- instructions for installing Gen VI dfi
- New computer system
- Where To Find Tuning/Monitoring Software?
- Folks with USB Laptops with no serial port, did the Belkin F5U103 solve your problems
- Diagnostic Cable Problems
- Idle won't come down while coasting??
- Needing BIN file
- need help with problems
- How does madz28.com or pcmforless.com work
- Question regarding scanmaster.
- need a .lt1 or .bin file for 221/227 cam.
- OBD1 or OBD2 ?
- Ls1 Edit Tuning
- Speedo off
- who does re-programming
- Location
- 93 OBD-I to 96 OBD-II Conversion?
- Worn exhaust valves cause false rich?
- problem with idle! --injuneer?
- BLEMS are 128, still running rich!!!
- tuner pro software
- W/B under $500 ???
- cables for running freescan on 93
- hypertech question
- Tuning on stock car worth the money?
- Car is still running rich
- bad grilfriend......
- question about tuning?
- LT4 Knock Module (OBD2 to OBD1)?
- What line pressure you running (A4)?
- Accel Gen 7+ DFI and LTCC
- HPP3 Part #345752. What will it work with?
- I need a stock 94 A4 bin file
- Why does Datamaster NOT work, but Freescan DOES??
- Will someone please look at my freescan file?
- Camshaft position Sensor
- How to adjust part throttle and WOT fuel on TC??
- flash program for pcm
- How to lock BLM
- Cable connection for OBD1
- Datamaster ?
- just got gears, have a ?
- What's Better LT1 Edit Or Madz28?
- OBD conversion tranny fix?
- using lm1 to simulate the nbo2?
- First Gen Camaro...C5 Vette Guages
- How does Autotap figure AFR off the PCM
- Will a re-programmer do anything for an M6?
- cam install...now bad idle...whats wrong? Long...
- Tuning idle with CC306
- Flash PCM with engine out?
- Have a pcm tuning question?
- Help me set my shift points in TunerCat
- What is the BEST?
- OBD1 conv, still have problems
- 4L60E adjustment questions
- Help? just fried PCM
- Once again, Datamaster/ car tuners come in here PLEASE!
- Eedbrock Pro Flo 3500
- Want to get in to Programming
- Can a program like Autotap tell me what my A/F ratio is?
- Car wont turn over when I turn the key. Vats to blame?
- TunerCat shift point problems
- 93 Camaro LT1 Flash Test
- Can someone in IL run Datamaster on my 93 for me?
- where can i find tunercat & the cable for laptop? any1 know?
- Datamaster + AKM cable + usb adapter = no data!? HELP
- GM MEFI IV ecm info
- oversize tires
- DFI gen 6
- How much timing is too much (with no KR)
- Dtc 18 ??
- Spark retard at Idle
- possible? MAf to SD
- Burst Knock and Knock
- Any MAP over 60KPa is causing knock, but why?
- Need Help Fast!!!!!!!
- Strange problem with Backfiring.
- can someone look at this .csv file from my car??
- EFI live, who is using for monitoring on 93s
- VATS not correctly disabled? Help!
- 3rd gen OBD-I
- will mac laptop work with LT-1 edit or others?
- Where do I get.....
- Quick MSD BTM and Scanning Question
- BOosted tunning.. New idea? Possible?
- LT1 Editing
- ? about heated o2
- What should be changed to shorten high idle time?
- Going to the dyno
- Can you change blinker speed?
- anyone know where to get free tunercat?
- Can't connect with tunercats
- RPM Tables ?
- Split BLM's in ALL Cells
- Shift and rev limit problem
- keyless entry
- Running Freescan
- Guys with no PCM and FAST inside
- PCMforLess Question?
- scanned 2nd injector what?
- Any guides that tell you what to look for when logging your car?
- Fans arent going on...i tested them
- labtop scanning w/freescan
- Ion or any programer
- o2 simulators
- Post M6 Swap Tuning Issues.
- Need help with 700R4 conversion and the Computer
- Best aftermarket EFI system???
- Changing Transmission, What's Needed?
- Carolina Auto Masters
- What do I need to buy
- 4l60e programming
- I need a scanner...which one?
- what software?
- Datamaster/Car running like poop question
- Hptuners edit Q
- MAF circuit malfuntion error
- Anyone using the PCMCIA serial card?
- Hmm- TCC normal Vs performance engage/release
- TunerCats Definition File
- BLMs at 108; HELP!!!
- TPS low voltage
- 383 with SVO 42#ers 8psi ... need PE table
- How do you set idle in TunerCat?
- Data Cable
- FAST: WhiteRacing Harness and FIRE !!!
- MAF calibrated wrong?
- looking for bin or LT1 file for a 94 TA
- Idle timing /knock retard
- how do you use injectors instead of MAF for changing blms
- EPROM type for socketing OBDI LT1 PCMs?
- Speedometer incorrect
- lingenfelter programming
- dtc 77, 26, 27
- BLM locker
- Atten. MAD WOLF I need help with tuner cat
- help with tunercat program!!!
- Accel Gen 6 DFI Users Manual
- Please HELP!! PCM Tuning Problems
- Q@A time
- Tunercat basics
- Lockup MPH when?
- 1991 sd 730 ecm vs DFI?
- HELP! My laptop died while programming...:(
- Would a reprogram help
- Line Pressure...
- 93 PCM question
- OTC genysis
- KNOCK and low octane tables...again (new question)
- AKM cables
- obd-1/obd-2 cables??
- A4 TC lock up concern/problem
- ls1 edit info please
- need some comp help
- Tuning N00B needs help with new setup
- HPP connector for '95
- Any websites with modified bin/lt1 files? other than bfrankers site?
- MAP and TIMING....what do i look for
- still getting a code
- b-body pcm's
- Need some wiring help
- thermometer for tuning?
- Need a stock manual bin file
- ls1 edit or hp tuners??
- 97 SS need OBD I conversion info
- PCM re-programmers
- Will replacement digital odometer read my 97z mileage?
- PCM 95 Trans AM?
- converting from MAF to speed density
- Idle Speed
- Tell me about........
- Any TunerCat tutorials out there?
- code 43 again
- GEN7 DFI Install Questions
- GMS MAF sensor cause lean condition?
- Differences between Tunercat and LT1Edit?
- New PCM problem
- Having trouble with laptop cable
- Need TunerCat 1.98 demo - 2.0 causing errors
- ECM Scanner Options - what's hot, what's not?
- pcmcia to serial with tunercat
- Will MAFT + help tune this combo
- LT1 Edit & OBD II
- How to make TCC engage at WOT in 3rd? (TunerCat)
- Scanner connection
- VSS, TH350, and me....
- Am I doing something wrong?? TPS voltage
- 99 Camaro Programming
- IAT sensor
- gm/sec airflow
- How to tell if I have my original PCM?
- 95 camaro airbag replacement
- MemCal & Chip extention
- Adjusting fuel pressure affect air fuel ratio?
- 93 ses codes
- Pcmforless Tune for Hot cam
- Data logging Help
- 93 & auto xray ?
- What PE values are you running?
- Do Lt1s have an IAT vs Map timing table?
- chaning gear ratio question
- Fans Temp
- LT1edit manual correct?
- Help with engine miss...
- Measuring timing with opti/LTCC
- A couple easy questions
- Putting car on the dyno tomorrow.. help
- Lt1edit/OBD2 conversion problem-->
- Lt4 hot cam tune
- ls1 tunercat
- um....help? please?
- Tuning Accel Gen 6 DFI
- bad 02's???
- Flash chips for socketed 95 PCM
- Dan White Racing Hanress
- cheapest place to get ls1 edit
- SES after OBD1 conversion
- which bank is Left/Right with Scanmaster??
- how do i add 1 deg of timing? - tunercat
- Where can I get a cable for about 35 bucks?
- Heads and cam swap???
- TTS datamaster problem
- MAP at idle and off idle
- Tuning problems...need advice
- 1994 pcm-1996 lt1 in Toyota landcruiser
- PCM sync problem w/ Datamaster (already did Search)
- How much can I expect from a dyno tune?
- Beginner problems with LT1 Edit
- RPM jumps around during WOT
- Will SLP 85 mm maf work
- V6 PCM Problem?
- INJUNEER..Please help!scanmaster prob..
- Ported MAF question
- need help bad
- Anyone that likes looking at datamaster files?
- Battery reset kill tune?
- FANS+programming
- JET Performance strikes again!
- Whos running large cams with closed loop tune?
- wierd esc code 43 knock sensor problem
- LT4 Knock module w/ OBD1
- B4C Package
- Command 950 MAPS!! help
- Big Problem!
- VATS question
- tach wiring question
- O2 values before startup L0.514mV R0.451mV
