- lt1 edit vrs tuner cat
- USB to ALDL cables?
- lt1edit lean
- Best bang for the buck scanner?? whats your favorite?
- Who fixes pcms and what caused this?
- SES light is on Again!
- LTrim question...
- programmer@pcmforless.com
- best prom tuning for TPI cars?
- Can't pull any timing!!!!
- Passed Smog!!
- Need advice on datamaster run and fuel injectors
- Going to DFI
- please help answer my noob questions.
- LT1edit
- Need help converting OBD1 PCM for OBD2 conversion
- 383...Need a tune...
- speed pro computer for sale
- codes wont go away
- Looking for more...
- Anyone know how to use tuner cat?
- Those with datamaster look at this !!!!
- Tunercat 1.98
- Problems Pulling Codes
- IAC motor just need time to learn?
- Shift Points HELP
- Cable Differences
- K&N & Speed Density LT-1
- Hypertech and Jet together??
- Hypertech Programmer Question
- programing problem or mecanical
- low RPM cam surge
- code 33 map sensor high
- LT1edit Version 2.2 is out now
- Is it possible to edit my vehicle using a cable that worked for my thirdgen?
- security/VATS/pass key.. problems
- 94 wiring harness vs. 97 (LT1)
- Aftermarket Computer Questions
- Where's Andrew???
- That company on ebay, anybody?
- Low/High Impedance Injectors
- VE Master!
- what to do? newbie to computer tune
- faq thread?
- Datamaster people
- 95 reprogram
- What are the signs of a VSS failure in a '90 700R4
- need a good file
- emissions and LT
- Advice on data results
- GEN 7 DFI Questions
- best program to read codes on OBDI?
- formulas? spreadsheets? where to begin?
- Tuning a 1993 PCM
- 700R4 VSS signal into M6 PCM Possible
- P-code help please!!!
- Simple programming/exhaust question?
- what is a good program
- hypertech question
- OBD1 Conversion Question
- lt1_edit programming
- Need help-Car won't go closed loop
- need reprogramed?
- what interface is everyone using?
- BLM boundries for a cc306
- R&R Thermo reprogram pcm?
- cell-specific low BLMs
- logged some data, short term fuel counts?
- IAT vs Map timing
- OB2 programming
- VE Tables???
- LT1 edit to laptop communication - problem solved
- got a few data logs...can someone tell me what it means
- Easiest way to get stock program?
- Auterra OBDII scanner
- PCM4less -vs- Madwolf tuning
- Anyone use Diablo?
- Chip Burning software and hardware for 93 and older?
- Speed Density?
- Optimal Timing advance on an LT1?
- Chip for 93 LT1
- Programmer Purchase Help
- Ford SVO 30# injectors, put them in as 30# or??
- Reducing power through programming - tire spin issues
- LT1 Edit (only OBDII and NJ people need read this)
- shift vs mph and rpm
- shift time VS TPS
- No injector pulse, no start..
- how come no one has made a PC program that mimics a tech2?
- cooling fans won't kick on
- Scanmaster or equiv on '93 Z28
- Injector offsets ? 42# SVO
- Stock MAF vs Ported MAF vs Granatelli
- pcmforless?
- New GM ECM Tuning tool
- What is the proper injector constant setting for Lucas 42lb/Hr injectors?
- 93 speedo reprogram please HELP!!!
- This makes NO SENSE.. Auto Tuning...
- Where can I buy new PCM cheap for 93?
- any laptop programs that will interface the ABS?
- Crank fuel enrichment problem on '95 LT1 w/ 84# injectors
- Horn won't honk
- Need Shift Tables For A4 with 4.10's... Help!
- Injector Constant Question
- Swapping 96 PCM for 94
- HELP cant read or reprogram pcm(tunercat)
- headlight?
- CC306 Re-Programming?!?!
- tunercat pcm mem program error?
- installed cc306 stock tuning question
- Anyone have a bin file for 306 comp?
- Any better tuning resources?
- tunercat questions
- WTF are "readiness" codes?
- car wont start
- Socketed PCM not working
- better shifting for a stock 95 w/ 3.23s
- PCM for Chevy Vortec 8100 engine
- Misfire problem/comp not reading
- BLM's at 108
- How much does LT1 Edit Cost?
- Interesting Sticky Thread on VE
- datamaster problems, wont read PCM
- Very Very NEW to programing
- PCM burnt or Trans Bad
- Resetting ABS Computer
- MALF 83: TCC Control Feedback Fault
- obd1 or obd2
- URL for diagnostic software?
- can this cause o2 sensors to be bad?
- Need a tune for diagnostic purposes
- anybody with new dell or usb port on their labtop?
- obd1 and obd2 knock module?
- Split BLMs on 95Z
- Rich on cold start? LT1 editor
- LS1 Edit- multiple license question
- Speed Density Help
- Definition file (help)
- predator programer
- Computer will not learn idle...
- Computer Code testing
- Is this a tuning problem?
- whats a GOOD program to view what my car is doing?
- GM Drive Cycle - Smog incomplete
- ? on scanning a 95 OBDII/OBDI
- Laptop for tuning
- aldl timing adj?
- ? about thermostat
- voltage and pcm
- How to tune for vacuum?
- Questions about datamaster
- Tuning for open loop performance/mileage
- Anyone know where I can go to reflash my OBD I PCM?
- 6sp conversion & LT1 edit
- What do you think of this???
- new lt1 383, newbie to computer tuning,what to do?
- Cruise control doesnt work- Does it go Through VATs box under Glovebox?
- Freescan question
- Diable Predator Tuning vs Custome Tuning at a Dyno shop
- OBD 2 not responding
- Tuner Cat Help
- LT4 converted idling 108 blms
- PE table for stock car
- Fuel injector size question inside please...
- Torque Management
- Is this normal when I flash?
- OBDI conversion questions
- What is C220
- Tune on the Fly Tunercat???
- LT1 Edit help
- Jet Power Commander - Few Questions
- Air Bank Fault?!?!
- Wideband 02 as stock replacements?
- Delete 02's?
- tunercat help, which table?
- Cut o2 harness now SES
- LT1 Scanmaster install
- How hard would it be to tune my car on the dyno?
- low power, high & split BLMs, need ideas!
- Programming for bracket racing?
- IAT temperature reading vs spark retard
- Datamaster log files - stock A4
- what is this table used for ( in tuner cat)
- Wasting my time?
- How much Spark Advance is to much?
- Help Suck In Lafayette, Freescan info...
- Lt1 Edit
- tuner cat( vol efficiency vs rpm vs map) w/ hotcam
- got msd dist in. how do i make it work?
- knock counts on startup?
- -40* timing????
- Help Deciphering EFI Live Data
- iac ohms
- MADZ28 will be closed DEC12-JAN12. Check for savings inside...
- Did I fry my pcm?
- Freescan, Datamaster, Tunercat.....
- had chip reprogrammed for n20.....now car smokes blue smoke....
- is it possable to tune to pass emissions
- In car tuning?
- sending pcm to madz28 in the morning...
- need help with tunercat( wot tuning)
- Major Question In Here Regards To Tunning
- how much is a F.A.S.T system??
- Tuning with the knock sensor OFF
- Autotap run? Fuel Trims
- .ECU file for $DA LT-1 & Winbin
- lt1 edit
- lt1 edit
- Anyone willing to help me by looking at a Datamaster Log??
- Tranny Codes
- Accel System 7 Dfi
- Best way...
- "Tuning out" cam surge?
- 96, want to tune it myself... TunerCat or LT1_Edit?
- Quick MAF table question...
- computer tuning
- Will this programer work with our flash chips?
- Tuning totally in speed density on a MAF car.
- need a bin file for a 847 and 230-236
- LT1 Edit or TunerCat on a Palm or PDA?
- Backfires on decelleration and only 15.5 MPG
- New Calif Regs - Won't Pass
- Just ordered OBDI conv from Madwolf...
- IAC in gear w/cam surge
- 93 speedometer problem
- How do you affect A/F ratio at WOT and idle?
- TunerCat or LT1 Edit
- Here my problem? To all the big brains out their
- Why did I lose communications? Please help!
- How much slower will a car pulling 15 degrees of timing run?
- How good is an Acell GEN 6 DFI system?
- lt1 Edit!!!
- are the 93z & 94z body harness the same
- Pardon My Ignorance but . . .
- How to test PCM?
- DO I NEED TO REPROGRAM THE COMP with this cam???
- Car wont run without MAF plugged in!
- Can someone look at this cvs log for me??
- High Resolution Sensor
- VE Tables & MAF Cars
- The Willem Eprom programmer?
- who burns the best 93 chip??
- code 1153?
- T56 is out TH400 is now in!
- Keyless Entry remote number
- madwolf....do you just tune common cams?
- o2 readings
- Anyone have a LT1 Edit Cal w/ a vortech?
- Good Diagnostic Equipment ?
