- Will Freescan work on a 95 Lt1?
- updated tunercat
- anybody know about code p0300
- MAF tables
- Anybody want to check out my tune?
- What needs changed?
- Fast files to share?
- Put in computer and got a code...guys come in and let me know!?!
- free scan ?
- Do I have to change or reprogram my stock computer after I put a 383 crankshaft in?
- What to look for in an Inexpensive Laptop for Tuning?
- Tunercat help
- Speedo Correction w/ TH400
- Tuning Supercharger
- autotap
- anyone have a tuned bin file?
- Question about Jeff Creech
- OBD1 ALDL protocol questions...programmers, help!
- Understanding PE mode
- data logging OBDII ???
- Cam Surge and Closed Loop
- Turning off Air Pump and EGR???
- car runs real rich at WOT...
- Got a PROMinator
- Changing AF in Open Loop?
- clearing codes
- 96 OBD2 parameters - what will keep it from starting
- Cheapest place to get a cable for a 97 Z
- Newbie to Tuning
- Removing Jet Chip
- Has anyone tried PCMSCAN?
- Didn't know this would work
- Problems w/block learn at idle
- hypertech programming question
- Gen 7 dfi questions?
- computer bad???
- H/C 400RWHP LT1 dyno or mail in tuning???
- my obd II
- Does anybody have a list of ideal sensor readings for an lt1?
- Problem with windows xp and flashing computer
- need stock 96/97 tune
- OBD1 tuning program options
- Issue with Impalae idlign low rpm timing commanding
- How do you set a LT1 for open loop, in OBDI and OBDII?
- Basic bolt-on OBD2 LT1 log file...
- my obd II
- what is VEmaster and can someone explain BLMs?
- fuel problem while crusing
- Codes question
- Car running rich after new injectors
- spark advance?
- Spark advance fluctuation at idle solution
- Spark Retard
- Help with reading Datamaster
- Freescan Help
- What years were OBD1 or OBD2, what years were MAF, MAP, both?
- LT1 Edit,383 tune Help!
- aldl converter
- New to self tuning. Tunercat or LT1 Edit?
- Change Connector - Help
- OBD2 to OBD1
- Closed Loop Timer in OBD2
- computer Q
- LT1 Edit install HELP
- Important LT1Edit Info!!
- tuning prblems with my 97 ws6
- Datamaster file with a cc306 cam?
- experts in tuning please, can someone take a look. I WILL PAY FOR SERVICES
- diy cable
- obd1 to obd2
- Free Scaning Software
- Usb/serial port adapter for laptop datamaster
- Tuning for 4l60e-to-700r4 conversion?
- props to pcmforless
- Adjusting MAF tables.
- 2 Questions --> 1. TunerCat 2. General Tuning
- LS1 edit question?
- need help w door locks
- Early LT1 high stall shift problems
- Building a PC in the glove box?
- Currently Avalible OBD1 tuners
- what a/f ratio ??????
- SES light flashing
- Base tune/start up tune For FI eng
- Scan tools
- Help getting cable to work
- only 1 o2 sensor with fast?
- HC's, Open Loop and My Car HELP PLEASE
- Can someone help me interpret this log
- Data Cable
- Not Going to Closed Loop
- just ordered tuner cat. any advice?
- Heads/tuning
- All Kinds of Tuning Woes
- Carputing
- Tunercat error - INCORRECT MESSAGE SENT
- Any dyno tuners in socal/Los Angeles area?
- MAF sensor code
- Datamaster install help
- Adding 30lb injectors
- Cell 18??
- Any cure for false knock due to piston slap?
- scanner readings on ignition timing
- cords
- OBDII LT1 PCM's and emissions... I need an authoritative answer on this
- Do computers default when power is lost?
- I'm in need of a BDLD bin
- Predator 2
- OBD I Scanners
- Bad Miliage & Autotap ???
- Please Help, Reflash, which PCMCIA?
- big cam LEW heads long tubes obd1 conversion smokes white and smells rich?
- Change VIN's on edit files?
- A/F tuning with tunercat question please...
- Tuning for !EGR! and !AIR!
- A/c delete w/ odb2 needs tunE? +misc questions.
- Question about programming
- PCM tuning?
- quick TTS datamaster question
- Any one tuning LS2 yet?
- Key Fob programming
- What 02 mV for 14.7?
- 1994 PCM Info
- Dyno tuning?
- ATTN Shoebox...I need your help!!!!!
- Looking for some '730 help
- power programmer question
- Realtime MAF translator
- "Closed Loop Idle Vehicle Enable Speed"
- every single knock retard table zeroed out, still pulling timing??!
- kickdown downshift table
- Could this be OBDI high stall issue?
- just got in my pcm!!!
- hooking up shift light...
- does anyone know how the spedometer works? *Prize for help*
- line pressure tables for vacuum modulator
- CarChip Scan Tool...is it worth it?
- Tazzo VPC VS G-Tech.
- trip meter not functioning
- Issues with AKM cables ...
- air/fuel reading from Autotap
- Holley 42lbs injectors
- 93 Car, change to 94 Computer?? any info?
- Tuning Methods
- need advice on OBDX computers
- Sd ?
- how to compare files
- How to tune out CAGS with LT1 edit?
- USB to RS232 adapters for my AKM cable????
- Sensors...sensors...sensors!!!
- custom tune
- Please check out my datalogs and see what you think.
- Is this a change to make for a 58mm throttle body?
- Custom Tuned...will it be lost if car loses battery power?
- Tuning VE tables
- GM Tech II and HP Programer
- DTC def?
- LT4 timing charts
- Auto and Manual OBD 1 PCMs identical?
- tuning for a 2 bar map? Ion?
- Tuning
- (un)Usual communication problem?
- Free scanning w/ computer
- Help with new chip!
- What's the Best diagnostics software?
- only knock sensor pulls timing??
- OBDII to OBDI conversion, what about emissions scan?
- OBDII Scanning Solution Needed
- looking for tuning in dallas area
- Learn Mode
- LT1 to LT4 mods
- tunercat forum
- Need some info (HELP)
- OBD2 PCM edit options
- PCM Tranny Change
- More on the dtc P0300 multiple cylinder misfire
- Building an impedance converter
- Need someone to look at this datalog and tell me why my car runs like CRAP! PLEASE!
- tunercat shift point questions need help
- Safc Ii
- taking care of business....one SES light at a time
- I need of tunning for my 383
- Having A problem running LT1 edit on my computer.
- Tunning My LS1...
- PCM question.
- 94 trans am what other than lt1 edit to tune?
- obd1 question
- New cam and car won't stay running
- Scanmaster vs Datamaster display units
- TPS minimum voltage
- quick ls1 ecm question
- obd 2 to obd1
- 383 in finally but....
- 383 Tune running very rich....
- How can I dump my chip info onto my laptop?
- Do LS1 cars have a "black box"
- Chip Question
- OMG....got 20* of knock retard
- RT tuning a 93 pcm, then flashing a flash prom
- E-mail tuning
- car was converted obd1, need help
- LT1 ScanMaster.
- Very different O2 readings.
- ODB1 or 2 Plug
- reseting the ECU codes
- EGR problem, Need 2bar MAP for SC application?
- delphi/lucas inj offset vs volts (where can i get it)
- Hook computer directly into data/diagnostics port?
- need bin files. for my site. please read
- Third Gen Computer Tuning
- Emulators
- Using skip shift light as a shift light?
- SES Codes After Header Installed
- what diagnostic/scanner tool to get
- Want to learn to tune
- Shift firmness question??
- Injector sizing
- Manual for TunerCat?
- Need info on Tuning LT1
- OBD2 LT1 edit question
- Want to examine a .uni file?
- I want to tune, but what laptop?
- Datamaster Injector Duty Cycle
- Repinning a harness
- Anyone have the latest $EE def from tunercat?
- I need a pinout diagram for a port on the computer.
- DTC P1153 problem... (long story!)
- SES: Code 420 Caused by bad gas?
- Leaning out at idle with 72# injectors ?
- diagnostic ports
- help! no fire from coil
- A4 Tranny setting help
- reprogrammed pcm
- How do i tell if my car has been programmed?
- 2 computers better than one?
- Will someone take a look at a log for me? .uni Datamaster?
- Is it true that the factory computer is only good for 7,000 rpm
- *NEW* Mail order LS1 tuning by HPE
- PO Code
- hptuners ever gunna maket lt1 obd2 version?
- How Do I Reprogram My Stock Keyless Entry?
- datona sensors wideband
- PCM Tuning 95 Z28
- FreeScan Flagging Tool COMPLETED inside
- anyone know if this is a good product for tuning or not?
- Car sucks, can't find Madwolf
- Beginning tuner help
- Computer Location on 01 Z-28???
- Cable failure in cold weather?
- best data loger
