- Tuning for Stall?
- I am about to bundle all this ls1 edit stuff to a rock and sink it in the river!!!!
- New laptop keeps failing aldl test
- park/in gear idle change
- ECM Connectors Needed
- OBD2 - 1 swap without soldering PCM, and swapping KS?
- Tablet PC for Tuning?
- Possible to go from analog to digital cluster?
- PCM went BYE BYE.
- would +/- 2* timing change AFR much?
- Need Help with VATS Please
- 1995 Z28 bad opti-spark / distribution system
- What hooks to a laptop???
- switching to OBDI & tunercat?
- tuning for stroker motor?
- very low idle at anything more than 180degrees
- Hypertech ?
- 97 PCM Pinout help needed
- SES Light - P0335 & P0336
- Open Loop PE tuning?
- Speedo recal LT1 A4 -93 questions
- B&M Shift Plus
- Help, was told PCM ground is off
- Does spark retard go down when correcting from 350 to 383?
- Pcm
- Does changing the cyliner size from 350 to 383 in LT1_edit change any data?
- Dyno<1edit near bakersfield ca????
- How to load OBD2 LT1 Edit file?
- Anyone have a copy of LT1 edit that I can see?
- Anyone have a REALLY good Bin or LT1 file for Hot Cam??
- need help with tunercat please!!!
- ?.:PCM BAT fuse removal:.¿
- Anybody have an tested .LT1 or .bin file for a car like mine?
- which self tuning route to go???
- body harness
- Drop in Kpa?
- Pros & Cons
- how to read Codes (w/out scanner)
- !AIR! and !EGR! without tune?
- I'm At My Wit's End; Need Serious Help
- Mustang event coming up - i'm the only f-bod. Need a .226/.236 tune help
- what is going on with my car's computer or cable
- Tuning closed loop idle
- Ion @ MadZ28....where is he???
- Hypertech Programming
- GM847, need base file
- areas to get a tune
- tunercat or lt1 edit
- What kind of tuning should I do, Predator, ls1edit, vht?
- getting the cable to work with laptop
- Strange tuning problems
- Tuner comparison
- anyone know a good place to get epros for cheap?
- 93 bin file for 221-227 m6 car
- Freescan not working??
- Tunning prgram
- Looking For Tunercat 95 Z28 M6 Bin File
- Help with PE tables, does PCM ignore past a sertain point?
- I've Got a Half Dozen DTC Codes
- 2 codes need help!!!
- Knock retard
- uploading tune problems...
- Settings / Table For MAF
- Please help with car shutting off!
- Odd 02 readings
- Cruise mode shift points?
- programmed pcm learning curve
- Security light/ Pass key problem
- Can a bad tune cause this problem?
- Tec3 Computer
- looking for VE table from a large cam speed density tune
- RPM drop going into gear (a4)
- Desperate, posting everywhere. Why the low MPH?
- wiring
- Spark, but no fuel or RPM after FAST install
- ABS Scan Codes/Scanner
- Looking for FAST file- blown 383
- CD Player - need help
- Flashing "Change Oil" light
- OBDI Conversion
- Help reading Freescan file
- Quick ??
- OBD2 CC306 GM847, GTP6 big cam guys with tunes inside
- service engine light question
- heads and cam LT1 cars....
- P0133, P0141, P0147
- Cheapest place to get a cable for LT1edit, or...
- tunercat- remove false knock- what tables
- Injuneer, Ion, others.. ???
- PCM Crashed need quick answer?
- CEL Reads 01 On Startup & Full WarmUp???
- 4l60e to th400 conversion
- Freescan and Datamaster issues
- pcmforless
- 1994 vs 1995 Connector?
- Options for ODB2 Programming
- O2 simulator question
- Accel LT1 units
- LT1Edit mailing list....
- MALF 16: Lo-Res Fail
- Error Codes PO171 & PO174
- Why do i keep on blowing my vehcile speed sensor?
- Idle showing very lean on both sides (Need Help)
- Changing AFR during normal driving with Tunercat???
- FreeScan Question.
- tunercat
- shift points?
- OBD II Readiness Help
- Car feels faster with A/C on
- I am thinking about getting one of these programs i need help
- Help using Freescan
- false knock retard? Take a look 4 me please!
- Programming Keyless romte for '98 ls1
- Wait for Tunercat or buy LT-1Edit for OBD-2?
- I have a quick question.
- Looking for CC306 Tune
- Fixing exhaust leak made split BLMs much worse!
- VE tables tuning, please explain
- Coolant Fan Malfunction????
- Laptop not able to connect to PCM
- Keyless entry transmitter, VATS etc.
- Problem getting Freescan to initialize
- turbo and emissions monitors kinda interesting
- O2 not switching problem after header install
- Recomendations for a engine tuner?
- i am droppin the complete drive train into i think an 63 impala...questions bout comp
- Reading O2 Voltage with Multimeter
- wtb autotap and lt1 edit
- abs, airbag gages light up
- tc in ms-dos mode
- Connection of Software
- What is Ideal TPS Voltage at Idle
- .bin files wanted
- how to set rev limiter with tunercat (LT1)
- Off idle hesitation 97 LT1?
- datamaster readout
- MAF Tuning
- Tuner Injector Flow Rate Setting
- PCM compatability
- EFI101 Class
- Does this thing do any good???
- Best chip or reprogram for 1995 Z28
- 94-95 OBDI w/6speed
- Where to start programming with Headers
- PCM Fried
- Cable for hypertech?
- Split O2 readings on top end?
- Just bought a DFI 7 ECU
- weird tach read out
- 400-4000 rpm Spark Advance..Whats the best way?
- Sticker on pcm says not comp. with lt1 edit etc... WHY?
- right blinker
- Anybody using efilive v4 here?
- My car is possessed, codes gallore..
- 1994 obd1 powerdyne
- so cal tunning
- Looking for a 226/236 cam tune. Anyone?
- APEXi SAFC II, failed intall. Need help
- Wideband
- :( which scanner
- HELP! holeshot problems!
- Please look at my Freescan Files
- My 95' LT1 has OBDII...WTF???
- Anyone have a stock 95 A4 bin file?
- So I have a Tech 2.......
- how to get PCM out of speed density mode
- NEEDED: xe230/236 bin
- code 48
- M6 file
- Differences b/w '94 and '96/7 Z28 wiring harness
- Wierd!!!!!!!!!
- TA's got problems
- File to use for OBD1 conversion???
- Radio Codes!!!!!!!!lil Help Here
- Can someone look at my freescan file please?
- Strange LT-1 O2 sensor readings
- Removing the computer
- How do you identify what year a PCM is?
- Cooling Fans
- Code 16 low resolution failure
- Firmer shifts programmed(PCM)??
- Who custom tunes PCM's???(LS1)
- Freescan log...need help and opinions on it
- LT1 tuning advice
- Looking for a stock or mod Bin for 93 M6
- Predator help please
- tuners?
- Need help with 94 camaro wiring
- Different tire/wheel size--easiest way to adjust speedo?
- they make lt1 edits right
- Dyno tune/Hyper tech
- jet chip uninstall
- monitor 2000 as a gift
- what else needed with tuner cat?
- Need some information on OBD2 emissions readiness stuff
- Adapting Cable for editing LT1 PCMs...
- Scanmaster questions and an odd one..
- Tuner or RT Tuner
- Got alot of in-depth q's about tuning
- Whats involved in changing an A4 program to M6
- TPI 165 $32 and $32b compatability
- air/fuel ratio on datamaster
- Autotap lt-1/LS-1?
- Is there a DFI that will...?
- Read my Specs..your input please
- Predator tuning help. What temp to set cooling fans with 160 degree T-stat?
- Low Idle Problems
- Spark advance help!!!!
- LT1 Edit
- new to laptop and tuneing
- Can you diagnose a bad O2 sensor with DataMaster?
- full time open loop mode
- How the Hell do i read this Freescan data
- Need help with Code 36( HI-res failure)
- Is this right?
- Failed E-Test Need Help
- Autotap
- Knock Sensor Question
- tuning w/minor mods
- Adjusting non-WOT AFR in Tunercat?
- Power Programmer III/M6
- Innovate LM-1 and Accel Gen 7 DFI
- Arrrggggg need scan tool
- problem with air/fuel metering?
- Code 48 an 84
- May have fried PCM...
- PE tables compared
- Does anyone know the voltage range the MAF puts out?
- Programming my 96 SS's PCM
- Is there a way to tune out the front O2's?
- Speed sensor
- Tunercat - quick ? about speedo cal and 4.10s
- Question regarding LT counts in Datamaster
- info on what info to get help.
- cable not working? Help
- Data Logging OBDII
- IAC Park Position Vs. Coolant Temperature
- Air Fuel Ratio at WOT
- how to "log" a run w/freescan
- Adjusting the Fuel Balance (off idle)
- Looking to get Programmed. What needs to be done?
- install cats
- Need your opinion
- Need 100% Stock 94-95 BIN
- LT1 Edit
- LS1 inputs
- can't get this code
- what the hell? Ignition issues
