- obd 2 cable
- My Cpu Burned Out
- wideband readings at idle with a big cam with lots of overlap
- Injector #8 stays open.........................
- Cold misfire/hot and cold performance?
- Cable Question
- Replacement PCM needs my VIN in it to use edit
- Removal of VATS
- Datamaster issue
- PCM, Sensors,.....
- Speed Limiter Elimination?
- Help..ERROR Messages Reading 95 Z28 OBDII
- security light??? (VATS)
- Formula for changing injector constant when changing fuel pressure
- Idle spark advance?
- i broke it
- Need a tune
- deprate! need help with my Mallory box!
- computer question
- Injector offsets for Siemens 57lb injectors?
- Minimum value in inches that will set a MAP code
- Editers/Tuners
- false knock?
- car tuning ? please
- 93 camaro supercharger program
- Possible O2 sensor problem...Gurus inside!!
- Price of Ignition and Computer in '84 Camaro RS?
- Scanned PCM quick?
- Help needed- LT-1 engine swap into v-6 95 Camaro
- PCMCIA to USB Adapter
- cheap laptop serial port addon
- help, blown something!?
- o2's appear low on one side
- Sudden Surge in Power... PCM problem?
- team zr1 tuning vs madwolf, anyone ever had tuning by team zr1?
- Quick Kpa question please...
- Can someone look @ a freescan log?
- Does anyone have a-->>
- Vats
- Anyone have a copy of LT1 edit?
- Locked Programming?
- 383 STROKER<SPARK ADVANCE AT IDLE>?
- Where to get the male connector for my akm cable?
- ok, i have
- Help! Data errors!
- WOW - this thing is rich
- Tuner help
- Tunercat help on transmission functions
- Delteq's ECU
- Need pressure Accel 30#'ers are rated at
- Knock Retard Everywhere!!!!!
- 383 stroker help
- Need help with datmaster
- Scanning OBD-2 pcm IN A OBD-1 car???
- Ditching VSS signal ... consequences?
- Tuner, Or Rt Tuner (tunercat) For My 95'ta?
- Just got MadZ tune, but.....
- 1995 Z28 Camaro
- Quad module driver.
- DFI and Delteq?
- Knock count going bizerk
- Heads up Display anyone?
- Is there LT1 edit for 93's
- Tuning help for newly installed 383 OBD1
- LT1_Edit help for Air Fuel Ratio Tuning...
- Question about tunercat(re: tranny line pressure)
- VE Tables And Air Fuel Ratio?
- Ques. about main spark advance vs. rpm vs.map
- autotap 2.05 questions and problems.
- Maf translator and gms conficts..???
- LS1 scanmaster......need info
- accel 300 and 375+ unit ,Good???
- where can I buy LT1 edit and the proper cable for OBD1?
- datalogging issues
- LT1_edit 2.2
- Anyone have a good stock head hot cam file??
- Tuner Cat - Need Stock 95Z Auto Bin
- T56 Swap into 93...VSS Problems...
- Just Installed my Scanmaster and have a couple questions...
- got ls1 edit programmer installed today and still doesn't have 2nd downshift at wot
- How to download Datamaster, site is not working?
- Will TunerCat work with the L99?
- injector and tuning question?
- help me out with upping the line pressure...
- have a question about bringing my car to get a tune for my A4 trans
- Accel DFI
- 4L60E Shift consistancy tuning
- 93 Keyless Entry
- Computer in Roadmaster/Caprice same as Z28?
- no matter what we do, car does 9.7 AFR
- Suggestions for tuning for boost
- hypertech settings
- MAF and possible opti problems??
- LT1 Edit Files Sites
- What do I need, computer wise...
- Non-topic kind of post
- help with tune when cold
- need a tune for a cc305 cam
- 94 computer into a 93 Fbody
- erratic rpm
- Normal Mode, Performance Mode, Manual Mode shift settings in LT1 Edit
- start up program for 93 camaro blower
- Using Skip Shift Light As A Shift Light
- turbo, SC, or nitrous activated spark retard in the PCM
- Can I manipulate the kickdown threshold to get rid of kickdown tables??
- emissions problems 94 Z28
- Turn Off Security Light Via TunerCat
- FreeScan Question
- Carputings LS1Scan beta...
- Mail Order vs Dyno Tune
- Hopefully my final VATS question. :)
- pcm won't scan
- scan master do I need it?
- Programmer
- New TC tables
- TunerCATS for OBD2 soon!
- Tripometer resetting randomly
- Stock LT1 MAF table?
- is computer bad
- stick with OBDII or switch over to OBDI
- 96...396
- what options do i have to tune a 96 LT1 obd2?
- Going from 52mm TB to a stock 48???
- AKM cable problem.
- scanning problem
- Can't scan the PCM.?
- SES light after header install
- How can I completely remove VATS???
- Any FAST tuners here?
- what does this code mean
- Anybody have a STOCK 96 M6 .LT1 file?
- Any Good?
- couple tuning questions...
- Final word on open loop operation
- tables missing in the new EE$ def file. and what is this for
- need advice on monitoring/tuning software
- ABS code C1236 - system voltage low
- SLP takeoff injectors
- PCM's
- Scanned car the other day. . . Have a few questions
- I got another Datamaster logfile for review...
- anyone get a stupid dell to work with usb->serial
- knock sensor ?'s
- LT1 Edit-IAC follower
- Computer won't chat with car
- got my 373 gears installed today and i have a question about using the hypertech
- o2 problem ses at about 100 miles
- need aldl cable help
- Just sent an email directly to GM
- anyone know this???
- transswap
- Please help with these codes!!!
- Can I look at your trans table?
- Cheapest scanner
- 98 3800 Series II Programmer???
- Wide band reading about 1 point off
- Reducing Transmition shift pressure? Bad?
- Lean!!!
- Need LS1 Programming!!!!
- Computer tuned for Bosch 36#, will Lucas 36# require a retune?
- open loop issue, need some insite
- Lean Code, BLM's at 160
- can someone take a look at my FASTfile?
- Bad dyno numbers, need to scan?
- OBD I ECM Scanning / Logging using a PDA - do they exist?
- Code 1626: Anti-theft system--Fuel enable circuit. What does this mean?
- SES Light AGAIN, Banks 1&2 Rich, Please Help
- Can't get the trans tuned right...
- Anyone have the latest $EE Def from Tunercat?
- Dyno tuning an LT1? NY?
- Dyno Tune Special
- PCM pinout diagram help!
- Alarm or somthing
- Well.. I need new airbags.. what else do I have to do?
- Mastach Cable not working!?!?
- unpluged the battery?
- Just ordered my MADZ28 tune!!
- MAP high
- Run A/C without PCM?
- Freescan question
- PCM Identification
- Rough Startup '88 IROC
- Madwolfe....where are you???
- Hypertech Tuning questions
- cool feature
- WOT 2-3 shift is not after HPP+ install...??
- LT1 Edit File
- Injector Constant of Acell 32#
- Codes programmed out
- Maf Q....
- replys
- Scanned my car with FreeScan. Need help to decipher the spreadsheets
- Wife's car lost .3 by adding Hot Cam over little Lunati cam... ????
- Any FAST or GEN 7 users out here?
- Security Light while at WOT...
- Typical IAC count Cammed Z28
- For those thinking of using MADZ28.com
- Can I put a A4 computer on a m6 car...
- Timing vs. Altitude
- wondering about ECM Part #.
- Newbie to the edits. Just got a laptop...
- car acting crazy, scanned info here..
- Add timing, or pull timing...
- Tunercat Tutoring
- Recommendations on programming for 10psi 383
- Anyone ever have a problem viewing the tables in tunercat?
- Temp problem - Tuner
- Can someone tell what this checksum means.
- Need a stock 94 bin (M6)
- Bought Diablo Predator Tuner - Need help
- Security Light?
- Car weaker after dealer program........
- Hypertech or Superchips programmer
- pocket PC tunar programs?
- Tunercat problems
- 2 codes..HELP
- Help With Choosing Tune
- o2 sims... how do they work?
- ? on F.A.S.T. system
- have i fried my pcm
- Edit for new cam...
- Intake popping under rapid throttle accel
- Emissions ? with obd II - obd I conversion
- Need help before tomorrow!
- new to edit
- CC306 Bin file
- Datalogging
- Extreme fuel trims
- what is the turnaround time for madz28?
- any PCM problems???
- Forcing open loop operation in TunerCAT
- Urgent Help Needed
- Hypertech worth it?
- Could you guys take a look at my Data stream PLEAESE!!!
- I hate computers
- speedo recalibrate
- I have a PCMForLess GM847 tune, can I use it temp with my cam?
- 02 sensor ?????
- Reman. PCM
- computer upgrade
- injector offsets for stock LS1 injectors (28#)?
- Anyone ever ran into a laptop that just wouldn't work?
- problem with lt1 edit
- Help with a a4 shifting problem
- Wanted PCM Tuner That pays attention
- Anyone ever gotten help from the LT1edit mailing list?
- Pcm tunning for Fuel press?
- another tunercat question
- TunerCat Help ... can't copy to 2nd PC!
- UPgrade a 93 to 94-95 ODB1 Computer?
