- WOT BLM confusion...
- Need Help Bad...Which size injectors to run?
- Tuning for part throttle
- VE tables...controversal...i know
- need help
- tunercat --- How to? Desciptions of functions?
- who can burn me a chip
- Question???
- Lt1 Edit
- leaning out according to tuner cat
- Predator .. Not applicable to 98 LS1's?
- Hypertech Thermomaster....
- Quad Driver Modules
- DELTEQ anyone use it yey ?
- Ok guys, big question please.
- Should my car
- FAST pcm piggyback?
- Will this work for idle
- tuner cat ?
- LT1Edit won't work for me
- 93 Speed Density ECM disassembly?
- LT1 Tuning Help Needed!!!!
- Settings for handheld programmers
- low rpm stutter
- Madwolf, Question for you.
- Can someone reflash my PCM?
- Upload PCMforless tune?
- Anyone have a stock '97 .LT1 file?
- Anyone with a 230/236 tune I can see
- Hypertech power programmer
- need help identifying harness... supposed to be 94LT1
- LT1_Edit - and linux
- performance maf
- What Cables For Tuning
- Datamaster problems
- Tuning out a MAF sensor with tuner cats
- Freescan troubles
- Lt1 edit or tuner cat users inside
- LT1 Edit No0b
- datamaster files
- madwolf rocks
- Idle tuning troubles...
- LT1 Edit OBD2 Question
- LT1 OBDII Seed/Key Algorithm?
- Major tuning around a new MAF?
- Pcm
- Timing / Knock retard
- AKM Cable
- 1st Time Scanning...What to Look For?
- Turbo LT1 file
- Coast-down lean roughness
- tuning after cam install?
- Specific question on KR
- Tuning options
- TunerCat users... Read this if you have issues...
- IAC counts
- question about DFCO when tunning
- 97 OBD2 pin out, and a few other ?s
- Simple OBD2-OBD1 swap question.
- What is the most popular way to tune a 396 LT1???
- 88 IROC ECM question
- Will pcm throw wrong codes if it goes bad
- Need help with codes.
- dtc code
- 233/239 on 113 lsa tuning
- Odd tunercat problem
- need tuning but PCMFORLESS website is down?
- Code 51 ECm Prom Error
- open loop tune, about to test
- right bank running lean
- 93 Dtc 28
- split block learn multipliers
- tuner cat vs tuner cat rt
- BLM cell boundaries
- Anyone willing to have look
- tunercat tables ?
- Tuning for a new intake
- P0420 Code....any help?
- MAF Translator question
- Quick SBLM variation at WOT
- Shifting with Tunercat
- Help- Need Pcm Connector Terminals
- Can anyone check out my Freescan scans?
- someone help me w\ these abbreviations
- LT1 edit data logging errors
- emissions tuning
- Anyone running a wide band af sensor, where do you mount it?
- Advancing the timing table
- Salvage 2002 LS1 won't start
- Fan Hystersis
- tunercat to desensitize KM??
- anyone know how to reprogram an eprom?
- TunerCat tuning for WOT?
- pcm read???
- No cat, No tuning?
- Eliminating EVAP on '97 T/A with OBD! to OBD@ conversion..>>
- Accel DFI tuning
- When to get an aftermarket ems?
- Diacom blues, won't connect...
- computer compatabilites
- first start after heads & cam
- 95 z28 programming
- Wide band o2 sensor kits
- going above 14.7 AFR
- OBD-II and emission cheating
- What is the best scan tool/data loger
- does tuner cat log data & scan
- Tune Pro's inside
- how "LEAN" can yo go
- fan on thresholds in tunercat
- LT1 Software & Cables
- Fast track performance harness?
- '95 OBDII problem
- Simple Question: What are Accel Fuel Injectors rated at?
- instrument cluster swaps
- timing retard question
- Tuner cat tables
- ? on Auto X-ray scanner results.
- Stock 93 M6 .bin file Desperately Needed!!!
- Winflash ok to use now?
- swapped MAF sensors, strange...
- simple freescan questions
- FAST LT1 harness?
- GM 2 bar MAP sensor #
- Ve table
- tuning a bolt on only Lt1
- TunerCAT tuning for beginners?
- AFR tuning
- set up ildle speed
- 94z tunercat shiftpoints????
- speed density mode
- Idiot Light......
- Performance mode shif on a ´96 z28
- Any Have a Stock 6m .bin file or better yet...
- Lt1 edit to tuner cat (bin) converter
- Anyone ever made a .bin for gas milage?
- Do I need to get my shift points reprogrammed with a high stall?
- Q's about my A-Tap Log
- could someone analyze this freescan log?
- tuning a bolt on car
- 96 Z28 A4 to M6 swap PCM question
- need help decide on a tune program!
- Dtc: Po412, Po418
- Windows 2000 and no DOS? Tunercat related
- Need someones help
- Tuning with gas
- 24 to 30lb svo injector change with Tunercat...What changes??
- Guys, take a look at this thread please.
- have 96LT1, using 94PCM.. now what?
- How to set Fuel Pressure?
- need a/f help PLEASE
- Cooling fans stay on after program upload
- Unhook MSD when uploading a tune?
- Whats the pest PCM tuner out there?just installed new weels.
- data logging for 93
- OBDII LT1 Edit question...
- which unit should I buy for my Camaro LT1?
- Bench harness compatable w/ LS1 Edit??
- z28 pcm and v6 pcm....? same?
- Engine misfire code and LT1 edit??
- C.a.t.s. ?
- Removing the computer
- different fuel trim from each bank
- Obdii P1641 & 1642
- Dumb question...TunerCAT related.
- I read my pcm and now it will not start/ tunercat
- OBDII code=P0420
- Logged a drive with Datamaster
- Desperately need help with Lt1 tune...
- How do I remove CAGS using tunercat?
- dtc 83
- newb programming question - speedo
- What can I do to prevent frying PCM
- .A-Tap Wire, any other software i can use with it
- short term and long term fuel trim
- Strange fan settings?
- 1994 trans am..CAn i tune this car with hypertech?
- tunercat howto?
- PCM tunning for the 96-97 V6;s
- Tuning with OBD1
- 6 speed and 8#SC Bin Please...
- Handheld Wide band A/F ratio meter from SEMA?
- ECM Ground
- hypertech programmer
- OBDII and 7500rpms?
- MAFT How to?
- Question about MADZ28
- Disgusted.. engine backfires, shakes stumbles..then runs perfect.. HELP!
- Anyone Care to Look @ my Log? :)
- Easy one, tell me what the DTC: "MAT Low" Means?
- LS1 tuning help ...PLEASE
- Can I gain with tunning, LT's and RRs?
- Newbie to computer tunning, what do I all need?
- LS1 edit ? ANYONE ?
- cc306 prob
- Need TunerCat help badly please....
- Gauge Problems
- bad obd1 conversion
- OBD-II vs. Aftermarket System
- tips for running obd-2.com diagnostic software
- Governor Switch Removal
- In dire need of stock '95 LT1 M6 program
- Tuning Guru's give me your thoughts!!! (Long)
- Any recommended reading for new LT1 Edit user?
- new to tuning
- 30lbs inj to 36lbs inj
- ecu program
- simple question for those with Accel DFI
- FAST question
- what could be causing a P0128 code?
- inj calc
- Getting pricing straight on tunercat
- Just got my MaStach.com interface and software
- Question(s) and Problem(s)
- "error: incorrect message sent" while flashing a .bin
- tts datamaster problem
- Laptop question
- .bin file for a 95 6spd LT1
- Madwolf Help!
- Need as much info as possible on Tunercat and tuning- opinion, links etc.
- base tune
- Injector problem cus of programming?
- Connecting My Laptop to my PCM
- Tuner Cat Questions
- Finally got the money for a tune, but ran into a prob.
- PCM fried???
- I am changing my stall..Do I need another reprogram.
- What's with Accel?
- Speed Density to OB1 MAF Setup
- Computer requirements for Tunercat?
- Lt1 Edit Help
- few general questions on tuning
- Tunercat, for OBDI only? Please help!
- Need some help with Tuner Cat
- Best place for a PCM edit ?
- Where can I buy 28F512 chips?
- Gear change and speedo recalibration
- I need help with a obd2 code
- Stock LT1 computer "on the fly" programming
- Tuner Cat Programing
- New edit software for LS1
- anyhthing similar to tuner cat for mustangs?
- LT1 edit or Tunercat
- Best place to get ALDL cable?
- Problems adjusting VSS calibration param's in the 95 LT1 PCM
- PCM from an Impy?
- paging Madwolf
- speedo adjustment after intalling gears
- TTS datamaster pcm sync problems
- How to tell if PCM is M6 or A4
