- 1996 Scanner Codes
- lt1 edit or tunercat
- predator question?
- Anyone want to look at my autotap file?
- 96 SS computer different???
- Some simple questions for avid tuners!
- OBD-2.com scanner problem...
- 50 lb injectors and LT1 edit help?!
- LT1 Edit and 58 MM throttle body?
- Anyone have a 96 .LT1 file that is really STOCK? Can you please email it to me?
- BTC29EAS Electrical Fault?
- Closed throttle tuning while cruising..
- Can someone help me figure out whats best for me?
- FAST tuning opinion sought.
- Knowledgeable OBD2 PCM and electronics guys within...??'s
- what are the minimum PC requirements for Freescan? Tunercat? etc...
- OBD I pcm rev limit?
- Swapping from 93 to 94 PCM in a custom setup.....
- Is this right cable?
- Stroker guys. Please post your timing tables.
- 93 Speedo settings in TunerCat
- Transmission related tables....How do they affect the tranny?
- db25 pin layout
- accel 30lb injectors
- Questions about the Predator.
- No serial port on my new laptop!
- LT1 Program Help
- Need Holley Pro-Jection Program for Slightly Moded 350
- Low RPM part throttle timing adjustments for cammed cars?
- Lowering idle to get more lope?
- new cam is in.. now i have a very large BLM split at cruise?
- Park/Neutral pin on PCM, do I need it?
- hookup regular pc to pcm?
- Disconnect Scanmaster?
- Large CFM MAF Sensors: What's Available?
- ?s about programming
- Cheapest place to purchase F.A.S.T.
- PEvsRPM table comparison....stock vs supposed ws6 file.
- Does tunercat need a language convertor ??
- chip for a 93?
- Question about stock program and Tunercat
- Just read the pcm off my ss, now im lost?
- Can you look at my log file?
- lets explain this computer stuff
- How to reflash a new PCM???
- where is PE v.s RPM in tunercat?
- Flash in Windows or in DOS?
- Can some1 tune my OBD2
- Where can I go to learn basics about LS1 tuning?
- Tuning for stall ?s
- Anyone have a bin file for a 94 auto?
- bin file
- why wont a scanmaster work in a 93
- PCMCIA & USB Serial Adapters
- Can anyone look at my autotap log?
- Anyone have a 95 LT1 A4 bin they can email me?
- Sunpro code scanners?
- Possible to fry and MSD box by jumping battery??
- A:F/PE tables on the wideband
- OBD2 Autotap users inside please
- Anyone program out cam surge?
- where are the ls1/lt1 dyno tuners around detroit
- How often do you fry your PCM with TunerCAT?
- What kinda AKM cable to I need?
- Stuck in cell 16
- BLMs near 128 but it still smells like raw fuel atidle.
- how do i change a/f ratio at idle in tunercat?
- Anyone have a stock 96 M6 file?
- Why is it that Datamaster only records up to 6375rpm?
- "Not a Licensed PCM"
- tricking emissions
- CAM programing??
- Help me find Tuner cat/LT1 edit files and the file converter
- how do i get cyl vol for 355 ci in tuner cat ?
- Tuning suggestions needed...Please come in and post.
- Annoyance with Tunercat
- Converter locking at 105mph, why?
- Tahoe Programming?????
- Which version of Autotap?
- If Im using SVO's and my FP is 50psi....
- Anyway to tune for rich idle or low RPMs?
- transmissions DTC err.
- How do they program your ECM with a Dyno Tune?
- speed pro F.A.S.T.
- Neat/creative programming idea; can't get LT1_Edit or Tunercat to do it, any ideas?
- Timing Suggestions
- What kinda Cheap Laptop can I use with Lt1 edit?
- Timing question and a 160 T stat fan setting
- What should I log for autotap?
- What can ls1 edit do?
- Help me....somebody please view my Autotap log.
- Bought a camle for OBDI and need some software...
- How to convert .bin to .lt1 file?
- need some tuning advice!!!!
- MAT sensor
- obd1 computer
- HPP3 question...
- AFR, tip-in and related q's
- WB Vlin into Oil Temp Input
- Idle stays up after LT install.
- A4 pressure offset to soften shifts ?
- Car feels like it missing or jumping forward...
- 30# injectors w/ no tune???
- Closed throttle tuning/advance...
- Is there a programmer that will do LS1 and LT1?
- AutoTap w\o Laptop?
- CRAP...my PCM is now erased..how/were do I get it reflashed?
- Can someone HELP???
- Where to Buy LT1 Edit ?
- guage lights out
- Premature shifting A4
- What would it take...
- Part throttle tuning?
- OBDII LT1 edit....controlling detonation/pinging?
- Code 44???
- Need an SC tune
- Need help with LS1 computer
- Offset tables for Accel 48lb injectors???
- Code 51 Scanmaster 95 Ta
- Anyone mess with the cranking advance?
- Help w/ Scanmaster readings!!
- 02 simulator electrical question
- What cable is needed to run autotap...
- Just bought Tunercat ????
- trans. performance mode
- 00 v6 to 00 ls1 in progress, need wiring diagrams, please help
- Anyone using an Accel 375+ on their car?
- Any experience with EPROMER or the ROMulator
- Target Air fuel ratio with FAST
- Need Help with Hotcam and stage 2 heads programming..can someone take a look at it??
- Throttle follower?
- Cheapest aftermarket ECU?
- hypertech pp3 shift points, need help
- How to re-program A4 for an M6 conversion ???
- What can/should I get changed in my programming
- Wiring oil temperature sender into OBDI PCM
- Stock OBD2 tune and larger injectors
- I have exactly 1 week to get this right....please take a minute to look
- How Do I Check BLM'S
- 93 Diagnostics SES Light
- Opti Spark low res wave form questions
- Flshread.exe error #5 address 9039? Anybody know what this is?
- How does low octane retard work?
- blown 383 Solid Roller files?
- A4-M6 swap.is the wiring the same as 97' for a 99'
- Advantages of using LT1 Edit on an OBD2 VS and OBD1?
- Tuning in general
- Tech edge Wideband setup. Where did ya tap in the RPM wire for logging?
- '95 V6 Camaro Question...
- Adjusting speedo calibration with Tunercat?
- help with error code
- I am running lean with Headers
- Car won’t run when MAF is disconnected?
- 99 Z and Hypertech
- MSD 3-step question
- Anybody know how to lock the TC in the computer?
- free scan (doing strange stuff) ver 2.07
- PE tuning for 1228746/L03
- URGENT: Need help
- URGENT: Need help on Wiring
- Best Book For Learning What each Readout Means
- xe230/236 ported heads need tuning help
- FAST Programming
- CCXE 230-242 program changes?
- where to get dyno tune
- BLM Locker
- Oxygen Sensor Simulators
- Just getting into Programming, few questions....
- serial to parallel adapter for autotap? possible?
- need $ee calibration file
- Bought and installed the serial-to-usb adapter for laptop...still nothing!
- Does the cam LSA effect tuning at all?
- Can I disable Traction control
- Datalogging Question (Datamaster, Free Scan)
- seat belt
- tuning shop needed in S. FL
- woohoo
- For Sale LS1 Edit and Two 98 PCMs
- Computer Problem??
- early OBD2 no scan, error
- ??? for you pcm pros
- Understanding DataMaster information? Max and min values???
- Cc306
- Anything I can do programming wise to increase my off-the-throttle vaccum??
- LT1 AIR/EGR technical question
- need help with tunercat
- 4L60E to a turbo 350....what to change flash program?
- This place isn't very busy
- OBDI conversion worth it?
- HELP:installed MSD-6A-ASR service light on?
- Just fried my computer?
- where to get calibration file $42
- wanted:stock tpi bin file
- SES Trouble...Help
- programming for 3200 stall
- need a GOOD tune for 355ci w/hot cam ported heads
- EPROM Programmers and eraser.. which one works?
- Playing with FAST. Car is'fa*ting'?
- FAST eDIST with FAST SEFi and LS1 Coils
- How much can I gain from computer programming
- SES is killing the joy
- How to Erase trouble codes
- Quick fuel pump question please....
- Predator owners, what do you think about logging?
- What is the differance between F.A.S.T. system bank/bank +sequential?
- GOOD tune for XE224/230 stock heads??
- injector offset
- Wiring LT1 to a 3rd gen
- Have datamaster....what info for bad map?
- VEMaster!?!
- Funny Injector size
- What can be read from OBD-II plug?
- DATAMASTER veiwed parameters
- Dfco
- SES light, low water temp, cooling fans stay on
- DIY o2 sims (possible?)
- running rich
- Auto computer EXPERTS inside please
- Data Master/ glowing headers
- Turnaround time for receiving LT1 edit?
- SES and stock programing
- prom chips!
- Is there any point in correcting...
- Code P1336 HELP!
- PCM bench tuning
- Help: Error during programming with PCMforless
- Tuning for 1.6RR
- tuning for an ls1
- OBDI trouble code 11?! Help
- crank trigger ignition ???
- LS1 edit files
- PCMForLess guys is ill, anybody know where I can get new program?
- who sockects pcms
- Scanmaster LT1 and scanmaster 2.0
- Fan Temps ?
- Tunercat second to none!!!!
- torqe conv. lock up switch question
- Programming help tunercat?
- Gear ratio/top speed limiter
- does anyone have desktop drag2000?
- KR upon startup--stall condition
- swap question about my computer HELP
- Help with Tunercat
- LT1 edit w/ PCM For Less
- Trouble Code Help. Please?
- In the power enrichment vs RPM table...
- F.A.S.T. who deals real cheap ?
- Benefit of alot of timing at a high KPA and low RPM?
- where to buy tuner cat or lt1 edit?
