PDA
View Full Version : Computer Diagnostics and Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18] 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36
  1. Can someone please take a look at my cars scan
  2. Can someone lower my idle and change my rear end?
  3. 95 Z28 T56
  4. Misfire in the rain
  5. 94/95 .bin file work in a 96/97 pcm?
  6. Will 486 33mhz computer run tuner cat?
  7. tunning for a turbo
  8. Stock tune capabilities???
  9. recommendations for pcm repair
  10. What are the symptoms of having a bad batch of gas?
  11. need 96 LT1 auto tranny file for 4.10's
  12. Programming new remote
  13. ASR wiring schematic...
  14. "ASR Off" light is on all the time...why???
  15. Anyone using the new FAST XFI?
  16. TunerCat & PCM Questions
  17. what temp is closed loop in pcm for less tuning with 160 termostat?
  18. OBDII files for LT1
  19. Need a tune for a stock (ex. full exhaust) LS1
  20. How should I go about upgrading my computer?
  21. Free LT1 PCM editing and diag software
  22. IPAQ rx3115
  23. mail order tune...how?
  24. Lbl And Rbl
  25. Need New Tuning??????
  26. Can't Decide
  27. Can someone please look at a datamaster file, PLEASE.
  28. putting in a new wiring harness, mine is junk, will this one work?
  29. question
  30. HP tuners vs. LS1 edit
  31. Open loop 02 sensor readings insane!
  32. Madz28 saved the day
  33. how to save stock tune?
  34. Freescan is not working right with USB adapter
  35. Help: Dyno question on 94 LT1 A4 car
  36. Aldl cable problem
  37. Tunercat Customer Service :bs:
  38. Is this Bad Programming?
  39. HELP 94 TA has low rpm miss, HELP, PLEASE.
  40. Easyiest and Cheapest way to bump my shift points
  41. 1997 LT1 Camaro LT1edit or Tunercat
  42. What do I need to buy to use tunercat?
  43. OBDII leaning out closed loop
  44. tunercat
  45. GM847 Tune...
  46. Anyone use a Serial RS-232 to USB Adaptor?
  47. power off storage/failed emissions
  48. Datamaster Help
  49. HELP! Alarm system is preventing my car to start!
  50. Live Data Question
  51. time to tune???
  52. ProScan v2.0! what do you think
  53. Scanning, ALDL, and more, oh me oh my!
  54. Tune for gm 847 cam and afr190 heads?
  55. Need VCI number.....please help
  56. Predator tuner
  57. Help with Speedo Correction
  58. Enabling lean cruise mode...?
  59. ANYWAY to simply check if the Laptop is correctly connected to the PCM ???
  60. OBD1 cable and 95 Z28 Question
  61. ALDL Problems
  62. 95 LT1 and 700R4
  63. Iffy about friend tuning
  64. PE Tables and A/F ratio
  65. Need To Tune Car. HELP!
  66. Innovate Motorsports Widebands
  67. LT1 in 49 ford pcm help!!!!
  68. Need Datamaster .UNI file for 1227730 ECM (90-92 F-body)
  69. looking for tunercat expert. need help tuning stock 94z
  70. supercharger tunes.
  71. lean condition
  72. How do I get into my steering column?
  73. mail tune...confused on what to get
  74. dyno tune..on the street
  75. P1115, What is it?
  76. Takes a little cranking to start when warm
  77. how can i tell if my computer is shot?
  78. need akm cable help
  79. Equus/Innova 3110 OBDII C.A.N. Scanner?
  80. Custom Tune'd PCM?
  81. VIN changed in PCM, now it won't program!!
  82. Can someone help me out? 2.73 to 3.73 change
  83. What s/w will work with my EASE cable?
  84. dum question
  85. Running rich I think - any advice?
  86. tachometer problem.... help!!!!?
  87. Anyone Here Make A Speedo Recalibration Box?
  88. I have a laptop and the right cable...
  89. obd I question
  90. I am having problems with Tunercat OBDII
  91. 94Z28 SES light ?
  92. LE2/GM847 bin file?
  93. PE idle....
  94. Ion?
  95. anything else besides lt1-edit?
  96. Lots of tuning problems :(
  97. Adjusting MAF
  98. Car won't start... pcm???
  99. Second PCM fried by TUNERCAT!!!!
  100. I hate paying the dealer $90 for a scan
  101. strange blinker problem
  102. Any way to tune for gears without HyperCrap?
  103. OBD2 PCM with Stand alone??
  104. 94 LT1 computer woes
  105. Base program for LE2 head and cam package
  106. Can someone verify injector serial numbers?
  107. Anyone have PCM flash capabilities??
  108. hard to start when warm
  109. yes, i did a search, and no i didnt find a response.
  110. Question about SLP Camaros
  111. Diagnostic Programs
  112. hypertech question
  113. scan problem
  114. ODD DTC Errors
  115. 20 gps MAf at idle?
  116. Tried everything but wont shift at WOT!!!
  117. Still getting knock at 5krpm...
  118. ob1 ses lights
  119. How do you obd1 guys check your ses lights?
  120. used TunerCat OBDll, now car will not start... flashing SES light???
  121. finally ordered the tune
  122. SES light and codes
  123. Where can I buy LT1 Edit??
  124. Black smoke on dyno...
  125. Timing questions
  126. CAM - Carolina Auto Masters - Jeff Creech
  127. Programming out hesitation on tip-in? (big injectors)
  128. Keyless Entry Programming?
  129. SES light still on!!!
  130. Weird stuff on scanmaster ,car or scanmaster what you think?
  131. Where to start (added 52bbk, 30lb svo's)
  132. newbie here...need some help
  133. Piggy Back Harness?
  134. 97 keyfob w/ 94 TA???
  135. Hypertech (hypercrap) programmer problems
  136. Possible to run 42 lbs with OBDII?
  137. Using Scanner on OBD1 conversion
  138. Where can I get VE Master
  139. Autotap or Datamaster for OBDII
  140. Stand Alone EFI systems
  141. need EFILive logging tool! HELP!
  142. Malf 48: maf system fail ??
  143. Need Help...tach problem.
  144. Question about Fuel Gage needle
  145. anyone have any experiece with madz28
  146. Autotap (BDII LT1) lists two sets of LTrims for bank 1 and 2, whats the difference?
  147. How do you keep OBDII PCM in open loop?
  148. Code 1133....
  149. How to make tranny shift faster...
  150. Tranny Not Down shifting and TCC - Need Some Help
  151. engine managment
  152. Autotap users inside pls
  153. deleting egr with tunercat
  154. my 297rwhp cammed car now has been logged. please help.
  155. LT1 Edit fuel tables
  156. Fried my pcm, where do i send it to get rechipped?
  157. P1441 EVAP code... help
  158. scanner ?
  159. which is left O2 sensor in Freescan?
  160. Datalogging software comparisons
  161. Stumble off idle
  162. tunercat...easy to use?
  163. Tip in throttle is always lean
  164. fuel tables
  165. Change Oil Light
  166. "Invalid Response from PCM" TunerCATS 2.08
  167. Tunercat demo version question
  168. LS1 Injector In Lt1??!?!?
  169. what to do with timing...
  170. Data Logs
  171. Electrical gremlins.....need help ASAP
  172. i need the basics
  173. Lost my PCMforless bootable floppy, need help ASAP.
  174. Need to extend wire harness that goes over passenger fender. Will This...
  175. will i lose my tune if?
  176. Low Coolent Light ON???
  177. Can't read the PCM
  178. Take a look at my closed loop values
  179. Is USB available for obd1 lt1 edit?
  180. False knock problem.
  181. how to test voltage?
  182. Have Ses Codes For 1991 Camaro, How Do I Know What They Mean
  183. Whacky trouble code
  184. EFILive 5.26.8
  185. Converting PCM from M6-A4
  186. slotting tps on BBK 58mm T.B.?
  187. Injector constant for 42#
  188. Painless Engine Management System
  189. Wanting to purchase tunercat for obd-1 and 2 few questions
  190. Can someone take a look at this freescan files files for me?
  191. PE IDLE- LT1 Edit
  192. Whats this "freescan" you use?
  193. Malf 44 & 64
  194. LS2 LS1 LS6 Dyno tuning now available
  195. Hypertech Programmer with a 4.10 gear
  196. best place for a dyno tune???
  197. fixing pcm
  198. anyone want to look at datamaster file?
  199. 1993 Chip Programming
  200. MSD6al+datamaster=trouble
  201. Data logging software....which one is better?
  202. new 381ci LT1 ecm concerns.
  203. just ordered tunercat ! want to learn to tune on own any ideas ??
  204. Is Autotap worth the $$$?
  205. Bump timing up to 50+ ????
  206. Using cells 17 & 18 SO MUCH, and what's going on with the CCP ????
  207. No connectivity from data port
  208. 94 Z28/A4, stock... can someone recommend me a tuner?
  209. Deleting Tranny
  210. 108/160
  211. What's wrong with my speedo???
  212. Alarm trouble
  213. Light throttle closed loop tuning tips needed
  214. need a tune
  215. Going to buy a 97z28 soon.
  216. Question about Powerporgrommer 3 with 4L60E
  217. Jumper cables to mate Xray 12 pin cable to 16 pin connector
  218. Please help with the programming for my TC!!
  219. pcm bad?
  220. Local to NJ for LT1 tuning
  221. Just scanned car don't know what to make of data
  222. Wierd data ideas for me running out of them!!
  223. OBDII: Code 100 and 1657
  224. this ever happen to any of your hypertech guys?
  225. Power-washed engine- BLMs to 160 both sides
  226. ses light for code 43 esc failure? obd1. what does this mean?
  227. Timing, Which to Believe?
  228. OBD1 to OBD@
  229. Where to download tunes from....
  230. ls1 and lt1 maf interchangeability and part numbers?
  231. mystery injectors
  232. anywere to download
  233. speedo/turn signal
  234. OBD1, Code 48 MAF Circuit Problem
  235. Looking for a base LT-Edit program for a SC LT1.
  236. Link error
  237. Tuning Methods
  238. PCM for less owners
  239. problems with current program..lean
  240. Base tune for cruise
  241. PCM Reset, BLM=120?
  242. In Datamaster how can you tell if your rich/lean? roughly
  243. Want to invest in a scanner
  244. Running a little rich
  245. where to buy tunnercat?
  246. Changing degree extension
  247. VSS used for engine operating parameters?
  248. Removing Cats?
  249. MAF Calibration Tables
  250. Cable Compatibility (AKM or Moates with Turbolink)
