures now....
- What does PCMForless actually program in PCM to gain the extra 10 horse???
- EGR
- LT1 scanmaster-blow up Prom?
- Hal- What Should I Shift at ?
- Help ASR won't turn on
- Using LT1 Edit for my 97 Z-28 (OBDII)
- LT1 Edit?
- How to adjust Shift Points?
- Guys who know A4 trannies, shift points...
- MALF 34 + 16 on LT1
- Broken digital odometer ??
- offsets for seimans injectors? idle problems also, after injectors.
- Need some help with split idle blm's...
- How much hp would I gain on a dyno tune vs. mail order
- Is changing the injector voltage necessary?
- MAF out of range and injector locking
- PCM forless tuning options
- If my WOT mph shift points are.....
- How important is it to program PCM after gear swap?
- 93 LT1 computer upgrade options?
- need help with TunerCat security error
- Help code 36, 42
- Just got my new Laptop, what kinna programs can i get?
- What pcm's will interchange with mine?
- First run on open loop 13.3@98, 9 degrees retard!
- LS1 edit idle return adjust?
- LT1 Edit File for cam and heads
- Computer Codes not displayed
- Finally found that dang auto 3rd gear hang...
- False Knock Caused by dirty O2 Sensors????
- Need 323 A4 trans tables
- What is an opti?
- Question about reprogram after cam install
- '97 pcm in a '94 z28
- 383 D1 file?
- tuning issues for tight LSA cam
- Lookin for a 396 blown + stroked lt1 edit file
- Basic Hypertech Question
- Anyone w/ .bin or .lt1 files inside please! :)
- Problem reading PCM
- PCM kills tranny regularly(4x's in 6K)
- 3" Cat SES Light ... 0420
- Paging Michigan Skip
- Please help - I can't get DataMaster to work!
- Anyone successfully tune with an FMU?
- service engine soon light after ran out of gas
- PCMforless.com
- Code 43...should I start with KM or KS?
- weird, stupid ses light.
- ? For those with Trans Performance button in TA
- I want my A4 to shift harder
- where to start w/ tuning
- Can you adjust injector size in Tunercat??
- Powerdyne6#, pulling PE like crazy and still rich?
- I need a Hotcam 3.42 auto bin file please help?
- P0300 code flashing even after being disabled!?!?
- Stumbling problem, extremely rich. Why??
- Is the AFR X 10 file used along with the (2) %Change tables to calc PE???
- Help
- LT1 Edit/BIN files for stock/modded cars
- Any one have some shift point tables for 3.42 gears??
- LT1-Edit; How to compensate for changing from 5 --> 8lbs of boost?
- SES light flashes after program
- Datamaster/freescan
- looking for work
- Finally got it to work now what
- what to use to program an LS6?
- Odd BLMs only on cell 06.
- TC- Editing the %Change F/A vs. Cool Temp WOT
- anyone ever put a carb and single plane int on a 94
- Computer newbie...some basic materials questions
- I just bought new computer, downloaded prog,but
- Tunercat starting point
- Problems with 98 LS1 PCM
- Looking for 1995 Bin
- LT1_edit: Would someone tell me how to move shift-points both upshift and downshift??
- Vigilante 3200 now I need pcm help!
- Anybody using USB/serial converter?
- Anyone try the Line Pressure Mod in WOT vs RPM (TC)?
- pcm problem.....
- Sensor in washer reserve?
- Rough cold idle, tuning tips?
- 93 SC bin files
- TunerCAT tables for Burst Knock????
- Question about tuning?
- Problems w/ FreeScan
- How to lower BLMs?
- LT1 PCM for 400 sbc and FAST eDist compatibility ??
- PE table in Tuner Cat?
- 96 Computer ID
- Programming a '97Z
- Need Stock .bin file for LT1 A4 3:23
- Need help tuning VE tables on 93 Z
- Scan Master Rin=88, Lin=185, what the.....
- Some questions about programming
- Review Datamaster File: Shakey on top end, slow MPH?
- What about tuner software for a PALM??
- Autotap???
- Part Nos for piggyback/eprom
- Having problems with tunercat
- Tuning with lt1 edit?
- Urgent: PC- ALDL Interface Question regarding Port Power.
- tuning msd digital 6?
- Tuning
- Upload/download files
- Quick FreeScan Question
- In tunercat... Which is the PE table?
- Anyone use the dyno inside Datamaster?
- any recommended tuning for my new set up ?
- Corvette LT1 computer Q's
- Where to Buy Wideband O2 Sensor
- Security light?
- Long term fuel trim question
- Where can i get LT1 edit....And would it really benefit me?????
- whos running constant open loop?
- Fan Issue
- Mode 6 scan codes
- Flow rate
- WANTED : stock 93 bin file
- Where to find .BIN or .LT1 tune files????
- A4 manual shift 2 - 3 hits limiter
- So many Fuel Injection Setups.!!!!! Help Me choose
- Jet Stage 2 chip???
- PC to ALDL question, ie. programming with a homeade PC-ALDL cable
- Mr Mattei- You still around?
- Consequences of Exhaust leaks..
